Offline Danlake
#1 Posted : 02 February 2012 11:07:27(UTC)
Danlake
This is how I made relatively cheap wooden bridge pillars for the standard size Marklin bridges, which I think turned out ok for a first attemptLaugh
Soft pine wood. Cut to size and make lines with pencil:
Step 1
Use a sharp knife to make a dent horizontally:
Step 2
Deepen the cut using a soldering iron:
Step 3
Use a sharp screw driver to make the vertical dents:
Step 4
Spray paint in grey colour:
Step 5
Weathering (first a light grey colour and then various colours using dry brush techniques. Used some soft black pastel powder on top of pillar to simulate the soot from trains):
Step 6
In position taking the load!
Step 7
Brgs - Lasse
thanks 5 users liked this useful post by Danlake
Offline BillJ
#2 Posted : 02 February 2012 13:26:00(UTC)
BillJ
Those are great!
Well done, and thanks for taking the time to share.
Bill
Offline BrandonVA
#3 Posted : 02 February 2012 15:16:50(UTC)
BrandonVA
Wow, nice job!
Offline Chris6382chris
#4 Posted : 02 February 2012 18:06:58(UTC)
Chris6382chris
Very nice, thanks for sharing that. I will use the idea on my layout for sure.
Chris
#5 Posted : 02 February 2012 18:13:37(UTC)
Thanks for the tip, Lasse.
Good idea and nice result.
Offline Piggy
#6 Posted : 02 February 2012 18:35:45(UTC)
Piggy
Very nicely made Lasse, looks really good.ThumpUp
Kenneth
Offline hennabm
#7 Posted : 02 February 2012 19:12:09(UTC)
hennabm
Excellent idea
Thank you for sharing ThumpUp
1957 - 1985 era
What's digital?
Offline Lollo
#8 Posted : 02 February 2012 20:03:00(UTC)
Lollo
Great job, well done. ThumpUp
Brian.
Brian
Yaasan's Desktop Station/Railuino & Marklin MS2, DB Era III/IV Diesel & Steam, ESU Loksound/Lokpilot & Lokprogrammer, Marklin mSD, Tam Valley Depot Octopus III Servo Controller.
Offline Yumgui
#9 Posted : 02 February 2012 20:12:27(UTC)
Yumgui
Nice technik Danlake ^^ ThumpUp
Y Tongue
Offline BR01097
#10 Posted : 02 February 2012 20:19:49(UTC)
BR01097
Much better than the uniform, plastic pillars. Thanks for the tip!
A favorite is the mosses in the mortar!
Offline Nielsenr
#11 Posted : 02 February 2012 20:55:21(UTC)
Nielsenr
Great work!!
Offline Johnvr
#12 Posted : 02 February 2012 21:01:11(UTC)
Johnvr
Excellent weathering & pictures.
Thank you.
Regards,BigGrin
Offline Shintaro
#13 Posted : 02 February 2012 21:06:12(UTC)
Shintaro
Thank you.
I'll be using your tip.
Marc.
#14 Posted : 02 February 2012 23:31:24(UTC)
My bridge pillars were even quicker to make!
They were intended to imitate a concrete pillar rather than brick.
Take 2 pieces of 20mm MDF board, cut to approximate width and glue together. Once dry, setup an electric router (wood router not a network router) with a bullnose bit, and run pillars through the router, putting a rounded edge on each corner.
Cut pillars to needed height and paint and weather as needed!
Job done!
BTW Danlake, I do like the method you used to score the brick markings on your pillars.
Offline kariosls37
#15 Posted : 03 February 2012 05:42:31(UTC)
kariosls37
Nice pillarsThumpUp The only thing I would do as well is to higlight some bricks by making them ligter or darker. It makes a huge diffrence.
Offline Ian555
#16 Posted : 03 February 2012 07:42:25(UTC)
Ian555
Hi Lasse,
Nice work. ThumpUp
Ian.
Offline Danlake
#17 Posted : 03 February 2012 22:06:46(UTC)
Danlake
Thanks for comments.
Good idea Bigdaddynz with using a router for wood work. Must buy one of these for my toolbox.
Cheers - Lasse
Offline Western Pacific
#18 Posted : 04 February 2012 00:04:50(UTC)
Western Pacific
Very nice pillars from both Lasse and Bigdaddynz and I could actually imagen using both techiques.
In cases where a single track line has been converted to double track, one track could be on a bridge with older pillars an the secon on one with newer pillars.
Then there is also a more sad aspect of having older and newer pillars and that goes in particular if you are building a layout in a German setting where many railway bridges were destroyed towards the end of the second world war. An example below, the Hohenzollernbrücke in Köln (Cologne).
Hohenzollerbrücke
#19 Posted : 04 February 2012 00:10:16(UTC)
Since the pics don't show ok in the first post, go here - https://www.marklin-user...um.aspx?u=3670&a=100
Offline Danlake
#20 Posted : 05 February 2012 09:51:05(UTC)
Danlake
Thanks Juhan
Am Iam doing something wrong when posting photosConfused I use the album facility on the Marklin server and link the photos.
Is it better to upload photos to one of the free photo servers provider and then link from there?
Cheers - Lasse
Offline Danlake
#21 Posted : 05 February 2012 09:56:16(UTC)
Danlake
Great idea "Western Pacific", having 2 types of bridge pillars. Food for thoughts for furture expansion plans!
#22 Posted : 05 February 2012 10:07:39(UTC)
Views messages in topic : 2,883
Excellent work, something to remember when I'll be installing a few bridges on my future layout!
Just a suggestion (or constructive criticism if you prefer) if I may: You'll see that, in real life, most bridge pillars are not parallelipipedic in shape but rather truncaded pyramids.
Doesn't take anything away from your good technique though!!
#23 Posted : 05 February 2012 10:42:05(UTC)
.....parallelipipedic......
Try saying that real fast!! Crying Crying Scared BigGrin
Offline hennabm
#24 Posted : 05 February 2012 12:26:00(UTC)
hennabm
are the supports holding M bridges or some other make. If M bridges are they the plastic or metal variety.
Why I ask is on the metal variety there are the holes to locate them to the M bridge pillars and I was wondering if you have used the same support point and how you locate them?
1957 - 1985 era
What's digital?
Offline Loadmaster
#25 Posted : 05 February 2012 21:25:34(UTC)
Loadmaster
Lasse,
What type of wood do you use for the piers, balsa or something harder?
#26 Posted : 05 February 2012 21:27:40(UTC)
Lasse, it is a flaw of the current forum software - this albumimage thingy - will be fixed with the next update which is coming within a week or 2...
#27 Posted : 05 February 2012 21:30:06(UTC)
Originally Posted by: Loadmaster Go to Quoted Post
Lasse,
Robert, check Lasse's 1st post, he uses 'Soft Pine' wood. ThumpUp
Offline JRPiano
#28 Posted : 05 February 2012 21:55:16(UTC)
JRPiano
The creative juices are flowing in New Zealand! Thank you both for your how-to ideas. What do you use to attach the tracks to the piers and do you fasten the piers to your table also?
Joel
#29 Posted : 05 February 2012 23:52:38(UTC)
I used some contact adhesive to attach the pillars to the base board. Then when dry, I used ordinary M track screws to fasten the bridges to the pillars.
Offline Danlake
#30 Posted : 06 February 2012 20:34:58(UTC)
Danlake
Hi Mike,
The bridges are the "newer" one of plastic. I used contact adhesive as Bigdaddy to secure them.
I like the idea of making the pillars more pyramid shape.
Brgs - Lasse
Offline polabear
#31 Posted : 07 February 2012 02:59:03(UTC)
polabear
Mad Mad Nice job with the pillars guys. I have just completed some for my layout. I cut up some 7064 pillars Mad and glued the locating pins to a piece of wood, then built the piers around them using casted plaster of paris. I need to finish the painting.
thanks 2 users liked this useful post by polabear
Offline Loadmaster
#32 Posted : 07 February 2012 05:32:31(UTC)
Loadmaster
Lasse,
Thanks Dave,
I'm have a case of "Brain Fart" this week.
Rob
Offline Yumgui
#33 Posted : 07 February 2012 08:11:29(UTC)
Yumgui
polabear,
Originally Posted by: polabear Go to Quoted Post
Very nice ! Why be mad about it Confused
Yum
Offline Smudge
#34 Posted : 26 October 2012 07:18:07(UTC)
Smudge
Very nice job on those pillars
– shape, angled ends
– the double layer with the 2 tone greys
– and the stone work looks great too
I'm sure this scene will look very realistic when finished, make sure you post some updated image
Many thanks
Smudge
Smudge
Marklin Modellers of Sydney
Offline polabear
#35 Posted : 28 October 2012 02:48:56(UTC)
polabear
Hi Smudge,
Thanks for your comments. I didn't like the look of the Marklin brown plastic pillars and couldn't find any suitable ones commercially.
I have done only a little on the layout since then, but have been picking away at the area behind the bridge recently. It is a corner that I can't reach with the bridge in place. It is very tight so the track is almost against the wall. It is also my first attempt at scenicing.
Dave
Offline Smudge
#36 Posted : 28 October 2012 23:42:14(UTC)
Smudge
Hi Smudge,
Dave
Hi Dave
Your first attempt at scenicing! Well done your getting there that's for sure, and it looks like you've been looking at lots of reference pictures.
Once again your casting work is very good, the little bridge abutments are nice additions, when I'm weathering brick or stone work I like to use a blackish wash that seeps into the shadow areas, if too much goes on a damp rag cleans up the top surface. Then I dry brush the highlights or razed edges, by dragging the paint brush top to bottom to catch the top edges with paint. Just check your reference pics for details, colours, how the rain/water runs down the surface and leaves its traces behind
For grass, one of the clubs members has built a static-grass applicator, like the Nock ones, I'm looking forward to getting my hands on that, I really like the finished results. That will be sometime, I need to get some light weight bridge pillars and abutments done. It's for a exhibition layout so maybe the plaster will be too heavy or I need to keep its use to an absolute minimum.
For reference, I checkout the MIBA publications, Eisenbahn journal, some totally amazing stuff, I hope I haven't set my sites too high
Well done again
Smudge
Smudge
Offline FMS
#37 Posted : 29 October 2012 00:30:29(UTC)
FMS
ThumpUp
FMS
#38 Posted : 29 October 2012 05:22:35(UTC)
Thanks for all the different styles of pillars, and the various manufacture methods. All good.
In this photo, I have a contrast. The older bridge is the one at the rear, and it is supported by pillars made of steel cylinders, with steel sheet between. They are riveted together (the 1890s). In HO scale, I don't need to show the rivets, though I could with a darker colour dot.
I made them from electrical conduit, and styrene sheet.
http://www.qldrail.net/altkloster/75classbridge-800.jpg
Another view when being built.
http://www.qldrail.net/altkloster/twobridgeextension640.jpg
#39 Posted : 29 October 2012 19:06:43(UTC)
Nice picture of bridge stone walls.
But i prefer by using plaster and scraping traces of stone wall.
Later i put colour.
In that way you will get more realistic bridge stone wall.
#40 Posted : 29 October 2012 19:09:00(UTC)
If you shall use plastic walls i suggest you try to dirt with colour mixed with thinner and dry of with a clean cotton old T-shirt.
This page was generated in 1.958 seconds.
