#1 Posted : 27 September 2006 14:03:43(UTC)
Question , what is the best method of Cleaning & lubricating Loks, Wheels, Carriages and Wagons.
JUst realised that all are due for Service.[:I]
Ta,
Nev
#2 Posted : 27 September 2006 14:21:01(UTC)
M-oil and Q-tips
#3 Posted : 28 September 2006 01:37:04(UTC)
<br />M-oil and Q-tips
Thanks John, What about wheel cleaning??
Nev
Offline HueyCE
#4 Posted : 28 September 2006 03:50:05(UTC)
HueyCE
I use alcohol swabs on the non-traction wheels.
Ira
#5 Posted : 28 September 2006 08:56:07(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by HueyCE
<br />I use alcohol swabs on the non-traction wheels.
Ira
TA Applied Internally or Externally
Nev biggrin
#6 Posted : 29 September 2006 00:19:44(UTC)
Maybe both?
One for the wheel cleaner and one for the wheel cleaning...
Offline HueyCE
#7 Posted : 29 September 2006 01:49:09(UTC)
HueyCE
<br />Maybe both?
Both get medicinal alcohol applied. Isopropyl for the one, 15 year old scotch for the other. I'll let you figure which goes where.[:p]
Ira
#8 Posted : 29 September 2006 02:21:52(UTC)
I use Heptan (Dipropylmethane), what we used to call, directly translated from Norwegian, "cleaned gasoline" (for the wheels, that is) and Q-tips. If the wheels are very bad, I mechanically remove the worst dirt first, with a small plastic scrape.
15 years old scotch? Hm, not so bad either.
#9 Posted : 29 September 2006 02:34:28(UTC)
<br />I use Heptan (Dipropylmethane), what we used to call, directly translated from Norwegian, "cleaned gasoline" (for the wheels, that is) and Q-tips. If the wheels are very bad, I mechanically remove the worst dirt first, with a small plastic scrape.
Thanks all for the tips, make the 15 YO Scotch a Single Malt please. biggrin
Nev
Offline Vardex
#10 Posted : 29 September 2006 02:52:39(UTC)
Vardex
I don't clean the wheels,the more traction tyres,the better!biggrinbiggrin
Bart
Offline MHauge
#11 Posted : 29 September 2006 19:53:40(UTC)
MHauge
[size=1" face="Verdana" id="quote]quote:Originally posted by Vardex
<br />I don't clean the wheels,the more traction tyres,the better!biggrinbiggrin
Bart
Well, this might go bad someday, as the wheels need to have electrical connectrion to the tracks.
But then it's easy to clean a few of them Smile
Michael
Märklin C-tracks, Mobile Station, Danish Ep 4
#12 Posted : 30 September 2006 01:45:09(UTC)
Thank you all for all of the tips.
I think I will have another Scotch and Comtemplate Lubricating the Loks and Cleaning the Wheels.
TA
Nev
Offline grnwtrs
#13 Posted : 30 September 2006 08:13:44(UTC)
grnwtrs
On some of the older rolling stock, I have used a product called "Goo-Gone" This stuff, I don't know what it really is, takes off some of the rust also. I would not use it on anything that has a rubber tyre.
Alchol is also good, especially for track. One of the Kiwi's years ago recommended it on the MML(the 90% variety). Somewhat hard to find as most of the stuff is 70%. Takes all the crud off the track, and doesn't leave any residue. Not for internal consumption. wink
I guess in a pinch, Wild Turkey, would do. biggrin Not for the rolling stock!
Gene Harvey
on the left coast
#14 Posted : 30 September 2006 10:35:34(UTC)
I do cleaning wheels with dry clothing with fluids.
Offline pserup
#15 Posted : 30 September 2006 11:52:28(UTC)
pserup
quote:
<hr noshade size="1]
Don't do that at home kids - it's carcinogenic [xx(][xx(][xx(]
Unless you have access to a fume hood at your work stay with ethanol or isopropylalcohol (sprinkler fluid for your car) [^]
Offline Vardex
#16 Posted : 30 September 2006 12:23:43(UTC)
Vardex
SR24
Bart
#17 Posted : 30 September 2006 16:09:35(UTC)
I think Methoylated Spirits will do. Straight for the Wheels and with Orange Juice for internal cleansing
Nev
Offline pserup
#18 Posted : 30 September 2006 17:14:12(UTC)
pserup
end of quote
Hmm... Must be the Ozzie way of going blind Cool
#19 Posted : 01 October 2006 03:01:42(UTC)
biggrinbiggrin biggrin
#20 Posted : 01 October 2006 12:51:32(UTC)
biggrin
PS Don't forget 46042 track cleaning wagon for cleaning track rails.
Wheel Cleaning (Small scale)
by spinnerguy 01/01/2024 22:39:18(UTC)
Locomotive Wheel Cleaning (General MRR)
by Ranjit 06/08/2020 14:14:38(UTC)
Does anyone have quick wheel cleaning tips/tricks to share? (H0-scale)
by 5HorizonsRR 16/04/2020 07:58:57(UTC)
Cleaning the 66623 wheel cleaning brush (Small scale)
by Trainiac 16/02/2019 20:07:57(UTC)
Lux H0 scale wheel cleaning devices (H0-scale)
by Rinus 23/03/2008 22:35:13(UTC)
This page was generated in 0.518 seconds.
