Offline Dgriman
#1 Posted : 17 March 2012 01:59:04(UTC)
Dgriman
I decide to convert my old and already converted once BR38 from AC 3 pole motor, to a new DC 5 pole motor and mLd
Before the 2nd convertion
Mar-3098 (BR38)-4091 by dgriman, on Flickr
the new motor in place
Mar-3098 (BR38)-4104 by dgriman, on Flickr
tests with mLd soldered with motor
Mar-3098 (BR38)-4106 by dgriman, on Flickr
the old plastic for lights ready to removed
Mar-3098 (BR38)-4114 by dgriman, on Flickr
I create a board with 3 leds of 3mm, that fit exactly at the same place of the plastic
Mar-3098 (BR38)-4120 by dgriman, on Flickr
the board in position and soldered
Mar-3098 (BR38)-4131 by dgriman, on Flickr
the locomotive running very smooth and you can see the new lights
Mar-3098 (BR38)-4122 by dgriman, on Flickr
My web directory for Model RailRoading (Greek and English Language)
http://trains.dgservices.gr
My Photo Album
http://www.flickr.com/photos/dgriman/
My Video Channel
Trainsmodeler Video Channel
Thank you for visiting
Dimitris
thanks 2 users liked this useful post by Dgriman
Offline Johnvr
#2 Posted : 17 March 2012 07:54:03(UTC)
Johnvr
Dimitrios,
Thank you for showing the nice and detailed pictures of your conversion.
Regards,BigGrin
#3 Posted : 17 March 2012 08:46:28(UTC)
Hi Dimitrios,
Did you have any problem with the new brush plate touching the inside of the boiler? I remember someone else doing this conversion and having to file a bit off the end motor bearing on the brush plate to allow the body of the loco to fit back on.
Also, I find the back of the loco is a bit too light after the conversion. I have added a bit of weight at the back, where the old reversing relay used to be.
#4 Posted : 17 March 2012 09:10:43(UTC)
Excellent work, Dimitrios.
Offline Dgriman
#5 Posted : 17 March 2012 14:42:52(UTC)
Dgriman
Thank you all for your comments. Cool
My Photo Album
My Video Channel
Dimitris
#6 Posted : 21 March 2012 23:02:56(UTC)
Very good, Dimitrios.
Thanks for showing us.
Offline Dgriman
#7 Posted : 22 March 2012 13:42:29(UTC)
Dgriman
Hi Dimitrios,
Hi Ray,
The new motor fit absolutely perfect in the position of the old one, there wasn't any problem at all.
I didn't see any problem for the moment with weight. This is the 3098 and not the 3099, at 3098 the body is metal and not plastic as at 3099, the weight of the loco is about 360gr .
Thank you for Asking. Smile
Dimitris
My Photo Album
My Video Channel
Dimitris
Offline Dgriman
#8 Posted : 22 March 2012 13:44:14(UTC)
Dgriman
You are welcome intruder.
My Photo Album
My Video Channel
Dimitris
#9 Posted : 22 March 2012 23:22:15(UTC)
My 3099 has a metal body, Dimitrios. As far as I know, all the Br38s based on the model introduced in 1967 have metal body.
The 1967 type was replaced by a new model in 2003.
The 1967 model:
The 2003 model:
Offline Dgriman
#10 Posted : 23 March 2012 01:23:47(UTC)
Dgriman
The 1967 model:
The 2003 model:
Dear Intruder,
I have no reason to disagree with you. My information comes from this page http://www.miol.it/stagniweb/maerk40.htm. After the middle of the page, you can find this article :
"3099, P8
1967 - 2002 = 36 years
The P8 is one of the most famous Prussian locos. The 3098 model was quite simple (especially in the wheelset area), but with a full metal construction.
In 1978 the new version 3099 turned from DB to DR (Era II), thus changing fairings and tender. Around 1990 it turned back to Era III, without changing article number.
In 2003 a new, digital, highly detailed, full metal version of P8 was introduced (also in the Italian version Gr. 675).
At the picture is the 3099 P8, which is exactly the same locomotive as mine one.
1967 - Marklin 3099
From this phrase, the conclusion I made, is that the 3099 wasn't full metal body
If the article is not accurate, I'm sorry for the misleading conclusions I made.
Dimitris
My Photo Album
My Video Channel
Dimitris
#11 Posted : 23 March 2012 10:51:47(UTC)
Hi Dimitrios,
The article is misleading. Both 3098 and 3099 are essentially the same model. All that varies are the smoke deflectors and type of tender.
I have the KPEV green version 34988 which is also based on the same metal body, and the Primex 3010, which is a simplified Marklin 3098.
Offline Dgriman
#12 Posted : 23 March 2012 11:11:55(UTC)
Dgriman
Hi Dimitrios,
Thank you Ray,
From my pictures above, can you say which loco is mine ? I have no informations about her, I have it since I was 6y/o, and after 41 years, I have nothing else except the loco, neither the tender.
Can somebody help me to identify her so I'll be able to order the right tender for her. I'll appreciate that.
Dimitris
My Photo Album
My Video Channel
Dimitris
Offline Western Pacific
#13 Posted : 23 March 2012 13:09:37(UTC)
Western Pacific
Originally Posted by: Dgriman Go to Quoted Post
Thank you Ray,
Dimitris
Is this the photo you are referring to?
In that case you should try to get hold of a "Wannentender" as it is called in German, because 38 1807 was the 3098. I have it, but not available to take a photo. However, both my own database and Helmut Kern ( http://www.hfkern.gmxhome.de/ )give 38 1807 as being the 3098. This picture (that you have posted earlier) shows the right tender: 3098 and this even if the Italian site gives it as 3099.
You should perhaps give this eBay.de item some thought: Wannentender.
#14 Posted : 23 March 2012 13:25:12(UTC)
Hi Dimitrios,
Thank you Ray,
Dimitris
Have a look here:
http://www.modellbahnboerse.org/3000-21.htm
This website, as well as Helmut Kern's are my Marklin "Bible"
http://www.bahn.hfkern.d...aerklin/Dt_Loks_D38.html
...and yes, I believe your loco is a 3098
Offline Dgriman
#15 Posted : 23 March 2012 13:30:26(UTC)
Dgriman
Thank you Ray,
Dimitris
Thank you very much for the help, I'll check it also from my dealers
Dimitris
My Photo Album
My Video Channel
Dimitris
#16 Posted : 23 March 2012 13:31:43(UTC)
As a matter of interest, my Primex 3010 is also 38 1807. The difference is that the Primex loco has simplified valve gear.
Primex 3010
Marklin 3098
Offline Dgriman
#17 Posted : 23 March 2012 14:29:19(UTC)
Dgriman
Thanks Ray,
From here, http://www.frankenbahn.de/primex/loks01E.htm, I assumed that mine is the M 3098, because I have it since 1972.
Thank you all, I'm already searching for the tender.
Dimitris
My Photo Album
My Video Channel
Dimitris
Offline Dgriman
#18 Posted : 23 March 2012 15:10:37(UTC)
Dgriman
Here she is
BR38 1807 - 8481 by dgriman, on Flickr
My Photo Album
My Video Channel
Dimitris
Guest (8)
This page was generated in 0.720 seconds.
