#1 Posted : 21 February 2010 06:17:07(UTC)
(Edited 17 May 2010 with new photos from port side with addition of flags)
As in model railroads, the first thing you do after unpacking, is to test the running qualities.
In order to do this test, I used our swimming pool. I did not fit the lifeboats, because it was only a short run.
The 16064 ship "Jolanda" produced as a new item in 2009, is quite heavy, built of steel, and settles low in the water. The lowered stairs just touch the water. The wind up mechanism is accessed by a very long key, through the funnel. The propeller shaft is driven by an ingenius arrangement of universal couplings, and flexible shaft.
With about 6 turns of the key, the ship had no problems going two lengths of the pool. I now have to build a small wooden transportable jetty, so I can set that up at the shallow end, and will seem to give a reason for having the boat in the pool.
All I need now, is for Märklin to produce some accessories, such as life preservers (rings), deck chairs, figures, and coils of rope. I don't think the model is to a particular scale, but my guess is about 1:50 (or O gauge) accessories would look OK.
These later images (May 17 2010) show Jolanda from the port side. This time I have added the life boats, and the flags, so it is complete. This photo displays the bow profile to advantage, indicative of a beautiful design, and why the model is so desirable.
I really like this model, and I hope you like it.
Edited by user 16 May 2010 15:26:04(UTC)  | Reason: Not specified
Offline ozzman
#2 Posted : 21 February 2010 06:32:20(UTC)
ozzman
Thanks for the photos Kimball. It really looks magnificent! Would the ultimate accessory be a loco smoke unit in the funnel?
Gary
Z Scale
#3 Posted : 21 February 2010 06:37:00(UTC)
Yes Gary, that would do nicely, say a 9 volt battery should do the trick.
And I think the smoke should be a little darker than what we use for the locos.
By the way, the ship is about 82cms long.
And I jsut thought of another accessory.
A mermaid, or other type of figurehead, that can be attached under the bowsprit.
#4 Posted : 21 February 2010 07:13:50(UTC)
Kimball,
You should have had a Launching Ceremony/Party.
It looks great. every pool should have one.
NN
Offline Tony
#5 Posted : 21 February 2010 07:40:41(UTC)
Tony
Hey Kimball
Wow that is a Special item Cool - I didn't realise the thing could actually float.. Very nice
Thanks for sharing
Regards Tony
#6 Posted : 21 February 2010 08:28:25(UTC)
Hi Nev and Tony, thanks for comments.
Yes, Nev, I should really have a launching party, however the BBQ has never been fired up, and I think it has wasp nests in it (or something just as nasty). I bought it about 4 years ago. I think the BBQ would be mandatory.
I have unwittingly made a few enemies, as my wife often says "Oh, you'll have to come around for a BBQ sometime". Trouble is we hever have one, and people don't forget that.BigGrin
#7 Posted : 21 February 2010 11:18:19(UTC)
There are a series of accessories available:
Underwater 3D CS2 with pressurized knobs
What about a launching ramp, the one that Märklin produces to guide the loco and carriages onto the rail ?
Interior lighting with led's.
Telex coupling to release the anker(s)
piazzo motor for the stairway to go up and down.
There is a sound modul available with 4 speakers with a harbour message: This is not the titanic, please come aboard and mind the gap (english message) or pi.. off and get your own boat (Australian message)
There is also a limited edtion with a long range key available for longer journeys, e.g. the 2010 marklin users.net.forum meeting in germany.
Prices start at the bottom of the harbour scheme, depending which class you are travelling with, bookings are taken at the BBQ office with a complimentary pool drink with different aged flavours (2-60).
#8 Posted : 21 February 2010 11:56:38(UTC)
Lovely, Thanks for sharing the pictures Kimball.ThumpUp
#9 Posted : 21 February 2010 12:18:37(UTC)
Thankyou John and Stephen.
John, I didn't know Märklin had made those accessories.
I will write to Märklin, enclosing your list, to check prices and availability.
BigGrin
#10 Posted : 21 February 2010 14:09:19(UTC)
I will write to Märklin, enclosing your list, to check prices and availability.BigGrin
preferable write in german and use the international ship code: dammit
You realize of course 103 years before your successful launch, a sister ship in Italy "Principessa Jolanda" sank when launched.
Offline LionelMPC
#11 Posted : 22 February 2010 04:24:27(UTC)
LionelMPC
I didn't realize it actually floated either. It's still a real toy, wow!
Looks like a lot of fun.
-James
Offline Kodiak
#12 Posted : 22 February 2010 04:55:38(UTC)
Kodiak
thats realy cool. has it got a remote with for steering? or is it only the wind up motor?
John and his M track, the only way to train. Now with added C track and bonus K track.
If your gona be a bear, be a grizzly!
You have the right to bear arms, the right to arm bears, what ever the hell you wanna do!
Offline jonquinn
#13 Posted : 22 February 2010 05:21:50(UTC)
jonquinn
that would make a nice radio control boat for the pool or small pond, even if it would cancel out the old-time characteristics.
#14 Posted : 22 February 2010 12:28:23(UTC)
Hi James, Kodiak and John,
There is a manual windlass at the stern to adjust the rudder, and it can be locked in one position if required.
Märklin state in the literature that it is not suitable for retro-fitting of remote control gear. I guess that is because it needs electrical power, and you have to manually wind up the clock work mechanism anyway.
I rather like the model, because it is an old-world sort of thing. That has its charm. It does not tax my brain too much, so it is certainly very relaxing getting it to run.
I wonder how faithfully they followed the original 1910 model?
The fact is, the model sits well in the water, is very stable, just like a real boat, and rolls under wave just like a real boat. I wonder if they had to employ a naval architect to ensure that it sat in the water correctly, or is this just simple mathematics? And of course the weight of the mechanism and shaft, and upper deck had to be set precisely to keep the boat in trim.
The boat gets up quite a speed, a good walking pace if given enough length.
It appears from the literature, that they may have made only 2009 of these models. A certificate came with it.
#15 Posted : 22 February 2010 12:54:15(UTC)
It must be relaxing watching it going up and down the pool and it does'nt need any nuclear powered boats to protect her against malicious damages.
Do you think the salt or chlorine water could damage the hull paint or dull it in time ?
If it would be mine, I would'nt upgrade it
regards.,
#16 Posted : 22 February 2010 13:19:35(UTC)
Hi Kimball
In a book I have here about Märklin toys build between 1895 and 1914, there is a picture of the original, and from what I can see the repro is pretty close to the original.
The only major missing detail appears to be the absence of 4 rescue boats.
But that seems easy to fix, since the davids are already in place.
Looks like a great toy!
Offline skeptic49
#17 Posted : 22 February 2010 15:02:41(UTC)
skeptic49
Very nice! I like the pool too!
Jim in Philadelphia
See my online magazine - Tinplate Times at http://www.tinplatetimes.com
#18 Posted : 22 February 2010 15:06:39(UTC)
I think that is the first time we see a ship test run in this forum.Thank you for the nice presentation.
#19 Posted : 22 February 2010 21:22:35(UTC)
Now, here I thought the ships were display stuff only and imagined they would sink as a rock if put into water...
I was surprised that it is a real usable toy, also somewhat silently proud of that fact since it seems M has made good quality toys also in the past... Imagine being a kid in the 1910:s and get a big metal boat you can play with in water... Opened my mind up a little, so to speak... That's 100 years ago...
#20 Posted : 22 February 2010 23:24:37(UTC)
A dream cruiser - congratulations, Kimball ThumpUpThumpUpThumpUp
#21 Posted : 23 February 2010 00:31:39(UTC)
Hi Jacques,
Thanks for your reference to the earlier catalogue. The rescue boats came with the model, but I did not fit them for the test run - naughty, naughty...!
Hi Panayotis, Jim, Juhan and John,
I doubt if the pool water would hurt the model, so long as it is wiped dry after use. The pool looks so nice, simply because here in Queensland we have weather that is described in the tourist literature as "beautiful one day, perfect the next".
I can imagine this boat being the sort used on the Swiss lakes, or elsewhere on the continent. Come to think of it, I think I saw one like this in "The African Queen", where Bogart's boat ended up being used as a make-shift torpedo, and sank the splendid German lake cruiser. With its bewhiskered captain.
Offline Macfire
#22 Posted : 23 February 2010 10:16:43(UTC)
Macfire
Nice, old son, very nice.
Seems to float better than Marklin in the financial seas Blushing Blushing
(ducking for cover)
Edit:Used the BBQ yet????
(ducking for cover again)
Wub
Edited by user 08 March 2010 02:18:21(UTC)  | Reason: Not specified
Lord Macca
#23 Posted : 23 February 2010 19:53:47(UTC)
Very nice, Kimball.
Thanks for showing us.
Offline Piggy
#24 Posted : 24 February 2010 01:06:42(UTC)
Piggy
Very lovely to see it float, Kimball. I had no idea either that it could actually float.ThumpUp
Kenneth
Offline EuroKev
#25 Posted : 06 March 2010 20:12:35(UTC)
EuroKev
Thanks for sharing your first cruise with us. It is a very nice model. I knew Marklin ships floated and ran but did not know M made this ship before. I now am wishing I could afford one of these for my collection. Happy sailing and thanks again.BigGrin
Kev
#26 Posted : 06 March 2010 22:46:26(UTC)
Nice one Kimball, thanks for posting the pictures. Now all you need is for Nev to come and clean the pool and chase the wasps out of the BBQ. Scared Scared Macca and I will get the Insider Canoe out and come over for said BBQ! ThumpUp ThumpUp
#27 Posted : 06 March 2010 23:06:41(UTC)
If you want a BBQ at Kimballs, YOU remove the wasps.
Only needs a bit of fire.
ThumpUp ThumpUp LOL LOL
#28 Posted : 06 March 2010 23:30:28(UTC)
This do?
Hoorah!
Edited by user 07 March 2010 05:00:13(UTC)  | Reason: Not specified
Offline kariosls37
#29 Posted : 07 March 2010 03:34:05(UTC)
kariosls37
Scared Scared Scared don't burn down the house Bigdaddynz! the M* may get damaged if the house burns downCrying
spray 'em with some WD40. kills them quicker than any incecticideCool after initial treatment I prescribe regular usage.ThumpUp
#30 Posted : 07 March 2010 09:27:26(UTC)
Hi Tony, Svein, Kenneth, Kev, David, Nev and Rick,
Thanks for comments.
As far as the BBQ is concerned, yes, the fire would certainly get rid of the wasps. They regularly haunt our garden, and I have a permanent fix on hand. A pole with a kerosene soaked rag wound around one end, leans in a corner of my shed.
I think the problem is that I am so used to my wife's extraordinary cooking, there seems little point in having a BBQ.
As far as affording a Jolanda for the collection, I gave it to my wife for Valentines day. She has been giving me this sort of weird look ever since, as though she doesn't quite believe me. Smile
She has not however taken it out of the space where I store my trains, so I sort of still own it!!!
#31 Posted : 07 March 2010 09:34:42(UTC)
Very crafty Kimball! BigGrin
#32 Posted : 08 March 2010 13:15:52(UTC)
Kimball,
Don't be surprised to find an Ocean cruise ticket floating around one day.
They know we like surprises.
Offline atilla
#33 Posted : 14 March 2010 17:02:23(UTC)
atilla
What an impressive model. The catalogs do not really do it justice!
Offline alonso231gery
#34 Posted : 14 March 2010 19:28:25(UTC)
alonso231gery
Kimball i love your boat, ThumpUp ThumpUp ThumpUp .
An outsider.
#35 Posted : 15 March 2010 02:37:04(UTC)
river6109 wrote:
Kimball,
What!!!, you mean I will find the butt end of the ticket, and she will be gone without me!!!
Sneaky
Thankyou Alonso and Ralph for your comments.
You are correct, the catalogue only gives you a hint.
I think that is true of all Märklin models.
It is like faith (or trust), in the Märklin capability, so you have to be bold, and say you want it.
I have to make up my mind from the catalogue, and order the item well in advance. I think the boat took almost 12 months.
I have never been disappointed with a Märklin item.
#36 Posted : 16 May 2010 15:28:48(UTC)
May 17 2010
I added two new pictures to the first post.
#37 Posted : 16 May 2010 16:58:29(UTC)
Again - just loverly, Kimball SmileCoolThumpUp
Still more, we can see Nev was here ... TongueLOL
#38 Posted : 17 May 2010 00:57:08(UTC)
I was just thinking how nice it would look if you had a model of a bridge across the pool with a nice 1 gauge loco pulling a passenger train full of 1 gauge passengers for your boat.... It shouldn't cost too much to turn the thought into reality.. Smile
Offline SNAFU
#39 Posted : 17 May 2010 02:55:19(UTC)
SNAFU
Yeah it could be like a day excursion package with a BBQ lunch followed by a complimentry gift of a jar of honeyBigGrin
Tony
Curiosity hasn't killed this cat yet.
Offline igf2
#40 Posted : 21 May 2010 19:27:44(UTC)
igf2
Nice idea for a true nice boat !
#41 Posted : 22 May 2010 11:03:30(UTC)
May 17 2010
Nice pictures.ThumpUp
This page was generated in 2.057 seconds.
