Offline fstrobel
#1 Posted : 12 March 2019 21:53:20(UTC)
fstrobel
I guess that this will mostly come down to personal preference but I was wondering if anyone has practical experience they are willing to share.
So, I have a Mobile Station II. At this point, I am planning on using the Mobile Station only to control (and power) trains running on the layout.
I am planning on controlling the turnouts (and possibly other solenoid mechanisms) using a separate power source and a control box (e.g. 72720) (fed by a power bus separate from the bus fed by the 60116 digital control box).
There are three reasons for my approach:
1. I am concerned about pulling too much power from the Mobile Station when controlling several turnouts in addition to trains (and, I am not ready to invest in a Control Station just yet).
2. "Mechanically" controlling the turnouts using a control box seems to me to be easier than fumbling through the rather small screen of the Mobile Station.
3. Last but not least, adding a digital decoder to each turnout gets quite expensive.
Anything wrong with this overall approach / train of thought (pun intended... BigGrin)? Anything that I should generally be aware of when using this approach?
Many thanks in advance for any and all feedback!
Offline rbw993
#2 Posted : 12 March 2019 22:12:29(UTC)
rbw993
For smaller layouts I think that this is a sensible way to go. Splitting the analogue and digital functions works because it isn't that difficult to keep track of or label which button controls which switch. The layout display on Control Stations make it easy to keep track of which turnout is which. At some point the wiring runs in larger layouts become unwieldy and digital makes more sense.
Roger
Offline TEEWolf
#3 Posted : 12 March 2019 23:39:39(UTC)
Nothing wrong with your idea.
Here are two different wiring plans
completly analogue
only the turnout lights separated. They are the highest current consumer at a turnout, but you need a decoder for toggeling the turnout, but this wiring is helpful for a CS 3.
Using an extra transformer for the light brings also the possibility for dimming the lights with the red knob.
Offline fstrobel
#4 Posted : 12 March 2019 23:50:48(UTC)
fstrobel
Very helpful diagrams! Thank you.
So, the third option then is to use a digital decoder (e.g. 74462) inside the track and to control everything using the Mobile Station. At the same time, I am assuming that I should power more permanent lights such as turn-out light, building lights, etc. still separately.
Offline TEEWolf
#5 Posted : 13 March 2019 00:50:09(UTC)
This is generally recommended to use the digital current via the tracks not for lights, etc.
But your problem with the MS 2 is just discussed at marklin-users.net in another thead.
https://www.marklin-user...ol-turnouts-with-decoder
Offline dominator
#6 Posted : 13 March 2019 03:06:30(UTC)
dominator
I can run my trains on analogue or digital but I prefer the analogue method of switching points. Easier to find and operate for my BRAIN.
DERECK
Northland. NZ
thanks 2 users liked this useful post by dominator
#7 Posted : 13 March 2019 06:38:28(UTC)
DERECK
Agree - look after your brain.
After my experience on the CS changing from engine control to accessory control and back to engine control is just a big pain.
So except for one digital signal (which is still a pain) all my accessories are controlled by push button.
Offline fstrobel
#8 Posted : 14 March 2019 02:32:16(UTC)
fstrobel
Sounds like my approach makes sense. Thank you everyone for the feedback.
So, if I want to use this configuation:
Does anyone have a recommendation for which transformer (I am in the US) I should get?
Also, I have read somewhere else that it would actually be better to use 12 Volt DC to power the 74491 turnout mechanism rather than 16 Volt AC. Is that true?
This page was generated in 0.564 seconds.
