Offline Beano
#1 Posted : 23 July 2013 23:19:19(UTC)
Beano
I want to model NA locos. Marklin have very limited selection. Does anyone have experience converting standard 2 rail Locos to use with the CS2?
Edited by user 24 July 2013 10:24:57(UTC)  | Reason: Not specified
#2 Posted : 23 July 2013 23:53:59(UTC)
Electrically it is pretty easy. The slightly tougher set is mounting the pickup shoe in a manner that won't effect locomotive performance.
The real problem is how they perform on Marklin track due to difference wheel profiles and being designed for larger radius curves.
I advise only doing conversions you know have been done sucessfully by others...
Offline Beano
#3 Posted : 24 July 2013 08:04:06(UTC)
Beano
Thanks. Can you expand on the "electrically it's pretty easy" part. I assume i have to purchase a replacment Marklin or 3rd party decoder and try to fit it into the loco but dont' know about sound (is it a separate decoder?) Are voltages compatible with the types of motors available on NA locos? This is my first attempt at something like this, i dont mind investing a little and i'm not averse to risk.
Offline witzlerh
#4 Posted : 24 July 2013 21:01:45(UTC)
witzlerh
NA locs should have no problem running on Märklin C track when you have the following kept in mind.
*Most NA rolling stock have minimum operating radii and most will not handle R1 and a few will not handle R2 if you have longer stock.
NA modelers like to be very prototypical and as such, will have full length cars and body mounted couplers.
For modern rolling stock, that means very long cars and the overhang will not tolerate R2, let along R1.
However, if you have short rolling stock, R1 is possible.
As switches are either R2 or WR you will have to try out if the rolling stock you have in mind can handle R2.
S curves are really bad so plan a straight between curves. Look at the manufactures instructions or try it out yourself.
I have a Rapido Canadian and my minimum radius is R3 in the plan for the mainline. I do have it planed to run over the straight part of R2 switches but I will never take it into the "branch line" or yard which will be R2 switches and R2 and R1 curves.
As there are low flanges on NA rolling stock, there will be more derailments than expected if you are used to Märklin. You will also see more jittering as the train passes over Märklin switches as compared to NA switches.
*Electrically, all new loks will handle DCC and it should be no problem getting a decoder for your lok. Most new loks are DCC ready. If it is an older lok, then you should talk to an experienced decoder installer to get the correct CV's to best match your motor type and get realistic parameters set. Older loks may need some wiring to have separate ground for functions like lights. This is covered in decoder manual and other decoder installation posts.
You will need to jumper the left and right side wheel power pick-ups to get constant ground.
The hard part electrically is to find a place to install a center pick-up. 2 of my loks have very low clearance between bottom of body and top of rail. Your slider must be able to get over the rails at turnouts. However most passenger cars have a hollow truck requiring a spacer to mount the center pick-up.
I will transfer power between cars with a wire that looks like a brake hose. This will avoid having a lot of center pick-ups.
I have done 1 conversion so far and have 4 more to go. I do have a fellow Fleishmann enthusiast who has done a few conversions himself.
Harald
CS2 DB & Canadian Era 3-6
#5 Posted : 25 July 2013 10:27:03(UTC)
All good advice here...
I have converted literally hundreds of 2-rail to 3-rail locos (and vice-versa...BigGrin ), including *many* North American and even Chinese models.
There are essentially two types of thing to consider: mechanical and electrical.
The electrical part is indeed "simple" and I won't add anything except that with a CS2 or an ECoS or an Intellibox , etc. you won't even have to change the decoder (if present) since you can have your central producing the DCC control signals required. Just read the manual for all the answers...Wink
And with the advent of today's really small decoders, finding space in the loko is no longer an issue, even in older models
The real complexity is in the mechanical work: the wheels/axles, the pick up shoe and accessorily the couplers.
Wheels: RP 25 profile only work 95% reliably on C-track, even though you may not get any derailment, the lower profile flange will "sink" into switches' frogs and dance an unaesthetic shake..
When possible, I systematically replace RP 25 wheels with Märklin ones, even though this definitely requires more works and involves the use of a lathe, wheel puller, wheel etc.
The key though is to correct the inner spacing from 14.2 mm to 13.8 ...14.0 mm, which will greatly reduce derailment issues due to flanges picking up the point of the frog or a counter rail.
I use this simple gauge to check proper spacing: http://www.fohrmann.com/...ahner/rail-gauge-h0.html
With the same supplier you'll find many other useful tools like wheel pullers, whell presses and quartering jigs (indispensable for loks with side rods)
As for the pick up shoe , in 99.9% of the cases, I have succeeded to fit a Märklin ski under the loc, as long as
1) you remove the insulating plate, and mount the ski directly in to the loco plastic bogie, after cutting four small slots (see picture below)
You'd still need about 2 mm free space if you use the older style rigid Märklin pick ups, the newer "floppy" versions are so thin (and it's good news!) you only need about 1 mm clearance.
The one in the picture was fabricated "in-house", using a 0.5 mm brass strip, properly slotted and shaped to fit a Märklin spring (which is 0.3mm thick for instance) .
2)... and you should be ready to eventually make little cut-outs in the base plate cover, in order to accommodate the "curl" at the tips of the ski. (again check the picture below)
I use a milling machine for that operation..maybe an overkill, but I am AnR ...
As for the couplers, I have solved the problem once and for all on NA style models.
If there is no original short coupler mechanism/ NEM pocket installed, I systematically install the Symoba products.
That includes even long coaches, where I can also use the Kay-Dee NEM shaft style couplers when compatibility with these is required.
Rather than chatting Wink indefinetly over "generalities", show us a *specific* example of a "to be converted" lok, and I'll be offering *specific* suggestions.
thanks 8 users liked this useful post by jvuye
Offline Beano
#6 Posted : 25 July 2013 15:12:17(UTC)
Beano
All good advice here..................
Fantastic advice and very inspirational. I will post pictures of my first project next week. I am in Switzerland at the moment returning to Toronto on Saturday and will probably have my DCC-Rapido FP9A waiting for me on Monday. Talk to you then.
No need to repeat the complete post in your quote, it clutters up the thread, and is a pain especially for those browsing with mobile devices. We can all read the original post! /BDNZ
Edited by moderator 10 August 2013 01:22:30(UTC)  | Reason: Not specified
Offline witzlerh
#7 Posted : 25 July 2013 16:20:59(UTC)
witzlerh
And I have 2 Rapido FP9A loks to convert too!
As the gear covers are too low for a pickup, I am thinking of placing the pick-ups under the unpowered dummy (hava an A-B-A for my Canadian) or the baggage car and running power from there.
Harald
#8 Posted : 25 July 2013 18:10:15(UTC)
I had spoken to Jason (Rapido) regarding AC versions or conversion of their models and he had replied to me that they had no plans to market AC versions of their catalog line, nor did he think that any design changes to facilitate user selfconversion would be implemented.
There was a recent post about MTH introducing some NA prototype models for 3RAC. It should also be noted that many NA models have all wheels powered. One solution to this may be to acquire a dummy or B-unit which is unpowered, take one bogie from that unit, replace one of the two powered bogies on the locomotive with the unpowered one from the dummy and install the slider on that bogie. This might be even easier if you can obtain parts for the dummy or B-unit from the manufacturer or from a supplier.
#9 Posted : 25 July 2013 19:34:01(UTC)
This is the typical situation, for which I have suggested the method highlighted in my reply...
Before having it I was sometimes disabling one of the power trucks to get room to install the pick-up...but this is no longer needed.
All is needed is to be able to slide a 1mm thick piece of cardboard between the power bogie and the pukos on a switch which are the highest on the whole system
After I check the pictures of that FP9 I'll give you suggestion.
Cheers...
Offline Beano
#10 Posted : 25 July 2013 22:48:50(UTC)
Beano
[img]null[/img]
I am in Toronto. I just purchased a VIA FP9 and will try to convert it. I really liked the answer from Jacques it gives me hope. I am still note sure about the "electrical is easy" part from the other responder, I am not too experienced in soldering wires onto tiny expensive boards, we will see.
I have had great success with Marklin-ready Protosound 3E+ MTH locos. I have 3 of their locos and 2 more coming They work great, sound great and work well in DCC mode. That gives me access to NA locos but I really want Canadian CP or CN, VIA and GO (Ontario). So I bought a 3E+ SD70 M-2 in Norfolk and Western colours and a non 3E+ CN version. I exchanged the casings, a few tricky moments but essentially easy and now I have a beautiful CN SD70M-2 in CN black and red.
Unfortunately, that is the only possibility at the moment with MTH so I have purchased 2 GP-35 in sant-fe colours and I am going to redecorate them. One CN, one CP. I also have an F7 in Santa-Fe coloyrs that I may re-do as a CN. Depends how the conversion experiment goes.
I was talking to a great guy in Australia who runs "DCC info and Advice" he recommended the Lokpilot v4.0 M4 multiprotocol decoder for conversions. This decoder will talk MFX and is recognized by CS2. Another crazy attempt but it all adds to learning.
Good luck with your FP9's we will see how this works out.
Beano attached the following image(s):
Offline tulit
#11 Posted : 26 July 2013 00:56:45(UTC)
tulit
Beano I'm really interested in this as well for the same reasons.
If you need help with any of the electrical stuff let me know. I'm in the GTA as well.
#12 Posted : 26 July 2013 09:34:56(UTC)
You have been a member since:: 14/03/2005(UTC)
Hi guys,
I hope you pardon my ignorance, but if you are keen on modelling North American locos why do you bother with 3 rail?
The reason I like Marklin is because of the heritage and quality of their locomotives, but if you are going to buy other manufacturers locos why not stick to 2 rail and save yourselves a lot of hassle? Some of our members have both 2 rail and 3 rail tracks on their layouts, so it's possible to run both Marklin and others without complicated conversions.
I am also interested in British prototypes, so I'm pretty much restricted to 2 rail locos. I wouldn't dream of converting a new Hornby or Bachmann loco to 3 rail just to use it on my Marklin layout.
I'm curious to find out why you stick with Marklin track if your interests are North American.
Offline tulit
#13 Posted : 26 July 2013 13:29:47(UTC)
tulit
Hi Ray. For me it's just for the variety and ease of availability.
Ill still collect marklin and am not too concerned with accurate prototypical setups.
My other thought was to run a loop of trix ctrack alongside the marklin to avoid any of the conversion issues.
thanks 1 user liked this useful post by tulit
Offline witzlerh
#14 Posted : 26 July 2013 15:33:26(UTC)
witzlerh
In my case, my love of trains was generated in Germany. However, I am Canadian and had some wonderful memories on the VIA Canadian so it has to be on my layout. I do have the Northlander from Marklin as well as many Marklin rolling stock. Not planning on anything more from 2rail.
Harald
#15 Posted : 26 July 2013 15:50:20(UTC)
Same here!
Grew up in Europe and hooked to Märklin, then spent 1/4 century in the US and moved my Märklin collection along...then started to really like the looks and sound of NA trains.
Now back in Europe, moved back both all my original Märklin and some more along with my NA trains and I still love both!
What can I say?
And 3-rails is so much more reliable...BigGrin
Offline waorb
#16 Posted : 26 July 2013 19:32:17(UTC)
waorb
Brazil
Hi guys,
Hi Ray!
I think I have an answer... The challenge!
IMHO it's a pleasure to achieve something unusual... sometimes is just the pleasure to do it...
I'm one of those modelers that have 3 and 2-rail in the same layout. 90% Märklin, 10% Frateschi (brazilian manufacturer of 2-rail model trains).
I never had (until nowThumpUp) the idea to convert a 2-rail to 3-rail lok... Maybe someday...
Sometimes I receive(d) as a "gift", or bought, a broken/old/jammed Lok to put in order again... Now I have a little collection of old loks running flawlessly.
RollEyes
Walter
Offline kbvrod
#17 Posted : 27 July 2013 18:32:38(UTC)
kbvrod
As Dr. Eisenbahn explained the challenge is where/how to put the slider/shoe/ski on the lok,....the rest is as easy as pie,....BigGrin
Dr D
Offline Beano
#18 Posted : 30 July 2013 15:17:09(UTC)
Beano
Ok Dr. Eisenbahn, please see the attached pictures of the FP9A VIA loco. There is not much clearance as you can see.
#19 Posted : 30 July 2013 16:04:49(UTC)
OK. Nothing unusual..Wink
You need 2 mm clearance (if you use a std Märklin ski) between the bogie's bottom and the highest pukos: the ones on the switches.
With the newer style or if you make your own (like shown above) you need about 1.3 mm.
Cut yourself a strip of cardboard or balsa of that thickness, about 13 mm in width and 20 cm in length.
Place the loco on the straight part of a switch, with the bogie on top of the high pukos.
Slide the gauge strip between the wheels...it if passes , you have enough clearance.
Take a Märklin ski as long as you can find, to possibly have the "ears" to be outside of the bogie (see picture below)
Carefully separate it from its insulating plate and straighten up the little brass fingers from the spring blade
Take the bottom off the bogie and mark it exactly where the fingers should be coming to place the ski perfectly in the center and with ears clearing the bogies' bottom..
Cut 4 slots (I do it by drilling a number of adjacent 1 mm holes, then open the slot with an X-acto cutter and finish smooth with a thin file)
To accommodate the ski "ears", you may also need to cut the edge of the bogie's bottom (as in the photo below) if it is a long one.
But from the looks of it, not needed in your case!
Mount the slider by sliding the fingers in the slots, either bend the metal or simpler, super glue them to the bottom of the bogie.
Voilà!
Offline witzlerh
#20 Posted : 30 July 2013 16:45:03(UTC)
witzlerh
Thank you! I can do that!
Now I can order the powered B unit!.
I will also order spare gear covers in case I want to sell it later as 2 rail.
Harald
Offline kbvrod
#21 Posted : 30 July 2013 17:43:41(UTC)
kbvrod
Please remember that others make shoes/slider/skies. Lililput made a very low profile one,....
Dr D
#22 Posted : 31 July 2013 17:00:15(UTC)
Hi Ray...
My problem is the breadth and width of my railroad interest.Woot
I think many people suffer from the same "diversification syndrome"...LOL
And then it comes to decide what's the most dependable sytem to use and run the locos rather than having a fleet of shelf queens...
So here comes the need for transplant surgery...but is it "3-to-2 rails" or "2-to 3-rails"?
At least for me , the choice was obvious: it's 3 rails/ Märklin...but again it's only my opinion.
(I don't want to start WW III!!Scared Wink )
Offline witzlerh
#23 Posted : 31 July 2013 17:12:25(UTC)
witzlerh
Hmm. I have about 14 Marklin Trains and love German (and Swiss) railroads.
However, I am Canadian and wanted to have the VIA Canadian as well as I have taken it several times already.
So 2 loks against 14(and growing)??? Three rail it is.
It is also the challenge and it is my railroad and I get to dictate what I want. But it is hard work I admit, but it will make the end result all the more rewarding....
Also. Do you know how many European vacationers LOVE the VIA Canadian! I think that if Marklin would come out with the Canadian, they would sell well too. They have all the tooling as proven when they made the Wabash Blue Bird.
Harald
Offline Beano
#24 Posted : 05 August 2013 03:44:30(UTC)
Beano
Dr D
can you recommend where to get these "low profile" slider shoes. All went very well wit my conversion, exactly as Dr. Eisenbahn had recommended. Locomotive started, all DCC functions running great then we hit the first switch and shorted out. I have tried everything to lower the profile of the Marklin shoe and have carved the heck out of the bogie but i can't get it low enough.
thanks
thanks 1 user liked this useful post by Beano
#25 Posted : 05 August 2013 22:24:32(UTC)
thanks
Did you measure the clearance as suggested?
If you know the value, I can probably suggest a part number or two.
Also maybe a picture underneath the loco, with the shoe installed of course...
We'll get to the bottom of this affair!!Cool
Offline Beano
#26 Posted : 07 August 2013 00:38:54(UTC)
Beano
Thanks again, no, i did not check the clearance, but even if i had i would have tried anyway. I am attaching pictures of my efforts. it would be great if you have suggestions. I got a new bogie cover so we have a fresh cover to modify if required.
#27 Posted : 07 August 2013 21:25:25(UTC)
Well from the looks of it, you may have a case where the thinner (home made, as shown on one of my pictures) slider may be required.
Also make sure the solder doesn't interfere with the slider.
But before that , try to establish if you are in the 2 mm or the 1.3 mm clearance case, using the technique I suggested.
Iy is really primordial and an integral part of the "recipe"..;can't skip that step!Wink
Offline GvanWyk
#28 Posted : 09 August 2013 22:08:38(UTC)
GvanWyk
Hi Guys, my very 1st post on the Marklin forum.
is it also not true that by converting your 2 rail DCC to a 3 rail, you can run it using the new mobile station 2?
I got my hands on a Trix DCC with sound, so I got someone to add a slider. he tested it and it is running very well, cannot wait to get it back and run with my Marklin!
one of the problems I foresee however is that by converting 2 rail to 3 rail, is that only one side of the wheelsets will be grounded unless one do a bot of connection there as well?
Offline witzlerh
#29 Posted : 09 August 2013 22:29:01(UTC)
witzlerh
GvanWyk, Yes you can use a DCC lok with the MS2 as it is multi protocol. The decoder does not care how it got it power, either from a rail (2 rail) or a slider (3 rail).
Yes only one side will be grounded unles you jumper both sides to get ground. Can be done if you have power transfer problems. It is also necesseary if you want to use the block detection technique with an isolated rail.
Harald
#30 Posted : 09 August 2013 23:02:20(UTC)
....or...one can replace the insulated wheels by regular (non insulated) wheels.
This however gets a little more complicated!
First you need to have the right tools (a wheel puller, then a wheel press)
Assuming that part is taken car of, you need to procure the wheels, not always simple , especially on older locos.
I have had so much trouble procuring wheels, that I have developed a technique to replace the original insulating bushes with brass ones.
To manufacture these on my lathe and install them properly on the wheels, I have machined a set of collets that accomodates all the wheel sizes used by Märklin.
That guarantees perfect centering and maintains wobbling within a (self imposed) limit of 0.05 mm (measured using a dial gauge)
If there is true interest (I mean beyond "curiosity" Wink ) , one of these days I could make a little photo shoot of such an operation.
Offline witzlerh
#31 Posted : 09 August 2013 23:14:29(UTC)
witzlerh
That's extreme...but nothing is impossible for dedicated Marklinists!
My 2 rail club has soldered a resistor between the axel and the wheel, bypassing the bushing.
(they did this for train detection purposes...)
If you can solder small wires, you can do this too if you do not have a puller and lathe....
I am a machinist turned engineer and am jelous of those who have their own shops!
Harald
#32 Posted : 09 August 2013 23:16:25(UTC)
No, typically you have to resolder one or two wires to get all or at least most wheels grounded. With Trix locos this depends on the loco and which slider is used.
With Trix locos you often remove the wheel pickups from one truck and install the slider instead. In this case, half the wheels of one truck are lost for ground contact.
#33 Posted : 09 August 2013 23:55:32(UTC)
Seems like it's time to bring up the silver paint option again... Wink
Offline Beano
#34 Posted : 16 August 2013 04:39:19(UTC)
Beano
Ok Jacques,
My apologies for the delay, I was distracted doing my first attempt at redecorating an MTH GP35. It's not beautiful but I am quite happy with the results. Anyway, the other conversions are looking a little hopeless. I measured the two candidates and the results are discouraging. The Rapido is less than 1 mm (0.6) clearance and the Athearn is only slightly better at 0.04" or 1,02 mm. I also think that the wheel flanges are not deep enough to keep the wheels aligned through the switches. I am looking into changing the wheels to the MTH marklin style but there are clearance issues with the trucks.
Offline Beano
#35 Posted : 13 January 2014 03:36:09(UTC)
Beano
Well, it has been some time since i updated this post. Not sure if anyone is still interested, I now have the following successfully running on my Marklin layout...
1. ES44 Canadian Pacific. Athearn Genesis
2. GP9 Athearn Genesis.
3. FP-9 VIA Rail, Rapido.
I am Working on a GO Transit GP-40 Athearn Genesis
I have the following on order from Rapido and Will Convert when they arrive
GMD-1 CNx2, F7 VIA, LRC VIA
I also have the following MTH locos running very nicely..
1. GP35 SP
2. GP35 CN(Redecorated from SF)
3. GP35 CP (Redecorated from SF)
4. SD70 M-2 CN (CHanged bodies from NS)
Thanks to all of you who helped get this rolling esp. Jacques.
Ok Jacques,
thanks 4 users liked this useful post by Beano
Offline witzlerh
#36 Posted : 13 January 2014 06:23:14(UTC)
witzlerh
Well done all! I have not done any conversions from 2 to 3 rail since my last post. ( I did convert my train room to have better bench work instead! Far more fun and have twice the space for track!)
I am currently borrowing some TRIX C track and have my Rapido Canadian loks running great! However, each of the cars need some work to reliably handle R3 curves. There are too much pipe in the truck area that I have to tuck away to get full range movement of the car trucks.
As each of the cars are beautifully lit, and get their power from the track, it is the 12 passenger cars that I have for that train that are making me pause and re-consider conversion.
I will give this 2-3 rail conversion more thought and attempt it after the Canadian runs reliably on 2 rail AND the rest of my Marklin rolling stock is all running well. (4 sick loks and 7 damaged cars to get running). ( Anyone know where I can get bumpers for the HOBBY/my world freight cars? I have some broken off and missing; and they are integrally moulded. Most of the higher end freight cars are metal and screwed in.)
I am also starting to get ready for SUPERTRAIN, Canada's largest and best train show held in Calgary in April. I will have a layout showing Märklin's best; and have kids running the MyWorld stuff too. So the conversion thing will wait a while. If I find a good, reliable way to convert the cars and get power picked up and run throughout the cars, the Loks are more doable to convert. ( I do not want 13 pick-ups; too much drag!
I will need to find or make very thin pick-ups for the loks. Märklin's are too thick for some of the conversions.
Harald
Offline BenP
#37 Posted : 15 February 2022 21:47:24(UTC)
BenP
Anyone converted a DC-based 'Hondekop", like Piko 57521 (pic), to Marklin Digital? This is classic Dutch intercity trains.
train
Alternative is the later yellow version
train2
I use CS3+ digital and have converted several Marklin analog 3-rail to digital, incl engine replacements. Never added a 3rd rail (yet).
Offline witzlerh
#38 Posted : 15 February 2022 23:43:15(UTC)
witzlerh
train
train2
Hi. If this is part of the PIKO Expert line, then they would have spare parts to change out the truck base to allow a PIKO slider to be added. You will also have to change some or all the wheels to solid. I have done it this way with a couple of PIKO engines.
If not, then you will have to get creative with getting a centre pickup and rout the wheel plus or minus wires together as they will be the ground.
What I did do as i have both 2 and 3 rail track (but with lots of 3 rail Flapper ) I routed the power and ground to a switch inside that I added so that by sliding the switch I can make it 2 or 3 rail, I would then have to remove or pop in the centre pick-up.
Harald
#39 Posted : 16 February 2022 00:54:39(UTC)
Piko produces AC and DC locos, so have alook at the Piko catalogue and see if this modelis produced as an AC model as well., besides this all Piko models regardless whether AC or DC have the option of adding a slider.
#40 Posted : 16 February 2022 20:39:10(UTC)
Piko sells an AC version of the Hondekop models. You can try Huenerbein.de or other European dealer. I don't know how much of the AC product line Piko North America keeps in stock. A larger dealer like Reynaulds may have the item in stock. Many times, getting AC versions is best assured when preorders are placed as there are limited excess quantities available outside of Europe.
Offline BenP
#41 Posted : 17 February 2022 13:45:23(UTC)
BenP
Decided to do just that. The good folks at ajckids found me an AC yellow hondekop, which I'll convert to digital. Need to do some homework, as i have only converted Marklin locos thus far. Suggestions welcome.
Offline BenP
#42 Posted : 22 February 2022 23:27:25(UTC)
BenP
The Piko hobby line is basic in feel and rolling behavior, but has the exact train I want. It is AC 3rail and includes a basic 8pin DCC/Marklin decoder that works analog and digital. I will add cabin LED light strips, and drivers cabin lights that switch with direction. The good folks at ajckids found me this one.
NS "Hondekop"
This page was generated in 1.384 seconds.
