Offline drstapes
#1 Posted : 26 February 2009 00:28:44(UTC)
drstapes
After years of large sprawling layouts,having moved and downsized I now have room for an 8 by 4 layout. I am having difficulty in planning this. Idealy I would like a tail chaser, an in and out and a figure of 8. However there doesn't appear to be enough room.different levels might be the answer. Any track plans would be helpful
Geoff (UK)
Offline Writhdar
#2 Posted : 26 February 2009 01:40:48(UTC)
Writhdar
Geoff,
If you can squeeze out two more feet for 1/2 of the 8 ft length, I have a plan (based on an old Marklin plan) that has a lot of activity but minimal scenery.
It is with M track and utilizes some 5137 switches but it can be modified to 5202 types. I also have a plan using C track. Email me if you are interested and I can pass on more info.
Dan
Offline Laffe
#3 Posted : 26 February 2009 19:49:03(UTC)
Laffe
Having room for an 8x4, usually means that you have a 12x8 foot room (assuming 2 feet access space all around). Have you considered doing an around the walls or walk-in type layout instead? With that kind of space you usually get a longer run if you avoid the basic 8x4 shape.
Otherwise, take a look at this way to split and re-arrange a 8x4 board:
Outer size is 8x9, but you can butt it up against a corner, since it's no wider than 3 feet at the widest parts. The descriptions are in swedish, but the plan should speak for itself. The right hand track disappears down into a valley and then to a hidden return loop below the main level. Here you can have a small storage yard for a couple of trains, so you vary the traffic.
/Laffe
Wargamer, Roleplayer, Proud Father and Born-again Model Railroader
Offline atilla
#4 Posted : 28 February 2009 16:02:34(UTC)
atilla
I've been messing around with railly 4.0 and drawing all sorts of plans. I found myself looking at the Marklin book that came with my starter set and found several of those that seemed quite nice to me. They seem to fit in pretty compact spaces.
Offline drstapes
#5 Posted : 01 March 2009 01:39:25(UTC)
drstapes
thanks for the ideas guys.
Geoff (UK)
#6 Posted : 01 March 2009 10:25:48(UTC)
Excellent trackplan.
Offline obxbill
#7 Posted : 02 March 2009 00:02:48(UTC)
obxbill
I like the general arrangement of this layout. I wonder, could it be made to fit in an 8x8 room? That's all I have to work with, myself. I'm using M-track.
Bill
[size=1" face="Verdana" id="quote]quote:Originally posted by Laffe
<br />Having room for an 8x4, usually means that you have a 12x8 foot room (assuming 2 feet access space all around). Have you considered doing an around the walls or walk-in type layout instead? With that kind of space you usually get a longer run if you avoid the basic 8x4 shape.
Offline Laffe
#8 Posted : 02 March 2009 01:04:24(UTC)
Laffe
[size=1" face="Verdana" id="quote]quote:Originally posted by obxbill
<br />I like the general arrangement of this layout. I wonder, could it be made to fit in an 8x8 room? That's all I have to work with, myself. I'm using M-track.
Bill
I didn't make this plan originally, but I can try to fit a similar plan with M-track. Give me a couple of days though...
/Laffe
Offline obxbill
#9 Posted : 03 March 2009 00:53:07(UTC)
obxbill
Thanks, Laffe! I really appreciate it. My plan was to just lay track and see how it works. Some kind of plan would really help me. Smile I plan to just use 5100 radius because of space.
Bill
Offline drstapes
#10 Posted : 23 March 2009 04:13:14(UTC)
drstapes
If you look in the layout section you will see the beginnings of my layout. Thanks for all the suggestions.
Geoff (UK)
Guest (6)
Marklin Magazine Track Plans (General MRR)
by BwanaJoe 08/06/2025 17:22:40(UTC)
Track plans help (Track plans)
by Sir Timbo 19/02/2019 04:00:41(UTC)
Marklin magazine track plans (Track plans)
by dpetersen 29/03/2018 19:08:52(UTC)
PDF dl of lots of old Marlin track plans from Marklin Track plan books? (Track plans)
by ShannonN 24/12/2017 01:15:20(UTC)
3600 track plans for post-war historic/dealer square-shaped layout (Collector's Corner general)
by Marklinista 24/09/2017 05:28:29(UTC)
Track Layout Software: Given the number of track as input, should suggest possible track plans (H0-scale)
by madhu.gn.71 18/11/2015 06:47:28(UTC)
New website with free track plans and layout designs (General MRR)
by Mixy 05/11/2013 19:27:25(UTC)
Loisl Track Plans for Swiss Railways (Track plans)
by 5HorizonsRR 29/10/2012 19:59:16(UTC)
marklin 'track plans' book for C track (General MRR)
by chelseadrake 11/10/2012 21:49:11(UTC)
Track plans...1930's and 1950's. (Collector's Corner general)
by Ian555 08/09/2012 09:43:55(UTC)
Track Plans for Marklin 3-Rail H0 / Catalogue Scans ? (General MRR)
by 20-VOLT-AC 02/03/2012 17:12:13(UTC)
K Track Plans to C Track (H0-scale)
by jonnymac 29/11/2010 08:13:35(UTC)
by Joseph Meiring 15/05/2010 19:19:06(UTC)
track plans 0292 (Small scale)
by terry.whitworth1 15/05/2010 18:55:18(UTC)
Streamlining Track plans with barcode (Track plans)
by river6109 02/03/2010 02:20:12(UTC)
M track Plans needed (H0-scale)
by Joseph Meiring 14/02/2010 23:06:15(UTC)
Mario Fabro - Era V-VI - CH/D/I track plans (Track plans)
by MarioFabro 13/03/2009 19:54:53(UTC)
R3 and wider track plans (General MRR)
by ttenordave 16/02/2008 15:34:13(UTC)
Needed Z Gauge track plans (Track plans)
by kiwi 30/04/2007 04:19:39(UTC)
C Track plans (H0-scale)
by kiwi 27/03/2006 08:37:15(UTC)
Book on C Track plans? (Track plans)
by cazart 23/03/2005 00:40:48(UTC)
This page was generated in 0.368 seconds.
