Offline Or Vivante
#1 Posted : 27 December 2016 10:59:06(UTC)
Or Vivante
Israel
Hi friends
Maybe someone here can help me BigGrin
I'm a newbie in the Train Digital world
I recently bought Intellibox Basic and 2 locomotives
1. Marklin BR 80 016
2. Marklin Br 89 010
Can you please explain to me how to operate them with my IB?
One ain't responding at all
The other just runs like a doe LOL
Thanks a lot!
#2 Posted : 27 December 2016 11:25:41(UTC)
The IB defaults to DCC,
you will find ..
- a global setting to change the default
or
- a per-address setting to change the mode.
The loco that runs at high speed may be either
- an analogue loco , or a delta set to analogue mode
- a MM digital that does not recognise the signal (DCC) and switching to analogue mode.
Offline Or Vivante
#3 Posted : 27 December 2016 11:30:11(UTC)
Or Vivante
Israel
I have found the per address setting
I changed it to Motorola old.
Still no change.
How can I find out what is the loco address??
And about the doe,
How can I help him recognise?
I think he is Delta. how can I find out?
#4 Posted : 27 December 2016 12:06:02(UTC)
The Intellibox has a Motorola address search feature.
It's slow, but it works. And you only have two Lok's to test
#5 Posted : 27 December 2016 16:07:17(UTC)
A Delta loco that is configured for analogue operation behaves like an analogue loco. Open the loco and set an address using the DIP switches on the decoder.
I assume your 89 010 (no BR before a complete loco number) is the Delta version of model #30000. The serial number under Delta locos begins with "M". For digital locos it is "D" or "H" or "S". Look carefully as H and M are very similar.
The loco 80 016 has a programmable decoder (no DIP switches). Factory default address probably 78, maybe 24.
You can simply set a new address if you do not find the current address. It might be simpler to run the address search of the Intellibox as Jacques suggested.
#6 Posted : 28 December 2016 05:24:29(UTC)
Still no change.
And about the doe,
Worth checking also, is the track wiring correct?
Trafo to IB...
Brown Wire to "0" connector
Yellow to "L" terminal
IB to Track...
Red Wire to Centre Rail - ("B")
Brown Wire to the Outer Rail - ("0")
If the track leads are reversed the Loco's will run without control at about 60-75% of full speed
I'm sure you have them correct but it's a very common mistake. BigGrin
The other thing you could do is to remove the body (often a single screw in the top of the housing) , take a clear photo of the decoder and post here, we can quickly tell what style decoder you have and how to confirm the address if you can't get the address search function to operate correctly.
Hope this helps
Edited by user 29 December 2016 04:40:59(UTC)  | Reason: Not specified
#7 Posted : 28 December 2016 08:02:47(UTC)
Good point, but only relevant for older decoders.
I never experienced that - I had the wires wrong for years until I got an item with an old decoder that showed no reaction at all
The other thing you could do is to remove the body (one single screw in the top of the housing) [...]
No screws with the BR 80 track wart loco. Two hidden screws with the nice BR 80 model.
Offline Or Vivante
#8 Posted : 30 December 2016 16:25:55(UTC)
Or Vivante
Israel
Thank you every one for your replays
I can't seems to find the search option in my IB Basic
The 89 010 starts with an H, What does it mean?
Attached here is the two locos
#9 Posted : 30 December 2016 16:36:37(UTC)
With your BR 80 you should try address 60. Also try 78, 24, and 72 if 60 does not work.
With your BR 89, you can set all four switches to ON for address 80. Currently they are all off for analogue operation.
All 15 supported addresses can be found here:
https://www.marklin.com/tech/digital1/delta4.html
https://www.marklin.com/.../digital1/add_table.html
It is possible to change the address of the BR 80, but it is not simple.
This German post in the Uhlenbrock FAQ explains this:
http://www.uhlenbrock.de...en/ib-1/I79ACDE3-001.htm!ArcEntryInfo=0004.27.I79ACDE3&NewServerName=zeta
Offline Or Vivante
#10 Posted : 30 December 2016 16:47:09(UTC)
Or Vivante
Israel
HORRRRY!!!!
It worked!!!
thank you alllll so very much
specially HO
Thank you Thank you!!!
BigGrin BigGrin
Offline Or Vivante
#11 Posted : 18 January 2017 21:08:34(UTC)
Or Vivante
Israel
Hi :)
Just got my self another new locomotive :)
Piko H0 57201 Diesellok BR 218
Can't figure it out how to open it to upload a picture of the decoder...
How can I find out his address :)
Thank you all for your support!
#12 Posted : 18 January 2017 22:17:15(UTC)
The manual might help.
Default address will be either 3 or 78.
If you can switch the lights with 78, but loco does not drive then you will have to switch from Analogue mode to Digital mode - the manual will help.
The decoders with default address 78 are MM only, no support for DCC.
The decoders with default address 3 should support DCC and you can read the current address from the loco (CVs 1, 29, 17, and 18).
Offline Or Vivante
#13 Posted : 19 January 2017 07:54:19(UTC)
Or Vivante
Israel
Thank you HO
How ever both 3 and 78 didn't work not in DCC nor in MM
More ideas?
I didn't receive a manual with my loco
#14 Posted : 19 January 2017 08:09:34(UTC)
Under DCC, read CV 8 to find the manufacturer of the decoder. If successful you know for sure it supports DCC.
If that fails: the IB can automatically test all MM addresses.
As a last resort, a photo of the decoder might help,
Offline Or Vivante
#15 Posted : 19 January 2017 08:14:06(UTC)
Or Vivante
Israel
Can you explain to me how to open the loco?
The search option doesn't exists in my IB Basic :(
#16 Posted : 19 January 2017 08:19:34(UTC)
Check manuals for recent Piko BR 218:
http://www.piko-shop.de/is.php?id=16479
Remove one screw and take the body off.
Offline Or Vivante
#17 Posted : 19 January 2017 21:48:48(UTC)
Or Vivante
Israel
Hi :)
Here are the photos
Thank you HO for the manual who helped me open up the loco :)
#18 Posted : 19 January 2017 22:17:13(UTC)
Try this manual:
http://www.uhlenbrock.de...C3-011.apd/Bes75322b.pdf
Scroll down to the section "Setting the address with the Intellibox". If the decoder has the default settings (address 78, analog mode) this should do the trick.
Here is a German description how you can reset the decoder - if the current address is not 78.
http://www.uhlenbrock.de/de_DE/service/faq/decoder/I4B054FC-001.htm!ArcEntryInfo=0004.18.I4B054FC&NewServerName=zeta
I hope Google translation works for you. Feel free to ask if something remains unclear.
You have to connect two spots on the decoder with a wire/pair of tweezers while there is power on the track. Connecting the wrong spots could kill the decoder, so take care.
Offline Or Vivante
#19 Posted : 19 January 2017 23:21:41(UTC)
Or Vivante
Israel
Thank you HO!!
it tooked me awhile but i got it !! :)
Thank you so very much!
This page was generated in 0.510 seconds.
