Offline nunk
#1 Posted : 24 October 2013 00:40:35(UTC)
nunk
My collection is based on ERA III and I wish to add a small diesel shunter.
The appropriate item appears to be the 37655 but although it has a mfx decoder with 5 physical functions, there are no sounds effects.
The loco 37616 is a similar loco but from ERA IV. It too has a mfx decoder with (almost) the same physical functions but in addition has nine sound effects.
So my question is, can the 37655 be 'retrofitted' with the sounds of the 37616?
I have a CS2 and was wondering if the 37655's mfx decoder can be 'back-loaded' with diesel sounds from the Marklin upgrade facility?
Neil
Offline franciscohg
#2 Posted : 24 October 2013 00:49:33(UTC)
franciscohg
Chile
You have been a member since:: 10/07/2002(UTC)
Hello Neil
the answer would be "no"
You will have to change the decoder of the engine for one that supports sound, mSD or LokSound for example
Offline nunk
#3 Posted : 24 October 2013 01:32:28(UTC)
nunk
Thanks Francis?,
So, although both locos are mfx equipped, the 37655 has only the mLD version whilst the 37616 has the mSD version. Pity.
Neil
Offline franciscohg
#4 Posted : 24 October 2013 04:13:11(UTC)
franciscohg
Chile
Hello Neil, i was checking the manual of the 37655 and it seems to be no mfx decoder from Factory.
You get the loco used or new?
BTW, really nice loc, i thing it absolutely worth to put a mSD or loksound on it
tatatatta,,,checking the wrong page,,,,,,18 hours working are having some bad effects on meLaugh
mfx indeed
Offline nunk
#5 Posted : 24 October 2013 05:20:13(UTC)
nunk
Yes, mfx according to Marklin products site. Haven't bought the loco yet - still researching. I was contemplating a sixties vintage model and converting it with mSD. However, they have plastic bodies and the latest is metal - much nicer in my opinion.
I can recommend retirement over working 18 hour days.
Neil
Offline franciscohg
#6 Posted : 24 October 2013 05:41:46(UTC)
franciscohg
Chile
Unsure and 12 more yo go........
#7 Posted : 24 October 2013 07:41:43(UTC)
No, never. All mfx decoders are locked against updates (except early ones from around 2004 (but it takes ESU equipment to update those)).
A sound decoder is different physically: sound processor plus amplifier. You cannot upgrade silent decoders to become sound decoders. And locos without sound do not come with speakers.
The old mfx decoder will be plugged in. A sound decoder will probably be larger and may not fit - and you also have to find room for the speaker.
Offline nunk
#8 Posted : 24 October 2013 10:59:51(UTC)
nunk
Thanks guys. Firstly, could I ask:
Are the decoders factory fitted by Marklin in their locos exactly the same as the decoders Marklin offer as aftermarket items?
eg is the mLD decoder installed in the 37655 (Product programs 2007/8, 2008/9, 2009/10, 2011/12) a 60942 (or 60962) or possibly earlier decoder?
and is the mSD decoder installed in the 37616 (Product program 2012/13) a 60946 (or 60966)?
My thinking is that as the two locos appear to be dimensionally and physically identical (differ only in external livery reflecting different eras), then a mSD + speaker should fit into the 37655. And perhaps even in an old 3065?
I welcome your thoughts.
Neil
#9 Posted : 24 October 2013 11:41:31(UTC)
The 3065 has a plastic cover that may be thicker or otherwise different.
They may have changed the frame to allow a speaker (I don't know, I don't have that loco).
You can get a speaker in, but you may have to modify the frame.
The decoder in the 37655 will most likely be an ESU decoder that has nothing in common with a 60942. Depending on date of manufacture, it may be a crippled 60942 (no DCC, locked) as the loco was offered for several years.
The decoder in the 37616 will be a 60946 (same hardware, but no DCC and locked against updates).
Maybe someone who has the 37616 and an earlier metal V 60 without sound can compare the internals, maybe even show some pictures.
Offline jeehring
#10 Posted : 24 October 2013 11:47:11(UTC)
jeehring
there is another difference between them : the telex coupling.
It seems that the old style telex coupler(#37655) needs more space than the new one (#37616).The new telex is 100% external (external part) , there are only two wires INSIDE the lok coming from the outside. There is probably more room above the chassis but this should be checked, I haven't verified yet...
Offline BrandonVA
#11 Posted : 24 October 2013 15:12:22(UTC)
BrandonVA
This is correct and a good observation. I believe the telex magnets on the "old" style still sit under the chassis, so I think the question is whether the chassis dimensions are modified to accommodate this or if both are the same.
37655 - "old" style telex - chassis part number 406835
37616 - "new" style telex - chassis part number not recorded
Other differences worth pointing out (but not directly related to decoder conversions):
37655 - one traction tire - 2007-2012
37616 - two traction tires - 2012 MHI
I have attached the parts diagrams for both locomotives for comparison. To me, it looks like they use the same chassis (both using a DCM motor as well). I actually have a 37615 on order, I can take some pictures when it arrives if that helps. 37615 has the old style telex and two traction tires, and I think was another 2012 MHI. To me the construction of this loco also seems similar (if not identical) to 37655 and 37616. All three models are marked in the product database as mostly metal, but I am not sure if the shell is metal on any of them, or if it's really just that the chassis is so heavy.
-Brandon
#12 Posted : 24 October 2013 15:49:27(UTC)
When it comes to changes, the explosion diagrams are a bad source of information. Both drawings show the three-pole AC/DC motor while both locos have the five-pole DC motor. I don't see a speaker on the second drawing (and the decoder on the drawing is a Delta decoder with four DIP switches).
I cannot tell the number of traction tyres, neither from the diagrams nor from the product database.
37652 was the first Märklin V 60 with metal body (and it came with two traction tyres).
Offline BrandonVA
#13 Posted : 24 October 2013 16:05:57(UTC)
BrandonVA
Thanks Tom, seems like some recycling going on.
Regarding the traction tires, 37655 in the product database says "traction tire" and 37615 says "traction tires". It may be accurate, or just a translation issue. I had seen this discussion before, but not sure if it's based on product DB or experience:
https://www.marklin-users.net/fo...67457_Telex-choices.aspx
I found this post on Stummi which may help with sound conversion on 37655. There are some images that may help.
-Brandon
#14 Posted : 24 October 2013 17:10:14(UTC)
In the German text it used to be "1 Haftreifen" or "2 Haftreifen" or "4 Haftreifen" - but now all we get is "Haftreifen" (and cannot even tell singular from plural).
Offline nunk
#15 Posted : 25 October 2013 00:50:39(UTC)
nunk
Very interesting and extremely confusing. Explosion diagrams that can't be trusted. Product descriptions that are ambiguous or non-specific. Just what are Marklin playing at? A game of 'confuse the customer' methinks!
Anyway, some observations from the Marklin website:
1. The Marklin Product data base for 37655 states: "Traction tires" (plural). Parts list doesn't state how many.
2. The exploded diagram for the 37655's mfx components lists:
23 117586 Decoder MFX Progr.o. Sound 112084 (currently not available)
23 611868 LEITERPLATTE MTC DELTA (not available)
24 E405040 Halteplatte (Delta) 5 Stück (in stock)
3. The exploded diagram for the 37616's mfx component lists:
12 118619 Decoder M4v4 m. Sound o. ex P171344/37616 (currently not available)
4. The 37655's front and rear couplers consist of:
33 E205371 Anker (TELEX) (in stock)
34 E213870 Magnet (in stock)
35 E298470 KUPPLUNGSHAKEN (in stock)
5. The 37616's front and rear couplings are:
20 E117993 Telexkupplung für V90 (in stock)
The 37616's E117993 coupler appears to me to protrude further, is bulkier and doesn't look as good as the 37655's couplers.
I wonder how Marklin decides which type of coupler is to be installed on a loco. In addition to the above two Telex types, I also found a 210133 Telex installed on a 37953 BR03. Then there is the 701630 close coupler.
On looking through publications "Summer New Items 2013" and "Fall New Items for 2012", there is only one loco (37616) listed with Telex couplings. Have Telex couplings fallen out of favour? It would seem that the 701630 close coupler is most commonly fitted.
Neil
Edited by user 26 October 2013 03:38:08(UTC)  | Reason: Not specified
thanks 1 user liked this useful post by nunk
#16 Posted : 25 October 2013 02:15:07(UTC)
Would photos of my new 37615 help here? It has the new style telex, mFX and sound..
Offline nunk
#17 Posted : 25 October 2013 02:45:15(UTC)
nunk
Thank you Adrian. Photos would help, especially of the internals showing the placement of the decoder. I guess there's room for a mSD decoder and speaker as the loco appears dimensionally identical to the 37616. By the way, the Marklin parts diagram for 37615 lists for the coupler assembly:
23 E205371 Anker (TELEX) (in stock)
24 E214050 MAGN.ZU TELEXKUPPL. (in stock)
25 E298470 KUPPLUNGSHAKEN (in stock)
So yet another variation of the Telex coupler. It would appear that the magnet has been upgraded? Can this magnet replace the previous E213870 I wonder.
To me, your 37615's couplers look much neater than those on the 37616.
Also, what's the complete road number? 260 XXX-X
Neil
#18 Posted : 25 October 2013 03:44:19(UTC)
Blushing Blushing It is actually a 37617..
The road number is V60 608. The other information is correct.
I am about to post the pictures to my album. I have done a comparison between the 37617 and a 37654. The body shells seem to be identical, but there are small differences in the chassis between the two models. The 37654 was produced in 2004, while the 37617 has just been released in 2013. Smile
Update: Here is the link to the album. https://www.marklin-user...lbum&u=350&a=386 I am off to lunch, but I will update the captions shortly.
#19 Posted : 25 October 2013 04:13:22(UTC)
try this one,
2 of my converted locos (3065) with a 5 pole motor and 1 has an ESU sound decoder + speaker
ballbearings on commuter shaft and led's (white-red)
#20 Posted : 25 October 2013 06:34:41(UTC)
Maybe a supply problem or a reliability problem?
There is a 2011 new item with Telex they didn't ship yet.
There is a 2012 new item with Telex they didn't ship yet.
Why announce new items with Telex if they cannot ship them in short time?
BTT: They turned the decoder 90° (installed it horizontally) to get room for a rather large speaker. Clever move IMHO.
LED lights in the new version, light bulbs in the old one.
Offline nunk
#21 Posted : 25 October 2013 11:41:52(UTC)
nunk
Entertaining video John and a magnificently detailed layout.
Ball bearings on commuter shaft? Should that be commutator shaft? Where do you source the ball bearings?
Neil
Offline BrandonVA
#22 Posted : 25 October 2013 16:11:19(UTC)
BrandonVA
Nunk,
It seems to be after looking at what Tom said that they just recycle bits for their diagrams (sort of a photoshop copy and paste), the same rotors, decoders, chassis, etc. I think these diagrams are more for parts cataloging that service teardowns in that light. There are some really good ones in the old 0733 service manual, but not for every loco.
I am hoping in the end that someone who has 37655 can confirm the number of traction tires.
Neil
The old style couplershave a couple different styles of magnet, but the operation is the same. The new ones only work well with close couplers. See this discussion for more info:
https://www.marklin-users.net/forum/default.aspx?g=posts&t=27407
As far as favour, Marklin have never really produced that many items with Telex. With old telex, it was mostly limited to V60 varients, BR44, 81, 85, 86...all variants essentially coming from the same tooling of the respective class. If you look at the last post in this tread (by FrankF) you'll see a list of pretty much every Telex loco ever made by Marklin. The only things that are missing are those that have come out since the posting (37616 DB 260, 37907 DB 290, 37043 DR 80, etc).
https://www.marklin-users.net/fo...aspx?g=posts&t=21664
I think especially with the old couplers, it was harder for Marklin to fit them due to the extra room required. With the new ones, they can really put them pretty much anywhere there is a NEM socket. I personally don't think we'll see any more locos with the old style telex couplers, I think 37655/37615 will be the last.
In the new items 2013 there is also a telex era II (DR) BR80 coming out: 37043 and also a era IV DB 290 (37907). Both has the new style telex.
I personally like the old style better. The new ones are hard to uncouple without actuating them (for example, if your layout is turned off). I am hoping my 37615 will show up today or tomorrow, then I can take some photos for you...maybe help you gauge how to fit a sound decoder.
-Brandon
Offline jeehring
#23 Posted : 25 October 2013 16:19:46(UTC)
jeehring
Marklin Telex Era II are so rare...
On the last decade before 2013, I knew only one...
Offline BrandonVA
#24 Posted : 25 October 2013 16:22:32(UTC)
BrandonVA
True, although if you don't mind using the newer style couplers, with the right decoder you can add them to pretty much any NEM socket.
-Brandon
Offline BrandonVA
#25 Posted : 25 October 2013 18:32:24(UTC)
BrandonVA
Apparently I am wrong (not uncommon):
37862 appears to have the old style telex (as noted in another thread).. It's a set of two BR 86, but looking at the photos I suspect they are based on the 3096 tooling, meaning they would use a similar coupler design (probably different/newer magnets) to the original BR86 telex locos. If Marklin does a new tooling for BR86, I imagine there will be no more with old style telex.
-Brandon
Offline BrandonVA
#26 Posted : 26 October 2013 04:16:53(UTC)
BrandonVA
I got my 37615 today. Photos of a 37655 or 37616 would probably be more useful, but I think this should give you an idea. In the end, aside from the couplers I believe the tooling used to produce all three is very similar (and probably the same for 37615 and 37616 as suggested by the article number). None the less, I hope these are helpful. If you need a different angle, let me know. Also, 37615 has two traction tires.
-Brandon
Offline nunk
#27 Posted : 26 October 2013 05:11:44(UTC)
nunk
Thank you Adrian and Brandon for the excellent photos you have provided. I now believe that I have learnt all the detail I was seeking in my original post, which I think can now be ended.
However I do have some more questions on Telex's but I will follow that up in the more appropriate topic at:
https://www.marklin-user...aspx?g=posts&t=27407
One last question. What cameras are you using to achieve such great close-ups?
Neil
Offline BrandonVA
#28 Posted : 26 October 2013 05:32:35(UTC)
BrandonVA
Neil,
I'll PM you so as not to derail the thread too much more.
-Brandon
Offline Dave Banks
#29 Posted : 26 October 2013 12:44:24(UTC)
Dave Banks
Hi Neil, my two cents worth from Parkwood on the Gold Coast. I installed an ESU Loksound V3.0 decoder into my #37655. Pictures below are of my conversion that was done a while ago:
D.A.Banks
thanks 3 users liked this useful post by Dave Banks
Offline nunk
#30 Posted : 27 October 2013 10:07:27(UTC)
nunk
I thought I had all I needed but one last thing. Does the 37650 have a metal or plastic body? The 37655 is metal according to the Marklin database.
Thanks, Neil
#31 Posted : 27 October 2013 10:17:54(UTC)
Hi Neil,
I have the 37650. It has a plastic body. I think it was the last red V60 Marklin made with the plastic body as they changed to a metal one shortly after.
Offline nunk
#32 Posted : 27 October 2013 10:27:06(UTC)
nunk
Dave,
Thanks for the excellent pics. Why did you choose the ESU Loksound V3.0 decoder rather than the Marklin mSD 60946 or 60966? Was it just a timing/availability issue?
Cheers, Neil
Offline nunk
#33 Posted : 27 October 2013 10:32:04(UTC)
nunk
Thanks Ray,
Cheers, Neil
Offline nunk
#34 Posted : 27 October 2013 11:05:21(UTC)
nunk
I have been browsing ebay and Google in order to define a couple of locos but confusion reigns!
3064 is variously described as: V60 1009; 260 920-4; 260 417-1
3065 is variously described as: 260 417-1; V60 1009; V60 706
I'm thinking V60 1009 for the 3064 and 260 417-1 for the 3065. If I'm correct, then what are the other respective loco numbers to match the Road Numbers?
Could someone kindly sort these out for me. Unfortunately the Marklin site isn't any help with 4-digit locos.
Offline Dave Banks
#35 Posted : 27 October 2013 11:55:27(UTC)
Dave Banks
D.A.Banks
Offline Dave Banks
#36 Posted : 27 October 2013 12:07:25(UTC)
Dave Banks
Hi Neil, firstly at the time of the conversion the new Marklin decoders had only just come on the market & I preferred to stick with what I knew. Secondly I have a Lokprogrammer & it is just so much fun to sit & fine tune & tweak the loco to your satisfaction. But it was at that time when Marklin had the so called divorce with ESU when availability of the new Marklin decoders were hard to come by Downunder & available at a premuim price.
D.A.Banks
#37 Posted : 27 October 2013 13:04:15(UTC)
The main difference between 3064 and 3065 is that 3064 has no Telex. A couple of different versions of each were produced, with different road numbers:
3064 1963-1968 Relais SFCM III V60 1009 DB rot
3065 1963-1968 Relais SFCM III V60 1009 DB rot, Telex
3064 1969-1983 Relais SFCM IV 260 417-1 DB rot
3065 1969-1992 Relais SFCM IV 260 417-1 DB rot, Telex
see Helmut Kern's site for all versions of the V60 up to 2004
http://www.bahn.hfkern.d...erklin/Dt_Loks_V260.html
#38 Posted : 27 October 2013 13:04:25(UTC)
Both models have been made with both numbers. Not unusual for Märklin models that were produced for decades.
See also:
http://www.hfkern.de/Maerklin/Dt_Loks_V260.html
Offline nunk
#39 Posted : 28 October 2013 01:17:49(UTC)
nunk
Thanks all. That makes it all much clearer.
Neil
Offline nunk
#40 Posted : 28 October 2013 01:58:52(UTC)
nunk
Thanks Dave,
I understand why you chose an ESU decoder for your upgrade. In my case, I only recently entered the Marklin game when I purchased (on Gumtree) a 29640 Starter Set. This included a CS2 and a MS2 also came with the deal. The set is Era III DB so I'd like to stay with this period if I can.
Now I want a small Era III DB diesel shunter. I like the appearance of the BR V60 model and find only these produced: 3064; 3065; 37648?; 37650; 37655. I wish for Telex and metal body so the only choice seems to be 37655 which I would upgrade with a mSD sound decoder 60946 or 60966.
With your conversion, did you have to change the lights to LED or did it already have these? Also, is there a cab light?
Neil
Offline Dave Banks
#41 Posted : 28 October 2013 04:52:00(UTC)
Dave Banks
Hi Neil, the Marklin #37655 which is the one you saw in the pictures above has globes namely #610080 specific for digital. Loco came with that already installed. No led's & no cab light. Simple & easy conversion.
D.A.Banks
Offline BrandonVA
#42 Posted : 28 October 2013 13:35:40(UTC)
BrandonVA
Neil,
37650 is plastic body according to the Marklin DB.
The 37615 I got has a metal body, but the upper cab is still plastic. I am willing to bet all the "metal" V60 variants are the same. Between the newer metal(/plastic cab) body and the original 3065 and 3141 I have, the metal seems more crisp.
-Brandon
Offline NZMarklinist
#43 Posted : 28 October 2013 17:18:53(UTC)
NZMarklinist
Hi Neil, All,
I have the 37655, and as I too had wondered about how easy it would be to upgrade to sounds I took the top off and found it is exactly the same as Brandon's 37615 as in above pic ! Smile
Firstly I can confirm the 37655 does have two tyres mounted on the rear axle ! and is an excellent choice for an Era III model of the V60 IMHO Smile
It has 21 pin decoder so an ESU one or a Marklin 21 MSD could be very easily retrofitted, however there seems to be little room for the speaker. But..............! Huh
Also the ESU V4 decoders have few functions amplified, so an MSD would be the better choice, as it has all functions amplified (ie with enough watts/output to operate Telex, lights etc) and Marklin do have a downloadable sound project for the V60/260.
Another plus for an MSD is the Marklin wiring colours are the same. ThumpUp
As for the speaker, space for that is likely to be a problem, so an internal pic of a37616 would be enlightening for all because as previosly mentioned, the parts digrams are no help at all ! ThumbDown
What Dave has done is fit a wired type ESU V3 decoder and done away with the 21 pin decoder board, allowing room for the speaker/s, those twin ones are quite small. Wink
That said I see in Adrian's pics of his 37617 that M have sat the oblong box speaker, one of which comes with an MSD, where the decoder board used to be and the decoder board on top of that. I may be necessary to change the decoder board as the original one looks likely to foul the cog wheel protruding from the front of the motor block and I have just checked with the leftover one from my V90 conversion and it is a bit shorter, enough to not foul the cog !
You will notice in Adrian's pic of his 37617 that the original bulb holder posts appear to be still there but the front light LED is on the front of the decoder board and the rear light LED board is mounted on the rear light post. If you wanted to buy two of the rear LED light boards from Marklin they are available @6eu each OhMyGod and I think could be used in both positions Wink
I have had a similar conversion done to my 37900 V90 using a Marklin 21 pin MSD, those small twin speakers, mounted in the allready factory fitted speaker cups, and the 117993 telex couplers and it works well, but those add on couplers can be fragile and I've had to replace three allready and I've hardly used it, altho two were damaged in the conversion process when mucking about with different decoders, so were either DOA or got spiked in the process, they do not take track voltage btw !!! Scared
Personally I would have to admitt that I will not be in any hurry to upgrade my 37655 to sounds, however when I get my layout operational I may change my mind Wink
Glen
Auckland NZ
thanks 2 users liked this useful post by NZMarklinist
#44 Posted : 28 October 2013 19:43:29(UTC)
I've taken a few photos of my 37616 with the body off. Hope it's useful.
RayF attached the following image(s):
Offline nunk
#45 Posted : 28 October 2013 21:09:37(UTC)
nunk
Thanks guys. All excellent advice and pics. However, I'm still a bit puzzled by the product description for the 37655 on the Marklin website which states:
Highlights:
- Metal version
I took this to mean that both the 'chassis' and the 'cab body were metal rather than the cab body still being plastic but it appears I am mistaken. Is something lost in translation??
Brandon states: "37650 is plastic body according to the Marklin DB" but I couldn't find that 'fact' there. He then states "The 37615 I got has a metal body, but the upper cab is still plastic"
Ray refers to 'body' meaning the upper cab component.
So I think what Brandon calls 'body' is what I would call 'chassis' or 'frame' and his 'upper cab' is what I have thought of as 'body'. The exploded diagrams aren't much help. Perhaps part no 26 refers to the 'chassis' (i'm not sure). In German that's a 'TREIBGESTELL' which translates to 'driftwood frame'; 'frame' is OK for 'chassis', but 'driftwood'???
Could someone please provide the correct terminology for these two components so that we can clearly understand what is being referred to.
Neil
Offline BrandonVA
#46 Posted : 28 October 2013 21:27:05(UTC)
BrandonVA
Neil,
Attached to this post is the product description for 37650. The little icon that has a locomotive that is black and white means that the body of the loco is plastic.
Also attached is the description for 37615 (37616 is the same as far as icons). You see the little icon is now mostly black except for the cab of the loco.
What it means:
37650 - you take the "shell" off, the frame with the motor, decoder, etc is metal. The shell that was removed (the likeness of the loco) is all plastic.
37615 - you take the "shell" off, the frame with the motor, decoder, etc is metal. The shell that was removed is part metal, part plastic. When I refer to the cab, I mean that the engineer's cab is plastic (the part with the DB and road number). The engine cowl/cover on either end of the cab/shell is metal. This is the same concept of how many steal locomotives have a metal boiler, but the cab and/or tender are plastic.
The way Marklin details modern models, it's very rare to have one that's 100% metal. Some parts of the construction will almost always be plastic.
I hope this clarifies.
-Brandon
Offline nunk
#47 Posted : 28 October 2013 22:26:22(UTC)
nunk
Thanks Brandon, much appreciated.
I obviously didn't take notice of the Features icons. I've now Googled the subject and located at:
http://www.maerklin.de/e...ten.html?sCountryCode=en
a listing of Marklin icons with explanations and I now understand the significance of the various icons depicting metal and (I presume) plastic combinations. I also note that the terms 'frame' and 'body' are used.
It now all makes sense and I will definitely pay close attention to these icons and their significance in the future.
Thank you for your patience,
Neil
#48 Posted : 28 October 2013 22:33:29(UTC)
Märklin show an icon with a steam loco in their product database: black parts are metal, white parts are plastic. Just symbolic, but indicates pretty good what you can expect.
The icon for the 37655 has a white cab, rest is black. A picture says more than 1000 words - and the only translation that is needed is from steamer to diesel.
This page was generated in 1.405 seconds.
