marklin-users.net community
| Forum
Home
Community Forum
Login
or
Register
Forum
Active Topics
Login
Register
OK
General topics
Digital
60128 Connect – 6021.
3 Pages
1
2
3
Go to Page...
Email this topic
LinkBack Topic URL
Retweet this Topic
Share Topic on Google+
Like this Topic
Share on Facebook
Digg this Topic
Reddit this Topic
Share on Tumblr
Watch this topic
Print this topic
» Normal
Threaded
Previous Topic
Next Topic
Nilkram
#101
Posted :
09 April 2010 01:27:33(UTC)
Retweet
Peter & Jos
I have a CS2 which replaces all the old Keyboards, Memory's and so on. I found out that the approximation of the integrated Memory in the CS worked completely diiferent from the 6043 Memory, which I bought in 1989. When I asked the Märklin Kundenservice/Customerservice about this they informed me that in 1995 they changed their first system of the Memory. The first system could keep a track occupied, when a train lost a car and prevented a signal from switching. It also could looking for free tracks in a shadowstation and thus automatically chooses a free track and changes the switches and signals. This was all done by contact tracks (no switch tracks or reeds). In 1990 the Märklin Magazine published 3 articles how to fix this all. But as most of the customers found this system too difficult (says Märklin) they created a new system in 1995(with which I have no experience). They also changed the production numbers of the Memory's then. Maybe this is a reason why some Memory's work and some don't. I think the old system was absolutely superior to what they produce now.
Jan
User Profile
View All Posts by User
View Thanks
#102
Posted :
11 April 2010 01:31:57(UTC)
Retweet
Nilkram wrote:
Peter & Jos
..... they created a new system in 1995(with which I have no experience).
Jan
Thanks Jan, I am aware there are different "Technology Versions" in a number of the 60xx products. And Yes it would be nice to have list from Marklin Identifying
- Versions
- Functionality
- Identification of product (Serial numbers)
re the 6043 Memory I quote the following (I hope Tom wont mind)
Specifically The bit in red helps explain the note in the 60128 manual page 17. But as this only applies to Type B variants it is important to understand which version you are attempting to configure.
Memory Types A and B
There are two versions of the Memory unit. ... They Can be identified by the panel lights that come on when the module is started up.
With version "A" the
"Extern"
light is on ..
With version "B" the
"Off"
light is on.
Version "A" is faster and allows for timing sequences to be set
between
commands as described in the booklet. Simply push Keyboard switches that are not connected to any decoders to causes short pauses between commands. Each keyboard switch can be pushed a maximum of 8 times. This version would be better for many small layouts since it is faster and commands are not likely to be complicated for the quicker speed of transmission
Version "B" fits in with the larger layouts and is slower in its transmission speed. It is possible to change the timing variables between commands in a different fashion. An entire series of commands in a route can be spaced with timing pauses
by pushing "Extern " and then one of the buttons A1-C8
before pushing "End" at the conclusion of a route. A1 is the fastest timing pause and C8 would be the slowest. A single pause between commands can be entered by pushing "Off" then the pause variable between A1 and C8 followed by the next command in the series. Be sure to push "End" at the end of the route.
Version "B" of the Memory will also only request a route once when there is constant contact on a track. This usually happens when a car is parked on a track contact section and the signal repeatedly comes through the s88 to the Memory. With version "B" the request is made once until changes occur on the layout (example: another route is requested). Then the constant contact will make the request again.
As to the interlocking discussion, the DIP switches position 3&4 at the back of the unit enable or disable this.
Jos,
Without testing I can conceive that a 6043 set for interlocking may interfere with the rest of the bus to monitor/enforce keyboard operations.
What are the settings of you DIP switches?
Separately, have you attempted programing routes by using multiple presses of the same button. This feature is good for sticky (old M-Style signals) and uncouplers. Up to 8 presses of the same key will cause an extended pause of up to 3 seconds.
User Profile
View Thanks
graafjp
#103
Posted :
24 April 2010 22:49:56(UTC)
Retweet
clapcott wrote:
Jos,
Hi Peter,
Well I'm back again after being stuck on the canary islands .....
I tested the memory (mem2) that is not functioning....dip switch 3+4 on or off makes no difference unfortunately.
I still have to test the multiple presses you described..
Furthermore I had a strange thing happening.
When starting up the CS2 and 6021 chain I suddenly got a message to update the GFP from 1.0 to 1.24
The GUID that was displayed was the id of the connect-6021 that is currently saying it's version 1.0
I cancelled the update request because I did not trust it.....
Did you ever see this happening???
and..unfortunately still stuck when connecting the loconet adapter . CS2 goes into stop mode very frequently when switches accessories, even when there is no other device connected than loconet adapter--connect6021--6021...
I just don't understand that Alberto got this working....perhaps he has a newer version than my 6021.
when checking my 6021 with 94 93 the led power-on led blinks twice.
Jos
User Profile
View Thanks
#104
Posted :
26 April 2010 05:05:13(UTC)
Retweet
Hi Jos.
My 60128 is @ 1.0 and CS2 is @ 1.24 (package 1.3.0(1) )
- I have not seen the update message that you describe
My 6021 is "One Blink" and 6043 is Type B (Extern =
OFF
on powerup)
From my observations with the LocoNet adapter, Things work as expected ...
- keyboard, memory , loconet generated changes work correctly AND their status is reflected within the CS2 keyboard display
- CS2 generated changes work
as long as you only ever use accessories on the same page (group of 16) as the last command from the 6021 bus device
Examples.
(With LocoNet adapter) Note:6021 I2C us only addresses 1 to 256 - up to 320 not possible
- fresh power-up -
ALL
commands issued from any 6021 bus device.
- - CS2 keyboard display on any page - Commands work and are displayed correctly
- fresh power-up - NO commands issued from any 6021 bus device.
ANY
CS2 keyboard change on ANY panel causes CS2 to
STOP
- CS2 Keyboard on the same page (group of 16) as the last 6021 command
- - e.g. CS2 on page 2 (17-32) and last 6021 device command was in the range 17-32
ANY
CS2 keyboard change
ON THIS PAGE
works.
- CS2 Keyboard on the different page (group of 16) as the last 6021 command
NOT
in the range 17-32
ANY
CS2 keyboard change causes
STOP
Conclusion:
There appears to be some "locking" based on the old keyboard (16) boundaries. While It is probable that Marklin could fix this issue with some firmware updates, I feel this is unlikely unless there is some symptom that I haven't found that relates to Marklin products as well as the LocoNet-6021 adapter.
Therefore ... My suggestions fwiw ...
If you do not have Loconet adapter and do not intend to explore it.
- The 60128 offers ROI on an existing 6021. WITH the caveat of checking for component interoperability (As per JOS's experience with one type of Memory)
If you DO have a Loconet-6021 adapter for your 6021.
- Buy a Loconet to PC adapter and link the 2 systems with a small software program instead of spending the money on a 60128.
Do not have Loconet and DO intend to explore it.
- Then spend your money on a Loconet-6021 and LocoNet-PC adapter (or equivilent - e.g. Intellibox) instead of a 60128
User Profile
View Thanks
graafjp
#105
Posted :
27 April 2010 23:54:32(UTC)
Retweet
Hi Peter,
About the update message:
I got an e-mail today from Märklin with a single line response (translated)
"The CS updates all connected devices, you now have prevented this.
Until now I did not have the message again...perhaps with a next update???
All my memories are the B-type...
Still no reply from Märklin why I have the problems I described earlier with the 3 memory units.
I have exactly the same behavior you described when connecting the loconet adapter to the connect-6021.
So until I can get two memories working on the connect-6021 I am stuck with the loconet functionality.
btw, the 60124 and connect-6021 versions are the same as yours.
A little bit off topic:
I also had problems with the loconet adapter before I had my CS2 and connect-6021
The 6021 went in stop mode when using the keys on 2 of my 5 keyboards 6040.
I did sent the adapter back to Uhlenbrock and when I got it back they said it was 100% working.
They suggested that I plugged it directly into the 6021 not using any keyboard or memory......
Jos
User Profile
View Thanks
graafjp
#106
Posted :
08 September 2010 16:01:18(UTC)
Retweet
Hi again,
Well it's a long time I was busy working on my problem that 2 out of 3 memory devices did not work correctly in combination with the connect-6021 and CS2.
Unfortunately I did not have much time last months to spent time with my modell railroad.
but...
I finally got a reply from Marklin (with excuses for the long delay) saying that the two memories that were not working properly had the need for a microprocessor update. So I sent them in and last week I received the two memories back.
I have tested these 2 upgraded memories and they are now working perfectly.
So besides the A en B versions there have been 'quiet' updates to the microprocessor programming I suspect.
The only drawback is that my third memory that did work ok exhibits now the same problems that it only switches the lights on an attached keyboard and nothing happens on the CS2 when used together with the two updated memories. So i'm going to check with Marklin but I guess it also has to be updated.....
b.t.w., the upgrade costs are about 50 euro's per memory.
Jos
User Profile
View Thanks
3 Pages
1
2
3
Go to Page...
General topics
Digital
General topics
- General MRR
- H0-scale
- Small scale
- Big scale
- Prototype
--- Videos
----- Steam
----- Electric
----- Diesel
----- Accidents
- Digital
- Model railroad software
- Model railroad photography
Reviews
- Loco Reviews
- Reviews of rolling stock
- Accessories reviews
- Model kit reviews
Collector's Corner
- Collector's Corner general
- Märklin Sprint
- Construction kits
- Steam engines
- Tinplate toys
The Projects & Workshop area
- Track plans
- Painting & Weathering
- Model railroad wiring
The Club Corner
You
cannot
You
cannot
You
cannot
You
cannot
You
cannot
create polls in this forum.
You
cannot
vote in polls in this forum.
Powered by YAF.NET
This page was generated in 0.548 seconds.
