Offline Trainiac
#1 Posted : 17 September 2018 23:39:42(UTC)
Trainiac
Hello everyone,
I have found a new digital decoder, that because of its small size, might fit inside any z scale locomotive without any major modifications (even the class 89s and V60s!). I found it while browsing a webshop that sells 1:450 scale (or T-gauge) trains and accessories. Click here for more information about the decoder
I have never converted a locomotive to digital operation before, so I'm wondering if you could tell by reading the product description and technical specifications if this decoder would work if I install it in a märklin z locomotive. (it would be controlled by a mobile station 2, powered by a 230 volt / 12 VA switched mode power pack.)
Erik
Mainly German trains era II-III
Collection consists of Z scale, digital H0 scale, G scale and T Gauge trains (they are sorted by collection size so my main focus is on Z scale)
Take a look at my Instagram:maerklin_z
thanks 2 users liked this useful post by Trainiac
Offline gwolski
#2 Posted : 08 October 2018 21:24:25(UTC)
gwolski
Assuming you have configured the MS2 to also use DCC - yes, in theory it would work.
You have to be careful - the decoder you are looking at has a max current draw of 250 mA. You'd need to ensure your Z loco fits that limit.
There are other decoders which support higher current draw, but they will be larger.
Helpful?
Gene
Gene Wolski
thanks 1 user liked this useful post by gwolski
Offline Trainiac
#3 Posted : 08 October 2018 21:50:15(UTC)
Trainiac
Helpful?
Gene
Thank you, yes that was indeed very helpful. But do you have any suggestions on how I can ensure that my locomotive fits the 250mA limit?
Erik
Offline gwolski
#4 Posted : 08 October 2018 22:25:21(UTC)
gwolski
Great question! I don't know where but would hope there is a reference, whether official or not, somewhere around here.
On a quick search, I found this video showing the current draw of two locos together:
I'm sure we have some very knowledgeable members here who could chime in and help out!
Gene
Gene Wolski
Offline Trainiac
#5 Posted : 09 October 2018 11:31:03(UTC)
Trainiac
By looking at the video, I think I might have a solution.
If I hook up my MS2 to a test track, the analog locomotive would run at the voltage that is constantly in the track, meaning that the motor is drawing its maximum amount of current.
Then I would just need to get a milliampere meter similar to the one used in the video and hook it up to the track
Erik
Offline gwolski
#6 Posted : 09 October 2018 21:29:55(UTC)
gwolski
I don't think your proposed setup will work. Remember that digital systems apply a high frequency digital waveform to provide power and transmit signals to the tracks (from the DCC wiki) - you cannot measure current or track voltage with DC meters. There are DCC specific meters/measuring equipment that would allow you to take measurements.
Gene
Gene Wolski
Offline gwolski
#7 Posted : 09 October 2018 21:31:43(UTC)
gwolski
Back to the key questions - does anyone know the current draw for the usual Z locos? is 250mA enough for a V60?
Cheers!
Gene Wolski
Offline Trainiac
#8 Posted : 09 October 2018 23:17:17(UTC)
Trainiac
You cannot measure current or track voltage with DC meters. There are DCC specific meters/measuring equipment that would allow you to take measurements.
Couldn’t I just use a regular märklin z controller and a DC meter and check if or how fast the locomotive runs once the meter hits 250mA?
Erik
Offline zscalehobo
#9 Posted : 10 October 2018 01:30:40(UTC)
zscalehobo
Gene
That's my video! :D
The railbus is only a lighted passenger car ... not motorized. So, this is a test of an 8811 with a 3-pole motor with a lighted railbus car ... it had been tripping Rokuhan controllers.
Back to the topic ... A V60 should be under 250mA, but I have none in stock to verify. The Marklin motors are all over the map as pertaining to current draw.
Frank Daniels
Owner - z.scale.hobo
A Noch "Top Dealer"
Irvine, California, USA
www.zscalehobo.com
thanks 1 user liked this useful post by zscalehobo
Offline Trainiac
#10 Posted : 10 October 2018 23:07:46(UTC)
Trainiac
Originally Posted by: zscalehobo Go to Quoted Post
That's my video! :D
Great video! I think it was very useful
Then it would probably be a good idea to test the current draw of each locomotive before installing this decoder
Erik
This page was generated in 0.707 seconds.
