Offline poppa-7
#1 Posted : 06 January 2017 06:19:24(UTC)
poppa-7
I have a Marklin 3397 Steam Engine fitted with a Marklin decoder and Im trying to operate it on a layout controlled with a Lenz LZV100 with LH90 and LH100 handsets.
But the Lenz does not seem to recognise the MFX decoder. I believe that that the Lenz system recognises DCC but no MFX.
The decoder address is 24. Any ideas on how I can get the locomotive to run on the Lenz DCC system. Ive search the Net but to no avail
Your help appreciated and anticipated.
Russell
#2 Posted : 06 January 2017 06:30:45(UTC)
Which decoder (ref. number)?
Follow the instructions that came with the decoder. Which protocols are documented for the decoder?
#3 Posted : 06 January 2017 07:19:41(UTC)
Russell
You have to set first at CV 50 adress and choice which protocol to switch off.
I believe your decoder stand only mfx.
If your decoder doesn´t have DCC protocol,you have to change out decoder to newer decoder made of Märklin or other products.
Lenz LZV100 supports only DCC.
#4 Posted : 06 January 2017 07:32:36(UTC)
We don't know what kind of decoder the loco has and we cannot know what CV 50 does.
It could be an ESU V3 decoder that does not support DCC.
#5 Posted : 06 January 2017 08:05:45(UTC)
But TS did wrote Märklin decoder...
#6 Posted : 06 January 2017 08:17:16(UTC)
Decoders in Märklin boxes can be ESU decoders - just like coaches in Märklin boxes can be Tillig or Fleischmann.
The Märklin 6092x mfx decoders are ESU decoders.
Maybe he has 6094x or 6096x, maybe ESU, maybe a decoder ripped out of a Märklin loco.
Offline poppa-7
#7 Posted : 06 January 2017 11:09:07(UTC)
poppa-7
Thanks for all the info. But after more investigation into the history of this locomotive I believe that the decoder is an upgrade and I think Marklin so no idea of the part number.
I have tried to look at the CV values on my CS3 but no values numbers are listed. Im sure now that I will have to replace the decoder with one from ESU. Which Loksound one do you this would be the best. Im a real novice when it comes to decoders.
#8 Posted : 06 January 2017 13:17:14(UTC)
Maybe you can find the Decoder Manufacturer ID as shown here on the CS2:
It can be 151 for ESU or 131 for Trix.
A retrofit decoder with ID 131 should support DCC, a retrofit decoder with ID 151 does not.
Did you open the loco? Is the decoder plugged in or soldered in?
Makes a difference when choosing your new decoder.
Offline TEEWolf
#9 Posted : 06 January 2017 21:44:34(UTC)
Russell
Spare parts list for 3397 by Maerklin
in the columne for the 3397 # 48, you see that this loco did not have a decoder on board when it was delivered by Maerklin.
Here a bit more information about this loco 3397 BR 03
http://www.lokshow.de/sh...DR&Seite=38&SID=
So you really have to find out, what kind of decoder you have inside of your loco.
Marklin Mfx decoder for DCC. (Digital)
by steventrain 21/08/2015 22:08:22(UTC)
NCE DCC compatible with Marklin MFX decoder? (Digital)
by Motley 01/08/2014 07:44:57(UTC)
Marklin Mfx Decoder 60942 - SOLVED (Digital)
by mancsaint 11/10/2013 20:15:14(UTC)
*Buzzy* Marklin MFX decoder (Digital)
by TimR 04/05/2011 23:38:56(UTC)
Sound download on Marklin MFX decoder? (Digital)
by martinfung 06/05/2006 16:55:40(UTC)
This page was generated in 0.461 seconds.
