Offline DB Fan
#1 Posted : 06 March 2019 05:38:16(UTC)
DB Fan
Hello
Looking to buy a CS 60212. Wanted to know if it is a good choice for running any Marklin digital engine with factory decoder or any analog engine upgraded wit a marklin decoder. Are there any limitations to run mfx engines? Just looking for basic digital control of the engines I have. Don't need to control anything else then engines or set up routes. Sound is not a priority as well. Can the engine address be changed on a programming track? Sorry if these questions where asked before. Any comments are welcomed. Thanks.
Robert
Edited by user 10 March 2019 22:25:05(UTC)  | Reason: Not specified
Offline Ove Malmström
#2 Posted : 06 March 2019 07:56:18(UTC)
Ove Malmström
Wouldnt the Mobile station 2 do the job, ore are the Mobile station 2 lacking somthing?
#3 Posted : 06 March 2019 08:53:47(UTC)
Take care which version it has.
If it has software version 1.x then it did not yet get the hardware upgrade from Märklin.
If it has software 2.x then you can upgrade to 2.0.4, the latest version from Märklin.
If it has software 3.x or 4.x then you can always upgrade to the latest version from ESU.
With version 3.x or 4.x it is an ESU ECoS 50000 with a Märklin logo - IMHO a very capable controller. You also get DCC and SX with that version and 4 A booster output.
With version 2.x it is OK, but limited to mfx and MM protocols with only 16 functions per mfx loco and only 9 functions per MM loco entry.
IMHO you should avoid buying one with version 1.x.
The 60212 is the only Märklin controller that supports 28 speed steps for the MM protocol.
Offline TEEWolf
#4 Posted : 06 March 2019 15:28:40(UTC)
Hello
Robert
The CS 1 is the controller from Märklin which is not compatible to all other controllers. Once I tested my MS 2 at a CS 1 and it was not working. If you want to waste money, buy it. In my opinion it is electronic trash today. Even a MS 1 is better, because this is functioning at a CS 3 too.
#5 Posted : 06 March 2019 15:39:54(UTC)
Why did you do that test ??
You must have plenty of links to Märklin pages telling you that it will not work. LOL
#6 Posted : 06 March 2019 15:43:14(UTC)
I once tested my MS2 with my CS1 and it was working. I know wot I'm doing.
Both devices have a Märklin logo, both devices use the CAN bus - it's a pity they do not communicate properly via the CAN bus. Thanks, Märklin.
Offline mbarreto
#7 Posted : 06 March 2019 16:42:21(UTC)
mbarreto
Maybe the software of the 2 different CS1s have a different origin ;)
Miguel
Mostly Märklin H0.
Offline DB Fan
#8 Posted : 06 March 2019 17:05:46(UTC)
DB Fan
Could we please comment or make suggestions on my original post. Posts 5-7 are not helping me to make a decision. Thanks.
Happy Model Railroading
Robert
Offline DB Fan
#9 Posted : 06 March 2019 17:07:24(UTC)
DB Fan
Thank you HO. Didn’t know about the different versions. Very helpful.
Robert
Offline DB Fan
#10 Posted : 06 March 2019 17:16:42(UTC)
DB Fan
Thanks TEEWolf. I’m trying to decide what digital controller I want to go with. Looking into intellibox, ms2, ms1, cs1 or any alternative to a CS2 or CS3. Looking for a basic controller to run my engines on a future midsize layout. Like I mentioned, I’m not interested to control anything digitally besides the engines . Any suggestions or comments, no matter if positive or negative, are welcomed. Thank you.
Robert
#11 Posted : 06 March 2019 17:21:43(UTC)
Well, most of post 4 is misleading / wrong, so using that to make a decision would not be a good idea.
Post 3 has all the relevant information.
#12 Posted : 06 March 2019 21:42:58(UTC)
Hi. I have a CS2. Great controller and if you can buy second hand at a good price go for it. Do not get a CS1. Made by ESU it has a poor screen and is outdated.
Either the Marklin MS or the Marklin CS2 will by fine for you. Don't let anybody confuse you. We have experts on here who are great but frankly most of the time I have no idea what they are talking about.
Best to make your own decision and any future problems can be sorted by somebody on the forum.
#13 Posted : 06 March 2019 23:43:18(UTC)
Robert
I would sooner have an MS2 than a CS1 (60212). The screen implementation of the Cs1 is not very god at all, and I was very disappointed in it when it was first introduced.
The ms2 will allow you to do everything a cs1 will, unless you end up with a very large layout. But if you have alarge layout then a cs1 will not help either as its output is not very high, and the booster implementation was flawed. I don't know if ESU fixed that when they produced the software version 3 and up, but you will only be able to use ESU boosters, if they do work. If you are running that many trains that a cs1 or ms2 cannot handle the load then you are into cs2/3 territory anyway, probably with boosters.
The track box that comes with the ms2 will allow you to use 1 or 2 ms2's plugged straight into it, and by using a CANBus expander you can have more than 2 (I believe up to 10?) ms2s.
You can get a brand new ms2 setup (including track box and 36VA power supply as provided in start sets) for a similar price to just a cs1 (which will still need a power supply, although you could use an old Marklin transformer for this).
#14 Posted : 06 March 2019 23:50:52(UTC)
Robert
Hi Robert,
I have a CS1 60212.
I have been using this consistently since 2007 on my layout, and have it connected to an MS1 as well.
The latest engines from Maerklin (including MFX and MFX+) register and work perfectly on the CS 1, with all sounds and features.
If you take note of what Tom says about the versions, a CS1 should be perfectly useful for you.
(The reality cab control and consumer replication of the MFX+ does not work, that is only for the CS3)
Yes the screen and the speed of the processor are outdated - but for me it is only a model train set!!!
Offline TEEWolf
#15 Posted : 07 March 2019 01:00:21(UTC)
Well you told this already once. Because of your statement, I was encouraged to test it at my last MIST. A member has a CS1. He already told me before, it would not function, nevertheless I tried and it failed. I do not know why.
In post #3 you describe detailed the problem of a CS1. Too many possibilities for a controller. And the CS1 at my MIST I do not know its standard. Sorry I only would take it as a gift, even it was about 15 to 20 years ago state of the art. But today it is totally superseded. I think it really can be compared to the development for a software like Windows. Who is still using Windows XP today? Even no longer supported by Microsoft, certainly there are a few people using XP. XP was a good OS.
I guess (but I never did a serious research about it) an influence has the try of Märklin to reorganize the current supply of its MRR. I only know the Märklin-Booster 60173 did require a separation of the ground rail between the booster circuits. The 60174 does it not. There must be an effect to the CS1 as well. It is to far away from me. I think you are much better informed about this desaster by Märklin.
Offline TEEWolf
#16 Posted : 07 March 2019 01:19:58(UTC)
Robert
In any case, I would decide for a controller, which is running perfectly in a CAN bus.
If I remember correctly once you wrote you are speaking German. Please refer to this marklin-users.net thread post #26
https://www.marklin-user...--Here-I-come#post588326
I listed some links about the CAN bus, mainly in German.
From my starter set I do have 2 MS 2 and one track box. Except the 16 functions of a MS 2, it is really a good and sufficient controller for all basic digital functions too. I still use the MS2 and sometimes even the track box. I had some software problems, when I received the MS2. But it was version 1.8 meanwhile it is updated to version 2.7 and I did not recognize old failures any more.
Just for your information, this offer includes MS2, track bx and power suppy
http://joes-modellbahnla...15f08b03b/Products/60657
#17 Posted : 07 March 2019 22:42:02(UTC)
Even two MS1s or a MS1 and a CS1 are communicating on a CAN bus.
It works fine, even without galvanic isolation LOL
#18 Posted : 08 March 2019 09:18:24(UTC)
There's an understatement........
The CS1 works fine with a MS1. You can plug a MS2 into a CS1, but the MS2 will not work with the CS1.
If the CS1 is at v2.0.4 it can act as a remote controller to any CS2 via the ethernet cable, and will work with a CS3 if you use a CS2 as an intermediary controller.
#19 Posted : 09 March 2019 07:53:56(UTC)
When it comes to programming mfx decoders a lot can be done with a CS1 that can't be done with an MS2.
MS2 cannot even do basic things like dimming the lights, changing the speed curve, changing the function mapping, ...
The screen of the CS1 is its weakness - but it still has more pixels than the screen of an MS2.
#20 Posted : 09 March 2019 07:56:41(UTC)
I don't know what you made wrong. It is very simple to connect the MS2 trackbox to the sniffer port.
Offline DB Fan
#21 Posted : 10 March 2019 05:36:19(UTC)
DB Fan
What transformer do I need/ can be used with the CS1? Can I connect it directly to the track or do I need a special connector? I’m going to use mainly M track. Thanks.
Offline kgsjoqvist
#22 Posted : 10 March 2019 15:20:39(UTC)
kgsjoqvist
The trafo should be a 60052 or similar that delivers 52VA AC. A special Calle has to be used.
Connection to the track can be through a connector M-track without chokes. Or just soldered wires to the track.
Guest (10)
Another central station 60212 question (Digital)
by DB Fan 10/03/2019 22:29:00(UTC)
This page was generated in 0.708 seconds.
