Offline Carlos
#1 Posted : 13 February 2019 23:55:41(UTC)
Carlos
Hello everybody:
I'm traying to install the 89983 turntable but I don't know how to make the circle to insert the turntable in my next layout. If someone can help me I will appreciate.
Thank you in advance and my regards.
Carlos
Offline zscalehobo
#2 Posted : 14 February 2019 03:02:34(UTC)
zscalehobo
Couple ways to read this ... are you asking the dimension of the hole or how to actually make the cuts?
Do you have the manual that comes with the unit?
If not, here it is : https://static.maerklin....00a8dbc5361534237469.pdf
In case you don't have the manual and cannot link to the pdf above ... it's a 145mm diameter as shown on page 2 of the manual.
If it's a physical "how to cut" issue, your best bet is to get a compass, scribe out a 145mm diameter circle and then use a saw or some blade to cut out the hole. Depending on the surface, you can use an X-acto knife (For foam layouts) or drill holes and then use a saw to follow around the circle you've scribed with the compass.
Frank Daniels
Owner - z.scale.hobo
A Noch "Top Dealer"
Irvine, California, USA
www.zscalehobo.com
thanks 1 user liked this useful post by zscalehobo
Offline Carlos
#3 Posted : 14 February 2019 22:52:55(UTC)
Carlos
Thank you Irvine for your answer, I hope I don't make a mess cutting that circle in the layout.
Carlos
Offline zscalehobo
#4 Posted : 15 February 2019 00:36:45(UTC)
zscalehobo
Glad to help, Freeport. :D HEHEH
Frank Daniels
A Noch "Top Dealer"
www.zscalehobo.com
Offline Carlos
#5 Posted : 15 February 2019 03:40:19(UTC)
Carlos
Carlos
I’m sorry, I mean thanks Frank Daniels,
Carlos
thanks 1 user liked this useful post by Carlos
Offline Filipão
#6 Posted : 04 March 2022 05:24:48(UTC)
Filipão
Hello, newby here, sorry for the silly question.
Got the turntable for 6 but no tracks included, can anyone please let me know which tracks I should buy to fit inside the roundhouse 89835 (still on its way to me)?
I'll be on Rokuhan tracks, I know I need adapters, only 2 (two) as the 6 tracks for the roundhouse will be Märklin.
Thank you so much!
Filipe
Offline Mman
#7 Posted : 04 March 2022 15:57:57(UTC)
Mman
Two 8500’s per roundhouse stall. Or, I suppose, one 8505 per stall as at 220mm it is twice as long as an 8500.
ChrisG
Offline zscalehobo
#8 Posted : 04 March 2022 17:43:53(UTC)
zscalehobo
Careful with Chris' (Mman) image ... that's showing the OLD roundhouse 8983 3-stall which has different entry dimensions vs the latest 89835 6-stall cardboard roundhouse kit. The old roundhouse sits BACK away from the turntable while the newer one sits really close to the turntable.
Latest 89983 turntable instructions:
https://static.maerklin....3ff69bc6c41638795581.pdf
Snip of instructions showing the latest instructions where you add 8503s instead of 8500s in-between the turntable and the roundhouse. After that - you use 8500s inside as shown in Chris' (Mman) attachment
Frank Daniels
A Noch "Top Dealer"
www.zscalehobo.com
Zme
Offline zscalehobo
#9 Posted : 04 March 2022 17:47:14(UTC)
zscalehobo
another page in the instructions:
Frank Daniels
A Noch "Top Dealer"
www.zscalehobo.com
Zme
Offline Filipão
#10 Posted : 04 March 2022 22:44:29(UTC)
Filipão
Thank you so much, I am overwhelmed with the swift and thorough replies!
Respect to this Forum and Users.
thanks 1 user liked this useful post by Filipão
Zme
Offline Terry Steen
#11 Posted : 19 September 2022 07:54:58(UTC)
Terry Steen
I have the Turntable and Engine Shed there should be special rail tracks (8993) that have a gap in a rail that is bridged by a diode that stops the train automatically when fully inside the engine shed, its the same rail used in the reverse loop track setup in the Marklin mini club instruction book 0294
Offline Toosmall
#12 Posted : 19 September 2022 12:16:39(UTC)
Toosmall
Offline Poor Skeleton
#13 Posted : 19 September 2022 20:41:29(UTC)
Poor Skeleton
Knock up your own. The diode is a 1N4001
And just about any 1A diode will do, 1N4002, 1N4003, 1N4004... A 1A Schottky will be even better, if a good deal more expensive. Anyway, the point is the 1N4001 is a very generic diode, so you can freely substitute whatever you can lay your hands on.
Chris
This page was generated in 0.346 seconds.
