Offline Bookfwe
#1 Posted : 31 August 2005 20:31:59(UTC)
Bookfwe
This may be a basic question to the experienced model railroader, however, I always wondered how, as an operator, an easy way to determine the route to put a train back in the yard and how do I know which train to pull out without having an accident. I would assume the yard is hidden from view so this must be done via train chart. I would appreciate any comments.Javascript:insertsmilie('Smile')
Smile Smile
Offline MärCo
#2 Posted : 31 August 2005 21:10:31(UTC)
MärCo
Staging Yard, also known as Fiddle Yard ?
Absolutly AFB-NOHAB fan ;-)
Offline stephenbb
#3 Posted : 31 August 2005 23:27:08(UTC)
stephenbb
Generally if you can't see the yard you would have a plann layout of the fiddleyard and track numbers as well as train configuration. If you are running digital you would have each of the turnouts numbered as well. When you build the consist you should have a work order to determine where the train would be located.
Stephen(USA)
Stephen(USA)
ETE,NMRA,MEA
#4 Posted : 31 August 2005 23:56:08(UTC)
It would be fiddle yard under layout or hidden yard in mountain or so.
Offline PierreGILLARD
#5 Posted : 01 September 2005 03:08:40(UTC)
PierreGILLARD
I would recommend this lecture :
"The model railroader's guide to Freight Yards" by Andy Sperando, Kalmach Books ( http://store.yahoo.net/kalmbachcatalog/12248.html ).
There are descriptions of how an actual yard is operated. Also full of advices how to build your model yard.
Pierre.
#6 Posted : 01 September 2005 03:22:00(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by Bookfwe
<br />how do I know which train to pull out
Ya better know nothing. It adds to the thrill [xx(] - Sorry Jeff, just a Smile[:o)]
Seriously, what about small windows plus lights just to be on the safe side ?
Offline Tony
#7 Posted : 01 September 2005 09:26:58(UTC)
Tony
Hi guys, seems to be many terminologies regarding Staging Yards, Shadow stations, marshelling yards, etc and their various operations. I came across this link which describes the types of staging yards very well. Some of you may be interested.
http://www.vetmed.auburn...LDSIGprimer/Staging.html
Also, I plan to install a small colour micro camera in my hidden staging yard so that I can see which train is in which position. This will then show on a small TV monitor.
Regards Tony
Help with automatic staging yard (H0-scale)
by Mike M 14/09/2013 02:59:28(UTC)
Help with automated staging yard (Model railroad wiring)
by Mike M 24/08/2013 01:23:49(UTC)
Automated Hidden Staging Yards (Model railroad wiring)
by Mike M 24/06/2013 20:31:10(UTC)
Staging yard control (Digital)
by Maurice 26/10/2008 03:52:01(UTC)
This page was generated in 0.573 seconds.
