Offline Will
#1 Posted : 05 October 2019 16:25:58(UTC)
Will
Recently bought a MS2 (with track set) and cannot get it to recognize locs. I've tried the "find" option, manual entry, reseting and doing again. Nada. During "find" operation, the lights on a V80-104 will come on briefly when search ongoing, but never registers and get "no loco" message.
My MS2 has 2.54 software version, so wondering if it is matter of updating. That means mailing it off to dealer, but curious if it might be something else. Any suggestions or thoughts?Crying Cursing
#2 Posted : 05 October 2019 16:40:11(UTC)
That's the normal behaviour for locos with LEDs. The "find" function is not reliable and does not work for MM locos if F0 has a low current draw (like modern LED lights)..
Entering MM locos manually is the better approach.
For older decoders make sure red (goes to B) and brown (goes to 0) are not swapped.
Programmable MM decoders can usually be programmed even if the current address is not known. Just program a new address if you do not know the address.
Offline TEEWolf
#3 Posted : 05 October 2019 19:47:17(UTC)
Indeed, in addition to H0 post, you should update your software. I had similar experiences with my MS 2. As far as I remember (pretty long ago) it was with software version 2.3 or 2.5. Meanwhile I updated to version 3.55 and have not recognized these problems anymore. But I cannot really certify, if it was a software faulty, because Maerklin does not say anything about it.
Who is still selling a MS 2 with a software version 2.5, recently? This version is about 3 or 4 years old. The new version is 3.55 plus a track box update too. Read here:
https://www.marklin-user...-for-32-Function-support
Offline Will
#4 Posted : 05 October 2019 20:09:53(UTC)
Will
Thanks for the responses. I'm going to try manual entry again, and regardless, get update.
Offline TEEWolf
#5 Posted : 05 October 2019 22:00:41(UTC)
Please be aware, Maerklin issued a new manual for the MS 2, extra because of the new software changes for version 3.55.
https://static.maerklin....f3c36e4fb91557845024.pdf
If your dealer is updating your MS 2 assure you get the complete and correct update, including the one for the track box. Well I had a bad experience with a dealer who had not yet the latest update at his CS 3 while he updated my MS 2. Therefore I received not the latest update for my MS 2. This finally was another reason why I bought my own CS 3.
Offline Will
#6 Posted : 05 October 2019 22:10:03(UTC)
Will
I'm clearly not a genius as far as M digital. However, V80 registers in database but won't respond. Tried an old BR81 with Delta decoder (4 pins means easier to make sure I do not screw up address, lol ). Again, nada.
Going to get software update from someone nearby and go from there. Can use older MS for now, but finally getting track out to plan/brainstorm layout ideas and this is a bummer. Maybe this means I just need to get a CS3. I'm going to go suggest that to the FD right now. Laugh
#7 Posted : 05 October 2019 22:38:44(UTC)
It is also possible you may have been sold a faulty MS2....
Offline TEEWolf
#8 Posted : 05 October 2019 22:49:58(UTC)
Did not want you to spend unbudgeted money.Smile But a CS 3 is a never ending story for learning the MRR hobby more and more intensive. For myself just perfect. I only told you my experience. BTW a CS 3 is also a manager for digital addresses and very helpful, especially using mfx. The track format Maerklin offers since beginning this year to everybody. So you can expect more and more supplieres will make their digtial devices mfx capable.
At the moment I would follow @H0 recommendation and try to register the loco manually. The necessary digital address for the loco you find in the manual either of the loco or of the complete starter set.
#9 Posted : 05 October 2019 22:54:57(UTC)
I agree, this doesn't look like an update issue.
Have you tried swapping the red / brown wires on the "B" and "0" under the tracks?
P.S: Actually I don't think your MS2 is faulty, since you can both register manually and have LEDs blinking during "find" Cool
#10 Posted : 05 October 2019 22:57:08(UTC)
How is this different to a MS2?
Offline Will
#11 Posted : 05 October 2019 23:13:02(UTC)
Will
I think my MS could be faulty, as I've tried everything suggested with 3 locs. I appreciate the help and expert advice! If nothing else, this sort of situation is a great tutorial.....Perhaps taking a break and starting over will help.
Or I will pull out my 35 year old blue transformer! LOL
Updating MS2 woes.... (Digital)
by Joseph Meiring 05/08/2014 22:51:47(UTC)
MS2 woes - and updating? (Digital)
by Joseph Meiring 18/06/2014 20:54:55(UTC)
MS2 woes (Digital)
by 65kombi 05/01/2012 10:01:20(UTC)
This page was generated in 0.449 seconds.
