Offline stororoj
#1 Posted : 07 October 2019 18:22:09(UTC)
stororoj
Korea, Republic Of
Hello.
I have 6 marklin 74991 (eletric turnout) .
But they are not working.
It can be put out when I control with CS2,
but it can not be put it back.
I attach clip.
please check clip.
Thanks.
Offline Danlake
#2 Posted : 07 October 2019 20:25:46(UTC)
Danlake
See previous extensive posts on this matter:
https://www.marklin-user...ectric-turnout-mechanism
Best Regards
Lasse
#3 Posted : 07 October 2019 21:21:54(UTC)
The above link should explain. However are they all new switches or have not previously worked on the layout in which case check you have them wired correctly. If you only have six and all are not working I would think this is unusual if all are new.
Offline stororoj
#4 Posted : 08 October 2019 01:14:08(UTC)
stororoj
Korea, Republic Of
Thank you for your reply.
that is not new.
I bought these few month ago.
It was working well when its new.
but now it works like clip.
Thats so strange.
#5 Posted : 08 October 2019 11:52:33(UTC)
IF you bought these new a few months ago it is unlikely that all six will suddenly have a fault. New versions are better although can still have problems but I would not think all would go at the same time. Have you tried changing the decoder or using another part of track and turnout. You could send back to the dealer and have them changed if nothing you can try works. Maybe set up again on your CS2 although probably would not help but anything is worth trying.
#6 Posted : 08 October 2019 15:48:58(UTC)
Hi Stororoj
I would check any of the motors in AC (disconnect the decoder and plug the set of cables delievered by Märklin). Then drive the motor by connecting the yellow and one of the blue to 16 VAC then with the other blue cable.
If it works then check the decoder and also the motor mounting on the switch. It is easy to mount them incorrectly: not is the proper location or with the driving lever not properly driving the switch mechanism
If it does not work then the swith motor is faulty. Then try to short the end switches inside the mechanism. There are many posts and pictures on the subject.
Offline stororoj
#7 Posted : 11 October 2019 18:42:19(UTC)
stororoj
Korea, Republic Of
Hi Stororoj
Thank you so much.
I wilil try!
Offline stororoj
#8 Posted : 11 October 2019 18:47:19(UTC)
stororoj
Korea, Republic Of
Best Regards
Lasse
Thank you.
Your link is very helpful.
Guest (4)
This page was generated in 0.409 seconds.
