Offline Rinus
#1 Posted : 26 May 2012 15:08:20(UTC)
Rinus
I'm in doubt whether to go for the Märklin, Roco or Fleischmann versions of the Rollende Landstrasse (Rola) waggons.
I'd preffer FS or ÖBB versions, which are/were sold by Roco and Fleischmann. As far as I know Marklin concentrates on SBB and DB versions.
My fear is that when going for the Roco or Fleischman versions, the wheelsets will give trouble, being prepared for DC track. I contacted Roco but their answer was very vague.
Does anyone has experience with this paticular type? Is there any difference between the Märklin, Roco or Fleischmann versions And are there AC axles to be bought for the Roco and Fleischmann versions?
Help is appreciated!
Rinus
Offline petestra
#2 Posted : 26 May 2012 15:15:28(UTC)
Hi Rinus, I am so glad I bought the Maerklin 28531 set back in 2000. The BR 184 runs great with the 5
cars 3x DB 1x SBB and 1x OBB and their trucks. My layout is C and M track and I have never had a problem
with derailments with this train. Sometimes I have my 37240 FS E424 pull it as the train originates in
Brennero, Italy. Good luck with your choice, PeterSmile
#3 Posted : 26 May 2012 20:54:15(UTC)
I have a few OBB ones from Maerklin. The number was 479X (think it was 4797). It came in a set of two cars. I am mainly using the SBB Hupac ones.
I was trying to see if these cars can be combined in consists. It seems to me that you would find only Hupac cars in a Hupac train and similarly DB ones in German operated trains and so on.
Can these cars be found in mixed consists? Maybe on the Kufstein/Brenner route between Munich and Bolzano?
If you are just getting into it now, the new RAlpin set from Maerklin will be out later this year. RAlpin in the new joint venture between Hupac and BLS Cargo that will operate between Germany and Italy via the Loetschberg base tunnel and Simplon. The RAlpin driver coach is available from Liliput and will likely also be available from LSM (old version) and ACME (new version ex Eurofima Bcm?)
Offline Rinus
#4 Posted : 27 May 2012 14:31:34(UTC)
Rinus
Hi guys!
Thanks for your replies! and thanks for the email Jeremy!
the consist I had in mind is:
[Marklin 37308 - Rh1012-002] - [Marklin 37309 - Rh1012-003] - [LS Models 47071 - WLABmz] - 8-10 X [Roco/Marklin Rola - Saadkms]
Like you say, Mike, I can't go with the Hupac ones, since I want to express the Brennerline trains. Your sugestion about a DB train though is intresting!
Then I could go for the 47415 set and buy two more.
Can you tell me more about the details of the Marklin items?
Rinus
thanks 1 user liked this useful post by Rinus
Offline supermoee
#5 Posted : 27 May 2012 21:51:19(UTC)
supermoee
Views messages in topic : 534
Hello Mike,
new?? RAlpin is existing since 2001 and is the joint venture between Hupac, BLS Cargo and SBB Cargo. On a little part FS were involved too, but in a very marginal way.
They are operating mainly between Freiburg and Novara, but have the line Basel - Lugano through the Gotthard route too.
The new coaches are the old Eurofima Bcm61. They got 20 of them.
rgds
Stephan
#6 Posted : 28 May 2012 14:57:32(UTC)
Interesting topic!
Rola is a staple of the traffic on the Gotthard line (my layout's theme) , albeit at a reduced pace these days, as I think most of the traffic is going the Lötschberg route these days.
On my layout I run a prototypical 16 cars + WL , all of SSB/ grey HUPAC cars.
I use an MU of two or three Märklin CARGO RE 482 or BLS RE 485 or BLS 185.5.
And here is a plaidoyer for these *really inexpensive* models from Märklin that are truly ideal for this type of use.
All it takes is programming the same values in the CV.
I use 50 for max speed and 3 for accel/decel. The loks are under ECOS2 control, using the multiple unit feature;
It works so well that I don't hesitate to put the third lok at the back of the train, as a helper (I know it is not a common occurence on a RoLa train, but since it is one of the "delicate" long trains to operate on a layout with spirals, I figured: "if it works with this one, the rest will be easy"
No strain on the couplers, all works smoothly;
And yes, my 32 cars container trains runs the same way, with a pusher lok at the end!
I can sit for hours, just looking at these making their rounds!!Love Wub
Super spectacular trains...whether in models or reality!RollEyes
Edited by user 01 June 2012 22:30:47(UTC)  | Reason: Not specified
Offline Rinus
#7 Posted : 30 May 2012 07:56:08(UTC)
Rinus
Any chance of a picture Jacques? 16 cars is very impressive! Razz
#8 Posted : 01 June 2012 22:05:50(UTC)
Hi Rinus
How about a little video?
Hope you liked it!
Offline Jeremy Palmer
#9 Posted : 01 June 2012 22:07:43(UTC)
Jeremy Palmer
Barbados
Thanks Dr. J., Liked it alot I am sorry to sayBigGrin BigGrin ,
Jeremy.
Jeremy.
Offline tiono
#10 Posted : 02 June 2012 01:15:12(UTC)
tiono
From the photographs and videos of the prototype which I had ever seen, seems as there are two distinctive features of the Rola consist:
1. The WL wagon always have the word "HUPAC" (or "RALPIN" on Ralpin consist), silver colored livery. And pulled right behind the locomotive.
2. The last Rola car (end-car) always carry truck, even if the number of trucks were less than the number of Rola cars. The empty Rola cars always sit in the middle, never at the end of the consist. (Except if all cars were empty)
example photo: http://www.flickr.com/photos/gerbenztmsfotos/4395553828/sizes/l/in/photostream/
http://www.flickr.com/photos/bb436352_newaccount/6931294395/sizes/l/in/photostream/
#11 Posted : 02 June 2012 06:27:19(UTC)
OOOps!BigGrin BigGrin
At least the color of the WL did not influence the good running.RollEyes Wink
In the early days of RolA, the locos were Ae 6/6, and the WL was actually an un-re-painted red ex-DB U type....and the cars were absolutely spotless, like "factory new".
So in fact there is nothing wrong with this model train as it reflects actually that original RoLa situation, except that the locos are the wrong ones Laugh Laugh Laugh Drool
Thank you for keeping me "honest"Crying BigGrin
Offline tiono
#12 Posted : 02 June 2012 08:23:18(UTC)
tiono
hi Jacques,
I have never seen a Rola prototype myself, therefore my observation was based on the photographs and videos. And I came to those two conclusions because I have never seen any photographs showing a Rola consist using WL wagon's original livery.
But I believe what you're saying.
during the beginning, probably they were using original's livery while waiting for the repainting schedule.
But the last Rola car always carry truck. I remember somebody else had explained the reason behind this in other train forum.
#13 Posted : 02 June 2012 09:16:03(UTC)
Hi Tiono
I know you are right about "the last car"...I was just too lazy Blushing to move the truck: the last car was added later to the train!
I have somewhere pictures of early Rolas with Ae 6/6s and a red WL, as soon as I dig them out, I'll bring these here.
Offline Ian555
#14 Posted : 02 June 2012 09:46:33(UTC)
Ian555
Hi Jacques,
Enjoyed watching the video. ThumpUp
Ian.
Offline Rinus
#15 Posted : 02 June 2012 10:28:19(UTC)
Rinus
Hi Jacques!
Great video! Whats the lenght of that amazing train? Must be over 3 meters!
Rinus
Offline Marius in Africa
#16 Posted : 02 June 2012 15:50:11(UTC)
Marius in Africa
Hi Jacques
Never forget, it does not have to be real, it YOUR OWN imaginary world!!BigGrin It can be what ever you want it to be!
Your video reaffirmed my quest to have my own Rollende Landstrasse. I did consider starting with the 2012 Marklin offering of the RAlphin AG Olten Switzerland (47416). I did ask for opinions on this forum regarding "quality" of the truck / trailer models and got varied responses on this forum. What is your opinion, are they really that "crappie"?
Marius in Africa
#17 Posted : 02 June 2012 16:41:06(UTC)
Jeremy Palmer
Barbados
Fitting in with my "little bit of everything" empire (BUT I am sure well short of "everything") I have 3 Rolling Road sets.
The Marklin Mercedes Actros set M # 26520, the Marklin Fulda set M # 26523 and the Marklin Santa Claus set M # 26528. The Santa Claus set might be the most
realistic as it has a coach. (With Santas in it). I have the Santa set here so took the photo below of the coach. Thanks to the magic of this forum, I know now why
there are 4 Santas in the coach - 4 trucks = 4 Santa Drivers and the coach must be for the truck drivers. I know I know - I am a bit duhhhhhhh but thanks to Rinus,
Jacques and many others I will get there in the end.
Edit.. @ Marius, the model trucks are what they are, however the transfers/decals are very well done.j.
Jeremy.
Offline petestra
#18 Posted : 02 June 2012 16:47:22(UTC)
Very nice Christmas coach! And since the truck drivers are in the coach and not on the roads there will
be less traffic driving thru the Alps and therefore more happy faces. PeterLove
#19 Posted : 02 June 2012 22:47:49(UTC)
Hi Marius,
They have been doing their rounds for 6 weeks now on my layout, not a derailment., not a trouble.
Run smoothly.
Don't know what's "crappy" about these??
The Marklin ones are really very good, solid, all metal.
I love them.
#20 Posted : 03 June 2012 07:42:57(UTC)
Marius in Africa
Hi Marius,
Run smoothly.
I love them.
Hi Jacques
Thanks for the feedback. I was asking about the "load" on top the railcars (the road trucks), not the rail cars them selves. Are the "load vehicles" of acceptable detail & quality? These are obviously supplied to Marklin by an outside supplier for example Busch or Herpa, etc. Do you know who the Marklin are using as a supplier?
Marius in Africa
#21 Posted : 03 June 2012 10:05:16(UTC)
Hi Marius!
Oh! that's an easy one!
The only one I got together with the truck is the one with the "Möbel Pfister" truck, which was made by Viking.
All other RoLa cars were bought "unloaded" in sets of two or in singles.
The trucks were purchased separately through the years (mainly Herpa) with some even undergoing superdetailing.
Nothing really fancy though: license plates, rear view mirrors, as available from Herpa.
And I still have room for six more...BigGrin
Offline Rinus
#22 Posted : 04 June 2012 07:32:50(UTC)
Rinus
There is a nice sales action now at Ranier. I might buy these two. Free axle change to AC axles.
LINK
Rinus
Edited by user 04 June 2012 12:05:21(UTC)  | Reason: Type error
#23 Posted : 04 June 2012 11:19:54(UTC)
There is a nice sales action now at Ranier. I might but those two. Free axle change to AC axles.
LINK
Rinus
Rinus, do you mean Rainer/Innsbruck/Austria ?
Offline Rinus
#24 Posted : 04 June 2012 12:04:43(UTC)
Rinus
Yess, thats what I ment. I allways misstype Rainer! Blushing
#25 Posted : 04 June 2012 20:17:40(UTC)
LSM has just announced some new models of the SNCF Modalohr type Rola trains www.lsmodels.com
Regarding the 47416, the set comes with trucks that have more the quality of Hot Wheels than of the better Herpa/AWM/etc models.
The only other issue that I have with the RAlpin set is that the trucks are Swiss and a Germany to Italy ROLA would normally have more German and Italian trucks
#26 Posted : 06 June 2012 18:20:19(UTC)
Marius in Africa
Hi guys
Placed an order for my first items, Marklin number 4740 & 4741. BigGrin I assume the “rollende strasse” cars have their own road numbers, like the other rolling stock. So ordering more than one unit of each part number e.g. 2 x no. 4741 makes no sense, correct?
Marius in Africa
#27 Posted : 07 June 2012 21:36:23(UTC)
Jeremy Palmer
Barbados
Here are the 4 trucks from my Christmas Rolling Road set and the elok.
Jeremy.
thanks 1 user liked this useful post by Jeremy Palmer
#28 Posted : 08 June 2012 05:40:42(UTC)
Marius in Africa
Hi Guys
Are the couplings between the intermediate cars as used by Marklin & Roco compatible with each other?
Marius
Marius in Africa
Offline Rinus
#29 Posted : 11 June 2012 08:16:54(UTC)
Rinus
Hi Marius,
The Marklin short coupler is compatible with the Roco universal and standard coupler. Only the Roco short couplers are not compatible.
Rinus
#30 Posted : 11 June 2012 21:48:02(UTC)
I don't think that the intermediate couplers on Rola cars from Roco, Fleischmann, Maerklin (Trix), LSM and others are compatible with each other. You will have to decide on one manufacturer for the whole consist (other than the Couchette coach).
It may also be important to remember that these "Rola" cars have very small wheels are are very low to the ground and this may cause problems, especially on layouts with older M Track due to contact with the middle rail and on switch tracks.
#31 Posted : 12 June 2012 19:18:40(UTC)
Marius in Africa
Thank you for your response Mike. I have also asked Andreas at Lokshop to check whether the Roco and Marklin intermediate couplings are compatible. For now i have only ordered Marklin "Rola" cars and have decided to stick to the DB cars. If i get a positive answer from Andreas i will order two Roco intermediate cars from Lokshop as well. If not it will take a while longer to collect a decent size consist. This is not a "one day" hobby after all.
Marius
Marius in Africa
This page was generated in 0.816 seconds.
