Offline cyclemomo
#1 Posted : 16 December 2013 21:06:02(UTC)
cyclemomo
Hello everyone…this is my first post to the forum. My 7-year-old son was given a Marklin train set and I have been working with him to assemble and use it. We have a black steam locomotive with the following information on it: "DB" is in white within a white outlined box, below that are the numbers 74 1070. I did some digging around the Marklin company sight and think that it is an HO scale BR 74. It came with a Marklin Transformer, 6450, 110v, 50hz, 10va. We cleaned the rails and used some 3-in-1 oil to lubricate the locomotive and put together an oval. Train ran flawlessly, pulling about 8 cars of rolling stock for about an hour. Then stopped working. I checked the transformer: power still going to it, but nothing coming out of it with the dial turned on. I am guessing that the wiring inside is shorting somewhere and would like some advice. Worth taking to an electrician to repair or is there a replacement transformer from Marklin that will work with this set? One concern I have is that the manual that I found on the Marklin site states that I should only use an "AC power, 32 VA transformer, item no.6646 and 6647". So I may be mistaken on the model locomotive that I have. I hope that the numbers that I supplied above can help identify the locomotive. According the serial number post, it appears that our locomotive was from before Marklin started using serial numbers and could mean that the manual I found is not the right one. Any help would be greatly appreciated. Both my son and I look forward to many years of fun with the Marklin trains.
Offline PMPeter
#2 Posted : 16 December 2013 21:24:01(UTC)
PMPeter
Welcome to the forum.
The information that you supplied for the locomotive just indicates that it is a model of the DB (Deutsche Bahn) BR74.
However, the problem that you describe indicates that something has gone wrong with the transformer output due to a possible short circuit experienced on the track or possibly an overload which is unlikely if you only had one locomotive running with unlit freight cars.
I suggest you unplug the transformer, let it cool down, plug it in again and check to see if you have voltage across the outgoing terminals. If yes, then check the wiring to the track. Sometimes it comes loose or even breaks.
If you have no varying voltage on the outgoing terminals of the transformer as you move the dial, chances are something fried in the transformer and you need a replacement.
Offline BrandonVA
#3 Posted : 16 December 2013 21:43:40(UTC)
BrandonVA
Hello and welcome!
To me, it sounds like your son received a "vintage" set. My guess is this made around 1968.
First, the loco:
If it was part of a factory issued set, the whole set will have a number (probably 2xxx). This locomotive appears to be from the first year of manufacture (1968) as the road number is 74 1070. In 1969 it got a different road number, and was made in various forms up until 2006. The "DB" as stated stands for "Deutsch Bundesbahn" which was the (West) German Federal Railroad at the time. 74 stands for the locomotive class (class 74), and 1070 is the running number of this locomotive. The Marklin part number for this locomotive is 3095.
The manuals on Marklin's site are for newer models, for the most part the information is year 2000 onward, although they do have spare parts lists for models back to the 50s. You do not need to worry about the warning for use with 6646/6647. These warnings are for newer locomotives with digital decoders that control their driving. Reversing the newer locomotives with an old transformer could burn out the decoder. However, your model is safe, it is older than any decoder. These old models are very robust, so I doubt anything serious will be a problem for 3095. They are easy to service as well.
Next, the transformer:
6450 is an acceptable tranformer for this model. It is a 10va AC US transformer. I agree with the above advice from Peter about checking for a short, removing everything form the track, cooling down, etc. However, since your son is playing with it I would recommend you are careful with the transformer as over time the insulation on the wires can break down and cause a shock hazard. At the very least inspect the cord to make sure it's in good shape. More information here:
https://www.marklin-users.net/fo...s&t=16037#post239795
If it's fine, you can choose to keep using it. You can also look for a newer transformer on ebay, I would recommend 6667 (16va) or 6627 (32va) as the oldest transformers to buy used. You could also look for a new or used 6646 (the current US model of analog transformer). Retail they cost around $150 US new, but often go for less used on eBay.
I am guessing you have brownish coloured metal track, Marklin "M" track?
-Brandon
Offline BrandonVA
#4 Posted : 16 December 2013 21:49:18(UTC)
BrandonVA
I believe your locomotive should look like this one:
-Brandon
Offline cyclemomo
#5 Posted : 16 December 2013 22:27:37(UTC)
cyclemomo
Hi Brandon and Peter,
Thank you for the welcome and the detailed suggestions. Let everything cool down. Inspected power cord: looks good. Checked voltage across outgoing terminals between transformer and track: measured varying voltage. Checked wires from transformer to track: good shape, solid soldered connections. Tried train again and it works flawlessly. Is there a limit to the number of cars we should pull with this locomotive? None of the rolling stock has lights. Perhaps this caused the transformer to overheat and shutdown?
Our track is brown and has a tan colored and textured bed. I think it is M track. That does appear to be our locomotive in your picture, Brandon. I think that we will shop for a replacement transformer to have as a backup, thanks for the suggestions, Brandon. Here are some pictures of what we have to start with…thanks again. We will spend some more time on the forum to track down further information on the trains that we have been given.
Cheers, Mauricio
Offline cyclemomo
#6 Posted : 16 December 2013 22:31:52(UTC)
cyclemomo
Here are the pics…
cyclemomo attached the following image(s):
thanks 1 user liked this useful post by cyclemomo
Offline cyclemomo
#7 Posted : 16 December 2013 22:36:43(UTC)
cyclemomo
Locomotive fotos. Clearly a rookie forum member here.
Offline BrandonVA
#8 Posted : 16 December 2013 22:37:40(UTC)
BrandonVA
Mauricio,
Glad it's all working again. These old 3095 are workhorses, I don't think there should be a real limit of cars they can carry (at least 8 should be fine). These old models had very strong motors. Maybe something else caused a short. Sometimes the metal couplers on the older cars can be bent, if it contacts the pukos in the center of the track it can cause a short. Maybe worth looking into.
I can't say with the older transformers whether they overheat due to extended use. I know with 6667/6627 (started around 1974) and newer they can run for hours (at least in my experience).
It sounds like M track to me. Classic Marklin.
What a great start for your son. My kids love trains as well.
-Brandon
Offline PMPeter
#9 Posted : 16 December 2013 22:44:40(UTC)
PMPeter
Glad it is working again.
In my old analog days with the blue transformers, if I had a derailment causing a short circuit, I usually had to unplug the transformer and plug it in again later to get it working again.
I never opened it up to see if it had some form of circuit protection inside, but based on the "no power" after a short circuit, I assumed it did.
#10 Posted : 16 December 2013 23:49:09(UTC)
The transformer is specified for 10 VA (10 Watts) - and that's about the power consumption of one loco (even more for some bigger locos).
So it's possible that the transformer just switches off after getting too hot.
Obviously this does not happen with a 32 VA transformer and a single loco.
Were you running the loco full speed for a long time?
Offline Harvey
#11 Posted : 17 December 2013 02:20:22(UTC)
Harvey
Just a suggestion for when you next oil the loc. 3 in 1 is not suggested for Marklin locs. The local hobby store or other members can suggest the appropriate oil. And, of course, don't over oil.
Enjoy.
Harvey
Offline cyclemomo
#12 Posted : 20 December 2013 17:40:50(UTC)
cyclemomo
Hi Tom and Harvey,
I do feel like we were running the loco pretty fast, trying to get a seven year old to slow down can be challenging. I think that it may have cut off because it over heated. I also followed Brandon's suggestion and inspected all of the rolling stock couplers, one of the cars had a bent coupler that was contacting the pukos and would spark as it rolled over a particular section of track. Also, headed to hobby shop today to get some proper oil for the loco. Thanks again, everyone.
Offline BrandonVA
#13 Posted : 20 December 2013 18:18:59(UTC)
BrandonVA
Originally Posted by: cyclemomo Go to Quoted Post
Hi Tom and Harvey,
If you search the forum there have been a lot of discussions on types of oil. There are many good ones. Since you are in the US, if you're looking to pick something up locally, grab Labelle, you should be able to get it at a lot of hobby shops (if you still have one). Otherwise, feel free to research and buy whatever online :)
-Brandon
Adjustments to 6450 Transformer (General MRR)
by mcnall 10/03/2018 16:41:26(UTC)
This page was generated in 0.669 seconds.
