Offline aussiephil
#1 Posted : 06 October 2019 05:19:17(UTC)
aussiephil
Hi Guys
I am pretty new to all this high tech digital stuff! I did have Marklin many years ago and decided to get back into it a few years back when I started collecting for my retirement!!
Most recently I was able to obtain a mint condition set 3471, for which I have bought a 60921 decoder set to fully digitize it.......any ideas for good sound - what sound card should I buy?
Hopefully someone will be able to give me some good advise.
I follow marklin-users regularly and hope to be able to make some worthwhile contributions in the near future.
Phil
Offline ktsolias
#2 Posted : 06 October 2019 20:10:04(UTC)
ktsolias
Where did you find the 60921 decoder??
This is from ages ago from 2004........
There is no sound on this decoder
Better to buy a modern decoder with sound for your case a 60976 or 60986
May be the motor from the set is OK but only if the 3471 has a DCM motor
Post a picture oh the motor, that will help to give right advise
Costas
Offline Dave Banks
#3 Posted : 06 October 2019 21:29:09(UTC)
Dave Banks
G'day Phil, you need to change the motor to a high propulsion motor at best or at worst fit only a permanent magnet. ESU sell them. You can install a ESU Loksound decoder in my case it was done a few years ago it was the ESU V3.5 Loksound decoder. Also I changed the interior lighting using LED globes. It turned out quite nicely.
Dave...
PS: This is just to give you some ideas: https://www.marklin-users.net/in...Tog/sites/CH/3071-3.html
D.A.Banks
#4 Posted : 06 October 2019 23:55:32(UTC)
The 3471 might have some special requirements for conversion. The model itself has a delta decoder, but it also has an electronic relay to determine which slider it takes power from.
I would inquire with a specialist before beginning any work on this model.
Perhaps Jacques Vuyes has done such a conversion and can contribute to this topic?
Offline aussiephil
#5 Posted : 07 October 2019 06:20:17(UTC)
aussiephil
Many thanks for the advice guys......I found the decoder cheap on ebay it is supposedly new but if it's that old I might just use it in a small 3000 I have that is analogue.
I will seek out a better decoder with sound for the 3471.......thanks also for the link Dave, nice to know there is another aussie around who appreciates Marklin!!
#6 Posted : 07 October 2019 06:47:06(UTC)
I found this diagram. I cannot attest to it's accuracy: https://www.ad-soft.ch/w...u/mae/3071/umbau3471.jpg
I also found this website (in German): http://jaray.ch/eisenbahn/mae_3471.htm
Offline ktsolias
#7 Posted : 07 October 2019 09:23:40(UTC)
ktsolias
I have done this conversion not in a DElTA but on an analogue model 3071
This is not an easy conversion anyway.
The problems are the Pick-up shoe changeover and the lighting.
The solution that I used was:
Motor: 60944 in my case, may be you need the 60941 a picture will help
Decoder: 60976
Base plate for the decoder: 60973, in this plate the changing pick-up shoe relais is on the board
For the lights I used LEDs witch is another story
BE CAREFUL: IS NOT A CONVERSION FOR A BEGINNER
Costas
Offline supermoee
#8 Posted : 07 October 2019 15:18:22(UTC)
supermoee
I have done the update long time ago. I used the ESU board for the change over for the pick up shoes:
http://www.esu.eu/en/pro...nen/change-over-of-skis/
Märklin has a similar circuit:
https://www.maerklin.de/...s/details/article/60973/
then I changed all the light bulbs with LED
ESU Loksound V4
high propulsion set
The next step will be to throw out the noisy Märklin Motor an substitute it with a Maxon motor from SB Modellbau.
rgds
Stephan
#9 Posted : 07 October 2019 22:06:26(UTC)
Originally Posted by: aussiephil Go to Quoted Post
Hi Guys
Phil
I would say one thing: please don't change the motor!!!
That type of motor was maybe the best Märklin has ever used...alas only for a short period!
ESU gives instructions on how to drive this type of motor in their booklet on LokPilot and LokSound de coders .
I have never performed that change so cannot give you specifics on those but I'm sure there is someone here who's done this before.
Good luck
Jacques
#10 Posted : 08 October 2019 03:41:39(UTC)
Hi Guys
Phil
Good luck
Jacques
Jacques, are you referring to the 39700 with the C-Sinus motor? The 3471 has the same motor AFAIR as the Ae 6/6 or the classic BR 103.
Guest (4)
This page was generated in 0.378 seconds.
