Offline kganotop
#1 Posted : 09 April 2018 21:40:57(UTC)
kganotop
Recently I added the OBB Reihe 1116 (Model 39358) to my collection. It is a Delta-fx locomotive with some digital functions. Unfortunately it has only one sound functions, the horn. I want to add a sound decoder to this locomotive, but I don't know if it is possible. Is there any idea?
Offline Dave Banks
#2 Posted : 09 April 2018 23:57:52(UTC)
Dave Banks
You are going to face some challenges namely that loco has a C-sine motor but it is achievable. You really have to know what your doing. Last one I did was a BR152 "Fulda" for my friend Peter but it had a high propulsion motor. An ESU V3.5 sound decoder was used. It sounded fantastic when completed. SoftDrive® Sinus motors, which are often used on Märklin® locos can also be controlled by the LokSound V4.0 decoders.
[img=UserPostedImage]BR152 Fulda[/img]
Please have a read of this previous thread namely the description by "Applor"
https://www.marklin-users.net/fo...binary-running-behaviour
11.5. Settings for the C-Sinus Motor
LokPilot decoders with the 21MTC interface can drive the new
C-Sinus motors indirectly via the circuit board installed in the locomotive.
The LokPilot can generate all necessary signals provided
you readjust certain settings:
Load compensation must be turned off as described in chapter
11.2.
The control electronics of the motor also need a switched logic
voltage provided by the LokPilot on output AUX4. AUX4 must
therefore be active while the locomotive is stopped and while it is
moving (in both directions!)
D.A.Banks
#3 Posted : 10 April 2018 05:21:11(UTC)
Just a quick note. My Roco Taurus ES 64 U2 097 MRCE/TXL has a very good sound decoder (Zimo) and the sound is really prototypical.
I don't know if you can use a Zimo PLUX 22 with a C-Sine, but it has that Taurus sound.
The real thing:
The Roco model (not mine):
and finally the Maerklin model (updated sound):
I also have the new Roco BLS Re 475 (Vectron) which also has nice sound, but the Taurus is still up there.
(30 seconds in)
I would like a more realistic sound for my loks. Most of them, especially the modern ones are missing that whine that electric locomotives make when starting up.
The best ones that I have are the above named loks plus the Roco ICN.
ICN (not mine):
One day, I will get around to reprogramming my Re 460s and other modern loks to have a more suitable sound.
This page was generated in 0.244 seconds.
