17 Pages«<34567>»
Offline BrandonVA
#201 Posted : 15 April 2014 21:57:29(UTC)
BrandonVA
...or that (Franfurt/Main, Germany).
Looks like a Marklin catalog form the 90s...or rather, I see where they get their inspiration :)
-Brandon
Online Alsterstreek
#202 Posted : 16 April 2014 09:06:40(UTC)
A new layout? May I voice a wish? I would like to see something compact like that:
Ak,
What are the dimensions?
-Brandon
Pheeew, if I knew... Lost track of the source. Looks like N scale. In Maerklin HO, incorporating/hiding some R1 curves in the tunnels, but using wider radii in the visible areas, considering the ramps for creating a twice around loop plus having some straight stretches of track, I would reckon 100 x 180 cm were needed.
Edited by user 16 April 2014 16:46:24(UTC)  | Reason: Not specified
Online Alsterstreek
#203 Posted : 16 April 2014 16:29:46(UTC)
Here is a similar - very ambitious - HO scale approach for which I know the dimensions: 45 x 82 cm. Considering that it is impossible to replicate such narrow curves with Maerklin track and allowing motive power to climb the hill with more than one car, the space needs at least to be doubled. Source: http://www.carendt.com/scrapbook/page77a/
Online Alsterstreek
#204 Posted : 16 April 2014 16:32:12(UTC)
Here is the "satellite view".
Online Alsterstreek
#205 Posted : 16 April 2014 16:35:04(UTC)
The inspiration for the above layout was a Portuguese industrial RR layout design: http://www.carendt.com/contest/vote/V30.html
Online Alsterstreek
#206 Posted : 16 April 2014 16:36:58(UTC)
Track plan...
Again, board dimensions need to be inflated considerably - i.e., doubled as a minimum measure - in order to match maerklinista needs. And clearances have to be adjusted, too - at least 7.5 cm without catenary.
Online Alsterstreek
#207 Posted : 24 April 2014 18:08:11(UTC)
No carpenter? No sculptor? Everything at street-level? Flat-top designer? Narrow curves left and right of the main station? Then get inspired by the late Everett Street Station, also called Milwaukee Union Station, a railway station formerly located in downtown Milwaukee, Wisconsin (USA).
A German model railroader had a go at this - see pix.
Source: http://us-modellbahn.net/acela/everett.html
Online Alsterstreek
#208 Posted : 25 April 2014 15:05:33(UTC)
Marklin Railroad Grade Crossing? Is that prototypical? Yes, it is in Timmendorfer Strand, Germany.
Online Alsterstreek
#209 Posted : 10 May 2014 19:17:26(UTC)
Curved stone viaduct adjacent to tunnel mouth in vertical in vertical cliff over endless abyss! Too dramatic? Not for the narrow gauge Rhaetian Railway in Switzerland.
Online Alsterstreek
#210 Posted : 10 May 2014 19:36:31(UTC)
A railway bridge pinned in front the steep walls of a narrow gorge looks whimsical? Not in El Chorro, near Álora in the province of Málaga, Spain.
1) The gorge with the railway bridge on the right side.
2) Yes, indeed still in use - train on bridge in 2012
3) Close-up of train
Online Alsterstreek
#211 Posted : 10 May 2014 23:39:01(UTC)
Facing space constraints? Stacking curved main lines above each other? Busy operations? Yes, that is realistic in Köln-Deutz, 1986.
Online Alsterstreek
#212 Posted : 19 May 2014 23:35:53(UTC)
At the Hiwassee Loop in Tennessee, the track encircles the mountain nearly twice before crossing back over itself via a 60-foot-high trestle.
Online Alsterstreek
#213 Posted : 19 May 2014 23:42:36(UTC)
Rifle Sight Notch in Colorado on the original Denver, Northwestern and Pacific Railroad.
Online Alsterstreek
#214 Posted : 01 June 2014 11:01:50(UTC)
Maritime themed layout with seagoing vessels? Rural backdrop? Waterways crossed by rails and roads at water level? Improbable? Get inspired by Canso Canal Bridge, Nova Scotia, Canada (c. 1960).
Online Alsterstreek
#215 Posted : 02 June 2014 14:07:37(UTC)
And now a similar setting which could be modeled using Maerklin stock:
Lindaunis Bridge over the Schlei, which is a narrow 20 miles long inlet of the Baltic Sea in Schleswig-Holstein in northern Germany.
Online Alsterstreek
#216 Posted : 02 June 2014 14:20:38(UTC)
Want to have a bridge over a river, but have no possibility to model a high elevation? Looks unrealistic? Not in Moorhead, Minnesota (USA). mn.jpg
Edited by user 27 July 2025 19:15:34(UTC)  | Reason: Replaced 'stream' by 'river'.
Online Alsterstreek
#217 Posted : 02 June 2014 16:18:23(UTC)
Yes, these whimsical bridges with short trains (LINT 27 on the Biggetal-Bahn near Olpe)...
Offline petestra
#218 Posted : 04 June 2014 22:52:19(UTC)
[img]http://[/img]
sorry guys. I couldn't get photo to upload.Peter
Online Alsterstreek
#219 Posted : 05 June 2014 18:57:16(UTC)
Spotted a freight car on a stub track while coming from the "wrong" direction? If the loco cannot get to your car, let your car come to your loco.
Blink
(Flying switch on Columbia Terminal RR)
Online Alsterstreek
#220 Posted : 09 June 2014 15:26:49(UTC)
And here an example of the classic "flying switch" manoeuver carried out by a Boston & Maine steam engine.
For "flying switch" description / explanation see:
https://www.marklin-user...mericana.aspx#post446319
Offline BrandonVA
#221 Posted : 11 June 2014 16:37:08(UTC)
BrandonVA
I missed this thread for a while. I have seen this one a few times, it never ceases to amaze me.
Now I suppose you'll be trying to sneak in some shots from your layout :)
-Brandon
Online Alsterstreek
#222 Posted : 19 June 2014 16:00:19(UTC)
More Hiwassee Loop pix.
Online Alsterstreek
#223 Posted : 19 June 2014 16:44:20(UTC)
The Bethungra Loop on the Main South railway line of New South Wales in Australia. Uphill trains use the spiral, while downhill trains use the original "straight" line.
Online Alsterstreek
#224 Posted : 19 June 2014 17:11:47(UTC)
Klisura, Bulgaria: spiral built around the town.
Online Alsterstreek
#225 Posted : 23 June 2014 18:40:10(UTC)
Former Borup Loop on the Stampede Pass route in the state of Washington, USA.
Online Alsterstreek
#226 Posted : 02 July 2014 21:05:10(UTC)
Ak,
-Brandon
Hahah!
I retrieved the source:
http://model-railroad-ho.../node/3262#comment-26076
The work is based on the "Lilliput Logger" track plan. I understand it is 4 x 8 ft in HO scale.
Offline BrandonVA
#227 Posted : 02 July 2014 21:49:46(UTC)
BrandonVA
I really like this layout...I have seen some really excellent layouts. You have to get really creative if you get much smaller (I know a guy). It has it all...a line for continuous running, tracks not parallel to the edges, lots of siding an shunting possibilities, and interesting scenic options. The only catch seems to be the mountain in the middle, which restricts the view of the far side (unless the owner can install it so the layout can be viewed from 3 or more sides). The other issue could be control panel, but a MS/MS2 or other wireless controller would easily fix this issue.
-Brandon
Offline petestra
#228 Posted : 03 July 2014 00:44:53(UTC)
I like it a-lot. It is very creative. Yes, you would have to walk around it to get the different views but I think this just adds to the fun.
Peter ThumpUp Smile
thanks 3 users liked this useful post by petestra
Online Alsterstreek
#229 Posted : 22 August 2014 00:19:21(UTC)
Downtown Montreal Spaghetti Bowl. Blink
Edited by user 25 August 2014 02:10:55(UTC)  | Reason: Topic watch deactivated
Offline Gert-Jan
#230 Posted : 22 August 2014 19:51:57(UTC)
Gert-Jan
Gert-Jan attached the following image(s):
Mosty era III DB.
thanks 4 users liked this useful post by Gert-Jan
Online Alsterstreek
#231 Posted : 03 September 2014 23:27:05(UTC)
Arnold Loop, Nevada, USA (40°56'29"N 114°16'7"W):
A horseshoe curve in the former Western Pacific rail line connecting Salt Lake City with California.
#232 Posted : 04 September 2014 12:24:13(UTC)
And now to appease the kiwis:
Raurimu Spiral, North Island Main Trunk Railway, New Zealand
More info: http://www.historic.org.nz/ther...terResults.aspx?RID=7588
-Brandon
I wondered if someone would list this one ... BigGrin
Unfortunately the picture doesn't show and the link goes 404 ... Mad
So this Wikipedia Link gives some nice info and a map.
This Government History Link gives some interesting history along with a picture of the construction of a nearby viaduct.
Online Alsterstreek
#233 Posted : 04 September 2014 13:03:09(UTC)
No space for station building? Stacking is the solution:
Now defunct railway station building of Piène / Piena on the still operating spectacular "ligne de Tende / linea del Tenda" between France and Italy.
#234 Posted : 04 September 2014 17:24:28(UTC)
Like this?
I count six rails...Laugh
Yes, but the two middle ones end at the end of the bridge on the Swedish side.
Link to a map of the Haparanda - Tornio area.
The bridge is between Finland and Sweden and given that the gauges are close - 1524 mm in Finland and 1435 mm in Sweden - there was no room to create a traditional three-rail track, instead this interleaved four-rail track was created. (Releated to the text on the map: Soumi is Finland in Finish and Sverige is Swedish for Sweden).
This one has six usable rails ... Picton rail Ferry Ramp
Between this and the one at the other end is a ship to take the trains.
Location: Picture at Wellington, New Zealand, northern end of the link between the North and South islands of New Zealand.
The points are on the wharf, so this represents 3 tracks into the ferry, you can see them getting splayed at the far end of the ramp, so there is no need for points which take up valuable rolling stock space inside the ferry, while keeping the bridge and ferry opening to manageable sizes.
Online Alsterstreek
#235 Posted : 04 September 2014 21:07:23(UTC)
More precisely it is Piène Basse near Breil-sur-Roya in France; until the end of WW II the place belonged to Italy.
Online Alsterstreek
#236 Posted : 07 September 2014 12:13:02(UTC)
More interesting features of that extraordinary line: (1) Bi-level bridge near Cuneo (for road and track) and (2) a glance at high line to France and low line to Italy to Italy near Breil-sur-Roya.
Online Alsterstreek
#237 Posted : 07 September 2014 12:15:56(UTC)
And finally the unusual Bevera viaduct, (1) prototype and (2) HO model (http://www.kirnbachtaeler.de/modell/karlsruhe2010/ausstellung09-karlsruhe.html).
Offline BrandonVA
#238 Posted : 11 September 2014 21:48:53(UTC)
BrandonVA
I have a station over a train track (or two) on my layout :)
Online Alsterstreek
#239 Posted : 12 September 2014 10:55:42(UTC)
Consider it approved prototypical.Cool
Online Alsterstreek
#240 Posted : 12 September 2014 22:20:56(UTC)
Consider the Semmering railway in Austria, the first standard gauge mountain railway in Europe. More (German) info and photos:
http://www.semmeringbahn.at/
Online Alsterstreek
#241 Posted : 12 September 2014 22:27:46(UTC)
Constructed 1848-1854. Horseshoe curve, curved double-track curved viaduct? Semmering has it all. In the background the Kalte Rinne viaduct - see pic.
Online Alsterstreek
#242 Posted : 12 September 2014 22:48:35(UTC)
Ridiculous short tunnel followed by a bridge? I say only: Semmering.
Offline petestra
#243 Posted : 13 September 2014 15:50:44(UTC)
Nice photo, AK. There is also a tunnel (longer than this tunnel)/bridge combo in the final scene of the 1965 Frank Sinatra film, Von Ryan's Express. I checked Wikipedia and
it states filming was in Northern Italy. Cheers,PeterSmile
Online Alsterstreek
#244 Posted : 13 September 2014 18:05:25(UTC)
Amongst other places in the Santa Maria Novella station on at Florence and on the Ferrovia Dei Due Mari between Civitavecchia and Orte, namely at the stations of Capranica and Monteromano as well as at the bridge over the Mignone.
The last scenes were shot at the Gorge of the Gaitanes near El Chorro in Andalucia, Spain - one of the places I presented earlier in this very thread:
https://www.marklin-user...rototype.aspx#post456547
Below a scene from the movie shot in Spain.
Edited by user 15 September 2014 16:57:18(UTC)  | Reason: Spelling
Online Alsterstreek
#245 Posted : 13 September 2014 18:58:07(UTC)
And another movie scene. The El Chorro bridge is clearly visible. This is on the old Sevilla-Cordoba line.
Offline petestra
#246 Posted : 15 September 2014 12:18:32(UTC)
HI AK, thanks for that good info. I didn't know that was in Spain. Goes to show Wiki is not always correct! Great scene and film.
Peter ThumpUp ThumpUp ThumpUp
Offline BrandonVA
#247 Posted : 19 September 2014 18:34:18(UTC)
BrandonVA
It almost looks like a painting! Excellent example.
Offline petestra
#248 Posted : 19 September 2014 20:59:19(UTC)
It's a great WWII film, Brandon. If you've never seen it, it's worth a watch. Peter ThumpUp
Online Alsterstreek
#249 Posted : 22 September 2014 12:59:53(UTC)
Western Electric complex, Manhattan, New York (1936)
Offline BrandonVA
#250 Posted : 29 September 2014 21:15:04(UTC)
BrandonVA
https://www.flickr.com/photos/wj...24351642/in/photostream/
Some of us have locos with lighted running gear. I am not sure this is prototypical historically, but even if it is added for a "museum train" this one has it so you can say it's true! (link rather than attach to give proper photo credit).
-Brandon
17 Pages«<34567>»
This page was generated in 1.176 seconds.
