General topics
Small scale
New digital decoder that could be used in z scale locomotives
Joined: 18/03/2018(UTC) Posts: 28 Location: Södermanlands län
Hello everyone, I have found a new digital decoder, that because of its small size, might fit inside any z scale locomotive without any major modifications (even the class 89s and V60s!). I found it while browsing a webshop that sells 1:450 scale (or T-gauge) trains and accessories. Click here for more information about the decoderI have never converted a locomotive to digital operation before, so I'm wondering if you could tell by reading the product description and technical specifications if this decoder would work if I install it in a märklin z locomotive. (it would be controlled by a mobile station 2, powered by a 230 volt / 12 VA switched mode power pack.) |
Regards Erik
——— Mainly German trains era II-III
Collection consists of Z scale, digital H0 scale, G scale and T Gauge trains (they are sorted by collection size so my main focus is on Z scale)
Take a look at my Instagram: maerklin_z |
 2 users liked this useful post by Trainiac
Joined: 17/12/2001(UTC) Posts: 171 Location: Central Virginia
Assuming you have configured the MS2 to also use DCC - yes, in theory it would work.
You have to be careful - the decoder you are looking at has a max current draw of 250 mA. You'd need to ensure your Z loco fits that limit.
There are other decoders which support higher current draw, but they will be larger.
Helpful?
Gene |
Gene Wolski
 1 user liked this useful post by gwolski
Originally Posted by: gwolski  Assuming you have configured the MS2 to also use DCC - yes, in theory it would work.
Helpful?
Gene Thank you, yes that was indeed very helpful. But do you have any suggestions on how I can ensure that my locomotive fits the 250mA limit? |
Regards Erik
Great question! I don't know where but would hope there is a reference, whether official or not, somewhere around here. On a quick search, I found this video showing the current draw of two locos together: I'm sure we have some very knowledgeable members here who could chime in and help out! Gene |
Gene Wolski
By looking at the video, I think I might have a solution.
If I hook up my MS2 to a test track, the analog locomotive would run at the voltage that is constantly in the track, meaning that the motor is drawing its maximum amount of current.
Then I would just need to get a milliampere meter similar to the one used in the video and hook it up to the track |
Regards Erik
I don't think your proposed setup will work. Remember that digital systems apply a high frequency digital waveform to provide power and transmit signals to the tracks (from the DCC wiki) - you cannot measure current or track voltage with DC meters. There are DCC specific meters/measuring equipment that would allow you to take measurements.
Gene |
Gene Wolski
Back to the key questions - does anyone know the current draw for the usual Z locos? is 250mA enough for a V60?
Cheers! |
Gene Wolski
Originally Posted by: gwolski  You cannot measure current or track voltage with DC meters. There are DCC specific meters/measuring equipment that would allow you to take measurements.
Originally Posted by: gwolski  is 250mA enough for a V60?
Couldn’t I just use a regular märklin z controller and a DC meter and check if or how fast the locomotive runs once the meter hits 250mA? |
Regards Erik
Joined: 22/01/2014(UTC) Posts: 186 Location: CALIFORNIA, Irvine
Originally Posted by: gwolski  Great question! I don't know where but would hope there is a reference, whether official or not, somewhere around here. On a quick search, I found this video showing the current draw of two locos together: I'm sure we have some very knowledgeable members here who could chime in and help out! Gene That's my video! :D The railbus is only a lighted passenger car ... not motorized. So, this is a test of an 8811 with a 3-pole motor with a lighted railbus car ... it had been tripping Rokuhan controllers. Back to the topic ... A V60 should be under 250mA, but I have none in stock to verify. The Marklin motors are all over the map as pertaining to current draw. |
Frank Daniels Owner - z.scale.hobo A Noch "Top Dealer" Marklin Dealer and Z Locomotive Service Irvine, California, USA www.zscalehobo.com |
 1 user liked this useful post by zscalehobo
Great video! I think it was very useful Then it would probably be a good idea to test the current draw of each locomotive before installing this decoder |
Regards Erik
General topics
Small scale
