Offline trainbuff
#1 Posted : 20 June 2009 21:49:17(UTC)
trainbuff
Are all three pole motors with a permanent magnet the same and can they all be driven by the same type of decoder?
Which decoder would be best for such a motor?
These questions are because I converted a Fleischmann loco that has a three pole motor and a permanent magnet to AC 3-rail using a marklin fx decoder out of a BR 86 from starter set 29533. The lok runs choppy at low speeds and the lights flicker. But at high speeds it runs smooth. The lights are fine at a stand still. I used marklin inductors (chokes) between decoder and motor. I'm pretty sure its a motor-decoder interaction, as all parts have been cleaned, oiled, etc.
Here are some details of the conversion: https://www.marklin-user...ult.aspx?g=posts&t=12968
Thanks for any suggestions
#2 Posted : 20 June 2009 22:13:19(UTC)
ESU decoders (and all other major brands) have CVs that allow them to match the motor.
The cheapo M* starter set and hobby decoders (e. g. 60760) cannot be configured to match the motor - so they'll work OK only with matching motors.
This is rather no matter of 3-pole vs. 5-pole - M* motors are different from GFN motors (but one M* Delta loco has such a GFN motor).
Load regulation measures the voltage generated in the motor - therefore it strongly depends on the kind of motor.
Offline Brakepad
#3 Posted : 20 June 2009 22:33:48(UTC)
Brakepad
France, Metropolitan
I'd use a LoPi or a UHL 76320 (this one is cheaper). You can modify CVs in both in order to perfectly match every motor needs.
Offline trainbuff
#4 Posted : 21 June 2009 01:58:26(UTC)
trainbuff
Thanks, that pretty much answers my main question. By LoPi I assume you mean ESU LokPilot. Whats a GFN motor?
#5 Posted : 21 June 2009 02:15:43(UTC)
GFN is short for Fleischmann ("Gebrüder Fleischmann, Nürnberg").
GFN manufactured locos for Märklin - sometimes with Fleischmann motor.
#6 Posted : 21 June 2009 04:17:21(UTC)
And for suggested CV settings, at least for Marklin motors, have a look here: http://www.toottoot.co.n...r%20Marklin%20Motors.pdf
Offline trainbuff
#7 Posted : 21 June 2009 07:10:54(UTC)
trainbuff
Thanks all. In my thread on converting the Fleischmann 4330 to digital, I just added some links to a videos of the lok running. Let me know if you agree if its an improper motor-decoder match.
This page was generated in 0.420 seconds.
