Offline Mark5
#1 Posted : 12 June 2012 02:06:05(UTC)
Mark5
I have a bunch of blue transformers from various years....
... recently got a "super" transformer from 50s, I believe, but most of others are much more recent.
I read somewhere on the forum that the older blue ones have had issues.
Can anyone document these issues from personal experience or close experience i.e. a reliable source.
I would love to use them and keep them going, but would like to know if they could damage equipment and locos or not.
- Mark
Offline kariosls37
#2 Posted : 12 June 2012 07:18:05(UTC)
kariosls37
The blue transformers have a few things you have to be careful about, but overall they are good to use.
They deliver a much higher voltage, especially in the reversing pulse than normal locos. Some decoders cannot handle that high a voltage, so you should only use them to power analog locos. I have seen someone's digital crane fry it's circuitry because of it.
The insulation in the high voltage cables may degrade over time, resulting in a risk of electrocution. If a power cable looks suspect, get it replaced by someone who is qualified to do it(eg. an electrician).
On a Digital layout, you can use them without problems for accesories, as long as both lighting terminals do not make contact with the track. This will fry your controller or decoders or both. There are other threads that document how to wire up everything correctly.
On my digital Marklin layout I use an old blue and a newer grey transformer for accesory power, including point lights on M track. No problems at all. I am also able to change over the layout from digital to analogue on the old blue transformer by disconnecting the digital gear completely and changing a few plugs.
On my 2 rail layout I have a 1950's transformer powering a 6021, which has also worked faultlessly.
Rick
thanks 1 user liked this useful post by kariosls37
Offline Markus Schild
#3 Posted : 12 June 2012 09:58:14(UTC)
Markus Schild
it is a trap, that the power-cables of the 280 look like perfect-condition from outside, even if the insulation of the wires inside the rubber-coat and inside the box is decomposed fully. The worst part is often found just at the point were the cable goes through the box. Maybe there is a kind of long-term reaction with the paint.
Markus
Offline NZMarklinist
#4 Posted : 12 June 2012 16:58:56(UTC)
NZMarklinist
Probably the correct answer is NO they are not reliable enough!!
They maybe OK for analogue use if you can be sure the high voltage cables are in good condition, but don't put them anywhere near anything Digital !!
Just saying that is all Scared
Glen
Auckland NZ
Offline BrandonVA
#5 Posted : 12 June 2012 17:30:31(UTC)
BrandonVA
Mark,
Mostly in repetition of above:
I had a couple of posts a few months ago discussing the issue due to my own ignorance. The end result is that if you have locos with Delta or Digital decoders of any kind (locos of 34xx, 36xx, 37xx, or almost all 5 digit part numbers), you don't want to run them with any kind of blue transformer. As stated, the maximum speed voltage and also reverse pulse voltage may be too high for the decoders, which will fry them and leave you with some heavy paperweights.
I purchased four new 6646 white/grey transformers for running tracks on my layout. I previously had three 6627 blue/red transformers. My personal feeling is that the 6667 (16va)/6627 (30va) generation of transformers would be fine for any analog locos and safe in that regard, but not for delta/digital. I have had these transformers for years and they seem to be reliable. I think they have been designed and manufactured in a new enough era to have the correct saftey protocols, so that if anything they will stop working but not present a risk. My gut instinct is to not trust anything older than these. My plan is to use them if I need auxiliary accessory power (also previously stated), but with four 32va white transforms I don't think I'll get there :)
One small bonus of the "new" 6646 (110v)/6647 (230v) transformers is that they are smaller and lighter than the older versions. I also like the connections that just require a bare wire, and not a plug on the end. However, they are still not polarized, so if you are setting up a layout with multiple transformers you will need to set this up. It's not hard, but very necessary.
On a somewhat unrelated note, I think it's a good idea to keep a fire extinguisher in the "train" room, just in case.
-Brandon
#6 Posted : 12 June 2012 17:58:26(UTC)
Another point: my 6647 switch off in less than a second in case of a short circuit. The blue ones may take up to eight seconds.
So a new transformer might save the things connected to it in case of a short circuit - where a blue one could be too slow.
Offline Mark5
#7 Posted : 12 June 2012 18:31:59(UTC)
Mark5
Thanks for comments gentlemen,
I have used my blue 30VA with two digital loks and they worked beautifully.
I was surprised how they also reversed seamlessly when in analog mode as they interpret the reversing high-voltage in the decoder and reverse as they should, without the jumping that the poorly adjusted tension spring in analog loks lend themselves to.
Other than the high-voltage in reverse, I don't understand how they can be too high voltage when my 6002 is 52VA.
Is it a question of how the voltage is applied? Can anyone with electrical knowledge explain that?
I have not yet tried using my 6002, nor the 6021 compliment, which is sitting here in styro box besides me.
I also wanted to know is if the blue transformers would work to add power to a large layout in series with digital,
as long as they were "locked-down" in a fixed high-speed position, thus applying adequate VA to compliment.
If not the blue ones, what about the newer white ones? I will need notes on polarizing too. I saw something the EE had in their literature about polarizing the current, but will have to check again.
I do appreciate your comments about the insulator and would like to know if I got an electrician to take a good look at them, that they may be useful. I have 7 of these, three are 30VA-6115 and the old "Marklin Super" 280, one is 16VA-6507 (immaculate condition), and three some are much newer 10VA (I am not sure about the correct numbers but one says 37547, another 37549, these two of have dials in mediocre condition).
However, if that is too much work and too risky, I might consider investing in newer transformers, but I will see what I can do to use my blue meanies safely with analog equipment. Tom, I do see how the rapid short-circuit switch off in the 6647 is a great advantage.
Brandon can drive his firetruck when he comes to visit, and bring up the hose and extinguisher so at least he will be safe. Wink
- Mark
Offline kbvrod
#8 Posted : 12 June 2012 18:33:28(UTC)
kbvrod
Hi Mark,all,
Good advise as always,....
Check that wiring!Both inside and the cord!
I had several of old blues,......I used them for lighting or a bench work transformer.Then I got Titan's,....BigGrin
Dr D
thanks 1 user liked this useful post by kbvrod
Offline Mark5
#9 Posted : 12 June 2012 18:35:45(UTC)
Mark5
Hi Mark,all,
I had several of old blues,......I used them for lighting or a bench work transformer. Then I got Titan's,....BigGrin
Dr D
Kev,
I will need to get out my Railroader Geek Glossary again, or you can explain to me what "Titans" are and why they give you a big grin.
- Mark
Offline Mark5
#10 Posted : 12 June 2012 18:38:15(UTC)
Mark5
Markus
So Markus,
You think the 280 "Marklin Super" transformers are not worth the time to check or repair?
Offline kbvrod
#11 Posted : 12 June 2012 19:07:32(UTC)
kbvrod
Hi Mark,all
>I will need to get out my Railroader Geek Glossary again,<
Flapper I think we need one here,......
> or you can explain to me what "Titans" are and why they give you a big grin. <
Titan is a German firm that made wonderful model railroad transformers.They were(in the 1990's) more powerful and cheaper that the 6001 Märklin's.
Plus they had a secondary winding at 14V for accessories.Thus you could power a CU/booster and use it for lighting.
Dr D
Offline BrandonVA
#12 Posted : 12 June 2012 19:26:44(UTC)
BrandonVA
Mark,
I did the same initially, running digital locomotives on blue trafos. although I noticed that my digital locs did not always take a reverse command from the blue transforms. The difference is absolutely in how the voltage is applied and where it is going. If you're using a digital controller (Mobil Station, Central station, etc), reverse commands are sent via the digital communication protocol in use. Running trains in analog mode (even if they are digital running in analog mode), when you reverse a full voltage spike is sent through the track. With the blue transfomers can send more than 20 volts in one of these spikes, which could be too much for the decoder to handle. Especially if reverse were held down. The white ones only send 16v if I remember correctly, which is within the "safe" limit for the decoder.
Newer locs with decoders behave like the older electronic reverse units in a sense, they don't have the mechanical mechanism with the moving "teeth" to engage reverse, so there is no jolt. Also, most 33xx and 35xx locs have older electronic units which will not jump. It's the mechnical movement in the original reverse units that causes the "jump". I have noticed a well tuned loco will not jump too much though ;)
Tom is also right, while it had never occurred to me, if there is a short the white units do power off pretty much instantly. It happens occasionally.
-Brandon
#13 Posted : 12 June 2012 19:38:02(UTC)
Suppose the transformer was made for 220 V input voltage, 16 V output voltage and 30 VA.
With an input voltage of exactly 220 V and a load of exactly 30 VA you should get exactly 16 V output voltage.
Higher input voltage (230 V instead of 220 V - or 120 V instead of 110 V for America) gives higher output voltage.
Smaller load than 30 VA gives higher output voltage.
Reversing voltage is a different matter: I presume they gave the transformers a few extra volts to prevent locos from leaping even if there are not enough feeder wires. I get 30 V reversing voltage from a blue transformer, but only 25 V from the grey ones. For the decoder this makes a difference of 7 V due to rectifying inside the decoder.
With my blue transformers, the light voltage is only 1 or 2 V higher than with the grey ones. A voltage of 5 % more reduces the lifetime of light bulbs by 50 %, other consumers will also suffer reduced longevity.
So in the long run you may waste money using blue transformers instead of grey ones.
OTOH you can connect lights to brown and red and set the throttle to about 75 %. Light bulbs last longer if voltage is lower than their specification.
Offline BrandonVA
#14 Posted : 12 June 2012 20:55:15(UTC)
BrandonVA
Thanks for the correct numbers Tom.
#15 Posted : 12 June 2012 21:30:15(UTC)
Markus Schild
Markus
So Markus,
not to be misunderstood: I love these old transformers, and I like the push-botton-reversing. So they are worth to be checked. But they even must be checked if they still have their first cord.
Markus
Offline kariosls37
#16 Posted : 13 June 2012 01:04:32(UTC)
kariosls37
I'm no electrical engineer, but isn't the output voltage determined by the windings, not the power it is putting through? Although I guess due to the nature of such things there will be some variation due to minor losses.
In simple terms, All of the Marklin transformers have more or less the same nominal output voltage. The VA value is in essence how much power the transformer has(In fact, VA is electrical power and is equal to Watts. The diffrence is that a transformer does not use the power, hence the reason VA or VoltAmps is used).
By increasing the current(Amps) a transformer can handle for a given output voltage, you increase the power, and therefore the number of lights/locos/accesories you can power.
The simple answer is DON'T. You will damage decoders and/or controllers.
If you want to add extra power to a layout, you need to add boosters. The voltage that an analogue transformer will send to the track is completely diffrent to the voltage that a digital controller sends to the tracks. The two simply won't mix. However, if you are not running many locos at a time, the power supply from the controller will be plenty.
Rick
Offline Kevin Weis
#17 Posted : 13 June 2012 01:51:44(UTC)
Kevin Weis
Beware, they 9older blue transformers) usually have very deteriorated insulation on the wires on the inside. Every blue one that I've gotten I have had to re-wire the inside. The insulation will usually fall apart in your hand when you touch it. Fortunately they are easy to re-wire. Otherwise as per previous posts.
Regards, Kevin
thanks 1 user liked this useful post by Kevin Weis
#18 Posted : 13 June 2012 10:33:54(UTC)
That applies to the ideal (hypothetical) transformer with no internal impedance.
Real transformers have an impedance, so the windings in the transformer lose voltage (voltage drop proportional to the current).
So if you get 16 V at 2 A, you might get 18 V at 0.02 A (single LED or small light bulb connected).
If you get 16 V at 2 A and 220 V input voltage, you will get 16.7 V at 230 V and 2 A - or 18.75 V with 230 V and very small load.
Offline kariosls37
#19 Posted : 13 June 2012 12:30:38(UTC)
kariosls37
Very interesting Tom, I never thought of that. It makes complete sense though.
Rick
Offline Mark5
#20 Posted : 13 June 2012 19:16:20(UTC)
Mark5
Regards, Kevin
Thanks for that comment Kevin,
While I am no electrician, I do understand basic wiring and I'm rather able in getting things done with my hands.
Could you give me a brief step-by-step of how to rewire the blue meanies.
Thanks for the warning Rick.
I'm convinced now. I won't be using my blue meanies in a mix with the digital transformers.
But I will need to use them for analog and lighting at this point, so I would like to get them into shape with a complete check and overhaul.
I think I will buying the newer models if I need another, or a replacement.
Anyone have an idea of what newer analog transformers should go for on ebay?
- Mark
PS - Slightly OT: I've been wondering were I can get a cheap/decent amp and voltmeter.
We had a classic beauty when I was a kid.
(Should ask my brother what happened to it 30 years later.)
Offline vtdochop
#21 Posted : 01 July 2012 14:04:39(UTC)
vtdochop
Mark et al,
I use the old transformers on a seperate circuit to run all the accessories on my digital setup. I too had to rewire the inside as the insulation was falling apart. Nice to see the old Blues working again...reminds me of my childhood setup.
Peter BigGrin
Offline Chris6382chris
#22 Posted : 01 July 2012 16:15:39(UTC)
Chris6382chris
I have two blue transformers, one 18v and one 30v both made for American outlets and I use them both to power the lights and my cranes. I love the hum they make when they are on. But I do keep them separate from my trains.
Chris
Offline Mark5
#23 Posted : 27 September 2012 22:08:26(UTC)
Mark5
Just for the record, some time ago I was running a fav. digital locomotive, a grey Franco-Crosti insider model 39160, and I was using a Blue Transformer.
The track was short circuited with a derailment I think and seems to have fried the decoder.
Some of us thick skulls have to learn the hard way I guess.
OT: Can anyone suggest a decoder with sound that would be an appropriate replacement?
Here is a photo of the same locomotive that Davy posted earlier:
http://desmond.imageshac...0074.jpg&res=landing
Any ideas? I have never purchased a chip/decoder to replace before. But I do have soldering skills, its just been years since I used them.
- Mark
Edited by user 28 September 2012 04:21:06(UTC)  | Reason: (number corrected in edit)
#24 Posted : 27 September 2012 22:29:53(UTC)
The only decoders I know that came with built-in driver electronics for the big C Sine motor are the ones from Märklin with mouse piano.
They made three locos with big C Sine and mfx decoder (driver electronics on a separate PCB), but you can't get that from M* as a spare part.
I'm sorry, but I cannot think of a simple solution (neither with nor without sound).
Maybe you can find a Franco Crosti loco on eBay that has been dropped, but where the decoder is still intact.
Offline franciscohg
#25 Posted : 27 September 2012 23:01:47(UTC)
franciscohg
Chile
hi, i dont know if there is another grey br42 franco crosti other than 39160, but i have found this video on you tube
it shows one with sound and mfx
perhaps you could ask the guy who uploaded it how he has done the conversion
#26 Posted : 27 September 2012 23:33:08(UTC)
SB Modellbau (click me) seem to make conversions to Maxxon motors for this loco: 102.50 € for motor and gear, 105 € for the installation.
Offline franciscohg
#27 Posted : 28 September 2012 01:15:28(UTC)
franciscohg
Chile
nice page Tom.....although a little expensive, it seems to be a great upgrade for locos, perhaps i will give it a try later for some old loco without a motor upgrade yet.
#28 Posted : 28 September 2012 02:08:04(UTC)
Just for the record, some time ago I was running a fav. digital locomotive, a grey Franco-Crosti insider model, and using a Blue Transformer.
I don't have the box here, but I think its the 39161
Any ideas. I have never purchased a chip/decoder to replace before. But I do have soldering skills, its just been years since I used them.
- Mark
Have you contacted service(at)maerklin.de or one of the authorized service centres (Germany)? It is possible that they do not have any spare parts for the decoder, but may have some of the part available for repairs.
Offline baggio
#29 Posted : 28 September 2012 03:26:33(UTC)
baggio
I have gone back to playing with Marklin trains after a 44-year absence. That is a fact.
A couple of weeks ago I got a very nice-looking metal blue transformer, the same (almost) as the one my father and I used to play with 44 years ago. I loved it, just for the nostalgia.
HOWEVER, it got overheated to the point of becoming almost hot after keeping it on (plugged in, not necessarily using it) for about 90 minutes.
I returned it to the store and got another blue transformer, lighter blue, made of plastic, but Ontario Hydro-certified.
Works just fine, no overheating.
The store owner told me he will not even bother to fix the old one (I might have been willing to exchange it for the present one).
Since I do not wish to have to use/buy a fire extinguisher when I play with the trains, I will hang on to this one.
I use strictly nostalgia vintage trains, M tracks, of course.
Hope this helps a bit.
Offline Mark5
#30 Posted : 28 September 2012 03:42:50(UTC)
Mark5
Thanks Francisco and Tom, that's important info, however, I can see I will have to do a bit of extra looking for this.
Ebay is not a bad idea, but chances of the decoder being in good shape on a dropped engine might be slim.
I guess I was hoping for something new with sound, is there no way decoders can be adapted without a complete conversion?
Thanks Mike, I should do that.
This be my first time contacting service(at)maerklin.de and my German is rather weak.
It can't hurt to try of course, but do they usually require to have the loco sent to them for repair, or will they also send a part like a decoder to replace?
- Mark
Offline Mark5
#31 Posted : 28 September 2012 04:19:37(UTC)
Mark5
Thanks again Francisco. Left a message/comment under the video.
Offline mvd71
#32 Posted : 28 September 2012 07:14:02(UTC)
Can I suggest you try contacting Dion at toottoot
He is a skilled electronics engineer and a Marklin dealer, and may be able to offer some good advise.
Cheers.....
Mike.
Offline TheVoid
#33 Posted : 18 December 2012 21:24:02(UTC)
TheVoid
You have been a member since:: 16/12/2012(UTC)
Does anyone know where I can find a good guide to rewire a 280 and some 6xxx?
My father owns several of those and after reading this thread I will have to rewire those.
Void
#34 Posted : 19 December 2012 19:42:31(UTC)
I had not noticed any problems on the inside of the transformer. I did, however, notice that the mains cable was frayed on a few of them, and on others, when inspected, the insulation on the individual cables inside the mains cable was deteriorated to a point where a short was possible. The reason that the push to reverse design was replaced by the turn past zero design was that in some instances, where the reverse mechanism spring was not tight enough, locomotives would shoot down the track at extra high speed instead of reversing. The newer design required the train to be stopped in order for it to change directions.
The nice thing about the older transformers is that they could be opened, by manipulating the little fold over tongues that held the cover to the base unit. The newer plastic models, both in blue and in white are not designed to be opened and require more careful work to open and may be even more complicated to reseal once they have been opened.
As there is presently no Maerklin dealer in Montreal, you will have a hard time getting any assistance here. The nearest dealers are in Toronto (Westend Trains or John's Photo) or in Intervale NH or NY/NJ.
If you still need transformers, I would suggest that you look around (ebay and dealers) to see if any dealers have specials on the newer white transformers from Start Sets.
Offline Mark5
#35 Posted : 20 December 2012 06:56:36(UTC)
Mark5
Thanks Mike,
I have been in touch with the other Mike at Westend Trains, ordered a few things and have found his service excellent.
Now I have a quite a collection of transformers including 4 white 6646 along with a stack of old blue ones which I hope to go over and change any frayed cables myself.
Have yet to open one...
Thanks for the explanation on the push-type reversal mechanism as opposed to the past-zero type.
I had always wondered why. Now I see it makes perfect sense.
- Mark
Offline Mark5
#36 Posted : 20 December 2012 07:11:40(UTC)
Mark5
For repairs and troubleshooting trafos, I found these two previous topics that contribute to discussion.
https://www.marklin-user...Transformer-repairs.aspx
https://www.marklin-user...ooting-Transformers.aspx
Offline TheVoid
#37 Posted : 20 December 2012 15:38:47(UTC)
TheVoid
Thank you for the links Mark.
My father has 2 or 3 Supers and other blues. But I don't know the numbers of those.
I already bought 2MM multistrand copper cable and some PC power supply cables.
A silly question, do super and other blue transformers have a ground connection?
Offline Mark5
#38 Posted : 21 December 2012 09:34:38(UTC)
Mark5
Tem ter uma terra, claro... Smile no accents on my keyboard so I get lazy.
I have yet to see a transformer without ground.... or do you mean a ground to the wall plug?
If so, no, no ground on my cables.
Mark
ps Morei em Portugal para 12 anos.
Offline TheVoid
#39 Posted : 21 December 2012 13:24:29(UTC)
TheVoid
Mark
I ment ground as connection to the earth :)
I'll just connect the ground cable to the metal in the box.
That should work.
Portugal is a great place to live :)
Why did you leave?
thanks 1 user liked this useful post by TheVoid
Offline MarkAF
#40 Posted : 05 March 2014 20:22:14(UTC)
MarkAF
Uh oh. I have been using the old blue transformers with my digital locos for some time. I don't have many and I never considered my layout to big enough to warrant switching over, and as far as sound is concerned I figured with everything running you wouldn't hear it anyway - plus the price. Anyway, if the decoder "fries" is there a way one can tell if you don't run digital?Confused
#41 Posted : 05 March 2014 20:30:07(UTC)
If the decoder fries the loco won't run at all. Sometimes it's possible that one or other of the output transistors on the decoder might have blown. In this case it might be that the loco will run in one direction but not the other. This happened to me on a loco with a 6090 decoder. I replaced it with a 60902 and it works fine since.
Offline BrandonVA
#42 Posted : 05 March 2014 20:32:20(UTC)
BrandonVA
It could be that your blue transformers don't output the reverse pulse on the higher end of the range...could be tested with a voltmeter. I will get in trouble for saying this, but IMO if it isn't broken, don't fix it ;)
-Brandon
#43 Posted : 06 March 2014 06:53:11(UTC)
In some countries, New Zealand for example, older transformers were supplied as 220v versions, as that was the mains voltage in Germany at the time. Using those transformers here, with our higher mains voltage of 240v meant that the output voltage from the transformer was higher.
I don't know the situation for US supplied transformers, whether there are some specified for 110v (or lower than 120v) but be aware of this and check the rating on the transformer before you use them.
I have a couple of blue 40va lighting transformers from the 1980's which are rated for 220v. They work OK, but will give a higher output voltage.
#44 Posted : 06 March 2014 07:00:59(UTC)
- Mark
Not with the digital system and digital locomotivs in analog power.
#45 Posted : 06 March 2014 10:24:32(UTC)
Decoder danger aside, it might be a good time to review this article and check your own units...
https://www.marklin-user...r-Danger.aspx#post389037
Offline MarkAF
#46 Posted : 06 March 2014 17:11:16(UTC)
MarkAF
Thanks for the warning. I have the newer, plastic bodied 6627 and 6667 Trafos. How do they hold up internally?
thanks 1 user liked this useful post by MarkAF
Offline kbvrod
#47 Posted : 06 March 2014 18:27:34(UTC)
kbvrod
Not with the digital system and digital locomotives in analog power.
More nonsense. I updated my IB via the internet with an old blue and broke in many a digital lok with the same!Or from starter set from transformer 1968.
The point is one needs to check if any deterioration has happened to the cord/connections or interior components.
Dr D
Offline BrandonVA
#48 Posted : 06 March 2014 18:28:14(UTC)
BrandonVA
Mark,
I don't think these units have the same issue from what I've read. It's mostly the blue units that pre-date this style that are impacted. I used 6627 with digial loks for a time with no impact, but I have switched over to 6646 for loco control (the blue ones still do accessories and analog carpetbahns).
-Brandon
#49 Posted : 07 March 2014 02:38:20(UTC)
If the mains-flex is PVC then you should be fine, the cords I'm referring to are the older rubber type, used on metal case trafos from the 50's. But even PVC may prove to have a finite life span, only time will tell.
For now I would say that plastic case trafos should be ok.
Guest (4)
This page was generated in 1.160 seconds.
