2 Pages12>
#1 Posted : 30 October 2018 22:24:54(UTC)
Does "my world of operation" works with the CS3?
I did bought an mfx+ locomotive and tried to open simulator but the screen of the CS3 start flashes and screen become black.
Default with the locomotive or CS3?
Edited by user 03 November 2018 10:07:16(UTC)  | Reason: Not specified
#2 Posted : 30 October 2018 22:49:57(UTC)
What power supply are you using? This sounds like the cs3 is rebooting.
#3 Posted : 31 October 2018 05:43:20(UTC)
I use 60061 at 60 VA.
#4 Posted : 31 October 2018 06:25:55(UTC)
Should i check at the system settings? Reboot is not setting in the system.
#5 Posted : 31 October 2018 12:16:30(UTC)
Nobody who knows the problem?
#6 Posted : 31 October 2018 18:34:47(UTC)
I would certainly check that you have the correct transformer configured. If you have the 100VA transformer configured then attempt to use draw more than 60VA from the transformer it would certainly produce the symptoms you describe.
#7 Posted : 31 October 2018 19:19:21(UTC)
I did set 60 VA configured in the CS3.
That did i do when i did start CS3 for the first time.
#8 Posted : 31 October 2018 22:43:41(UTC)
OK, that at least eliminates that as a possible problem.
Offline Crazy Harry
#9 Posted : 01 November 2018 01:03:11(UTC)
Crazy Harry
Does your locomotive work with the CS3 when not in "World of Operation" mode?
I have one mfx+ locomotive and "World of Operation" works fine on my CS3.
#10 Posted : 01 November 2018 06:53:31(UTC)
Yes
Offline Crazy Harry
#11 Posted : 02 November 2018 02:07:18(UTC)
Crazy Harry
Yes
Interesting. Unfortunately, I do not have any ideas what could be causing your problem. Which locomotive did you buy?
Harold.
Offline TEEWolf
#12 Posted : 02 November 2018 02:58:15(UTC)
Goofy, I did not recognize your problem at my CS 3+ yet. I use a 100 VA power supply (#60101) at my CS 3.
But I have another obscure phenomenon. My CS 3 does not shut down on the first time. I have to repeat the shut down procedure up to 3 times till the CS 3 shuts off. I do this via the menue button in "Systems". I already sent a mail about this to Märklin, but have no answer yet.
#13 Posted : 02 November 2018 03:12:27(UTC)
wondering if there is something weird about the electricity in your house. Nothing seems to work there.
thanks 5 users liked this useful post by DaleSchultz
#14 Posted : 02 November 2018 05:36:42(UTC)
No, I do not believe this is a (house) power problem, it is something that happens when the CS3 gets itself in a knot.
However my observations are (were) that it only happened very early on with a new CS3, before many locos were configured
Maybe even if the only loco was an mFX+ one.
The blank screen symptom is not a power off, more a reboot. I haven't seen the issue since last year -
I will see if I can dig out my notes on it. From memory the screen blinked/blanked out 5 times when doing a particular edit function
After that the CS3 was unresponsive until a power off/on restart.
I did try to get a response from Marklin Service at the time but there was nothing of substance there.
I suspected it might have been addressed with one of the code updates - but that seems not to be the case.
#15 Posted : 02 November 2018 09:25:38(UTC)
Strange...this happens to me too sometimes but just only two times to shut down.
Sometimes it happens and not...
This mean my CS3 does not working it should do.
No wonder why i did had problem with the m83 and Rocos semaphore.
#16 Posted : 02 November 2018 09:28:32(UTC)
Yes this is how it happens.
#17 Posted : 02 November 2018 12:21:21(UTC)
Should i leave the CS3 back to the dealer to repair it? Or stand by? Is it bug in the system? Any tip what to do?
Offline TEEWolf
#18 Posted : 02 November 2018 22:35:06(UTC)
Nothing is wrong with the electricity in my house. Works fine. But it looks like that with the software in the CS 3 is something going wrong. As a former employee of IBM, I guess you are excellent informed about software. Do you think a software without bugs is existing?
Märklin themselves announced the CS 3 SW Vers. 1.3.3 only as a beta version. They request their user telling Märklin about their founded bugs. What are you saying as a software specialist? Is it a software bug or not?
Offline TEEWolf
#19 Posted : 03 November 2018 03:14:38(UTC)
I just tested my CS 3+ with the "world of operations" and it was perfectly functioning. I even could easily install my only Liliput loco with a lokdecoder from ESU 3.0V on DCC. But the read function for the decoder is not working. Fortunately I found the digital address very quick.
And now the total surprise: after a long time the CS 3 shut down immediately after the first try. I make a bet there is a software connection between this "world of operations" (which I did not use for a longer time) and the shut down function.
My recommendation: if nothing more does bother you with the CS 3 and it is acceptable for you, keep the CS 3. Play with it, but write an e-mail to Märklin service telling them about this software bug in the version 1.3.3. Request for help as you can solve your problem.
I did this once, while my CS 3 was not updating my MS 2. I received a very quick and short answer. Märklin wrote, please wait for the next software update in 4 weeks, than it will work. And so it happened.
#20 Posted : 03 November 2018 09:23:11(UTC)
Okey i wait to leave my CS3 back to the dealer.
Seems there is defaults in the software.
#21 Posted : 03 November 2018 10:09:01(UTC)
Good news!
I did solved the problem.
It was foolish to solve the problem.
Thanks for the support! ThumpUp
Offline Herrfleck
#22 Posted : 03 November 2018 11:25:11(UTC)
Herrfleck
You have been a member since:: 08/08/2009(UTC)
Good news!
Hello Anders!
Good to hear that you solved the problem!
I have following this tread and others about CS 3 because I thinking about buying one myself?
Would you please tell us what was the problem?
Thanks in advance!
Bertil.
- since my lack in english I don't write so much here.. but learn by trying right? :) -
//Bertil
thanks 1 user liked this useful post by Herrfleck
#23 Posted : 03 November 2018 11:42:52(UTC)
Good to hear Goofy. It would be very useful if you can tell us what the problem was and how you solved it.
#24 Posted : 03 November 2018 14:17:36(UTC)
Originally Posted by: Herrfleck Go to Quoted Post
Good news!
Hello Anders!
Thanks in advance!
Bertil.
Hello Bertil!
The problem see you here in the picture.
This information did not stand in the locomotive manual which Märklin should present so customer knows it.
Offline MaerklinLife
#25 Posted : 04 November 2018 06:16:02(UTC)
MaerklinLife
So basically, it works when you read the manual? Who would have thought.
thanks 3 users liked this useful post by MaerklinLife
#26 Posted : 04 November 2018 08:45:32(UTC)
It is a good approach to place locomotive-specific information in the loco manual and controller-specific information in the controller manual.
mfx+ came before the CS3, so it is chronologically impossible to have CS3 usage tips in all mfx+ manuals.
Märklin's user information is often distributed over several "manuals". You have at least four pamphlets when you try to add a decoder, a motor, and a lantern to a turnout.
Having "How to" instructions would often be helpful. Sometimes you get those in Märklin Magazin or Märklin books.
Buy the books or read the fancy manuals.
Märklin presented the required information - and as far as I can tell they presented it at a reasonable location.
#27 Posted : 04 November 2018 08:50:05(UTC)
This information MUST stand in the locomotive(s) manual when it´s about mfx+ decoder which support "world of operation".
It support more easier to understand what to do with the CS3.
#28 Posted : 04 November 2018 09:09:48(UTC)
You cannot expect this information in a loco manual that was printed before the first CS3 was sold.
Resizing windows on a controller is controller-specific and not locomotive-specific.
This behaviour may change completely with a software upgrade for the CS3, rendering the redundant information in the loco manuals obsolete.
In your opinion the information MUST be in the loco manual, in my opinion it CANNOT be there. Let's agree to disagree. Over and out.
#29 Posted : 04 November 2018 09:55:26(UTC)
That Marklin CS3 book is very good.. When our local dealer got the first CS3, we were able to get up to speed with it by working through the book.. Personally, I feel that book should be included with every CS3 as the manual that comes with the CS3 is not as useful..
#30 Posted : 04 November 2018 09:58:44(UTC)
deleted
#31 Posted : 04 November 2018 10:03:08(UTC)
I did bought 37872 and in this manual it stand with CS3 how to use functions.
It MUST be same way how to use "world of operation" stand in the manual of locomotive which do have symbol + how to open the displayed in the CS3.
It verified easier way for the customer.
#32 Posted : 04 November 2018 10:12:54(UTC)
Correct!
Märklin should after all those years and even with the new CS3 tell how to open the displayed on the CS3 by use digital locomotive which support "world of operation".
When you buy an new CS3 there is no manual of it and Märklin says you must download the manual in the Märklins homepage.
I accept it but when we are talking about digital locomotive with mfx+ decoder it must stand in the LOCOMOTIVES MANUAL how to open the displayed in the screen of CS3.
#33 Posted : 04 November 2018 12:23:18(UTC)
I thought the World of Operation took over the screen when it was used, I didn't realise it could be resized.
Offline TEEWolf
#34 Posted : 04 November 2018 15:59:29(UTC)
Goofy,
and here you find instructions manuals for mfx+ "world of operations" on Märklins homepage, even in English.
https://www.maerklin.de/...pare-parts/instructions/
#35 Posted : 04 November 2018 19:49:49(UTC)
when we are talking about digital locomotive with mfx decoder it must stand in the LOCOMOTIVES MANUAL how to open the displayed in the screen of CS3.
So, if you buy new tires for your car, you expect the tire manufacturer to give you a manual telling you how to drive your car ??? LOL
#36 Posted : 04 November 2018 20:41:10(UTC)
Ohh, the pleasure of lousy internet on a ship, double-posting deleted. Blink
#37 Posted : 04 November 2018 23:49:32(UTC)
Manuals that come with locos are not great but most on here probably don't need them. I suppose a loco manual can have an insert if it works differently with a CS3. However not really practical and as long as the CS3 has all the information that should be sufficient. I can see if a loco manual says one thing and the CS3 something else that that can cause confusion. It does not take much to confuse me but it is part of the hobby figuring out hoe model rail operates.
#38 Posted : 05 November 2018 09:21:27(UTC)
What has the car and the tires to do with the CS3?? Confused
Get to the stick about topic! Huh
#39 Posted : 05 November 2018 15:30:17(UTC)
I just tried to make you understand how impossible your expectations were. Blink
I am, you just don't understand it. BigGrin
#40 Posted : 05 November 2018 19:14:43(UTC)
Goofy,
If you see my post 24 i did post this information does missing in the locomotives manual.
#41 Posted : 05 November 2018 19:18:22(UTC)
As i do write again...what has the car and the tires to do with the CS3 and the problem about train simulation?
#42 Posted : 05 November 2018 19:38:34(UTC)
You are miss-quoting me. Blink
You left the "I am, you just don't understand it." part out of your quote.
That's not nice, and that part is actually the answer to your question.
Per
#43 Posted : 06 November 2018 19:37:03(UTC)
Per
No you did start an off-topic so you don´t understand.
So get to the stick about the topic.
And i did solved the problem about CS3 and the world of operation.
#44 Posted : 06 November 2018 22:25:58(UTC)
Is that your reason for miss-quoting me ??? LOL
Maybe you should "get to the stick" LOL LOL
#45 Posted : 07 November 2018 09:27:46(UTC)
You are so childish that you don´t even support anything in ths topic.
As i did verfifeid that i did solved the problem and told what was the problem.
So why do you start provoce for? Confused
#46 Posted : 07 November 2018 10:40:19(UTC)
Goofy. Per was just adding a bit of humour to the topic.
Good to see you have solved the problem. Model rail can be fun and is not always serious.
#47 Posted : 07 November 2018 11:02:12(UTC)
I'm not trying to provoke you; I think the problem is that you don't understand what I'm trying to tell you.
Sorry about that, no further from me on this subject.
#48 Posted : 09 November 2018 09:27:18(UTC)
I'm not trying to provoke you; I think the problem is that what I'm trying to tell you.
There is no reason to start provoce when i did already told did solved the problem.
In fact do i see real problem was porr information by of Märklin when you buy an Märklin mfx+ locomotive which there MUST stand information how to start "world of operation" with the CS3.
My CS3 do work nice now.
Hopefully no more problem...
#49 Posted : 09 November 2018 09:36:37(UTC)
Don't tell us what Märklin MUST do, instead let Märklin know.
I think this Groundhog Day thread can now be closed. Cool
#50 Posted : 11 November 2018 10:02:01(UTC)
Märklin do know the missing part in the locomotive manual.
A picture with few words says a lot!
2 Pages12>
This page was generated in 1.825 seconds.
