#1 Posted : 27 January 2018 15:19:54(UTC)
Thinking of the CS3 plus in the near future. I want to connect my present (old type) S88.
Obviously I have the cable to connect the S88 to my CS2. What other items do I need. I have the CS3 book but (probably due to age)I cant quite figure if I need the S88 link or what other cables etc. and what connects to what.
Would be grateful for just a note of what I require although I expect this may have been asked before.
Thanks for any info.
Edited by moderator 24 January 2019 11:26:03(UTC)  | Reason: Corrected heading (CSV3)
Offline klarinettmeister
#2 Posted : 27 January 2018 23:38:14(UTC)
klarinettmeister
Hello!
You need the L88 60883. Just connect the old S88 cable to that. You can't use the old S88 without the L88. Just change the voltage switch to lower voltage. The makes them more sensitive to disturbances though.
thanks 2 users liked this useful post by klarinettmeister
Offline Thewolf
#3 Posted : 27 January 2018 23:43:10(UTC)
Thewolf
Originally Posted by: klarinettmeister Go to Quoted Post
Hello!
and the S 88 Viesmann (5217) compatible with the cs3? with the cs2 no problem..I use it ,,,but the cs3..I don't know...but no L 88 with the S88 Viesmann
#4 Posted : 28 January 2018 00:55:54(UTC)
klarinettmeister
Hello!
Oh. I can't tell anything of Viessman. I just assumed you meant Märklins 60880.
Offline TEEWolf
#5 Posted : 28 January 2018 02:16:07(UTC)
If you buy a CS 3 plus (60216) you can connect your S 88 directly with the CS 3+. If you buy a CS 3 (60226) you must first connect a L88 to your CS 3 and then you attach your S88. This S88 connection is one of the big differences between a CS 3 and a CS 3+. The CS 3+ has its input connector for a S88 in the bottom. (compare page 12 CS 3 book German version #03082 - top left the small picture - I hope the page numbers are identical with the English version).
On page 172 is a short overview and explenation between the 60216 and 60226 with a remark to the L88.
On page 93 down the page you see a graphics connecting L88 and S88 underneath the picture again you find a remark between the difference of a 60226 and 60216.
Under this link
https://www.maerklin.de/...gitalbuch-cs3/downloads/
you find more information about the connection of a S88 to a CS 3 - "Frequently asked questions about the structure of a feedback system". Unfortunately and as usual, not in English available.
The background is, that only the 60216 has an internal galvanic isolation. The difference occurs at a 60216 with an plug connector input and output for the Maerklin CAN-bus The 60226 has only a CAN-bus output and no input device. More you read in the 60216/60226 manual page 7 for a CS 3, please.
https://www.maerklin.de/...s/details/article/60216/
The manual for the 60216 and 60226 are the same. The differences for the controllers are listed on page 7 of the manual. Meanwhile this manual is available in 6 languages. And each page number is in each language the same.
If you got already a CS 2 (since CS 2 60215 with an internal galvanic isolation too) and if you want to keep it, I would recommend you to buy a CS 3+. Then you can connect them both via the CAN-bus and also your S88 directly to the CS 3+. Page 7 in the CS 3 manual should finally help you.
If you have already an old S 88 (art# 6088 or 60880) than you need a L88 for a further use of the old modules. (Read this in the CS 3 book on page 93 and at page 177 for the art# 60883).
#6 Posted : 28 January 2018 05:19:10(UTC)
... If you buy a CS 3 plus (60216) you can connect your S 88 directly with the CS 3+.
Nope,
You cannot ,as per current Marklin architecture, connect legacy S88s (6088,60881) to the S88 (RJ45) port.
#7 Posted : 28 January 2018 05:26:29(UTC)
The other comments about the L88 are noteworthy, and would be applicable if you are also intending to ditch your CS2
However, with the addition of a 60213 cable you can connect the CS2 to the CS3 and retain the existing S88 connection.
i.e. the CS2 provides a similar intermediary as the L88 would, and the CS3 can see/use these
Image show the host device selection as either the CS3 itself(60216 only), L88 or CS2.
I would suggest this is a better option EVEN if you bought a L88 which can support new S88s. If you do not have legacy 6088(60880)s to hold you back, the L88 can(sholud) be set to 12V to make the best use of the newer designs.
Offline siroljuk
#8 Posted : 28 January 2018 07:56:43(UTC)
siroljuk
Hello Peter
Can you tell me from which document you have found this very important detail information.Confused Confused
Nope,
You cannot ,as per current Marklin architecture, connect legacy S88s(6088,60881) to the S88 (RJ45) port.
I can tell that I haven't try this but I have such cables that I could have. What happenif I connect my old S88 device to CS3Plus RJ45 port
Jukka
Offline siroljuk
#9 Posted : 28 January 2018 08:39:40(UTC)
siroljuk
I just read L88 manual and made some testing:
When you use old S88 devices with L88 and RJ45 cables in BUS1 nad BUS2, just put the voltage switch to 5 volts. S88 devices are working OK. I don't have new S88-AC on my present layout so I cannot test that, but I suppose it won't work OK. I haven't test old S88 devices with their own cables, but I suppose that using 5 volts this bus3 will work fine.
I DON'T EVEN TRY TO USE OLD S88 WITH 12 VOLTS IN ANY KIND OF CONFIGURATION.
I suppose that if I put L88 to 12 volt-mode I can use new S88 AC and DC just using RJ45, but if I put these new devices to BUS3 . . . what then? I don't know... yet.
Someday I will test these combinations BigGrin BigGrin
Please tell me and us all, who have tested these, the real and supported combination.
Jukka
#10 Posted : 28 January 2018 09:10:34(UTC)
Originally Posted by: siroljuk Go to Quoted Post
Hello Peter
Nope,
You cannot ,as per current Marklin architecture, connect legacy S88s(6088,60881) to the S88 (RJ45) port. - of the CS3
Ok i should have been more precise with ".. the S88 (RJ45) port - of the CS3+.."
The point is, that there is no specific document.
In the first instance Marklin do not provide an adapter cable.
The 60884 is for the other way round - new S88s (RJ45) work with old S88s (6pin flat) controller )
I acknowledge the existence of the wiring/pin information in the 60881/2 manual, however as per your other post there is the issue of voltage for the actual device support. (The CS3+ provides 12V, but unlike the L88 there is no switch for 5V)
There are certainly some non-Marklin legacy S88 devices that state 12V support - I have yet to find any comment from Marklin on this for the 6088 or 60880 - and yes I had asked their service department.
Offline Thewolf
#11 Posted : 28 January 2018 10:48:49(UTC)
Thewolf
Nope,
Hi everyone Cool
Sorry...but I'd like to know who's right. The fake news are for the politicians. I don't think they belong here. No ?Laugh
#12 Posted : 28 January 2018 11:36:57(UTC)
Thanks for replies but I am still confused. I will not connect my CS2 to the CS3 plus.
Just wanted to know :
Connect old S88 using existing cable to the Link (presume this can be done)
then
Connect from link to CS3 plus (does this need another cable or is it supplied with link)
I will get the new switch mode. I presume tracks are connected as before. Looking at the book there appears to be a cable going from the link somewhere.
Sorry guys but I just cant quite get this. As for voltage ??
Offline Rwill
#13 Posted : 28 January 2018 12:27:06(UTC)
Rwill
May I add my low knowledge comment. i was recently looking at CS3 and CS3+ but I changed my mind. I perceived from the M website database descriptions that one of the advantages ( and justifications for extra price) of the plus version was the possible direct connection to s88 60881 ( and presumably 6088) versus the need on a base version CS2 to connect via a 60883 link (another 70 Euros). This is reflected in the bullet point descriptions in the database and in the manuals and the diagrams of system architecture contained therein. I have no knowledge based on physical & visual inspection/use of said items and a very low understanding of central station matters.
Offline siroljuk
#14 Posted : 28 January 2018 12:41:24(UTC)
siroljuk
Hello.
Look at attached picture, it is made by one of members not me:
Jukka
thanks 1 user liked this useful post by siroljuk
Offline kgsjoqvist
#15 Posted : 28 January 2018 12:57:03(UTC)
kgsjoqvist
TAMS offers an adapter for old s88 devices to connect them with RJ45 cables. It is 10% of the price for s88 link (l88). But the voltage mat be an issue ... not sure how CS3+ handles this, I use CS3 .
#16 Posted : 28 January 2018 13:04:55(UTC)
Thanks but the pic does not show an old S88. What I need is somebody who has an old type S88 and has to connected to a CS3 plus. Having looked at this there are conflicting views. At my age I need a diagram of 88 to link to CS3 plus and what goes where with the switchmode.
I am probably better just buying the stuff in order to see what is what.
Anyway thanks for all the various answers guys.
Offline Rwill
#17 Posted : 28 January 2018 14:09:00(UTC)
Rwill
In the CS3 plus manual from the database on page 4 (or about page 41 in English) there is a little picture in the corner and the note " CS3 plus also has a direct s88 connection on the underside". The picture looks like the same socket on the underside of the CS2 which we know is the socket from the good old fashioned S88. Cant copy & paste the page -too technical for me!
Edited by user 28 January 2018 19:22:11(UTC)  | Reason: Not specified
Offline Thewolf
#18 Posted : 28 January 2018 14:30:36(UTC)
Thewolf
Why don't you ask marklin directly?
Offline siroljuk
#19 Posted : 28 January 2018 16:31:15(UTC)
siroljuk
Hello, I try to explain:
If you want to use old type s88 devices with CS3 then you need:
L88 device and you should configure it to 5Volt and USE BUS 3, old type of s88 cables are capable to use. OR
You need this kind of adapter:
Please look here:
http://www.floodland.nl/aim/info_s88_kabels_1.htm
With this kind of pair of adapters you can use common RJ45 internet cable, as long as you need. Connect this cable into the socket under CS3Plus and that's it.
I have made these adapters and I use them with old S88 devices to L88 BUS1 and to BUS2 and L88 device is configured to 5 volts.
You have to realize that old S88 device uses 5Volts and if you put 12volt into it it will burn out.
As far as I have understand right Märklin DO NOT provide possibilities to connect old S88 devices into CS3-socket at the bottom of the device CS3Plus. You can put only new S88 devices 60881 and 60882 to that socket.
Hope this helps you
Jukka
Offline TEEWolf
#20 Posted : 28 January 2018 16:48:57(UTC)
Nope,
Hi everyone Cool
Hello Thewolf,
indeed, very understandable your question.
Clapcott wrote by himself already: he should have been more precise. That is it. He is not up to date and wrote about the old electronic stuff, but using the actual terms instead of the article numbers. So we are both right.
I wrote about the actual situation today, which is described in the new Maerklin book art# 03082 (German) and hopefully art# 03092 (English) too, [unfortunately nobody has not yet approved, if the pages of the English edition equals with the ones from the German edition. e.g. I did this several times already in this community for the manual of the CS (60216 & 60226)] to which David referred in his question. Unfortunately he also did not use the art#, but how should he know them, when he was confused by the book? It is a good book, but sometimes not easy to read and understanding. Maerklin implies sometimes that you are very well informed about the articles and background. But how should a newcomer know that?
The original question referred about this new book and not about the old, superseded situation of a 6088 or 60880. Unfortunately the name has not changed for the new stuff, but the article numbers did. So you have to be precise and use the art#, what I did.
I wrote about the new “60883 Link S 88”, the “60881 Decoder S88 AC” & “60882 Decoder S 88 DC” (page 177 art# 03082). The new decoders S88 are directly connected to the CS 3+ by the RJ 45 jack socket. You save the Link S88, because it is already built in for a CS 3+ (60216) but not for a CS 3 (60226)! For a 60226 you need the 60883 Link S88!
But you also need this 60883 Link S88 in the case using the old decoders 6088 & 60880. (see CS 3 manual page 4 and page 7 for description).
I wrote in my post #5 at the end: “If you have already an old S 88 (art# 6088 or 60880) than you need a L88 for a further use of the old modules. (Read this in the CS 3 book on page 93 and at page 177 for the art# 60883).” This was Clapcott repeating before reading.
And that is the point: this all stands on page 177 Maerklin book #03082 (German) first 3 articles from top. And heavens, can somebody approve here, please, if the page numbers of the German books equals with the one art# 03092 in English? Thanks.
Offline TEEWolf
#21 Posted : 28 January 2018 17:00:55(UTC)
Please look here:
Hope this helps you
Jukka
That is correct, but do not forget please, that with the 60883 L88 connected to a CS 3 (60226) you connect the CS 3 fully back to the CAN-bus getting the necessary galvanic seperaton.
Of course, if you need only 1 (in words: one) controller for your layout, no booster, etc. then a CS 3 60226 is absolutely sufficient. But if you got already a CS 2 I recommend to get a CS 3+ with full galvanic isolation inside for the Maerklin CAN-bus.
In another thread, I posted that based on Maerklin shop prices, if you put a 60883 L88 to your CS 3 (60226) the prices between CS 3 and CS3+ differs only by 15 Euro.
I bougth my CS 3+ with an higher discount than the dealer offered for a CS 3. So finally my CS 3+ was cheaper as the CS 3! Please do not ask me about this dealers pricing.
#22 Posted : 28 January 2018 17:25:59(UTC)
Blimey I am more confused that I was when started but that just me.
I will maybe just forget the old S88 and buy a new one and ask my dealer what I need to connect it to the CS3 plus.
Offline TEEWolf
#23 Posted : 28 January 2018 17:50:07(UTC)
Hello David,
ahhhh in a Maerklin CAN-Bus you may connect one, two or more L88 (60883) by using the so called Terminal 60125 (grey) or now 60145 (black). This you see in the system architecture @siroljuk posted. This named terminal is less a terminal but more a hub for almost everything you want to connect into the CAN-bus. It is recommended for the CS 3+ because the CS 3+ has only one Maerklin device connection (the 60226 has 2 of them! - compare CS manual page 7), therefore the CS 3+ has this CAN output device. Of course you may connect your L88 (60883) to this device, but then it is blocked for other usages. So put a terminal (60145) in between and you have more possibilities and more connections. Get a look into the manual of the 60125 (for the 60145 is at M homepage not a manual available)
https://static.maerklin....0d0c3e62e31434541986.pdf
and the 60883
https://static.maerklin....4c8c1dd20c1489747584.pdf
In these manuals you see a depiction of the possibilities of connection to and from a CS 2 or CS 3, which cables with how many pins you need, and which other devices can be attached to these boxes. Unfortunately this you do not see in the Maerklin book.
Make a long story short: if you got a CS 3 or CS 3+ (does not matter) put a terminal 60125 into it and then go from this terminal onwards with your 60883 L88.
Offline Thewolf
#24 Posted : 28 January 2018 17:57:27(UTC)
Thewolf
Nope,
Hi everyone Cool
Hello Thewolf,
TEEwolf...thank you ...but ...Uh .... if you allow me I'll read again what you wrote a little later ... it's a bit too technical Scared RollEyes
#25 Posted : 28 January 2018 18:02:03(UTC)
Thanks TeeWolf. Will have another look. Thank you for the downloads.
Offline TEEWolf
#26 Posted : 28 January 2018 18:03:43(UTC)
No not necessary - have a look into the 60883 manual (link in my post before) please. On page 4 (German but other languages available too) you see the connection devices for 6088/60880/60881/60882 and all other connections and much more if you scroll down.
For the 60881/60882 you got there 2 lines for connections!
If you buy a 60883 you can attach and use all your old devices as well.
This link is to an official document from Maerklin about frequently asked questions for setting up a feedback system
https://www.maerklin.de/...bau_Rueckmeldesystem.pdf
There this document is only in German available, here a link to a good translator machine:
https://www.deepl.com/translator
better than google.BigGrin
Offline TEEWolf
#27 Posted : 28 January 2018 18:27:04(UTC)
Yes that is very normal that you are confused! And you have to reread it, think about it and reread it again, and so on! Till you got the aha effect. That is nothing unusual and particularly. All the "pupils" have to do this at university and it is named studying. Because of that, they were called students and no longer pupils.Laugh
And do not forget - the books, manuals, etc. you need:
- the Maerklin book art# 03092
- the manuals from all various devices 60125/60145, 60881, 60883 you have to connect
- the CS 3 manual (and perhaps for you because you have a CS 2 the CS 2 manual)
- the system architecture from @siroljuk post #14
- maybe what I forgotConfused
I copied this system architecture picture down to my computer and opened it with my windows viewer. So I can easyly toggel between my PDF viewers (where I open all manuals available as PDF files) the book and the picture. Finally I only have my computer and the Maerklin book on my knees. It makes it easier to me crawling through the text, graphics, pictures and combine them together.
This shows what I wrote before: Maerklin expects a lot of knowledge to put their things together. But who got and has this knowlege? Not me - yeah perhaps @clapcott and 2 others, but these are 3 out of thousands.Huh BigGrin
#28 Posted : 28 January 2018 20:14:07(UTC)
Thank you and also for the translater.
#29 Posted : 29 January 2018 01:49:19(UTC)
Nope,
Hi everyone Cool
Hello Thewolf,
What are you talking about ?!
Given that this thread , and my reply, was about 6088/60880 S88s, I stand by my statement,
This was in response to the statement (quoted) = "If you buy a CS 3 plus (60216) you can connect your S88 directly with the CS 3+" <with "your" refering to Davids 6088/60880s>
My errata'd comment was to do with my own statement not including the term "CS3+" (even if this was is implied and not needed in context)
and was made, "just in case", someone quoted me out of context with the post I was replying to.
Offline Crazy Harry
#30 Posted : 29 January 2018 01:53:19(UTC)
Crazy Harry
The page numbering for the Maerklin book 03082 in German and 03092 in English seems to be the same. The first three articles at the top of page 177 are the 60883 (Link S88 or L88), 60881 (S88 AC Decoder) and 60882 (S88 DC Decoder).
Please refer to page 12 of the same books - the top picture of the CS3 and CS3+ has a small insert showing the RJ45 jack on the bottom of the CS3+ only and states "The CS3 plus also has a connection on the underside for the current S88 decoder (item numbers 60881/60882)." The point is that they are very specific in mentioning the current S88 decoders.
But to add to the confusion, see page 183 of the same books - under Items that have not been offered for a long time it lists the 6088, 60880 S88 Decoder (Feedback module) and states "Can continue to be used without limitation." No mention of any special conditions or cabling?
Now the 60883 (L88) manual is very clear and states that if you are using the 6088/60880 S88's or a mixture of the old and new S88's the voltage selector should be set to 5V. Therefore, I would conclude, if you want to continue to use the legacy S88 modules they would still have to go through an L88 with the correct voltage setting. The L88 would have to be connected to the appropriate plug on the rear of the CS3 or CS+.
Harold.
#31 Posted : 29 January 2018 13:14:26(UTC)
Did not think this thread when I started would cause any confusion.
However having read all the above. I will keep my CS2 for running my shuttle routes which will have their current Trafo. and separate from the rest of the layout.
Will purchase a CS3 plus with new switchmode and the new S88. Does the new S88 connect to the CS3 plus without the need for the Link.
Hopefully the answer is just Yes. lol.
Offline Thewolf
#32 Posted : 29 January 2018 13:30:43(UTC)
Thewolf
David, I understand very well how you feel.
I would certainly ask the questions here, but...as I trust my dealer's advice, I would ask him the question.
An example: a few months ago I wanted to buy an additional S88 marklin. He answered me:"No Serge no Serge no marklin... too expensive... you'll need an L88 or something like that to make it work... take a 5217 from Viesmann..."
That's what I did.
Have a nice day
Thewolf
Offline kgsjoqvist
#33 Posted : 29 January 2018 19:09:45(UTC)
kgsjoqvist
Yes - the new s88 (60881, 60882) connect directly to CS3 plus. No need for L88. As far as I can see Märklin say that old s88 (6088, 60880) also can use 12 V, but they don’t guarantee that other brands of s88 modules will... L88 has a switch for 5 or 12 V.
thanks 1 user liked this useful post by kgsjoqvist
Offline siroljuk
#34 Posted : 30 January 2018 07:36:18(UTC)
siroljuk
Hello.BigGrin
From Where did you find that?
Jukka
Offline TEEWolf
#35 Posted : 30 January 2018 17:40:22(UTC)
Hello.BigGrin
Jukka
No offence, but perhaps you may read some links I have listed. That is the idea why I do this. Wink Extra for you here again, even this special paper from Maerklin is in German:Scared
The last paragraph translated by a translating machine:
"Should I use my feedback decoder better with 5V or with 12V?
A signal level of 12 volts offers higher immunity to interference. Therefore, the current Feedback modules (Art. 60881/60882/60883) designed for operation with 12 volts.
The use of today's feedback modules is therefore preferable to the earlier versions. The predecessor generation that can still be used on the Link S88 (Art. 6088/60880) has been working with a signal level of 5 volts.
Nevertheless, the 6088 and 6088 decoders and 60880 can also be operated with a signal level of 12V on the Link S88. Inverted the current feedback modules optionally also work with a signal level of 5V. This can be set on the feedback module 60883.
When using systems of other manufacturers cannot guarantee that Märklin will not be able to guarantee that the higher signal level will not be exceeded problem-free. Therefore, you should use the 5V level as a precaution in these cases."
Translated with www.DeepL.com/Translator - not checked for correct translation
Jukka could I help you?
Offline siroljuk
#36 Posted : 31 January 2018 06:11:06(UTC)
siroljuk
Thank You TEEWolfBigGrin BigGrin .
Yesterday I opened old S88 module and looked it's circuit diagram (found from internet) and as you said it can be used with 12 volts also.
My my concern is due to the fact that I once burned the old-style CS2 by accident and it cost me quite much.
Everyone have to careful using expensive devices.
Well I always try to read all published documents especially those which I find here from Forums pages. I have to translate all German texts and Google don't always do good English text.
Anyway YOU people help very much THANK YOU ALL FOR your help.BigGrin BigGrin
I do all testings knowing risks sometimes I would like to tell all about testings results, but it is not possible knowing that I might be wrong.
Jukka
thanks 4 users liked this useful post by siroljuk
#37 Posted : 31 January 2018 21:44:09(UTC)
And don't forget that some of us here are native German and English speakers with train domain knowledge and thus can do a better job than Google Translate on some of those problematic sentences.
Offline TEEWolf
#38 Posted : 01 February 2018 02:37:08(UTC)
Meanwhile I recommend to try it by this translation software:
In my opinion it is much better than Google or as we call Google in sarcastic German "Gockel" (English: rooster)Laugh
Offline French_Fabrice
#39 Posted : 01 February 2018 22:47:28(UTC)
French_Fabrice
Sorry, I don't want to hijack this thread, but my question is closely related to L88/S88 and CS2 (not CS3).
As this thread has highlighted me a lot, I'm going to explain my situation there.
I've decided to give a try to new S88 Marklin devices with L88 as a hub. The ultimate goal is to get (completely if possible) rid of spurious feedback in my layout, due to old bus very sensitive to electronic interference.
As a result, I've purchased a power supply (66361), a L88 (60883) and S88AC (60881) in order to test them.
The L88 is connected to the CAN-bus using a terminal (60125). The voltage switch of the L88 is set to 5V.
It is identified in my CS2 with device ID #253.
I've set in the Layout Section of CS2 a feedback icon with device ID=253, and contact number 1.
The "T" plug of the L88 is connected to common ground.
When I connect contact #1 of the L88 to ground, it is detected successfully BigGrin so far, so good !
It is also detected successfully with rocrail - my driving software BigGrin
Now, I add a S88AC to bus #1 of the L88. Setup of the L88, according to the doc, is modified: I add 1 to number of RJ45 devices on bus #1.
Ethernet cable is plugged as explained in the doc.
Then I create a new feedback icon in the Layout section of the CS2, with device ID=253 and contact address #1001 which matches with physical contact #1 of S88AC.
When I connect contact #1 of the S88AC to ground, no change Crying. Contact #1 of L88 is still OK if I ground it.
I've also tested it on bus #2 with contact address #2001, changes in the setup of L88 (1 RJ45 device on bus #2), same results: no change Confused
My CS2 is a 60214, with software 4.1.2 . It is not the latest version (4.2.1) !
So I come to the conclusion, and my question:
Either the L88 has a problem, or I did bad configuration, or (more probably?) it is the software version of my CS2.
-> My question: Has somebody tested successfully such a configuration with the same CS/Software version ?
I've also tested it with LDT RM88N as per schema here: http://www.ldt-infocente...sbeispiele/page_1791.pdf . Same error: no change on contact #1 of LDT, but contact #1 of L88 is still OK Angry
Thanks for your feedback.
Fabrice
Edited by user 02 February 2018 08:02:58(UTC)  | Reason: Not specified
Offline siroljuk
#40 Posted : 02 February 2018 07:51:48(UTC)
siroljuk
Hi Fabrice
I used to have CS2 and similar configuration as you have. And first I had also similar problems.
Of course program versions were different than now.
Look carefully you connections and HOW YOU HAVE CONFIGURED all devices in your CS2, I had there mistakes.
Then. . . In an earlier version of the software, it was important in which order the devices get power on. First power to L88 and then CS2, and wait some time for CS2 to recognize all the devices.
I don't have CS2 any more but I am sure You get all done after allThumpUp ThumpUp . CS2 is good but in some cases quite slow.
It is good idea always when you are testing to test first L88 first 16 contacts, if they work ok then other should work if configuration is ok and you really use right addresses.
I used ground direct from CS2 main track plug sometimes I had problems when I took ground from the track far away from CS2.
I am sure you will succeedThumpUp ThumpUp
Jukka
#41 Posted : 02 February 2018 08:00:43(UTC)
French_Fabrice
Thanks Jukka,
Maybe I was too tired yesterday's night, and did a connection/configuration error ?
I will redo complete testing today or during the week-end.
I hope it will run, because I want to use now 12V with all my RM88Ns.
I'm reluctant to upgrade the CS2 software to 4.2.1 because I know some member (PMPeter) had trouble with Rocrail and feedback...
I'll keep you informed of the progress.
Fabrice
#42 Posted : 03 February 2018 14:42:03(UTC)
French_Fabrice
Hello folks,
Well, I don't have trouble any more.
All is running fine.Cool
Don't know what I did wrong last time ? maybe too much hurry ? The main difference is I've cut power off each time I plugged/unplugged devices... Maybe an issue at initialization time ?
Combination with L88+RM88N(LDT)+S88AC on bus 1 runs fine, with 12V voltage.
Previous feedback sensors wired directly on the CS2 (with traditional 5V S88 feedback bus ) still runs fine also.
All together is OK.BigGrin I hope to decrease the number of interference using 12V...
Now the layout will be updated... (quite some work to do) Blink
Fabrice
Offline siroljuk
#43 Posted : 04 February 2018 07:49:19(UTC)
siroljuk
HelloFabrice.
Well done!ThumpUp ThumpUp
Jukka
#44 Posted : 24 January 2019 11:47:57(UTC)
Nope,
Hi everyone Cool
Bottom of the CS3+ showing the S88 connector - RJ45 only.
Connector on the Viessmann 5217 (Marklin 6088 and 60880 S88 have the same connector)
You can see they don't match. The L88 is the only new generation device that has the connector for legacy S88 (although from the following pictures, the L88 has a 5 pin connector.......)
Edited by user 25 January 2019 03:20:19(UTC)  | Reason: Not specified
Offline Crazy Harry
#45 Posted : 24 January 2019 18:36:28(UTC)
Crazy Harry
The ribbon strip connector on the S88 Link (above the Bus 3) is actually 6 pins sticking straight up (I just checked mine). The little red rectangle just above the Bus 3 indication is a slide switch to select 5V or 12V for powering subsequent units.
Harold.
#46 Posted : 24 January 2019 20:48:51(UTC)
Thanks Harold. Now that you mention it, I can see the 6 pins in the above picture.
Offline franciscohg
#47 Posted : 26 January 2019 02:31:48(UTC)
franciscohg
Chile
Hello, has someone tried the LDT s88?
they are listed as compatible with almost all devices....CS3 and CS3+ included.
Also they have legacy and new s88 connections
Francisco
CS3 Plus and S88 (Digital)
by David Dewar 03/01/2019 20:24:11(UTC)
This page was generated in 1.286 seconds.
