3 Pages123>
Offline supermoee
#1 Posted : 13 January 2010 16:51:22(UTC)
supermoee
software available on the Update-Server since a few minutes.
Just let your CS2 call to home BigGrin
the double slip 2275 is now working properly....and you can connect the CS1.
rgds
Stephan
Offline Piper
#2 Posted : 13 January 2010 17:08:52(UTC)
Piper
Stephen,
Thanks, but what do mean "connect CS1"?
Pieter
Era I-V / HO / C-Track / MS2, CS2 & CS3 Z gauge. Insider
Member of Märklin Modellers Group
Offline supermoee
#3 Posted : 13 January 2010 17:10:37(UTC)
supermoee
Piper wrote:
Stephen,
Pieter
you can connect CS2 and CS1 together through the LAN cable.
rgds
Stephan
Offline Piper
#4 Posted : 13 January 2010 17:12:08(UTC)
Piper
Stephen,
Thanks, I'll have to try that.
Pieter
Offline supermoee
#5 Posted : 13 January 2010 17:20:06(UTC)
supermoee
do that.
Than go into the setup menue, press on the wrench and you will find a CS1 menue.
rgds
Stephan
Offline pa-pauls
#6 Posted : 13 January 2010 17:26:33(UTC)
pa-pauls
Notting on the Märklin internet page do...
http://www.maerklin.de/d...ds/software_updates.html
Pål Paulsen
Offline supermoee
#7 Posted : 13 January 2010 17:42:11(UTC)
supermoee
Hello Pal.
I wrote "Update Server". This is the server, where the CS connects when you press the "update" button in the setup menue.
rgds
Stephan
Offline pa-pauls
#8 Posted : 13 January 2010 17:56:14(UTC)
pa-pauls
Yes I saw that Stephan
But then it is not officially released yet I think...
Pål Paulsen
Offline supermoee
#9 Posted : 13 January 2010 18:00:22(UTC)
supermoee
if it would not be released, it would not be available on the server. I know what happened once in the past, but this is gone now.
If you mind, you can wait for the USB version.
rgds
Stephan
Offline davemr
#10 Posted : 13 January 2010 18:41:24(UTC)
davemr
Hi Stephan. Thanks for info. I will have to wait for the USB but how do I know when this is available as I dont think the update reference on the Marklin site changes. Other you letting me know of courseBigGrin
dave
davemr
Offline graafjp
#11 Posted : 13 January 2010 19:00:15(UTC)
graafjp
Changelog:
GUI Version 1.3.0 build 1, GFP 1.24 (Januar 2010)
* Diese Softwareversion soll die Möglichkeit der Verbindung mit verschiedenen Geräten verbessern
* Für die Verbindung zur 6021 mit dem connect6021 werden jetzt die verbundenen Loks dauerhaft gespeichert
* Die Verbindung zu einer zweiten CS2 kann jetzt einzeln für die Seiten keyboard, layout, memory und control eingestellt werden
* Auch bei größeren Datenmengen (mehr als 300 Loks ...) funktioniert die Verbindung jetzt besser als bisher
* Die Daten werden beim Start mit dem Master abgeglichen. Wenn später Änderungen erfolgen, werden diese ebenso an alle Geräte geschickt.
* Die übertragene Datenmenge wurde auf etwa die Hälfte reduziert, indem Defaultwerte jeweils nicht übertragen werden
* Die Verbindung zu einer CS1 kann jetzt über ein Netzwerkkabel hergestellt werden. Ausgewählte Daten können auf Anforderung zwischen den Geräten ausgetauscht werden
* Die Verbindung zu einer 6021 kann jetzt über den connect6021 (60128) erfolgen. Eine Seite im Setup verwaltet die Liste der Loks, die über die Fahrgeräte control 80F gesteuert werden können
* Die DKW mit 2 Antrieben kann ab jetzt im keyboard und layout eingesetzt werden
* Wenn ein Magnetartikel mit ungültiger Stellung aus einem Backup gelesen wurde konnte der Aufruf der entsprechenden Seite im Layout das Programm beenden. Jetzt werden ungültige Stellungen ignoriert.
* Es können jetzt auch alle Loks gleichzeitig ausgewählt und in die CS1 übertragen werden
* Die Stellung von Magnetartikel auf im Moment nicht sichtbaren layoutseiten wird jetzt auch aktualisiert
* Die Hilfe wurde um Punkte für CS1 und 6021 Hilfe erweitert
English translation:
- This software will improve connection to different devices
- Connection to 6021 with connect6021 now stores the mapping address
- When connected to a second CSII you can only connect 'keyboard' 'layout' 'memory' 'control'pages
- With a lot of data (more than 300 locs) connection is improved
- Data is synchronised with master after startup and during usage
- Only non-default values are transferred
- CS1 connection with network cable, selected data can be transferred
- 6021 connection with connect6021. Seperate page for locs assigned to control 80F
- Double slip switches for keyboard and layout
- Crash fixed for devices with wrong setting when restoring backup
- All locs can be selected and transferred to CS1
- Position of switches/signals on non visable layout pages is updated
- Help text for CS1 and 6021 expanded.
Have fun
Jos
Offline pa-pauls
#12 Posted : 13 January 2010 19:16:09(UTC)
pa-pauls
I just tried it and now my CS2 also have software 1.3.0 BigGrin
Thank's Jos for the Log in both German and English language Blink
Pål Paulsen
Offline laalves
#13 Posted : 13 January 2010 19:16:49(UTC)
laalves
Great! Now, who will be the first to connect a CS1 v3.0 or even an EcOS v3.0 to a CS2 v1.3.0? Sneaky
I've been waiting for this to happen to decide whether to upgrade my stored CS1 to v3.0 or just sell it, but I need to know if it works.
Offline graafjp
#14 Posted : 13 January 2010 19:30:54(UTC)
graafjp
Yep, included the German text in case I made a translation error....Blink
Jos
Offline pa-pauls
#15 Posted : 13 January 2010 19:51:14(UTC)
pa-pauls
Hmmmm... I have a CS1 v3.0 also that I use for testing, programming etc. but I don't know if I will be the first one to test it do... Blushing
Pål Paulsen
Offline supermoee
#16 Posted : 13 January 2010 20:43:09(UTC)
supermoee
hello,
following feedback from stummi forum the cs1 reloaded is not working with cs2
rgds
Stephan
#17 Posted : 13 January 2010 21:09:15(UTC)
Way Cool Cool
In combination with a 60128 <Connect 6021> the available connections options enormous.
Also allows satellite controllers to control/power their own domains but be aware of changes made by another throttle.
A little bit of German logic (flow) to contend with and a bit more needed in the Help (i.e. file missing from the download - will have to wait for the USB) HOWEVER quite functional BigGrin
Offline 7gauges
#18 Posted : 13 January 2010 21:25:37(UTC)
7gauges
graafjp wrote:
Changelog:
Any idea if this update will now allow functionality to have non updated MS-1's actually update from and work with the CS1?
I still haven't gotten around to have my 4 MS-1's updated by the newest CS 1 release, so that they are actually capable of working with the CS2. No one has a CS1 locally.
#19 Posted : 13 January 2010 21:37:49(UTC)
FYI. German help parsed through google translate
connect Central Station 1
It is possible to pass the Central Station 60213/60214 (CS2), a Central Station 60212 (join CS1) and operate. The following procedure describes how to prepare the equipment and be connected. For the joint operation of the devices together, the CS1 may not have access to the vehicle track.
Step 1: Preparation
We recommend that you create before the joining of CS1 and CS2 of the data on the CS1 a full backup. Please note this information in the manual of the Central Station 60212th After the data of the CS1 were backed up, it's completely from the track and possibly connected boosters separated.
Step 2: Structure
To get the broadest possible ways in which the CS2 operated as a "PC" in the CS1. The devices are so similar to a computer network connected to each other. There are several possibilities:
Step 2a: CS1 directly to CS2
Use a crossover network cable (Crossover patch cables, computer accessories in commercially available) and connect the two devices together. Set both devices to "Manual address assignment. Set in the CS1 (Setup1, network settings, IP address) the IP 192.168.1.55 (network address) and set in CS2 (setup, IP, CS-IP) address, the IP 192.168.1.53 (default on).
or
Step 2b: CS1 and CS2 in an existing computer network (hub, switch or Rooter)
Connect the two devices, each with a non-crossed network cable (patch cable, the computer-commercially available) to the network. When active in the network, a DHCP server, and both devices are set to automatic address allocation, both devices will be assigned an IP address. Read the assigned address in the CS1 and record them.
If no DHCP server is active, enter the addresses manually. Set both devices to "Manual address assignment. Set in the CS1 (Setup1, network settings, IP address) the IP 192.168.1.55 (network address) and set in CS2 (setup, IP, CS-IP) address, the IP 192.168.1.53 (default on).
Note:
Note that the Central Station after switching the network connection not immediately builds. Wait after switching around 1 to 2 minutes before using the settings of the IP address check or edit. In addition, the cable connection before switching on the device must be manufactured.
Step 3: connect
Prerequisites: Both devices are turned on, connected, CS1 separated from the track, IP addresses, both devices are known.
Call of CS2 in the page setup "CS1". Select the button "Add CS1.
In the new window you can enter a name for the connected CS1. The name is used only for clarity and may be freely selected.
Enter the IP address of the connected to CS1.
Reading With the key CS1 configuration, you can now read the configuration of the CS1 to CS2 and play.
Note:
To ensure the stable operation of the two devices, we recommend having the configuration of the CS1 was read, delete, delete them in the CS1 (CS1 button configuration. And then follow through with the CS1 reboot. Then you can CS1 of locomotives and accessory reassign.
Note:
Of CS1, you can assign a maximum of 250 locomotives (addresses). The assigned locomotives to operate in the CS1 always with Motorola as a locomotive decoder with a maximum of 4 functions. Locomotives with more than 4 functions, show the correspondingly more addresses.
Please note that the Lokmenü of CS1 with increasing number of locomotives is getting lazy. We therefore recommend that you assign as few locomotives.
#20 Posted : 13 January 2010 22:05:58(UTC)
Update to 1.3.0 was sucessfully.
Just note that some extra included 'Passengers' on Loco icon list.
#21 Posted : 13 January 2010 22:26:37(UTC)
I don't think you will do any damage to either device. It's just bits flowing across a data cable. Either they will talk to each other happily or they won't.
Offline jonas_sthlm
#22 Posted : 14 January 2010 00:35:54(UTC)
jonas_sthlm
Update to 1.3.0 was sucessfully BigGrin
Offline jeehring
#23 Posted : 14 January 2010 03:49:26(UTC)
jeehring
supermoee wrote:
do that.
rgds
Stephan
Sorry Stephan, I don't have a CS1, curiosity push me (the limits of my English as well ...): do you mean that we find into the CS2 a menu for settings & tuning to make work the CS1 & CS2 together?...Or is there something else in this menue ?
thank you
(I would hope pictures from kind contributors, I daren't ask...Blushing Confused )
#24 Posted : 14 January 2010 09:00:20(UTC)
Peter (Clapcott), I see you browsing this topic right now, feel free to step right in with pictures!
Offline Steamer01
#25 Posted : 14 January 2010 10:27:15(UTC)
Steamer01
The synchronisation function is available again. Only if you have a master CS2 and a second CS2.
Steamer01.
CS3 60216 + 8 x 60174 + 1 x 60175
www.rensenmodelbaanwereld.com
#26 Posted : 14 January 2010 10:35:23(UTC)
The red X turns into a green check when the CS1 is connected and powered on.
Status Change is dynamic (within about 5 seconds)
A friendly name can be entered.
The option to upload existing CS1 data is only available at initial add.
(Probably not the best idea - better to push configuration info from the CS2 out )
Both "Add Locomotive" and "Add Solenoid Accessory" show the list of items profiled on the CS2. The Accesories need to have been defined on the layout.
Still a few items not translated for English. The buttons shown mean "Clear Selection" and "Select All" (otherwise you can select multiple items with the mouse/stylus). Also when saving the changes the message indicating the data is being transmitted to the CS1 is in German.
The bottom 2 items are in the list as imported, from the CS1 when it was added - "New >0008<" ...
#27 Posted : 14 January 2010 10:51:56(UTC)
Thanks Peter! It will be interesting to see whether this works with a CS1 v3.0 or Ecos v3.0.
Offline supermoee
#28 Posted : 14 January 2010 11:21:44(UTC)
supermoee
Hello Bigdaddy,
as I wrote previously, first attempts showed that this is not working. You'll get the message " your version 3.0.x of the CS1 is not supported".
Is clear, Märklin does not know what how ESU is developing the software of the CS1. So why should they implement it?
rgds
Stephan
#29 Posted : 14 January 2010 12:05:39(UTC)
I would ask, Why not implement it! People brought their CS1's in good faith, and Marklin ditched them all like a hot potato when they released the CS2. At least ESU have provided some sort of upgrade path for CS1 owners.
But, it looks like Marklin wants to alienate a good proportion of their customers! They don't do it it because they don't like ESU any more, and they don't want to keep updating their legacy equipment. That's their choice, but I don't think it is a smart move for a company in insolvency!
Offline supermoee
#30 Posted : 14 January 2010 12:12:30(UTC)
supermoee
Hello Bigdaddy,
did you ever thought that maybe ESU is not giving out any information about their software and Märklin do not want to do a cost and time intensive reverse engineering for each software version of the reloaded CS1 to ensure full compatibility?
The lack of information of ESU was for sure one of the cause of the dispute between both companies. So why it should become better now?
rgds
Stephan
#31 Posted : 14 January 2010 12:17:31(UTC)
For sure Stephan. It would have been nice if the 'differences' (whatever they were) could have been sorted out for the sake of their customers. But they weren't sorted, so we the customer, have to live with the outcomes, and do the best we can.
Has anyone tried downgrading a v3.0 CS1 back to v2.0.4?
Offline davemr
#32 Posted : 14 January 2010 13:38:09(UTC)
davemr
Hi Big D. I would not really blame Marklin in this instance as ESU provided a crap MS and even the CS1 was not that great.
Marklin now having a different provider for the CS2 looks to be a good move ( I know that some have not worked as well as they should at the beginning)
It depends I suppose if you want to buy a controller for life or change say every 5/6 years for something better.
Marklin hopefully will match their control system to their locos and accessories where ESU just has to follow what the loco manufcturers do.
Marklin start sets although expensive with the CS2 appear to be good value whereas ESU can not do start sets.
My view which i know will not be shared by all is that if anybody is going bust then let it be ESU and not Marklin. ESU and Marklin between them killed off the CS1 and at least Marklin now have a supplier who is not also selling the items under their own brand name in competetion with Marklin which I thought should not have happened.
Try a CS2 and I am sure you will be delighted (Free advert now finished)
dave
davemr
Offline Hemmerich
#33 Posted : 14 January 2010 17:03:51(UTC)
Hemmerich
Edited by user 21 November 2010 02:20:08(UTC)  | Reason: Not specified
Offline Hemmerich
#34 Posted : 14 January 2010 17:37:06(UTC)
Hemmerich
Edited by user 21 November 2010 02:20:40(UTC)  | Reason: Not specified
Offline cyberbeast41
#35 Posted : 14 January 2010 21:21:42(UTC)
cyberbeast41
You have been a member since:: 14/07/2009(UTC)
CS1 and CS2 connection works like a charm.
It's amazing. You can now control 6 locomotives at one time:
- 2 with CS2
- 2 with CS1
- 2 with 2 seperate MS1's.
This CS2 is a whole other deal than the CS1 ever was.
#36 Posted : 14 January 2010 22:18:56(UTC)
Hemmerich wrote:
(unless ESU is going to change their SW).
That would be nice! Is the limitation in the CS2, or is it in the ESU v3 software? You seem to infer that it is ESU that has the limitation.
#37 Posted : 14 January 2010 22:43:27(UTC)
The question is: are they really incompatible or is this just a version check either to be on the safe side or to keep ECoS outside?
DOS 3.3 utilities didn't run under DOS 4.0 - but it was only the version check that prevented that.
A few years later they brought SETVER.EXE that allowed to fake the DOS version and the utilities were running again.
So Märklin could remove the version check - or ESU could fake the version reported by CS 1 reloaded.
If there are incompatibilities, either side could fix them.
It doesn't take reverse engineering if both sides would communicate for the benefit of their customers.
My CS 1 is reloaded. And this CS 2 limitation is another reason for me not to buy a CS 2 as long as my CS 1 is still functioning.
#38 Posted : 14 January 2010 23:20:54(UTC)
Well said Tom. Lets hope common sense prevails, and those with CS1 Reloaded can connect their CS1's to a CS2.
Offline supermoee
#39 Posted : 15 January 2010 14:32:44(UTC)
supermoee
Hello Tom,
since you have a CS1 reloaded I do not see any advantage for you to buy a CS2. Why should you? So this should be the same thinking of Märklin. So why wasting capacities and money on this subject?
ESU is not communicating anything about the CS1 reloaded. Do you know where to find the communication protocole of the CS1 reloaded??? I don't (no, it is not exactly the same than the EcoS).
So if ESU is not communicating to anyone, why should Märklin implement something?
This arrogant behaviour of ESU is the reason why I do not buy directly products from them anymore. The last product was the Loksound for my Gottardo 1 year ago and this will not happen anymore.
Märklin put the guarantee on that what was done under their authority (Vers. 2.04). Everything else doesn't matter and it is ok for me.
And at the time the ESU update was announced, Märklin informed that they will not support reloaded CS1, because the development was not more under their control and they could not take any responsibility.
So who updated anyway should not be wondering about the incompatibility to Märklin products.
rgds
Stephan
Offline Steamer01
#40 Posted : 15 January 2010 18:33:31(UTC)
Steamer01
I have the update for the CS2 installed (sw 1.3.0(1) and gfp 1.2.4) and I have tested it now for several hours. The double slip switches are now correct switching and the lay-out shows the correct figure. If you have two CS2 like me (60213 and 60214 connected) than you can use the synchronization function.
The problem with the routes has not been solved. It still happens that some solenoid accessories sometimes don't switch. Each time it is a different turnout or signal. Sometimes it is all switching correct for about 10 minutes and than it happens again that there is a faillure.
Steamer01
Offline laalves
#41 Posted : 15 January 2010 20:23:20(UTC)
laalves
Stephan
I have a CS2 and a CS1 v2.0.4. I wished the CS1 v3.0 would work with the CS2 because the EcOS/CS1 v3.0 have a unique capability that interests me: the capability to control a turntable using a Lokpilot, instead of the conventional way. I have modified mine that way. My intention was to use the CS1 v3.0 as a dedicated TT area controller and the CS2 as a master controller.
Offline alonso231gery
#42 Posted : 18 January 2010 17:24:26(UTC)
alonso231gery
Hello
I would like to ask you something about the CS2:
I wonder if an updated CS2 can update as well a CS1, i have not updated my CS1 since i have given it back to the factory, so i wonder if it can be automatically updated when connected with my future CS2?
An outsider.
Offline Fredrik
#43 Posted : 18 January 2010 18:03:28(UTC)
Fredrik
technically there would be no problem updating a CS1 from a CS2 yet not neccessary as an update can be made from the CS1 itself. If it will ever be done is another question. Depends on if M* has the sources for the CS1-software and if they want/need to perform any updates for it.
Fredrik.
WWW: MJ-fjärren
Offline supermoee
#44 Posted : 18 January 2010 18:33:05(UTC)
supermoee
alonso231gery wrote:
Hello
The communication through CAN Bus of CS2 is completely different than the one of the CS1. To do an update Märklin need to re-write the complete software of the CS1, because the CAN protocole of the CS1 is copyright of ESU and they cannot modify it.
If they have the right to change the software of the CS1 this I doubt, because the know how property of the CS1 is of ESU.
rgds
Stepahn
#45 Posted : 18 January 2010 20:59:41(UTC)
cyberbeast41
Maybe he means if the product listing in the cs1 can be updates through a CS2.
Mine didn't update but it would be usefull if it did.
Offline graafjp
#46 Posted : 18 January 2010 23:53:44(UTC)
graafjp
Found the following extra info for the GPF:
GFP - Changelog
V1.24 Bug Fix: Verbesserung der Software für den Booster 60173 - stabilere mfx-Anmeldung im Boosterbereich
Abfragemöglichkeit geschaffen um vom CAN den aktuellen Zustand der Funktionen einer Lok zu ermitteln
Enhancement of the software for booster 60173: more stable mfx registration in booster sections
Created the posiblity to read the actual settings of the loc functions by CAN.
Jos
#47 Posted : 19 January 2010 00:55:56(UTC)
alonso231gery
In the same way as the ms was automatically updated by the cs1.
Edited by user 19 January 2010 10:53:29(UTC)  | Reason: Not specified
An outsider.
Offline jeehring
#48 Posted : 19 January 2010 02:54:03(UTC)
jeehring
Thank you Clapcott for the nice photos and explanations !
due to its technology, user friendliness and clarity of the user-interface, CS2 probably is the most accomplished central station on the market ...Let's encourage Marklin to continue improving it & surprising us !
I'm glad to have kept my 6021-keyboard-Memory-Control 80f. Now I know the CS2 + connecting box will be my most important purchase in 2010. Should be a lot of fun and pleasure to see those good old boxes working together with the last updated CS2, to connect the old technology to the new one...
Offline jeehring
#49 Posted : 19 January 2010 03:08:44(UTC)
jeehring
GFP - Changelog
What do you think they mean with " read ...by CAN ?
Possibility to read by CAN...instead of what ?
Anyway, data of the decoders are always read through wheels + rails, so....if they want it to go through the CAN bus what does it means ? ability to connect "something able to read data" on the Can bus ??? Am I completely off Unsure
Are they talking about boosters sections only ?
Are they preparing something else ( improving the reading of the lok setting also means "improving communication with the loks "...Cool ThumpUpSmile )
Offline graafjp
#50 Posted : 19 January 2010 09:18:48(UTC)
graafjp
Jeehring,
I am also puzzled what this could mean?? Perhaps there is something new (functionality) in the making?
The changelog is about the GFP or Track Format Processor and that one is also included in the CSII.....
Jos
Guest (7)
3 Pages123>
This page was generated in 1.043 seconds.
