5 Pages<12345>
Offline GlennM
#101 Posted : 06 January 2015 00:07:35(UTC)
GlennM
Well it looks like it may be a cheap year for me, which is good as I overspent this year considerably BigGrin
Lets hope the Insider models are better
BR
Glenn
thanks 3 users liked this useful post by GlennM
Offline gerardo960
#102 Posted : 06 January 2015 00:30:53(UTC)
gerardo960
Argentina
Hi Boy more pictures in special the start set 29710 as the composition of the same. And please someone can get a brochure.
Thanks.
#103 Posted : 06 January 2015 09:35:49(UTC)
The newer steam locos tend to be quite expensive. I think I might go for the Br57 without sound to keep the cost down.
I think I might go for the desktop bitmap picture of the Br57 to keep the cost all the way down!
Dreaming costs nothing!
I used to do a lot of that when I had a young family and my wife was working part time. My pay would just about cover essentials so new locos during that period were limited to about one a year or less.
#104 Posted : 06 January 2015 10:32:59(UTC)
As it so happens, I obtained a PDF copy of the Eisenbahn Journal Dampflok Report #4 from 1997, which included some pages on the Br57. It's in German, so I can't read the text at all, but the pictures and diagrams are quite useful. I seems there were quite a few variants of the Br57. I've attached an extract to this post with 9 pages from the magazine on the Br57.
File Attachment(s):
EJ_Dampflok-Report 04_Br57.pdf (4,058kb) downloaded 178 time(s).
thanks 6 users liked this useful post by Bigdaddynz
#105 Posted : 06 January 2015 10:50:46(UTC)
I think marklin told all dealers to 10% limit discount on new items.ThumbDown
It's a pity that Marklin didn't tell dealers to stop price gouging as in the case of the 43866 dinning car - most prices on ebay are 80% to 100% above the RRP (129.95 eur).
#106 Posted : 06 January 2015 12:21:27(UTC)
Originally Posted by: 60904 Go to Quoted Post
.... G5/5 steam locomotive may be using the same frame and motion assembly as the recently released 3716x series of 0-10-0 tank engines.
With the driving rod big end on the 3rd axle from the front.
Driving wheel sizes are within 8cm.
The wheel arrangement is different. It will not be the same, but quite similar.
Yes, thanks, I can see that the axle spacings are different between second and third axles, compared to the 3716x series.
There will still be some standardisation of parts.
#107 Posted : 06 January 2015 15:14:41(UTC)
The G5/5 doesn't even show Telex in the photo. It is also a loco that doesn't have lots of pipes so it is assembled faster.
Things that could justify such a high price (in my perspective) are:
1- telex and smoke Seuthe both together are ok for more 30 euros in the price.
2- brushless motor (still dreaming with the SDS)
3- Cabin inside with great detail and painted in prototype colours
4- Light inside the cabin
5- Really multi digital systems including mfx+ and DCC with Railcom+
1.Telex from Märklin are "clumsy".
2.Too expensive to produce and not working good with the DCC protocol.
3.Agreed!But that will been too expensive as result,if not less you do it yourself.
4.Märklin do already started as standard in fine models.
5.I prefer to write...mfx protocol to use similar same like DCC protocol,when you buy ready digital sound locomotive.So you can also use it with MS2.Today you don´t.
#108 Posted : 06 January 2015 15:18:58(UTC)
I hope this time Märklin will do change K-tracks.
Maybe not...
Offline mbarreto
#109 Posted : 07 January 2015 12:43:17(UTC)
mbarreto
About first 2 points:
I like the new Telex couplers when used with the current close couplers.
The SDS works good and it is not dependent on the protocol between the command station and the decoder. It just needs appropriate electronics to be controlled.
Miguel
Mostly Märklin H0.
thanks 3 users liked this useful post by mbarreto
Offline vilithejou
#110 Posted : 08 January 2015 22:59:12(UTC)
vilithejou
Now the PDF in Spainish available for all (it's de PDF that I took the photos some days ago)
http://www.marklin-spain.com/home
There's Marklin, TRIX and LGB
Marklin confirm to dealers that all news will be out next week
Joan Vilarrúbia
vilithejou@yahoo.es
Fan of Märklín, Kroko lover
thanks 4 users liked this useful post by vilithejou
Offline Bart
#111 Posted : 08 January 2015 23:11:03(UTC)
Bart
*Bart
thanks 2 users liked this useful post by Bart
#112 Posted : 09 January 2015 20:20:37(UTC)
37229 In black livery Limited to 999! - https://www.marklin-user...-edition.aspx#post478847
Offline Bart
#113 Posted : 09 January 2015 20:27:21(UTC)
Bart
No Re 484 in Swiss set 29484 OhMyGod
but an Ae 610 Cargo,
and an mfx sound decoder in a €400 starter set:
Digital-Startpackung "Schweizer Güterzug". 230 Volt.
Vorbild: Elektrolokomotive Serie Ae 610 der Schweizerischen Bundesbahnen, Bereich Güterverkehr (SBB Cargo). Vier verschiedene Schweizer Güterwagen: 1 vierachsiger offener Güterwagen Eaos, 1 vierachsiger Kesselwagen für Lebensmitteltransporte, 1 zweiachsiger Rungenwagen, sowie 1 Staubsilowagen der Bauart Ucs. Alle Wagen eingestellt bei den Schweizerischen Bundesbahnen (SBB/CFF/FFS).
Modell: Lokomotive in Metallausführung, mit Digital-Decoder mfx und umfangreichen Geräuschfunktionen. Geregelter Hochleistungsantrieb. 3 Achsen angetrieben, Haftreifen. Fahrtrichtungsabhängiger Schweizer Lichtwechsel (Dreilicht-Spitzensignal und 1 weißes Schlusslicht), konventionell in Betrieb, digital schaltbar. Umbauversion der Ae 610 mit geänderten Griffstangen und unten angeschlagenem Scheibenwischer. Alle Wagen mit Kurzkupplungen.
Länge des Zuges 76,6 cm.
Inhalt: 12 gebogene Gleise 24130, 5 gerade Gleise 24188, 7 gerade Gleise 24172, 2 gebogene Gleise 24224 und 1 Paar Weichen 24611 und 24612. Gleisanschlussbox, Schaltnetzteil 230 V/36 VA und Mobile Station. Illustriertes Spielbuch mit vielen Tipps und Anregungen. Erweiterungsmöglichkeiten mit den C-Gleis-Ergänzungspackungen und mit dem gesamten C-Gleis-Programm.
*Bart
thanks 1 user liked this useful post by Bart
Offline ice 1
#114 Posted : 11 January 2015 09:57:25(UTC)
ice 1
I see it comes with a smoke generator and a lighted firebox.
But sadly no SDS Motor.
Its just another Steam loco to me how many of them was there how about a model of the latest ICE.
#115 Posted : 11 January 2015 11:01:52(UTC)
SDS engine is no longer sold,due to cost reasons.
#116 Posted : 11 January 2015 11:08:52(UTC)
Livery Similer to 37360.
#117 Posted : 11 January 2015 11:11:44(UTC)
Full 2015 new items will be show on Marklin database from 19 January 2015 or later.
#118 Posted : 11 January 2015 11:19:41(UTC)
I also do hope if Märklin this time do change working tools for railcar,due to better service by change out traction tyres.
Offline ice 1
#119 Posted : 11 January 2015 11:26:18(UTC)
ice 1
Well if its cheaper for Marklin to make locos without the SDS motor you think they would pass that saving onto customers or give a customer a choice pay extra for an SDS motor if you wish.I feel its a backward step.
#120 Posted : 11 January 2015 11:36:11(UTC)
Trix did also had SDS motor with same models like Märklin´s.
But there was defaults with DCC protocol and angry customer who bought Trix models.
That did also cost for Märklin Company to compensate their customers.
No it´s not backward step.
It´s an lesson for Märklin.
Offline ice 1
#121 Posted : 11 January 2015 11:54:04(UTC)
ice 1
OKAY
I just hope all the people with C-Sine motors can get replacements when there motors die in time.
#122 Posted : 11 January 2015 12:13:18(UTC)
The controller for the SDS motor has nothing to do with the protocol controlling the decoder.
#123 Posted : 11 January 2015 12:57:43(UTC)
Not necessarily.
But Märklin developed one type of controller boards for Trix locos with D&H decoders and another type for Märklin locos with ESU decoders.
But I think the DC users were complaining, not the DCC users.
Offline ice 1
#124 Posted : 11 January 2015 14:01:17(UTC)
ice 1
Yes
But will Marklin offer replacement SDS and CCS motors to customers who have them in there locos.
#125 Posted : 11 January 2015 14:20:20(UTC)
Yes
I wouldn't be surprised if they have a small stock of them in their service department for factory repairs.
#126 Posted : 11 January 2015 14:24:54(UTC)
Tom, I don't disagree; but still, the SDS controller has nothing to do with the protocol being used.
I think most of Goofy's information is based on rumours, read in a language he don't understand,
Google translated to Swedish, and then Google translated to English and posted here.
Most older M-users probably knows; but newcomers might believe a lot of this misinformation.
Offline ice 1
#127 Posted : 11 January 2015 14:59:36(UTC)
ice 1
I Dont know myself but if Marklin wanted them problems could be overcome with the SDS motor the real reason must be cost which makes sense i suppose.
Its great how such a small motor can generate such power etc to pull coaches n wagons etc at speed.
#128 Posted : 11 January 2015 15:06:50(UTC)
I did had one Trix diesel locomotive with SDS motor.
It did hade same PCB and decoder like Märklin´s.
But used for DCC protocol.
It was deafults between SDS and protocol.
Next time did Trix put Faulhaber motor.
It did worked good again.
So yes dane it was difference!
Märklin will never ever put SDS motor back again in the new models.
#129 Posted : 11 January 2015 15:39:10(UTC)
Goofy, this topic is about Märklin 2015 new items; not about a loco you once had.
If you would like to tell us about your loco, please start a new topic, and tell us which Trix loco you had,
which had the same decoder as a similar Märklin loco.
DCC is a protocol ( language ), and has nothing to do with the motor controller!!!
thanks 4 users liked this useful post by Purellum
Offline vilithejou
#130 Posted : 11 January 2015 18:37:31(UTC)
vilithejou
My dealer confirm me that the next week news will be out
And on Thursday put the information form arrivals and he say that have the brochure of the news.
A Marklin Store make a presentation of the news on 17th of this month....
Joan Vilarrúbia
vilithejou@yahoo.es
thanks 8 users liked this useful post by vilithejou
Offline supermoee
#131 Posted : 12 January 2015 16:28:03(UTC)
supermoee
Hello Goofy,
this is false.
Trix Locos with SDS had different PCB and Decoders. On Trix locos the control of the SDS driver happens through SUSI Interface, on Märklin loco's trough the AUX functions. That's why in the manual of the 60940 mSD special decoder is mentioned, that you cannot install it in Trix SDS locs.
but as said, this is OT.
rgds.
Stephan
thanks 3 users liked this useful post by supermoee
Offline Sander van Wijk
#132 Posted : 13 January 2015 09:36:57(UTC)
Sander van Wijk
While looking for a few 'normal' Märklin items in the maerklin.de product search, the search went down showing an 'in maintenance' message. Quite likely the 2015 New Items are being loaded onto the database right now... ;)
Edit 12:37 (CET): No luck yet, the search is back online without the New Items visible (yet...). Keeping those fingers crossed for news to come soon.
Sander
thanks 3 users liked this useful post by Sander van Wijk
#133 Posted : 13 January 2015 19:13:24(UTC)
Starter set Image.
#134 Posted : 13 January 2015 19:17:42(UTC)
Starter set Image.
The loco in the 'mein start with Marklin' set looks like it could be the same one as in my Aldi start set,
#135 Posted : 14 January 2015 14:32:44(UTC)
10% discount price limit on 2015 items at Lokshop.
#136 Posted : 14 January 2015 14:47:58(UTC)
Starter set Image.
...and the little electric in the set above it look like the other Aldi loco with a pantograph stuck on the roof!
#137 Posted : 14 January 2015 18:03:29(UTC)
FULL 2015 NEW ITEMS 168 LIST.
>>>>>>>>>>>>LINK TO MWL<<<<<<<<<<<<<<
thanks 7 users liked this useful post by steventrain
Offline Herrfleck
#138 Posted : 14 January 2015 18:37:30(UTC)
Herrfleck
Hello Steven.
I can not se any news from Märklin?
Only Old items !
Bertil
Now I found it Love ThumpUp
- since my lack in english I don't write so much here.. but learn by trying right? :) -
//Bertil
Offline danmarklinman
#139 Posted : 14 January 2015 18:53:13(UTC)
danmarklinman
Nothing thereConfused
Oops found it yum love the new traxxx dieselsLove
Wiking model car Fan
Instagram: marklin1978
Wiking fan
#140 Posted : 14 January 2015 19:01:52(UTC)
I presume the two locos in the page with the link are in the 2015 NI?
has an E03/103 ever worn an overall dark blue livery ??? Confused Huh
#141 Posted : 14 January 2015 19:05:10(UTC)
Interestingly, if you search the site for 37578 you get a dark blue 103 as a New Item ...
#142 Posted : 14 January 2015 19:10:45(UTC)
I presume you are doing what I am doing, scrolling down looking for the blue 'Neuheit' boxes. At least they are obvious, once you realise what to look for.
Most of the prices are 'on application' at present it seems.
Offline GlennM
#143 Posted : 14 January 2015 19:16:55(UTC)
GlennM
Unless I am doing something wrong the link does not take you to a Marklin New Items list, merely to a list of Marklin items for sale, the links on LHS show Fleishmann and others New Items but not Marklin.
Am I missing something?
BR
Glenn
#144 Posted : 14 January 2015 19:52:05(UTC)
thanks 8 users liked this useful post by steventrain
#145 Posted : 14 January 2015 20:03:30(UTC)
I like the Mak G2000! Especially in SBB cargo livery (37202)
I've been looking at the Mehano models, but a Marklin version is even better!
Online foumaro
#146 Posted : 14 January 2015 20:16:42(UTC)
The 37220 is an interesting model.
#147 Posted : 14 January 2015 20:20:57(UTC)
danmarklinman
Yes the G2000 looks great. I'm ordering the SNCB series 57. It's right up my street as it runs across in to Northern France were my layout is modelled onLOL
Wiking fan
thanks 3 users liked this useful post by danmarklinman
#148 Posted : 14 January 2015 20:57:33(UTC)
I'm having a lot of trouble getting on the website now. I got to page 3 and then page 4 refused to load. Now I can't access the website at all....
Offline Herrfleck
#149 Posted : 14 January 2015 21:13:54(UTC)
Herrfleck
Hello Ray!
Same for me!
Maybe too many users online ?
Bertil.
//Bertil
thanks 1 user liked this useful post by Herrfleck
#150 Posted : 14 January 2015 21:36:08(UTC)
Too many access the site.
There is many more list not in the site such as Borsig edition, Reproduction 3050 Ae6/6 in twin pack (red and Green).
2015 new item brochure is out now in Germany today (BR18.5 on front cover) Link to stummi for image >Stummi<
5 Pages<12345>
This page was generated in 1.579 seconds.
