marklin-users.net community
| Forum
Home
Community Forum
Login
or
Register
Forum
Active Topics
Login
Register
OK
General topics
H0-scale
Henschel - Wegmann: aka another Maerklin failure
4 Pages
2
3
4
Go to Page...
Email this topic
LinkBack Topic URL
Retweet this Topic
Share Topic on Google+
Like this Topic
Share on Facebook
Digg this Topic
Reddit this Topic
Share on Tumblr
Watch this topic
Print this topic
» Normal
Threaded
Previous Topic
Next Topic
laalves
#151
Posted :
12 July 2006 18:18:51(UTC)
Retweet
I tried a few things, but when I turn regulation on, the lok simply accelerates to max instantly and stops instantly aftewr a long delay to respond to the command.
Further, I also found out that the decoder sound memory is write protected, since I tried to upload a new sound image (I don't like the factory uploaded sound), but the decoder didn't let me too.
I also tried to check the firmware to see if it needed the latest ESU upgrade and it didn't let me do it either.
I'm getting annoyed.....
Luis
WWW
User Profile
View All Posts by User
View Thanks
Posted :
12 July 2006 18:23:27(UTC)
Retweet
Poor Luis [B)] - any chances to get your cash back ?
User Profile
View Thanks
Guus
#153
Posted :
12 July 2006 19:27:44(UTC)
Retweet
Hi Luis,
originally posted by Luis:
I read the decoder data of my BR 61 and was surprised to find out the following parameters:
Regulation influence: 0%
Regulation reference: 25V
Regulation parameter K: 1
Regulation parameter I: 100
All in all, it means that the BR 61's load regulation is turned off.
Any thoughts? Is decoder load regulation irrelevant for c-sine loks? Is it the motor driver doing the load regulation? Can anyone verify what are the regulation settings in other BR 61s and any other mfx c-sine loks (this is the only one I have)?
Interesting observations.
I have to dig deep into my knowledge of electric motors.
For all I know the motor driver does the load regulation.It's a bit like the direct drive turntables of a few decades ago, the ones with the Hall sensors giving the feedback signal.
The way I understand the priniple of these C-sine motors,is that they are basically constant speed drivers.
Correct me if I'm wrong please as I'm sure you have far more knowledge on this subject than I.
Kind regards
Guus
corrected:17:52
Kind regards,
Guus
User Profile
View Thanks
hmsfix
#154
Posted :
12 July 2006 19:43:41(UTC)
Retweet
Originally posted by Guus
<br />Hi Luis,
Correct me if I'm wrong please as I'm sure you have far more knowledge on this subject than me.
Kind regards
Guus
Yes I agree. I don't have a C-Sine loco, but as I understand the concept of this motor, it simply does not need any load regulation as it won't get slower under load. It then consumes more current, but still runs on the preselected speed.
When the load exceeds a certain point, the motor simply stops.
Quite different behaviour than 5* or Can motor.
Hans Martin
User Profile
View Thanks
laalves
#155
Posted :
12 July 2006 20:57:39(UTC)
Retweet
Mmmmm.... you guys are on the point, I guess. By principle the c-sine motors is a constant speed motor, being in fact a stepper motor. This stepper characteristic explains the slight startup jerkiness of all c-sine loks I have.
So, no need for load regulated decoders. And come to think of it, no need for PWM either! Which means that, as long as the correct driver interface is used, one could even use an old Delta decoder (with the handful of components needed to use it to control DC motors), or any older, non regulated decoder, to drive a c-sine motor!
Luis
WWW
User Profile
View Thanks
Guus
#156
Posted :
12 July 2006 21:56:20(UTC)
Retweet
Yes although I find its hardly noticeable with the old type of C-sine engine due to its large rotor,which acts as a flywheel.
The newer type comes in various guises, either with or without an external flywheel.
Funny when you think of it.
The engine designers make every effort to keep the inertia of the motor as low as possible and the train manufacturers put in a flywheel in order to make it more suitable for their locos.
Kind regards
Guus
Kind regards,
Guus
User Profile
View Thanks
Hemmerich
#157
Posted :
15 July 2006 01:47:23(UTC)
Retweet
Very simple reason.
For any loco with C-Sine motor, the driver pcb directly performs the load regulation; independent from the decoder.
That's why you'll find the load regulation parameters of the decoder being turned off at all models with such a combination; i.e. for example as well at the MWB Taurus (#39834) or the Imotrans V200 (#39820), etc.
In order to have this combination work properly, the driver pcb also needs an additional output line from the decoder.
Lutz
User Profile
View Thanks
laalves
#158
Posted :
15 July 2006 02:20:23(UTC)
Retweet
Originally posted by Hemmerich
<br />In order to have this combination work properly, the driver pcb also needs an additional output line from the decoder.
Hi Lutz,
What output line?
Luis
WWW
User Profile
View Thanks
Posted :
15 July 2006 02:42:02(UTC)
Retweet
Originally posted by laalves
<br />...This stepper characteristic explains the slight startup jerkiness of all c-sine loks I have....
That's odd.. I have several C-sines 39104, 39601, 39604, 39607 and 39610 none of them exhibit jerkiness on startup.. Their abiliy to run smoothly on grades at very low settings is nothing short of amazing to me.. [^]
The 37xxx series certainly has startup jerkiness on very slow speeds - the lighter the model the more noticable the problem... However, they still run much better than Deltas or very old digitals (eg 3665)..
Australia flag by
abFlags
.com
User Profile
View Thanks
VT95
#160
Posted :
12 August 2006 16:02:44(UTC)
Retweet
I just bought a new in box set. When testing on my layout it can't cope a 3% slope, the wheels begin to spinn. Anyone similar problems?
User Profile
View Thanks
Guus
#161
Posted :
12 August 2006 16:11:18(UTC)
Retweet
[size=1" face="Verdana" id="quote]quote: I just bought a new in box set. When testing on my layout it can't cope a 3% slope, the wheels begin to spinn. Anyone similar problems?
Haven't had this problem however I'll test mine again this weekend.
Keep you posted.
Kind regards
Guus
Kind regards,
Guus
User Profile
View Thanks
Guus
#162
Posted :
13 August 2006 14:16:59(UTC)
Retweet
Hi VT95,
Today I did a test with the HWZ pulling up a ramp with a slope of 3degrees and and one of 4 degrees.
The loco had no problem whatsoever going up these grades.It pulled the complete train and still has power left to pull some more waggons.
I used a temporary test track made up of C-track supported by a piece of particleboard.
Are your antislip tyres still in good shape?No hardened rubber?
Hope you'll find what's troubling your loco.
Kind regards
Guus
Kind regards,
Guus
User Profile
View Thanks
MärCo
#163
Posted :
13 August 2006 14:27:33(UTC)
Retweet
To complete Guus:
1) Are the traction tyres not hard or dirty?
2) Are the tracks clean. No dirt or oil on the tracks?
3) Are there no loose items in the gearing of the locomotive?
Absolutly AFB-NOHAB fan ;-)
User Profile
View Thanks
VT95
#164
Posted :
13 August 2006 23:43:18(UTC)
Retweet
Yhanks for the advise guys.
I cleaned the tires and the track of oil. A little improvement but not much.
Since the t slope is still under construction i have lowered it to the point where the loc can take it. The loc still has sicgnifficant less grip as my other locs though. Could there be something wrong with the rubber tyres, it is a brand new loc.
User Profile
View Thanks
Alberto Pedrini
#165
Posted :
14 August 2006 21:58:31(UTC)
Retweet
Hi friends,
any suggestion to resolve the behaviour of some trucks of the coaches?
After a bend they don't return straight! [:(]
Oil doesn't work.
Alberto
Marklinfan Club Italia
www.marklinfan.net
WWW
User Profile
View Thanks
Posted :
15 August 2006 00:24:13(UTC)
Retweet
Some added weight maybe? The coaches are awfully light...
WWW
Facebook
Your Twitter Name:
User Profile
View Thanks
Alberto Pedrini
#167
Posted :
15 August 2006 10:23:04(UTC)
Retweet
Thanks Juhan, but I have mistaked word [:I], I meant the skirts (right?), the trucks are ok.
Alberto
www.marklinfan.net
WWW
User Profile
View Thanks
VT95
#168
Posted :
15 August 2006 15:10:08(UTC)
Retweet
I know the problem....
The HW set is a least 200€ overpriced.
User Profile
View Thanks
Hoffmann
#169
Posted :
15 August 2006 22:33:51(UTC)
Retweet
Hello Alberto,
Please do not use oil on these skirts, Plastic does not take kindly to Oil ( it has a tendency to expand ).
A silicon Spray may be the answer however it may also be possible to fix the skirt to the boogie ( trucks ).
Someone here might have a better solution.
Martin
marklin-eh
User Profile
View Thanks
Posted :
15 August 2006 23:22:17(UTC)
Retweet
So the skirts are not mounted fixed to the trucks??? Sighhh....
I haven't run mine yet (no layout) but if that is the case, it seems like a very bad engineering solution indeed...
WWW
Facebook
Twitter
User Profile
View Thanks
MärCo
#171
Posted :
15 August 2006 23:54:54(UTC)
Retweet
Could this train be old Rivarossi or Lilliput tooling ?
User Profile
View Thanks
Hemmerich
#172
Posted :
16 August 2006 03:01:55(UTC)
Retweet
Originally posted by almagik
<br />Hi friends,
Oil doesn't work.
Known problem (warranty case - as long as Märklin doesn't determine that the oiling caused your problem).
User Profile
View Thanks
Alberto Pedrini
#173
Posted :
16 August 2006 11:47:24(UTC)
Retweet
Thanks Lutz,
I'll try to benefit of the warranty.
Faller oil don't damage plastic...
Alberto
www.marklinfan.net
WWW
User Profile
View Thanks
Armando
#174
Posted :
16 August 2006 21:34:18(UTC)
Retweet
What a piece of crap that Henschel-Wegmann turned out to be! I think that all of us "insiders" who got screwed by Mäklin with this set should write a letter to demand that our models be taken back for a credit or refund.
Sorry, but I cannot have any nicer words regarding this H-W issue.
Armando
Armando García
User Profile
View Thanks
Alberto Pedrini
#175
Posted :
26 December 2006 12:53:28(UTC)
Retweet
HWZ returned home repaired, now the skirts behaviour is correct.
Now I have a couple of questions.
Did anyone paint the violet curtain of the cab in black?
Is it possible change the synchronization of sound by the CS (I don't have it), mine sound too much ciuff ciuff every wheel turn, I think.
here the last pics of the train
Alberto
www.marklinfan.net
WWW
User Profile
View Thanks
laalves
#176
Posted :
26 December 2006 15:22:29(UTC)
Retweet
I removed the cab curtains altogether. I think it looks a bit more natural.
Luís
WWW
User Profile
View Thanks
Posted :
26 December 2006 18:31:31(UTC)
Retweet
Very nice,thanks for showing the pictures.
User Profile
View Thanks
Alberto Pedrini
#178
Posted :
26 December 2006 21:40:44(UTC)
Retweet
<br />I removed the cab curtains altogether. I think it looks a bit more natural.
Luís
It could be a solution, thanks Luìs.
Alberto
www.marklinfan.net
WWW
User Profile
View Thanks
4 Pages
2
3
4
Go to Page...
General topics
H0-scale
General topics
- General MRR
- H0-scale
- Small scale
- Big scale
- Prototype
--- Videos
----- Steam
----- Electric
----- Diesel
----- Accidents
- Digital
- Model railroad software
- Model railroad photography
Reviews
- Loco Reviews
- Reviews of rolling stock
- Accessories reviews
- Model kit reviews
Collector's Corner
- Collector's Corner general
- Märklin Sprint
- Construction kits
- Steam engines
- Tinplate toys
The Projects & Workshop area
- Track plans
- Painting & Weathering
- Model railroad wiring
The Club Corner
You
cannot
You
cannot
You
cannot
You
cannot
You
cannot
create polls in this forum.
You
cannot
vote in polls in this forum.
Powered by YAF.NET
This page was generated in 0.775 seconds.
