Offline White Buffalo
#1 Posted : 30 January 2018 19:40:47(UTC)
White Buffalo
Hello all,
I have a Märklin 37171 Dampflok with a Loksound2 V.1 chip that started acting very erratic & strange this past weekend. It will spontaneously just take off at a speed that is much higher than the max speed when using the Uhlenbrock controller. This locomotive is running like a sewing machine on steroids, I have to keep a very close eye when using it because it will all of a sudden take off at full throttle "Casey Jones" speed and switch directions (forward & reverse) as well. I have to be quick to catch it so it doesn't jump off the track and get damaged. It's on the shelf for now, until I have time this weekend to open her up for inspection.
Has anyone had something similar like this happen?
I am not sure if it is a decoder problem or the Uhlenbrock control unit. I do not think it is the Uhlenbrock unit since the other digital Locomotives are running just fine.
The decoder was installed back in 2002, it has maybe 5 or 10 hours of operating time.
#2 Posted : 31 January 2018 20:11:37(UTC)
White Buffalo
It did not do it at all last night and I ran it for about 20 minutes. I just don't want it to race off the track if I turn my back for a second or two.
Offline Dave Banks
#3 Posted : 31 January 2018 21:58:15(UTC)
Dave Banks
I have this phenomenon on my layout as well. It happens with one of my Roco locos with address #3. I use an Ecos 50200 controller & I have this happen when I activate a certain point with address #3. I think the fact that they have a shared address or I have possibly a shared ground connection maybe of some note but I must say this is a random act & hard to find but yes loco takes of at a rate of knots backwards or forwards & I have to hit the stop button fast or we have a catastrophe in the making. I don't believe there is anything wrong with your loco but there would be no harm in reloading the whole profile again just in case there is a software glitch if you can. I hope someone on this forum has a solution for me as well. So your not alone with this issue.
D.A.Banks
#4 Posted : 01 February 2018 13:25:55(UTC)
White Buffalo
Thanks for the advice Dave. I have never reset or done anything with the decoder except change the sound volume using CV's. I am definitely interested in learning how to do this though. I just need to put some time into researching the tools & procedures to do this. Playing with individual CV's through the controller can be tedious. I would like to learn how to do it with the better software & tools that are out there.
The locomotive did not do it at all, last night. But like you mentioned - you need to be quick to reacted to prevent a catastropheMad
Offline blid
#5 Posted : 01 February 2018 14:57:05(UTC)
blid
I have the 2003 Version R6 LokSound 2 booklet. On page 22 the CV 29 is described. Setting bit 2 to zero might help. It seems like the decoder change to analog mode for some reason. This will prevent running in analog mode.
#6 Posted : 01 February 2018 15:04:17(UTC)
White Buffalo
ausgezeichnet! BigGrin .
Thank you, I will try this out tonight when I return home. This forum is such a great place.BigGrin
tack så mycket ( is this correct?BigGrin ).
vänliga hälsningar,
Rich
Offline blid
#7 Posted : 01 February 2018 15:11:43(UTC)
blid
A German, English and Swedish mix! All correct as far as I can see.
#8 Posted : 01 February 2018 17:55:49(UTC)
When i use my trains and drive with the DCC protocol i make sure first by disable others protocol and analog drive in the adress CV 29 and CV 47.
This is for the version 4.
Yours lok sound are older version so i´m not sure if it only support DCC protocol?
#9 Posted : 01 February 2018 18:30:21(UTC)
Yes, I'm quite sure this will solve the problem. I had siùmilar problems with early Lokounds.
#10 Posted : 01 February 2018 20:52:22(UTC)
White Buffalo
Thank you goofy, and yes it only supports the Märklin Motorola and the DCC Protocols. On this Loksound 2 decoder CV 29 is The configuration register. 2 was set on bit 2, so I changed that to 0 to switch off analog operation.
CV 47 in this manual is Function Assignment F9(r), Which is a function outputs activated by key F9 when driving backwards. What is your CV47?
#11 Posted : 01 February 2018 21:44:23(UTC)
CV 47 are protocol selection.
#12 Posted : 01 February 2018 21:52:02(UTC)
White Buffalo
Thank you, I will look at my CV chart to see if there is a selection for that. But I did set the Uhlenbrock control unit to only transmit the Motorola New format for the addresses of this locomotive.
Offline blid
#13 Posted : 02 February 2018 14:19:00(UTC)
blid
I have replaced this decoder long ago and can't verify this.
As far as I understand this decoder has the DCC address in CV1 and the MM2 address in CV64 and no way of disabling either of them. In other words: it is always listening to commands for both addresses. If you are sending DCC commands to another decoder with the same DCC address, this decoder will also respond. The decoder don't know how you have set your controller.
#14 Posted : 02 February 2018 15:34:12(UTC)
White Buffalo
Danke Blid, your suggestion above seemed to work. My daughter and I ran it for about an hour without any problems.
besten Dank - Rich
thanks 2 users liked this useful post by White Buffalo
#15 Posted : 04 February 2018 00:54:03(UTC)
White Buffalo
So far so good, no problems yet
#16 Posted : 13 February 2018 23:46:42(UTC)
White Buffalo
it's been about 2 weeks and she hasn't repeated that behavior. Thank you all again for guiding me in the right direction.BigGrin
This page was generated in 0.515 seconds.
