Offline adelrs
#1 Posted : 18 June 2014 13:05:48(UTC)
adelrs
Can the Mobile Station 2 be used to control the Uncoupler Track 24997. If so what decoder can be used. The only reference I see is to use the 60830 K-83 decoder, which is no longer available. Any help would be appreciated.
#2 Posted : 18 June 2014 13:59:45(UTC)
The 60830 has been replaced by the 60831, which is available now.
This is the only way to control an uncoupler track at the moment. You can also get similar decoders from Viessman.
Offline sjlauritsen
#3 Posted : 18 June 2014 18:22:28(UTC)
sjlauritsen
Yes, the Mobile Station 2 can control an uncoupler track as well as other accessories. But only by using an accessory decoder as Ray mentions. :-)
You can get accessory decoders for both Motorola (MM) and DCC from a couple of manufacturers like:
Märklin (#60831)
Viessmann (#5211, Motorola or #5212, DCC)
Littfinski (#S-DEC-4-*) (http://www.ldt-infocenter.com/dokuwiki/doku.php?id=en:s-dec-4)
If you use DCC for the accessory decoders you have more options from other manufacturers as well.
Søren from Denmark
Offline DumbGuy
#4 Posted : 19 June 2014 14:35:52(UTC)
DumbGuy
I operate multiple uncouplers and semaphores with old Marklin 6083 k83s and with Viessmann 5211s using a 60214 CS2 and a 60653 MS2. Both work well. I have no experience with the more recent 60830 or 60831 boxes. My 6083s came from eBay. Listings are fairly common at around $30(+ or -) plus shipping. A new VM 5211 retails for about $37 plus shipping. I've never seen one listed on North American eBay.
As an aside, a 60831 offers a few more features, can use an external power supply, and may require an additional 60821 board for turnout motors, all of which seem a bit of overkill for my (no DCC) needs. But since I've never used one, no cogent advice.
Regards -- Richard
Long-time analog user, collector & tinkerer.
Discovered digital & began conversion a few years ago.
C-Track, CS2 Carpetbahn built, taken-down, rebuilt, etc.
Username reflects how much I still have to learn.
Offline adelrs
#5 Posted : 21 June 2014 03:03:40(UTC)
adelrs
Thanks for all the information. I will end up going with the 60831 decoder for my uncoupler track
thanks 1 user liked this useful post by adelrs
#6 Posted : 22 June 2014 16:01:09(UTC)
I have 16 uncoupling on layout with two 60830.
Up to 8 uncoupling per 60831/60831.
Offline FrankF
#7 Posted : 28 June 2014 01:03:31(UTC)
FrankF
Here is an example for wiring the MS2 to the Layoyt :
MS2-Layout-Wiring
and here is the way to connect the Marklin 24997 Unit to the Marklin 60830 (k83 Decoder)
Marklin24997-Connection-k83-Decoder
Each of the 4 outputs connector on the Marklin 60830 (k83) unit can control 2 Marklin 24997 Uncoupling units
which give a total of 8 Marklin 24997 for each k83 Decoder.
Hope the pictures will show you how to connect your Uncouplers to use them with MS 2.
CURRENT MARKLIN SOFTWARE/GFP/FIMWARE - UPDATES:
• CS3+ 60216 SW 2.5.2(6) • CS2 60215 SW:4.3.2(4) • MS2 (SW 5.6) • 6011x GLEIS-BOX (GFP1.70) • MS2-WLAN (FW 5.4.0.21) • 60117 WLAN-BOX (FW 0.3.0.2) • MS1 (SW:1.8 AP) • S88 LINK (SW1.1)
• MDT V3.6.0 (HW: 60970/60971/60801) • MLD3/MSD3 (FW 3.3.6.2) • MSD3.5 (FW 3.5.1.1) • 1098 MLD3/MSD3 DECODER-PROJECTS ON M-SERVER • MARKLIN SOUND-BIBLIOTHEK ( 33.744 SOUND-FILES )
• LOK-PROGRAMMER (SW5.2.15) • ESU HW (53451/53900/53901)
thanks 1 user liked this useful post by FrankF
Guest (5)
This page was generated in 0.378 seconds.
