25 Pages«<45678>»
#251 Posted : 18 April 2007 23:12:13(UTC)
Nice photos, Palle.
Thank you!
#252 Posted : 18 April 2007 23:25:36(UTC)
<br />A delta triple f7 worths it?
Any F7 is. And converting to fully digital is a walk in the park ...
Offline alonso231gery
#253 Posted : 18 April 2007 23:42:59(UTC)
alonso231gery
After that convertion will i be able to use both motors?Is there an upgrade kit(mfx) for upgrading double motored locos?
One mfx decoder for two motors?
An outsider.
#254 Posted : 18 April 2007 23:51:53(UTC)
Ask Neville - he successfully did a 2-motor conversion, lately ... Cool
#255 Posted : 19 April 2007 00:01:36(UTC)
alonso231gery
I have not done even a single motor conversion[:o)]but i will ask him,thanks for the info.
I will experiment on my 3374 before touching a f7.
An outsider.
#256 Posted : 19 April 2007 00:07:24(UTC)
biggrin
#257 Posted : 19 April 2007 01:06:51(UTC)
<br />I have not done even a single motor conversion[:o)]but i will ask him,thanks for the info.
No problems at all, Ordered 2 5 Pole Rotors, 2 Magnets, 2 ENd Plates, One ESU MFX Decoder programmed to F7 Sounds.
ALso a DCC 8 pin socket. Put the Loco Wires to the Socket and plugged in hte Decoder and away it went.
It is so easy a blind man and a seeing eye dog could do it.
I will dig out the part numbers and send.
See here for the full story:
https://www.marklin-user...ault.aspx?g=posts&t=5646
Nev.
#258 Posted : 19 April 2007 02:35:56(UTC)
alonso231gery
Very enlightening topic Nev,i will read it carefully,thanks.
An outsider.
#259 Posted : 19 April 2007 06:56:06(UTC)
<br />Very enlightening topic Nev,i will read it carefully,thanks.
My Pleasure Sir. biggrinSmile
#260 Posted : 20 April 2007 00:13:40(UTC)
A question for you F7 folks:
On a tripple unit, is the pick-up shoe originally installed under a center section bogie?
#261 Posted : 20 April 2007 00:23:49(UTC)
Svein - under the front bogie of one of the A-units
#262 Posted : 20 April 2007 00:54:55(UTC)
Thanks, John.
I like to alter things, make things work after my own theories (maybe not always the best?)
Would it be, from a user's point of view, better to install the pick-up shoe as close to the center as possible (which means under a B-unit bogie), to have a close to equal stopping distance e.g. in front of signals, regardless of the travelling direction?
I presume that the unpowered A-unit bogie and the B-unit bogies are identical?
#263 Posted : 20 April 2007 01:19:35(UTC)
<br />I like to alter things, make things work after my own theories
Now we are two, Svein ... biggrin
And you're right - all unpowered bogies on A- and B-units are identical.
Thus you can easily mount that pick-up shoe wherever you prefer to ...
Just one of many points why I love those classic F7s. They are beautiful, super-sturdy,
and you can convert and extend 'em perfectly nice to your personal taste & needs [:p][:p][:p]
Sorry - have no idea about signals [:I]
Offline hmsfix
#264 Posted : 20 April 2007 17:12:43(UTC)
hmsfix
Yep, if you use these contact tracks with these small nipples at the center rail (e.g. # 2299, sorry, don't kno the respective # for C tracks), it's some advantage. Also when the train enters a semaphore control sections.
However, I have abandoned this type of contact tracks from my layout. Not reliable enough in the long run. Everything controled now by small magnets on the locos and reed relays on the tracks, and therefore independet of the position of the pick-up shoe.
That's what I am trying, too. BTW in my theoretical physics lessons many years ago I have been told that reality (such as it is) is only a very mediocrate implementation of physical laws, so it may be improved. I don't know whether this is generally true, but it certainly applies to a few mrr features such as pick-up shoes and contact tracks.biggrin
Hans Martin
#265 Posted : 20 April 2007 19:35:43(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by hmsfix
<br />in my theoretical physics lessons many years ago I have been told
that reality is only a very mediocrate implementation of physical laws
biggrin
#266 Posted : 20 April 2007 21:18:03(UTC)
Thanks for the information and for the physics lesson, John and Hans Martin.
Offline pserup
#267 Posted : 20 April 2007 21:32:10(UTC)
pserup
There's only one drawback w/ a mixed layout. You can buy 2-rail locos by the numbers, then [xx(]biggrin
Yes [:p][:p][:p]biggrin - like these FP7s
not exactly up to M's standards, but at a fraction of the cost of M's F7s in UP livery
#268 Posted : 20 April 2007 21:34:41(UTC)
alonso231gery
Actually it is quite accurate,but our finite perception requires several simplifications.
An outsider.
#269 Posted : 20 April 2007 22:03:54(UTC)
Very nice, Palle ... Smile
But you enter dangerous territory. AC vs. DC = number of locos available x 30 (at least) [}:)][}:)][}:)]
Offline ulf999
#270 Posted : 20 April 2007 22:17:51(UTC)
ulf999
<br />Very nice, Palle ... Smile
indeed, very tempting [:p][}:)]
#271 Posted : 20 April 2007 23:00:25(UTC)
My job is done ... biggrin
Offline pserup
#272 Posted : 21 April 2007 01:19:18(UTC)
pserup
So true John biggrin
Anyway, I will be careful not to stray to far off the beaten track in DC - both geografically speaking and MRR-wise. For the latter the plan is to limit myself to the Challenger, the Veranda Gas Turbine (may require a new mortgage wink), and a few other indispensible UP locos like a shunter and an E7 consist.
City-wise I'm always careful in DC and this time I will basically be confined to the hotel for the entire stay...
#273 Posted : 21 April 2007 01:32:41(UTC)
Most healthy decision, Palle [^] (surely your hotel got an excellent bar ...)
Woooow - The Veranda is a dream [:p][:p][:p]
Offline pserup
#274 Posted : 22 April 2007 02:37:01(UTC)
pserup
A well stocked bar I'm sure, and a company card to pick up the tab UserPostedImage
#275 Posted : 22 April 2007 10:21:25(UTC)
Very nice picture,pserup.
#276 Posted : 23 April 2007 14:33:32(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by pserup
<br />and a company card to pick up the tab UserPostedImage
biggrin
Offline pserup
#277 Posted : 02 June 2007 12:27:51(UTC)
pserup
got my hands on an F7 repaint job [:I] ...used to be a 3662 Blue/Silver Santa Fe ...
Offline hmsfix
#278 Posted : 02 June 2007 12:33:32(UTC)
hmsfix
Congratulations for this UP F7 repaint job [:p][:p][:p].
Details are evenbetter than on my original UP F7 ! And the road numbers are prototypical, too.
Hans Martin
#279 Posted : 02 June 2007 12:42:56(UTC)
Very nice, pserup.
#280 Posted : 02 June 2007 13:04:14(UTC)
WOW [:0][:0][:0] ... Coolness, Palle - your excellent livery beats M 40 miles by sunday CoolCoolCool
How many hours did you invest in that paint job confused
#281 Posted : 02 June 2007 13:19:55(UTC)
alonso231gery
Very nice livery Palle,excellent job,but its former livery was very good as well.
An outsider.
Offline pserup
#282 Posted : 02 June 2007 14:23:41(UTC)
pserup
John,
I wish I had the time, tools, and talent to do something like this myself, but alas no... [:I]
Found it on ebay for € 275,-, which is less than I payed for my Blue/Silver 3662 in a local shop Smile Seller did the airbrush work ...
I agree Nikos, I like the former livery very much as well ...
#283 Posted : 02 June 2007 17:00:36(UTC)
<br />Found it on ebay for € 275. Seller did the airbrush work ...
Palle, this wasn't a deal - this was a steal, congratulations biggrin
Well, those who do the resto job plus wanna sell rarely make the cash. I recall my very own most
extensive & highly detailed frame-off restoration on my old JEEP Mod.MB about thirty years back.
In the end I had to be lucky when getting back the money I had invested for the parts.
More than 200 hours of hard work down the drain. Never again, little idiot me ... [xx(][xx(][xx(]
Offline Caboose
#284 Posted : 02 June 2007 21:28:38(UTC)
Caboose
OHH! I have,nt seen that UP locomotive earlier. It's just graet[:p]. That painter must really be a proffesional. By the way - I have heard that in the 70's you could leave your worn Märklin-locomotive to your local dealer, and he would send it to the Märklin-factory for overhaul and repainting. Comes back almost like new. Anywhane know if that story is true?
Sweden & USA
Offline pserup
#285 Posted : 03 June 2007 17:48:16(UTC)
pserup
John, I think the seller got a cheap, mistreated 3662 and repainted it - and also sure he didn't get much for the hours he spent ... [xx(]
... doesn't stop me from enjoying it though biggrin
and for Nikos ...
#286 Posted : 03 June 2007 19:17:19(UTC)
alonso231gery
A lovely sight indeed Palle,thank you for your imageSmile,maybe the f7 that i like the most[:p].
Now i must find that loco and the funds to buy it[B)].
An outsider.
#287 Posted : 04 June 2007 01:38:52(UTC)
<br />A lovely sight indeed Palle,thank you for your imageSmile,maybe the f7 that i like the most[:p].
Same Here Nikos. Funds Funds and More Funds. biggrinbiggrin
To be companions to my Amtrak A-A
#288 Posted : 04 June 2007 14:07:20(UTC)
alonso231gery
But imagine having all the funs you want Nev,wouldn't you get boredbiggrin?
An outsider.
Offline pserup
#289 Posted : 04 June 2007 20:33:53(UTC)
pserup
Unlimited fun(d)s, hmmm...
Zillions of locomotives, cars, animations and acres of layout with miles of track...
... that is when you can drag yourself away from the babe in the swimming pool bar ...
bored? Not me [img]UserPostedImage[/img]
#290 Posted : 04 June 2007 21:53:41(UTC)
<br />drag yourself away from the babe in the swimming pool bar ...
Pah - don't even look at 'em. Only my lady rules ... CoolCoolCool
Offline pserup
#291 Posted : 04 June 2007 23:03:55(UTC)
pserup
ain't no rule saying it can't be your wife in the pool ... Cool
#292 Posted : 04 June 2007 23:09:57(UTC)
Coolness - you gotta bar in your pool confusedbiggrin[:p]
Offline pserup
#293 Posted : 05 June 2007 00:47:04(UTC)
pserup
I would have if I had unlimited funds [:p]biggrin
#294 Posted : 05 June 2007 01:58:26(UTC)
Not too much funds. biggrin Just enough to build a nice size train room and Maybe a few F7s and No-Habs. SmileSmile
And a Swimming Pool with a bar. Model trains doing table service biggrinbiggrinbiggrin
#295 Posted : 05 June 2007 02:00:00(UTC)
alonso231gery
Now i realised my mistake[:o)][B)],but is it a mistake after allwinkbiggrin.
An outsider.
#296 Posted : 05 June 2007 02:32:26(UTC)
Nice "Tuco" avatar ... Cool
#297 Posted : 05 June 2007 02:44:53(UTC)
alonso231gery
Thanks JohnCool , his quotes made that film a classic.
An outsider.
#298 Posted : 05 June 2007 15:25:25(UTC)
Yeah. Eli Wallach is great ... CoolCoolCool
#299 Posted : 05 July 2007 21:31:45(UTC)
alonso231gery
The 37622 (29848) , after a short steam loco (37452) brake biggrin .
An outsider.
#300 Posted : 07 July 2007 15:49:36(UTC)
Congratulations, Nikos - you just bought the ultimate top of M's F7 evolution ... CoolCoolCool
For me she's ranking #1 - together with the F7 A-B-B "WESTERN PACIFIC" (#26600) [:p][:p][:p]
Guest (21)
25 Pages«<45678>»
This page was generated in 0.881 seconds.
