Offline costing
#1 Posted : 01 September 2018 00:46:49(UTC)
costing
I'm adding here for future reference a short description on how to add your own sounds to an mSD/3 decoder using the mDecoderTool software package and the 60971 programmer.
It's enough to add some extra WAV files to a new folder, for example "My Documents\Maerklin\Soundbibliothek\Sounds\My sound\". The file format should be 22050Hz, 16 bit, mono. A 44100Hz WAV file will be downsampled automatically, so it will actually take about half the space in the decoder. In the 8MB available on the decoder you can store about 3.1 minutes of sounds in total.
The file patterns are:
Start.wav - played once when the slot is activated. It's not interrupted by disabling the function. Optional.
01Loop.wav - played in loop until the function is disabled. An iteration is not interrupted. More NNLoop.wav files can exist in a sound folder. Optional.
End.wav - obvious. Optional.
Restart the app to show the new folder, add a new sound slot to the project and drag-n-drop the new folder on the slot. Then map it to one of the functions. The software doesn't make it easy to import your own sounds but in the end it works fine. And yes, the original ones are scrambled.
Why all this? I'm loading a steam engine with Christmas songs of course :)
.costin
P.S. Sorry if this is redundant information but I couldn't find it anywhere online.
thanks 1 user liked this useful post by costing
Offline TEEWolf
#2 Posted : 01 September 2018 01:38:06(UTC)
.costin
Have you seen this file?
https://www.maerklin.de/...1_Sounds_Hinzufuegen.pdf
Could not find an English version - sorry.
Does it help too?
Offline costing
#3 Posted : 01 September 2018 08:48:21(UTC)
costing
Hi TEEWolf,
Thanks for the pointer, I haven't found this one in the search.
It seems to indicate how to add sounds to CS3 to be played through its loudspeakers. I have no idea if they can later be transferred to a loco. Anyway, I don't have a CS3 so I can't try out...
.costin
Offline gamolina
#4 Posted : 27 September 2018 20:28:37(UTC)
gamolina
Argentina
hello,
How you arrange this with the programmer?
Offline costing
#5 Posted : 27 September 2018 21:03:10(UTC)
costing
You have to put files named like mentioned above in a new subfolder of "My Documents\Maerklin\Soundbibliothek\Sounds\". Please see below for an example of one sound file I have added.
.costin
thanks 2 users liked this useful post by costing
Offline TEEWolf
#6 Posted : 27 September 2018 21:15:10(UTC)
.costin
Hello costin,
just found a YT video about sound programming with a CS 3
and another thread was opened at marklin-users.net.
https://www.marklin-user...900-mSD-Sound#post575900
Offline gamolina
#7 Posted : 28 September 2018 12:59:47(UTC)
gamolina
Argentina
Many thanks Costin!!!
Do you want to share your Xtmas sounds?
my email is gamolinaar@yahoo.com.ar
Many thanks again!!!
Offline user2866
#8 Posted : 28 September 2018 14:20:31(UTC)
user2866
Hello everyone,
Except the 22050Hz, 16bit, mono parameters, is there anything else we should take into account for the .wav file format?
Because i use the above parameters and rename the file as start.wav as instructed , but the application does not allow me to drag n drop the file into my new sound selection. It seems that the format is not recognized after all.
I also noticed that none of the files already existing in the sound library, can play on media player or vlc player etc.
Is it really so hard or am i simply retarded? (rhetorical question)
Offline costing
#9 Posted : 28 September 2018 18:39:14(UTC)
costing
@user2866: Maybe you didn't restart the programmer app after changing the folder structure?
The library sound files are not straight wav, the content is scrambled somehow. But you can use the speaker icon in the app to try them out. And if you hear them, you can record them ... Though why would you do that? For a different manufacturer you have their respective sound libraries.
@gamonlina : you have an email
.costin
Offline OMarkert
#10 Posted : 24 October 2022 22:34:47(UTC)
OMarkert
I am fairly new to the Digital side, long time Marklin Analog user My question to Custom sounds does anyone have a directory or tell me where I can find custom files, such as Station files? I would be interested in Hamburg/ Ahrensburg along with Heidelberg Hbh station announcement files
Offline gamolina
#11 Posted : 25 October 2022 12:19:48(UTC)
gamolina
Argentina
Hello, with the new version of MSD3 software it is easy to add sounds.
Send me an email to gamolinaar@yahoo.com.ar and I can share a lot of sounds, includiing station´s one
Greetings
This page was generated in 0.466 seconds.
