Offline Rwill
#1 Posted : 16 March 2018 10:18:48(UTC)
Rwill
One of the workhorses of my layout is a BR216. It is neither ancient nor modern. It originated from start set 29845 and I picked it up (new???) on EBay from Keesmarklin a couple of years back. It has always been the nice heavy track testing /cleaning lok on call first in most situations. A couple of months ago it was playing up, so some maintenance - new brushes, drop of oil and push and prod with tweezers - and it was back purring round the layout like an old coffee grinder again. Currently relocating my layout so no running for the last two weeks but have got to the point of test running, so call for the 216. When powered on she will move a foot, stop a few seconds move another foot and etc. Same in both directions. To check my track laying another lok was used which works perfectly.
Any suggestions?
#2 Posted : 16 March 2018 11:10:45(UTC)
Check your brushes if they are free and not blocked in the brush holder, look for potentially lose wire(s), check slider and see if there are any signs of oxidation. take of front bogie and make sure the contact between bogie and frame is clean, again the most likely spot whereas oxidation can take place.
regards.,
Offline analogmike
#3 Posted : 16 March 2018 11:42:30(UTC)
analogmike
Any suggestions?
With the body shell removed, Run the Lok until it stalls. With track voltage up,Take a wooden tooth pic and touch the brushes to check spring tension. If the Lok starts to run this is where the trouble is. If not, keep exploring and poking round till she starts up.
Low teck at it's best but I have found many a problem this way.
Mikey
thanks 5 users liked this useful post by analogmike
#4 Posted : 17 March 2018 08:28:41(UTC)
Do the lights go off when she stops?
Filled up collector gaps could lead to a decoder overload with the decoder switching off.
Clean the collector, make sure there is no oil on the collector or the brush holders/motor plate and install clean brushes if the old brushes are oily.
Offline Rwill
#5 Posted : 17 March 2018 11:21:13(UTC)
Rwill
Thanks guys for your help.
Stripped down the motor -I know most of you do six of these before breakfast but to me this was a first!. Discovered a lot of gooey black stuff inside cleaned it all up with WD40 reassembled and off she went lovely. I wouldn't have said I was a loco oil maniac but clearly I must be!
Offline analogmike
#6 Posted : 17 March 2018 12:34:36(UTC)
analogmike
Glad you found it. Black stuff is normal, but if it is very gooey it may be a sign of over oiling. Take note. Live and learn.
Mikey.
BR 38, BR 24, BR 86, BR 216 digital conversion in its early stage (Digital)
by river6109 03/03/2016 01:46:35(UTC)
Märklin BR 216 (3075) - Ball Bearing and LED rear lights (H0-scale)
by Moritz-BR365 17/11/2014 12:18:42(UTC)
Brawa BR 216 (H0-scale)
by David Dewar 08/08/2011 23:48:25(UTC)
3075 BR 216 V160 Loco (H0-scale)
by nevw 27/06/2007 03:39:26(UTC)
This page was generated in 0.556 seconds.
