Offline 57vert
#1 Posted : 14 March 2019 20:27:33(UTC)
57vert
So I have Marklin bridges ( old m track style) and bought the gray Marklin oval pillars. Now that the pillars have arrived they don’t match up correctly. If I want to use Marklin pillars do I need the older red pillars? Is there a cheat to make the gray pillars work?
#2 Posted : 14 March 2019 20:53:26(UTC)
are you sure they are not compatible? The supports should be placed at the ends of the bridge and transverse to the track. Perhaps those are only for K-track and the older red plastic ones with green base probably work for M track.
bridges on old layout
#3 Posted : 14 March 2019 20:56:01(UTC)
The grey pillars are indeed for the newer plastic bridge sections, not older metal M-track bridges...
However, there are always workarounds and hopefully you will get some tips here...
Offline Markus Schild
#4 Posted : 14 March 2019 21:40:57(UTC)
Markus Schild
It is an interesting idea to design a 3d-printable adaptor to connect the new pillars with the old bridges. I will try. Give me a week or two.
Markus
thanks 6 users liked this useful post by Markus Schild
Offline 57vert
#5 Posted : 14 March 2019 22:16:09(UTC)
57vert
Markus
I was thinking the same about 3D printing. But I neither know anything about 3D design nor have a 3D printer. But my son does have a printer. I would greatly appreciate your efforts.
Charlie
#6 Posted : 14 March 2019 23:01:38(UTC)
Markus Schild
This is how it could look like. But I want to test it before I publish the file.
Markus
Offline 57vert
#7 Posted : 15 March 2019 02:04:24(UTC)
57vert
Markus
That looks about right to me!
#8 Posted : 15 March 2019 20:35:42(UTC)
Markus Schild
I finished the part:
Files and additional hints how to print: https://www.thingiverse.com/thing:3494300
Markus
thanks 13 users liked this useful post by Markus Schild
Offline 57vert
#9 Posted : 15 March 2019 23:15:47(UTC)
57vert
Markus
They look great! My son is going to print me out a few this weekend. Will post pictures when installed.
You saved me from a costly mistake!
Thanks so much,
Charlie
Offline 57vert
#10 Posted : 16 March 2019 00:38:09(UTC)
57vert
Markus
By the way, that was a quick week or two!
Thanks so much,
Charlie
Edited by user 16 March 2019 15:52:33(UTC)  | Reason: Not specified
#11 Posted : 21 March 2019 16:31:32(UTC)
Markus Schild
I updated the part at thingiverse. It is little bit higher now. The first version did not fit all series of pillars.
Markus
Edited by user 21 March 2019 20:16:08(UTC)  | Reason: Picture added
thanks 7 users liked this useful post by Markus Schild
#12 Posted : 21 March 2019 18:18:04(UTC)
fabulous job!
#13 Posted : 22 March 2019 22:20:39(UTC)
Brilliant.
Guest (5)
This page was generated in 0.441 seconds.
