Offline Alexander Juttner
#1 Posted : 10 August 2012 07:17:55(UTC)
Alexander Juttner
My first post.....I have collected Marklin now for about 9 years (second childhood) circa 1935-1950's is my focus. I just bought this 3015 and have it apart because she ran rough and heated up but can't find any issues looks pretty clean (version 10). Any suggestions Thanks Alex
Offline Markus Schild
#2 Posted : 10 August 2012 08:44:05(UTC)
Markus Schild
Hi Alex,
Welcome to the forum.
How did you lubricate the loco? The crocodiles run much smoother when the helical gears are threaten with grease instead of oil. I use TRIX-grease which is nowadays also suggested by Märklin for its worm-gears.
Markus
#3 Posted : 10 August 2012 09:42:22(UTC)
Hi Alex,
The 3015 is different to find, Very collector items.
Also Welcome to the forum.
Offline kweekalot
#4 Posted : 10 August 2012 10:00:21(UTC)
kweekalot
Hi Alex,
Welcome !!
Marco
#5 Posted : 10 August 2012 11:41:27(UTC)
Alex,
Welcome to the forum,
another problem could be the armature is faulty..
Offline Ian555
#6 Posted : 10 August 2012 12:22:32(UTC)
Ian555
Hi Alex,
Welcome to the forum. ThumpUp
Ian.
Offline Chris6382chris
#7 Posted : 10 August 2012 16:40:32(UTC)
Chris6382chris
Alexander, welcome to the forum. What part of CA?
Chris
Offline Renato
#8 Posted : 10 August 2012 18:35:19(UTC)
Renato
Welcome to the forum, Alexander.
Renato
#9 Posted : 11 August 2012 23:31:20(UTC)
Alexander Juttner
Thanks for all the welcomes.....Great to see fellow Marklin enthusiests. I used oil for the worm gears and will try grease if I can't find the problem, I think the armiture is good. I sold one a couple of years ago and it ran perfect but I always enjoy the challenge to fiddle with these gems. Thanks again everyone!
Alex
#10 Posted : 11 August 2012 23:35:05(UTC)
Alexander Juttner
Chris
Hi Chris-We live in the city of Riverside/LA area....Alex
Offline CCS800KrokHunter3
#11 Posted : 12 August 2012 01:02:15(UTC)
CCS800KrokHunter3
Hi Alexander,
Good to see you joined the forum...sorry can't help you with the 3015...do you have photos of it taken apart?
Heating up usually means either the motor is doing too much work because wheels or gears are rubbing or there is a small electrical short that causes heat.
Best,
Paul
#12 Posted : 12 August 2012 07:58:14(UTC)
Alexander Juttner
Originally Posted by: CCS800KrokHunter3 Go to Quoted Post
Hi Alexander,
Best,
Paul
Hi Paul,
I took her all apart cleaned and just finished with the re-assembly and she runs great.....There was a short from one of the light wires. Great forum I plan to check in often, great to get all the comments. Thanks Alexander
#13 Posted : 12 August 2012 10:40:25(UTC)
There is always a right answer to any question to this forum.BigGrin
Marklin 3015 version 11 (H0-scale)
by MALAVIKA 20/03/2025 08:31:44(UTC)
MARKLIN 3015 CROCODILE CONVERSION TO DIGITAL (Digital)
by lvfocus 20/11/2021 04:59:46(UTC)
Marklin 3015 1963 (H0-scale)
by Amcebee 10/10/2016 15:59:34(UTC)
Marklin 3015 Restoration Project (Collector's Corner general)
by johnmarklin 17/01/2015 19:27:01(UTC)
Marklin 30159 conversion to digital (H0-scale)
by eduard71 26/07/2008 06:37:05(UTC)
This page was generated in 0.495 seconds.
