#1 Posted : 08 October 2018 20:14:57(UTC)
30470.001 DB BR44 reproduction (from the 30470-01) mfx and now have sounds for first time on reproduction loco.
Very Limited to 300 pieces - 379.99 EUR each. Due NOV/DEC.
Note - Marklin asking about the 30470.001 mfx/sounds. You'll get this loco if you take place in a special workshop at Maerklin in Göppingen where they upgrade the 30470-01 with a new motor and a sound decoder.
Edited by user 11 October 2018 14:29:34(UTC)  | Reason: Not specified
#2 Posted : 08 October 2018 23:48:27(UTC)
I could put a mSD3 decoder into my 30470.1 and then there would be 301 pieces......
Offline TEEWolf
#3 Posted : 09 October 2018 00:44:41(UTC)
Probably even 301,5 pieces.BigGrin, because of the mSD3 decoder. I just read that eg in the Insider 103 long (39170) has ex factory a mSD3 decoder on board. But it is a castrated one. It shall not be possible to change something in the sound. Whereas at a retrofitted mSD3 the sound can be changed.
#4 Posted : 11 October 2018 11:17:27(UTC)
Offline Armando
#5 Posted : 27 February 2020 15:01:50(UTC)
Armando
Has anyone experienced any issues with these two locomotives in the 30470 set when they run over the C-track wide-angled turnouts 24711 or 24712?
They seem to cause short-circuit as they run over them.
Armando García
#6 Posted : 27 February 2020 18:22:08(UTC)
Hi Armando.
It could happen because of the short twin pick up shoe. I have had this trouble!
Check where the short happens.
I also had trouble with flanges touching pukos.
Check wheels' spacing, inner dimension should be 13.8mm.
Usually if you can find the "offending" puko, a very short piece of shrink tubing around it will take care of it, leaving only the tip exposed.
Good hunting. 😂
thanks 5 users liked this useful post by jvuye
Offline Armando
#7 Posted : 28 February 2020 04:41:41(UTC)
Armando
Hi Armando.
Good hunting. 😂
Jacques,
Thank you for directing my attention to the possibility of the wheel flanges making contact with the pukos on the C-track wide-angled turnouts!
It was exactly that! There are at least two "culprit" pukos. Once wrapped with the shrink tubing, the problems was solved.
I'm attaching a photo opukos.jpegf the problematic pukos.
Armando García
thanks 1 user liked this useful post by Armando
This page was generated in 0.341 seconds.
