Offline Rwill
#1 Posted : 15 January 2016 22:38:48(UTC)
Rwill
What have you done today dad? - Well I've been cooking - Cakes? - no 6083 decoders 2 off !!! - Don't ask , you know when you are about to do something very silly but you still do it (in life in general as well) - The smell was interesting and I suspect a bit toxic.
So the 6083 has been and gone to be replaced by the 60830 with the poncey plugs and now that has gone to be replaced by the 60831 which doesn't look anything like its predecessors and has a couple of extra input ports.
Don't fancy the Ebay 6083's - "looks little used in good condition but not tested" - that describes my two muffins so at last the question. Is the 60831 compatible with my old gear and does anyone recommend possible cheaper alternative - Viessman 5211 or something else?
Offline mrmarklin
#2 Posted : 16 January 2016 03:38:21(UTC)
mrmarklin
The first gen 6083 had weak transistors that were very prone to frying. I had mine fixed by an electrical engineer who is an ETE member. They can be fixed, but it requires some expertise.
#3 Posted : 16 January 2016 09:03:19(UTC)
there isn't much inside an 83 decoder and I've fixed one the other week after it had malfunctioned a few years back and never got around to fix it. and this was the only one out of 64, to your question whether or not they can be used with newer versions: I don't really know.
Offline PeFu
#4 Posted : 16 January 2016 10:45:11(UTC)
PeFu
I will go for these again:
http://www.ldt-infocente...i/doku.php?id=en:s-dec-4
I used them on my last layout (sold in 2007), never had a problem.
Cool Peter
#5 Posted : 16 January 2016 11:14:10(UTC)
60831 are cheaper than the old 6083 and works better.
If you use MM,you can even use the new m83,which Märklin do produce today.
Yours wally are enough big to buy an 60831.
If not less,get one as the second hand.
#6 Posted : 16 January 2016 14:32:04(UTC)
I can repair them, the question is it economic to do?
I'll investigate what current replacement transistors would suit. It will certainly be possible to find some that are more robust than the originals.
But having fried the 6083 do check the coils in your points and signals to make sure they are still OK.
Offline Rwill
#7 Posted : 16 January 2016 20:28:31(UTC)
Rwill
Oh yes when I do a job I do it thoroughly - melted a coil and a case of an almost new point motor. Put the remains of everything in one of my just in case bits and bobs coffee tins and if I lift the lid the smell is devastating and in its not coffee The board certainly has an incinerated "transistor" - different type in each of the two cookies the back of the pcb is well scorched and the cases have started to melt. If my daughter full of cold and unable to smell anything had not popped her head round the door to moan at the smell I would by now be living in a tent! Kind of decided to maybe try one "new" 60831 and one Viessmann 5211 but the Marklin item is yellow dot in the database - back order and terribly expensive at Gaugemaster (what's new?) and not showing on all the usual suspects on Ebay so I guess I'll wait a whlie
#8 Posted : 20 January 2016 19:59:45(UTC)
I can highly recommend the Viessmann 5211/ better specs and an exact replacement of the k83
#9 Posted : 20 January 2016 21:08:40(UTC)
Me too. I think that I have only lost 1 in the past 13 years. They have always been cheaper that the k83 units.
Offline PMPeter
#10 Posted : 20 January 2016 21:31:25(UTC)
PMPeter
I can also vouch for the Viessmann, LDT, and IEK equivalents. They all work well on my layout.
Offline fkowal
#11 Posted : 21 January 2016 14:17:14(UTC)
fkowal
I have used both the Viessmann 5211 and the ESU Switchpilot 51800. Going forward I would recommend the Switchpilot as you can use it as both a K83 or a K84. There is a mechanical switch on it were you choose the K83 or K84 mode of operation. This gives you future application flexibility.
Offline Karl Gunnar Sjöqvist
#12 Posted : 21 January 2016 16:29:10(UTC)
m83 works with DCC as well, but Märklin recommends to use DCC only for programming the decoder and then switch back to MM. Because in MM mode the decoder is locked from programming so you can't change anything by accident.
Offline Rwill
#13 Posted : 21 January 2016 17:24:19(UTC)
Rwill
Thank you all for your comments and advice. The postman today brought me a Viessmann 5211 which was incorporated into my little layout within minutes with no problems and all is now working fine with no cooking smells at all.
Offline Mark5
#14 Posted : 21 January 2016 18:15:34(UTC)
Mark5
Hello Karl and others,
However, this would be fine if using a CS or Ecos because both speak either DCC or MM. In fact, it seems a good way to prevent accidental changes. Do you see any drawback with using the m83, other than the price?
- Mark
#15 Posted : 22 January 2016 01:29:28(UTC)
... Because in MM mode the decoder is locked from programming so you can't change anything by accident.
I do not think you can lock a decoder.
If you are referring to a MM decoder ignoring any PoM activity then that is a small safeguard.
And, sure, the MM addressing capability does not extend to CVs above 80 if you are using a 6021.
But saying a m8* that is set to MM mode is locked out from programming is incorrect.
For one example (published because the m84 left the factory with the light brightness set to "0")
Ref: http://www.maerklin.de/f...mmierung_M84_Signale.pdf
`K83 Decoders (Digital)
by Rwill 21/06/2016 14:12:20(UTC)
k83 decoder plug type (H0-scale)
by aquaanox 19/12/2015 00:28:16(UTC)
60215 Wiring with k83 decoders (Digital)
by Steven S 18/08/2015 01:39:17(UTC)
6021 Control Unit with Uhlenbrock UHL64820 Loconet & IRIS infrared remote control to use k83 decoder (Digital)
by Hoover007 20/03/2014 08:00:50(UTC)
k83 Decoders - Series or Parallel? (Digital)
by waorb 19/07/2013 15:47:13(UTC)
Using k83 decoder with MS2 for use of 24997 uncoupler track (Digital)
by Geneva1 20/09/2012 11:10:08(UTC)
Power supply for k83 decoders (Digital)
by ChrisP 21/10/2011 09:20:21(UTC)
Connecting k83 decoder to 60653 Mobile Station (Digital)
by Bob 02/08/2010 16:59:38(UTC)
K83 decoder question (Digital)
by Tex 01/02/2010 19:19:46(UTC)
k83 decoder price (Digital)
by steventrain 10/11/2004 19:01:15(UTC)
This page was generated in 0.527 seconds.
