Offline DamonKelly
#1 Posted : 15 September 2007 17:53:18(UTC)
DamonKelly
Maybe this should be in Digital...
I just fitted a Seuthe #11 to my SZD 37159.
Very easy installation -- just insert and push down.
Upon squirting some Seuthe smoke oil in -- lots of smoke! Smile
Then I got to thinking...how does the smoke unit cope with no oil?
It appears that the decoder in 37159 is not set up to turn the smoke gen ON or OFF. [:(]
Will the smoke gen unit be damaged by being ON all the time with no oil in it?
Damon
Offline 2ndChancer
#2 Posted : 15 September 2007 18:59:11(UTC)
2ndChancer
Hi Damon
The 37159 comes w a 6090 decoder, so I suspect the smoke unit is tied with the headlight. Mine doesn't smoke(!?), but I can check the connections later.
Eric
#3 Posted : 15 September 2007 19:16:29(UTC)
If you install another decoder you may use one of the functions (e.g. f1) to control the smoke generator.
Offline M-Trackman
#4 Posted : 16 September 2007 04:05:03(UTC)
M-Trackman
[size=1" face="Verdana" id="quote]quote:Originally posted by DamonKelly
That shouldn't be a problem. I have a 3046 loco that came with the smoke generator installed back in 1975. Digital was a long way off, those generators were always on while the loco was running. I ran this loco sometimes with smoke oil, but most of the time without.
It has covered a fair amount of ground and it still works today.
#5 Posted : 16 September 2007 21:02:21(UTC)
I use a relay to switch it off.
See towards the end of http://layout.mixmox.com...stalling_digital_decoder
Digital current is higher than the old 16vAC and the older decoders were designed to be used as a various voltages up to 16V AC certainly not full 16V AC all the time. Digital power is on all teh time and higher so I do not let my smoke generators run unless I am using them. Even when using them, my software switched them OFF if it goes into a tunnel or invisible areas of the layout. This also conserves digital power.
Offline Hemmerich
#6 Posted : 18 September 2007 21:03:06(UTC)
Hemmerich
I just mentioned it already in another thread but here again:
The "smoker selection rule" is quite simple:
- for analog and switchable digital operation use the normal 16V units
- for Delta and other non switchable digital operation use the 19V units (i.e. direct connection between the smoker and the slider)
16V units are #7226, 72270 and Seuthe #10, 20 (pink bottom inlay)
19V units are Seuthe #11 and #24 (green bottom inlay)
Note: 16V units are actually specified for voltages between 10 and 16V, 19V units for voltages between 16 and 22V.
Offline DamonKelly
#7 Posted : 24 September 2007 15:07:18(UTC)
DamonKelly
Dale,
Have you any experience with using solid-state relays?
They are very small (particularly the surface-mount devices), but I'm having trouble finding the frequency response specifications. They generally seem aimed at 50/60Hz applications (unsurprisingly).
I wonder how they cope with #kHz power?
A relay does solve the problem of the potentially variable voltage difference provided by a digital decoder output against chassis ground.
I assume a "19V" unit would be appropriate in this case...
Damon
#8 Posted : 24 September 2007 18:07:47(UTC)
no, I don't think the ones I used are solid state.
I have been using 12V ones and getting away with it as can be seen at http://layout.mixmox.com...stalling_digital_decoder
Certainly a 20V one would be perfect
Offline DamonKelly
#9 Posted : 25 September 2007 17:17:18(UTC)
DamonKelly
Dale,
The relay in your photo is mechanical.
It's been at least 15 years since I last looked at "solid-state relays", and things have moved on! [:I]
It seems the low-power units are equally at home with AC or DC.
I answered my own question [:I]
BTW the "19V" was about the smoke units, not the relay.
Damon
#10 Posted : 25 September 2007 17:40:20(UTC)
cool, let me know if you find a nice small and cheap solid state relay....
Offline laalves
#11 Posted : 25 September 2007 17:49:35(UTC)
laalves
The answer to your prayers is:
http://www.loksound.de/index.php?showId=133
Scroll down to product 51963.
I've used it for things like switching a whole bunch of coach lamps from the lok. Current rating is 1 amp. It's very, very small, you can fit it anywhere.
#12 Posted : 25 September 2007 19:22:18(UTC)
is that solid state ?
Offline laalves
#13 Posted : 26 September 2007 00:02:24(UTC)
laalves
[size=1" face="Verdana" id="quote]quote:Originally posted by DaleSchultz
<br />is that solid state ?
Don't think so, it makes a relatively loud mechanical click when it actuates.
#14 Posted : 26 September 2007 01:14:24(UTC)
a loud click would indicate to me that is IS mechanical.
Offline laalves
#15 Posted : 26 September 2007 02:33:14(UTC)
laalves
<br />a loud click would indicate to me that is IS mechanical.
Ditto....
Guest (4)
This page was generated in 0.400 seconds.
