Offline oranda
#1 Posted : 14 February 2018 17:23:17(UTC)
oranda
Is there a diagram which describes the geometry of the Märklin rail parts?
There is nothing I can see in the recent Märklin catalogues.
If Ive got this right most curved tracks need 12 of them to make a complete circle, dependant on the radius, but I also need to know how the various straight track lengths relate to each other.
Offline Henrik Schütz
#2 Posted : 14 February 2018 17:59:59(UTC)
Henrik Schütz
The length in mm is the last digits in the part no 24188 is 188 mm 24172 is 172 mm , with curves the two last digits denotes degrees 24430 is 30 degrees, the 4 in the middle stands for R4 would be 24130 if R1
thanks 4 users liked this useful post by Henrik Schütz
Offline midwestbls
#3 Posted : 14 February 2018 18:58:57(UTC)
midwestbls
The full Marklin catalog shows many diagrams about how the various Marklin C-track (and K-track) pieces work together. In the new 2017-2018 catalog start on pp. 214-215. You can also Google "Marklin C-track geometry" and there are a number of reference images posted.
As already noted, on the straights the last 3 digits show the lengths in mm. On the curves the 3rd digit shows the "radius" (243xx = R3, 244xx = R4, etc.), the last two digits show the degree of the curve (24x30 = 30-degrees).
You are correct that the "standard" curved track degree of curve is 30-degrees, meaning to make a full circle (360-deg) you need 12. But there are other compensating curves as well - for use as the complimentary curves to parallel the two tracks from a turnout (switch) (24224 = R2, 24.3-degrees for the regular turnouts; 24912 = 1,114.6mm radius, 12.1-degrees for the wide-radius turnouts) these can also be used as different-degree curves as needed. In the smaller radii (R1, R2 & R3) there are smaller degree compensation curves (24206 = 5.7-degrees (almost "6"), 24207 = 7.5-degrees ... 48 of those would make a full circle too!)
- Bill
thanks 2 users liked this useful post by midwestbls
#4 Posted : 14 February 2018 21:07:55(UTC)
The track type (C/K/M/etc) of course is needed too.
Something like this?
thanks 4 users liked this useful post by Minok
#5 Posted : 14 February 2018 23:44:32(UTC)
Here is a really useful table of distances up to 1 metre, showing the straight C track combinations you can use to achieve a particular length.
I am not sure of copyright, so my apologies to the author.
https://www.marklin-users.net/up...86_cgleislangerTABLE.pdf
#6 Posted : 13 March 2018 21:00:30(UTC)
Good Evening
For those interested in C Track geometry may I suggest reading this topic in this forum: C Track Topics
Also you can create special tracks (straits with specific lengths or curve combinations / special angles) by
- cutting the track with a diamond disk and nicely filing and
- assembling the cutted tracks with hotmelt glue so as to obtain a new geometry C Rail with 2 C Track ends
- wiring the 3 connections of glued rail.
The resulting new C Rail section may be inserted anywhere in your C Track Layout
Offline TEEWolf
#7 Posted : 31 March 2018 18:35:37(UTC)
I just read your topic and here is a link to a brochure Issued by märklin on its homepage. But I guess you only get access to it via the German homepage version. Maerklin issues plenty of informations, but mainly in German language and only with access at the German homepage.
https://www.maerklin.de/...C3%A4nzungspackungen.pdf
https://www.bogobit.de/track/
http://www.henningvoosen...nloads/cgleisrechner.htm
At the first sigth I hope this is allrigth to you.
#8 Posted : 31 March 2018 18:57:23(UTC)
The Copyright is bogobit, on each page...
I had not seen that table before, and I notice lengths that cannot be achieved are listed at the end. I tried some of them in my track calculator and found many of those 'impossible' lengths that can be achieved to within less than 0,5mm
For example 798mm can be obtained exactly with:
24077 (x2) 77.5
24064 (x10) 64.3
so I suspect that the table is not exhaustive.
My track length calculator can be obtained at:
http://cabin-layout.blogspot.com/2002/05/track-length-calculator.html
#9 Posted : 31 March 2018 19:02:21(UTC)
That calculator is limited to 9 pieces only. So the page declares that 1199mm cannot be solved.
It needs 11 pieces and can be solved exactly:
24188 (1) 188.3
24172 (3) 171.7
24071 (7) 70.8
Offline TEEWolf
#10 Posted : 31 March 2018 21:00:58(UTC)
24188 (1) 188.3
24172 (3) 171.7
24071 (7) 70.8
Did you also check the complete installation routine, which you get scrolling down the homepage to the bottom? It is a ZIP file. After expanding you get a CGleisrechner.exe file.
For my understanding you get more than these 9 possibilities there.
#11 Posted : 31 March 2018 23:35:16(UTC)
24188 (1) 188.3
24172 (3) 171.7
24071 (7) 70.8
Good.
I went by the first paragraph that states that it uses up to 9 pieces.
Der C-Gleisrechner errechnet alle kombinierbaren Gleislängen, die mit 9 geraden märklin C-Gleisen erreicht werden können
I do not see more than one calculator.
It goes on to say that there is no solution for 1199mm
Für eine Länge von 1.199 mm gibt es keine Gleiskombination
Offline MaerklinLife
#12 Posted : 01 April 2018 07:50:30(UTC)
MaerklinLife
I usually work with 2 - 3 mm wiggle room. It works fine. 0,5 mm difference is an acceptable match in my eye.
Offline TEEWolf
#13 Posted : 02 April 2018 22:25:31(UTC)
Kombinierbaren Gleislängen, die mit 9 geraden märklin C-Gleisen erreicht werden können
Dale,
I think it is up to everybody himself calculating his track combinations. I only suggest tools to him making his life perhaps easier. I do not feel I have to sell this track calculator. You also may use the 2 tables regarding to track length, etc. at the links in my post #7 too.
Good tracking timesBlink
#14 Posted : 02 April 2018 22:36:07(UTC)
I never said anyone should use any particular calculator either, just pointing out limitations that I saw in one of them, and responding to other statements.
The two tools are hardly comparable, one is simple, static and incomplete table (and is platform independent), the other is comprehensive, handles K, C and M tracks and also calculates lengths at various angles and ability to control tolerance limits, but needs Windows. I get zero benefit from anyone using mine.
Guest (4)
This page was generated in 0.524 seconds.
