Offline Marklin in Oz
#1 Posted : 30 September 2014 09:37:28(UTC)
Marklin in Oz
Good day all. I've currently got a bit of a quandary. I'm looking to install a railroad crossing across a span of double track pictured below.
Originally, I was going to do so by setting railroad ties cross ways (Parallel with the rails) across the tracks and center ballast.
The problem however is that they're too thick. They would stand above the third rail and pickup shoes would lose contact. I've thought about sanding some down, but I'm not sure how I would do so and keep them all uniform in their thickness. I've also considered a paper option, but really don't know how well that would work as far as looks.
I'm open to suggestions.
Confused
-Fred
#2 Posted : 30 September 2014 10:54:28(UTC)
Hi Fred,
It's not an easy thing to do. I used a Faller level crossing on my layout, and they bring some planked sections of plastic for laying in the track, but they also stick up above the level of the pukos. I also experimented with bits of card, but they tend to curl up and catch the pickup shoe.
In the end I decided to ignore the part of roadway inside the tracks, and just laid card and plastic strips up to the outsides of the rails. I then painted the middle of the tracks the same colour as the roadway and at first glance it looks OK.
#3 Posted : 30 September 2014 11:01:52(UTC)
I always use "Viessmann 5102 Gleisfüllstück H0". It is quite cheap and works on curved track, too.
#4 Posted : 30 September 2014 11:17:05(UTC)
Here a German (albeit illustrated) description of how to use a salvaged M track center piece for creating a realistic grade level crossing - click on link:
http://stummiforum.de/vi...pic.php?p=592180#p592180
And some homemade alternatives - see pic.
#5 Posted : 30 September 2014 21:42:05(UTC)
What about simply painting the appropriate section the colour of the street or crossing. This way, it would appear to be paved, but would not outright interfere with the operation of the trains?
The other option would be installing the Maerklin Crossing with add on for multiple tracks which has all the necessary parts.
Offline MS 800
#6 Posted : 30 September 2014 23:14:53(UTC)
MS 800
... or use strips of brass sheet instead of wooden sleepers - at least for the two middle ones. The brass can be connected to the centre stud contacts either by directly soldering them together or by wiring it accordingly. It even can be given a dark surface finish by an appropriate stain (no paint).
In Germany, in newer level crossings the gap between the rails is filled by a rubber mat like that one:
This can also be imitated by a piece of brass sheet with a structured surface
stained dark (deepnes of blackening can be adjusted by time of treastment)
and connected to the centre studs.
MS 800
When we were kids we enjoyed our tinplate trains rattling over tinplate tracks - nowadays they're in need of sound decoders.
thanks 6 users liked this useful post by MS 800
#7 Posted : 01 October 2014 04:42:57(UTC)
Marklin in Oz
Thanks for the responses everyone. I like Ray's idea with the card stock, but to prevent curling, I'm thinking I could use sheet plastic.
-Fred
thanks 1 user liked this useful post by Marklin in Oz
#8 Posted : 01 October 2014 08:42:25(UTC)
-Fred
Fred, here's a tip you might not have thought of. Old credit and debit cards are a great source of thin plastic for projects like this. It's tough and doesn't curl up easily. I keep a stock of old cards for this purpose.
#9 Posted : 01 October 2014 12:10:39(UTC)
-Fred
Smart! Very smart!ThumpUp
One for the "things to remember" file!
#10 Posted : 01 October 2014 12:16:57(UTC)
Marklin in Oz
-Fred
I've already got some some pieces of sheet plastic floating around, but as jvuye noted that's a damn fine idea.
Smile
-Fred
Guest (5)
This page was generated in 0.797 seconds.
