2 Pages12>
Offline davidrod
#1 Posted : 16 February 2005 05:45:02(UTC)
davidrod
Views messages in topic : 15
Hi All,
This is my first post here. I have been a marklin "follower" since my first trip to Germany back in 1991. That's when I bought my first starter set, and ever since I have been buying little by little pieces to add to my set. Several moves accross countries and then states didn't help my layout, and finally a 4 years ago I bought a Noch layout and was able to get my system going in a permanent place after so many moves...
That didn't last long, as we soon got a dog and the bastard started eating the cables which prompted me to lay the layout agaisnt the wall and not look at it for 3 years.
Finally a couple of months ago I moved (again) and I finally found myself with the space to not only have this layout but add several pieces to it...
Always being a big technology freak, I thought that I would jump on the digital bandwagon, but since I didn't want to buy "Old technology" I jumped in with a starter set with the 60652 Mobile station and the power pack...
My impressions? It looks cool, it handles cool, too bad my old locos don't have all the extra functions, but I'm sure I'll be getting those eventually...
One thing I think sucks big time is the fact that I can't have more than 2 locos running at the same time... (I'm using the power pack that came with the set)
The question is (finally!) if I get a 42 va transformer, would I see a big difference... Would I be able to drive 3-4 locomotives???
From what I have seen, it seems that I'll be needing to get the 60212 station whenever it comes out, (I'm planning on having about 110 feet of track) but I'm a little desperate as you can imagine and was wondering if this would be a temporary fix...
I do have a 32 va transformer here, but I believe I need a special cable which I can't find the # for...
Thanks for your answers/insights on this matter...
By the way, my name is David Rodriguez and I live in South Florida. I'm running C track on a 4' x 8' (2 x 1 meters) with 4 switches and 4 lights (viessmann) but I'm already working on a bigger layout...
It is nice to be important, but it is more important to be nice...
Offline Hoffmann
#2 Posted : 16 February 2005 06:02:34(UTC)
Hoffmann
Hi David welcome,
You can make the Cable yourself, go to Radio Shack and purchase the Plug which goes in the Ugly Box( where you plug in your 18VA Transformer) It is a Standard Plug, attach two wires to the Plug and plug them into your 32VA TRansformer (brown and yellow).
If you take your 18VA Trafo with you Radio Shack will be able to get you the right Plug.
Martin
marklin-eh
Offline Lars Westerlind
#3 Posted: : 16 February 2005 08:58:09(UTC)
Lars Westerlind
and nice to hear you!
First, both the transformer and the Mobile Station (MobStat) have precautions agains overheating = power limits. So, if you use a 30 VA transformer with the MobStat from a starter set, you will still nog get more than around 20 VA to track.
Becuase,
the starter set MobStat is limited to 1.2 A, the 60652 bought separately, 1.9 A or near 30VA.
If you buy another 60652 separately, you can use the old MobStat as "slave" controller provided you have the piece of cable needed for this (may be you get it with a 60652?). In this case you have 30 VA, and two controllers.
Lars
It's the Mobile Station that limits the power, regardless if you use a stronger transformer or not. You may buy an
Offline davidrod
#4 Posted : 16 February 2005 15:26:14(UTC)
davidrod
Thanks for the info. It seems to me like this is a little bit of false advertisement on Marklin parts... "You can control 10 locomotives" just not at the same time... Not even half, but just 2... As nice as it is I liked it better before when I was able to run 4 locos at the same time with the Delta box...
I will try to do what you guys said here, see if it helps make any different... I will post the results in here too
thanks
#5 Posted : 16 February 2005 15:33:40(UTC)
Lars Westerlind
Well,
I understand you, but I don't not agree. You can control 10, but you can't run them at the same time. If your power doesn't suffice for more than 2 trains, either you use the current for more, like car lights, or other lights, or your locos are really heavy drinkers...
In the past the rule of thumb was 3-4 locos with 30 VA, which is in correspondance with your situation; however, recents reports say that modern locos consume less.
/Lars
#6 Posted : 16 February 2005 15:40:33(UTC)
Lars Westerlind
BTW,
if you have a Deltabox, I think you can do something smart.
Use the connection track of the MobStat as a programming track (in DCC sense), meaing, let it be a loose track beside the layout. Connect the Delta with the old transformer as a booster to this track. Meaning; it's red and brown cable connected to the programming track, it's yellow and brown to the old trafo, connect the two grey sockets with cable, and the knob in the rightmost position.
And the layout connected as in the past to the Delta.
There was a german site reporting that this works, and you will have the same amount of power as before (30VA). The speedbar of the MobStat flashes, that's all. And everytime you buy a new mfx-loco, it must be put on the programming track to be introduced to the system.
Don't do any more connections than those described, unless you understand what you are doing.
Lars
#7 Posted : 16 February 2005 16:02:26(UTC)
Hi David:
Welcome Smile to The Forum !
BTW, should you really be in need for an 2nd Mobile Station don't buy this item separately - it's wasted money ! For the price of an solo-buy MS you can get the cheapest Systems Starter Set (Firetrain) - or for a few bucks more a better one - and loco, cars, track, plus another transformer are virtually for free.
I often buy starter sets (when they contain locos I'd like to have) - since they're for promotion and thus real bargains biggrin
The connection cable for plugging a 2nd MS into connection track is # 610479
post scriptum: You would be surprised how many locos can run troublefree with a standard MS & that little black 18VA tranny - just test it by yourself [:p]
#8 Posted : 16 February 2005 16:57:37(UTC)
Hi David (not another David...must change my name!!) You should be able to run more than two locos. I can run four and that includes two with cars with lights.
I agree with John if you want another MS but a start set with a loco you like and you get it free. Central Station will come at the toward end of this year which will solve most problems (I hope) and the IB boys can tell you about their stuff if you cant wait until then.
Welcome to the forum.
David
#9 Posted : 16 February 2005 17:08:42(UTC)
Lars Westerlind
<br />Hi David:
Dear John,
did you read what was asked for[:p] The question was about more power, not more MobStats. And to my knowledge, the Mobstat with higher rating is not supplied in the starter sets you speak about...
Lars
Offline Davy
#10 Posted : 16 February 2005 17:24:36(UTC)
Davy
The mobile station out a starterkit with the small black 18va trafo can deliver 0,9 A
With a 6647, 6002 it will use 24 va that is with digitaal use 1,2 A
The mobile station that is sold lose can use 36 va with digitaal use 1,9 A.
These numbers are from the Dutch Marklinsite. There is a lot more information about Marklin systems there then on the German website.
You must only buy a mobile station with 1,9 A if you want to drive with four, five locs at the same time. Our with three of four big va users. That is locs with the old 3 star engines.
M-track with a CS2.
Offline frankv
#11 Posted : 16 February 2005 20:45:02(UTC)
frankv
So, if one wanted to move from the 6021 to the mobile station and have the setup able to handle the most loks:
1) Buy the 60652 Mobile Controller. (by the way I read on one distributor's web site that the controller that is included with the starter sets is a 60651. Could be a typo, but could it explain the 1.2A vs 1.9A issue?)
2) Keep your 6002 Transformer as the power supply.
Then, would you need to:
a) Buy the Mobile Station Feeder Track?
b) Buy some type of cable to connect the 6002 to the Mobile station?
Is there something else involved, or would this be a complete shopping list?
Frank
Offline stephenbb
#12 Posted : 16 February 2005 20:51:48(UTC)
stephenbb
It's official the cebtral station won't see delivery until late 4th quarter. Its not the hardware, the software has not been finalized and will take some time to be completed.
This information came to me via my local dealer who was at the factory this past week. Bob said that their were many new items in development that won't see the light of dayuntil late this year or 2006.
He also thought the detailing on the insider was excellent!
Stephen
Stephen(USA)
ETE,NMRA,MEA
Offline Davy
#13 Posted : 16 February 2005 21:53:47(UTC)
Davy
Then I was right when i said that it could be a software problem.
It is almost always the software.
M-track with a CS2.
Offline HueyCE
#14 Posted : 17 February 2005 00:15:11(UTC)
HueyCE
Welcome to the forum David.
#15 Posted : 17 February 2005 00:33:15(UTC)
Second MS can be used if the layout is split. This should allow 6/7 trains to run.
David
#16 Posted : 17 February 2005 00:41:19(UTC)
In one of the numerous topics about the MS in the forum, our friend perz had made a real life test with the MS and the 18VA power pack - and if I remember correctly, 3-4 locs was no major problem.....
Offline davidrod
#17 Posted : 17 February 2005 01:19:41(UTC)
davidrod
I guess I must have some very heavy drinkers then... I run without a problem a 34633 Pepsi Loco and a 33184. Those 2 guys go around the tracks without any problems. As soon as I give some power to the third loco (Cargo Loco from 29646 starer set) the Mobile Station gives me the overload signs... This doesn't happen with just that particular locomotive, but with any combination of the three.
I bought the Mobile Station off ebay. I thought that $90 I was getting a pretty good deal, considering the unit itself costs over $160. For $90 I got the unit, the power pack and the 24088 connector.
According to the instructions, you can only have the track connected to the power pack, therefore I connected all of the signals to the separate transformer.
I checked on the back of the unit and all of the cataloges, and everywhere it says "60652" however, there is no electrical information on the back, only on the power pack.
My guess is that there has to be a difference somewhere, otherwise why would they sell starter sets with different transformers?? Some have the power pack and others have a 60VA transformer...
Maybe I need a crash course on electronics and electricity to understand all of the factors to be taken into consideration. It was my understanding that the transformer would make the difference, therefore having a 18va power pack or a 42 va transformer...
I did think about buying another starter set because they are a pretty good deal, I thought that I would do that because I could get the bigger transformer, but if now you are saying that won't make a difference, I'm not so sure if I should get it...
Offline hqstu
#18 Posted : 17 February 2005 02:35:13(UTC)
hqstu
Hi David, all.
As Lars has said, the output is limited by the mobile station itself, not the size of the transformer. Davy has mentioned from the dutch sites that real life tests have determined a "little bit" more can be gained from using (say) a 42VA trany over the 18VA power pack.
Making your own cable is no big deal, the connecting track (uglybox) can take DC or AC 16-18 volts, you just need a suitable plug found in any electronics store. Yes it is a bit misleading of Marklin to supply 60VA tranys with the 1.2amp starter set MS, but this I guess is a bit of future proofing for the Central Station.
A delta decoder engine will use significantly more power than a permanent magnet high efficiency digital decoder, which explains your situation. I have run up to 4-5 digital locos simultaneously with a 1.2 amp MS. It all dies quick however if you start using filament bulbs etc, which many delta locos also probably have.
Also as has been said often before, it is important not to confuse the role of the MS with that of the 6021 controller. The MS was never designed to be the central controller in a reasonably sized layout.
Stuart
#19 Posted : 17 February 2005 05:50:19(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by Lars Westerlind
<br />Dear John,
did you read what was asked for [:p] The question was about more power, not more MobStats. And to my knowledge, the Mobstat with higher rating is not supplied in the starter sets you speak about ...
Dear Lars,
I did but then was carried away by those prices - my mistake, sorry [:I]
YOU are right Smile
Offline dudok12
#20 Posted : 17 February 2005 09:57:06(UTC)
dudok12
Hi David,
This may have been suggested before, but another solution to more power is to consider buying an Intellibox. This control box, used by many of us, has 3 A output, 2 controllers, a computer interface, a keyboard for switches etc. You can even connect your mobile station to it via an adapter. It currently doesn't 'do' MFX, but it does function very well with DCC and marklin motorola ('old' marklin digital) and even Selectrix.
Downside is that is expensive, but sometimes you can get lucky on Ebay...wink Nobody knows when the central station will be in the shops, so this could be a nice solution, given your plans for a big layout...
Cheers, Bernhard
IB since 2000. Latest loc aquisition: 37554 BR 55 a long time ago...
Offline Rudi Bekkers
#21 Posted : 17 February 2005 11:46:55(UTC)
Rudi Bekkers
Hi everybody,
Sorry that my reply is so long, but there are several interesting issues here which might also benefit others….
First of all, like some of you I was surprised to read that David was only able to run two loco’s simultaneously from his Mobile Station. I can run 5 loco’s from the same device (the 1,2 amps MS and the 18 VA transformer from the smaller start sets). At the same time I have two illuminated couches running, and steam in one of the loco’s. And it all runs well. I do realize that I have to invest in more power of I add one or two other things, but as long as things run well I just keep it this way. David, I infer from your text that you tried your setup with three or more locomotives. Does the system halt with ANY combination of these loco’s? If so, that would mean that either all your loco’s are extremely power-consuming (which seems unlikely), or that something is wrong with your MS/transformer.
It might be a good idea to look at the two voltage readings build into the mobile station, at different loads (1, 2 and 3 trains). If I remember well, you can get these reading when you go to the option menu. I could compare your findings with those of mine, if you like me to.
BTW for this type of purposes it is a great thing to have an build-in voltage meters. If this was not the case, each of us would have to use his or her own voltage tester. And this could be quite troublesome, since the signal is a complex one, meters might give total different readings, and we would have to discuss (expensive!) RMS metering and so on. It is much easier and cheaper to compare the build-in meter readings (even though we do not know how reliable these are, this is not too much of an issue here).
Secondly, the Dutch Märklin website seems to give some more detailed information concerning the power of the mobile station than the other language sites I looked at. In fact, it indicates that the power limitation in the smaller start sets is actually the small black transformer, not the small Mobile Station itself. Below, I translated this information. It is taken from www.marklin.nl/systems/faq.html, I just copy it for what it’s worth.
<ul><li> Mobile Station from the H0 start sets, in combination with the supplied small black transformer can handle a load of 18 VA and a maximum current of 900 mA. This is sufficient for 1 or 2 small Delta loco’s or loco’s with a 6080/6081 decoder. It is also sufficient for 2 to 3 small loco’s with a Hochleistungsantrieb or C-Sinus motor.</li>
<li>Mobile Station from the H0 start sets, delivered with the larger grey transformer or an existing 6647 or 6002 transformer, handle a load of Max 24 VA and a maximum current of 1,2 A (1200 mA). This is sufficient for 2 or 3 small Delta loco’s or loco’s with a 6080/6081 decoder. It is also sufficient for 3 to 4 small loco’s with a Hochleistungsantrieb or C-Sinus motor.</li>
<li>The separately supplied Mobile station (available later on) or the Gauge I start sets, combined with the supplied larger grey transformer or an existing 6002 transformer cvan handle a 38 VA load and a current of 1,9 A =1900 mA. This is sufficient for 3 or 4 small Delta loco’s or loco’s with a 6080/6081 decoder. It is also sufficient for 6 to 7 small loco’s with a Hochleistungsantrieb or C-Sinus motor.</li></ul>
Conclusion: this all seems to confirm David’s experience: no more that two loco’s in for the smallest combination. And a larger transformer would allow him to run some more trains. It remains strange, however, that many of us actually manage to run many more trains using the same set. (((hey, could it be that Märklin did not have the cheaper, 1.2 amps rated 60652 in stock and supplied many people the stronger, 2 amps rated 60651 unit, without telling them?.. just fishing… )))
Thirdly, I would like to raise the issue WHY we have two different mobile stations…. Märklin argues that this is a cost issue; the additional component cost would be so high that they decided to include a lower-power version with the cheaper start sets (www.maerklin.de/systems/index2.html).
I dare to question this claim. Although I very well realize that that there usually is a rather large multiplier between component price and the end user price of a device, it is hard for me to believe that this particular component (the power driver) would be so expensive that it makes up for the extra expenses on production and logistics on Märklin’s side. To be honest, I suspect that having two mobile station types is really a marketing issue, not a cost issue. Would be interested to hear other people’s thoughts.
Lastly, I was thrilled to read the suggestion to use a Delta station as a small booster. I have seen this suggestion before, but didn’t yet think of it in combination with the Mobile Station. Does anybody know what the actual output current (in amperes) of the Delta station is? I would like to know how this compares to the two versions of the mobile station. And any one knows how much current is the central station supposed to offer?
If my need for power grows, I might consider to use the ‘Delta booster’ for one part of my layout, and the regular Delta output for the other (being aware the first-time recognition of eventual MFX decoders has to take place at the latter part of the layout). Are there any issues concerning the transition track from the one part of the track to the other? What are the generals rules connecting tracks fed by different 6017 boosters, for instance?
Ok, sorry to take so much of your time and space. And so many questions. I’ll try to do that never again…
Regards, rudi
Offline HueyCE
#22 Posted : 17 February 2005 12:25:40(UTC)
HueyCE
Rudi- Long posts are not a problem, especially not ones as well written as yours. There are never too many questions, the answers to which I would like to know myself.
Ira
#23 Posted : 17 February 2005 13:17:23(UTC)
Rudi Bekkers
BTW, sorry Davy for overlapping with some things you stated earlier about the Dutch website... I overlooked that.
/rudi
#24 Posted : 17 February 2005 14:09:40(UTC)
Lars Westerlind
Hello Rudi,
1. Delta control (and Delta control 4f) limits to 2A before it shuts of. To David: BOTH the transformer AND the central unit (regardless if MobStat, Delta, Intellibox or whatever) have limiting circuits; it's primarily a regarding protecting your equipment and not limited 'capacity' of the transformer. Meaning, that the unit with the weaker rating sets the limit.
2. I certainly agree that the reason for two different ratings of the MobStat is a marketing issue. Nothing to do with cost; it should have been much cheaper just to have one model.
3. With the delta booster setup, I would recommend not to control any part of the track directly from the MobStat, just to be sure. You can have several Deltas connected in parallel instead. Reason for this is the Delta is reported to give a slight delay in the signal; possibly causing shorts when a trains goes from one power district to another.
Lars
#25 Posted : 17 February 2005 14:59:45(UTC)
Rudi Bekkers
Hi Lars,
Thanks for the reply. Good to hear the Delta puts out 2 amps, so if you have one lying around there is no more reason to invest in the more expensive 2 amps MobStation.
It's also interesting to read your reply on de Delta station as a booster while feeding another part of the track directly with the MobStation. This was indeed what I was wondering; whether voltage differences, timing delays or different ground levels would bring me into problems. Are there no problems if you would use two Delta controls, both receiving signals from the same MobStation and each feeding half of the layout? Though I do not expect to need more than 2 amps in short notice, you can now buy additional Delta units at ridiculous low prices.
regards, rudi
PS are you willing to share the URL of the German site you mentioned in this context?
#26 Posted : 17 February 2005 15:08:09(UTC)
Lars Westerlind
I really don't KNOW that the delay of the Delta is significant. I've hear reports about problemfree operation, and warnings. My thought is that as long they all are connected directly to the MobStat, they will have the same delay.
The link is here in the forum somewhere, Peter Cederstrand, do you keep it?
/lars
Offline rschaffr
#27 Posted : 17 February 2005 15:26:30(UTC)
rschaffr
I have used the 6604's extensively as boosters and I have had no problem with delay. I do have them all connected directly to the source (in my case an IB). Any delay that they might introduce would be compouned if you fed them successively, so I would definitely recommend not doing that.
I have, however, started a project of replacing them with the LDT boosters for several reasons. My main reason is that I use computer control and am spending more time away from the computer watching the trains. In the case of a computer crash the trains just keep running without control. I decided to make use of the LDT "Watchdog" to shut things down if the computer crashes, but that requires that you use real boosters with the watchdog as the first station after the CU. A second reason I'm changing is to get a little more current. Thirdly, I have had the nagging concern about the "Delta delay" and this eliminates it.
-Ron
Offline perz
#28 Posted : 17 February 2005 20:36:25(UTC)
perz
Regarding how many locos that can run out of a Mobile Station, and whether it is the power pack or the Mobile Station that sets the limit:
I have a "Feuerwehr" start set. Immediately as I got it, I tested those things. I could run 5 6090x locos, with head lights on, without problem with the MS+Power pack solution. Adding a 6th loco, it did not run any more. With the 60 VA 6005 transformer, the result was exactly the same. It is the MS that limits the current, not the power pack.
With Delta or 6080 locos, you can run much fewer. I just have one Delta loco so I can't push the limits with Delta locos only. But I have measured the power consumption for different kinds of locos, and my results are perfectly consistent with the practical experiences reported:
A 6090x loco (with head lights on) draws about 240 mA. Five of these draw about 1200 mA together, i.e. at the limit for the starter set MS.
A small Delta loco draws about 420 mA. Three of these draw 1260 mA, just over the limit ! Bigger Delta locos draw a bit more.
A C-sine draws significantly less than a 6090x, only around 200 mA.
The real record was a 37646 with "Glockenancker"-motor and 60905-like decoder. With lights off it drew less than 100 mA. You can run 10 such locos out of one single starter set MS! (haven't tested that thoughbiggrin).
To compare, I also tried a capacity test with the 6021. I could run 10 6090x locos at the same time. That was what I managed to control without crashing them into eachother, so I never reached the power limit.
Offline dudok12
#29 Posted : 17 February 2005 21:06:43(UTC)
dudok12
To add to your confusion of possible options to get more power to your digital layout: consider buying a 6021 brand new on ebay.de. These can be had for 90 euros or less. Gives you enough power, see perz's email, and can also be used in conjunction with your mobstat, with an adapter solution by Uhlenbrock or in time by a solution provided by Marklin....
Choices, choices...
Cheers, Bernhard
#30 Posted : 17 February 2005 21:26:19(UTC)
I am not sure if this has been mentioned but could there not be a fault in the MS. Most of us who use the MS can run up to five locos without too much bother and this should be the case with any MS although with some locos this maybe reduced to four.
Had the MS been bought from a dealer I would be inclined to return it for another one. I am talking here about the MS supplied with start sets.
David
Offline perz
#31 Posted : 17 February 2005 22:59:02(UTC)
perz
No, it is not so strange that David's MS can only drive 2 locos. His locos are all Delta, and rather big ones.
Five locos is possible with 6090x, C-sine or "Glockenancker" with high-efficiency decoders. With Delta, 2-3 locos is all you can expect to get.
#32 Posted : 17 February 2005 23:42:48(UTC)
Thanks Perz. I dont run Delta locos as I sold them when going for the new start sets. The layout could still be split into two sections if suitable and two MS used until either an IB or CS is purchased or available.
David
#33 Posted : 18 February 2005 00:23:48(UTC)
Rudi Bekkers
[size=1" face="Verdana" id="quote]quote:No, it is not so strange that David's MS can only drive 2 locos. His locos are all Delta, and rather big ones.
Well, that would be in accordance with Märklin's claims and consistent with the measurements Perz presented. Nevertheless, there seem to be quite a few people (including myself) succeed to control many more loco's than that on their layout. I run two Delta's, three digital loco's (including a 37265 ET87 train with two LED-lighted couches), another two separate lighted coaches (two bulbs each) and one steam heater unit. This all runs simultaneously without any problems on a 'small' MobiStat and the small black 18 VA transformer. If I use Perz' findings on current draw, then I would be consuming somewhere close to 1.6 amperes (and even that is conservative and does not include the energy use of all the lights and the steam heater). Why does my 'small' 1.2 Amps MobiStat allow me to do this? (I'm not complaining but would like to understand Smile)
The quite different experiences make me curious. Could it be that some 'small' MS do actually deliver more power? What event exactly makes the MS unit's circuitry decide to switch down? Depending on its internal circuitry, component tolerance, procuring component from different suppliers or using slightly different components all could have a significant consequence for the maximum power a unit actually can deliver.
Could it be explained by differences between individual MobiStats? Or differences between the transformers? Could the output of the 110V transformer be different from the 220V transformer? And how does the MobiStat (and, more particularly, its switch-down circuit) react to differences in the voltage of the transformer by which it is powered? Could it be that some loco's pose an off-phase load (capacitive or inductive)?
Today, I measured a 6090x loco and it drew 270 mA of power. That result is rather similar to that of Perz. However, I am hesitant to interpret such values. The thing is that a normal current meter only gives reliable readings if you are working with a sine wave. The Märklin digital signal, however, is not like a sine wave at all and is rather rectangular. I just made a picture from an oscilloscope (sorry for the horrible quality but it’s for illustration purposes only).
The only correct way to cope with such signals, I believe, is to use an RMS (root mean square) type meter. I used a Fluke 75 for the current measurement I just mentioned, but that’s no RMS meter (these things are rather expensive and I think most of us would prefer to have some extra nice loco’s instead).
So, I’m not sure how reliable to interpret the measurements and whether we could conclude from this how many trains you can run using a specific apparatus.
So, there are many questions left (or, many interesting things to be figured out). I would still be interested, however, to hear from David (and others’) about his voltage readings in the MS (both loaded and unloaded) and compare those with mine.
I would be happy to see your thoughts and comments
regards, Rudi
Offline nico van zon
#34 Posted : 18 February 2005 01:17:36(UTC)
nico van zon
[size=1" face="Verdana" id="quote]quote:Originally posted by Rudi Bekkers
<br />.....Could it be that some loco's pose an off-phase load (capacitive or inductive)? .....
No, that's not possible. The first component that the current finds on its path in the decoder is a bridge rectifier. The whole internal circuitry in the decoder is DC based, so phase shift is not part of the story.
As for measuring digital voltage or current, true RMS meters are not that expensive anymore. You can have one between 50 and 100 euro's.
If you don't want to invest in a true RMS meter, then a simple workaround is to use a bridge rectifier and set the meter for DC measuring.
#35 Posted : 18 February 2005 14:46:06(UTC)
Rudi Bekkers
Hi Nico,
Good to hear that internal circuitry is DC. At least one hypothesis that we can skip. And good to hear that true RMS meaters got cheaper (well, I could have guessed this, prices of such things have been dropping a lot over the years).
Concerning true RMS, I'm not totally sure of what you say. We were discussing current measuring. The meter is connected in series with the load. If you would introduce a rectifier circuit there you would very much influence the circuit you are measuring (not at the least by introducing a voltage drop of at typically twice 0.6 volts for the diodes in the rectifier bridge). This while a current meter should be (virtually) invisible to the circuit, i.e. adding a voltage drop of a few thousands of a volts at most. Moreover, introducing non-linear components might not be anticipated by Marklins' designers and might have other effects too (ie. switching speed diodes, etc.)
There are also some other, more fundamental issues concerning true RMS metering and I'm not sure I can follow you in the workaround you suggest. But I guess that we better not bother the forum members with this and discuss that bilaterally (unless other readers like to get involved too in that discussion).
The main point that I want to make is that I think we must be quite careful when measuring and drawing conclusions from that. There is much we don't know. How is the max. output current of the MobStat defined (peak, average)? On what exact condition does the power shut down occur? To what degree does the MS behavior depend on its power input? Could MS-ses of the same type number have different characteristics? In addition, several things are actually more complex to measure than they might seem to be.
I don't want to cut the discussion or keep people from trying and measuring, but would suggest not to reach bold conclusions too easily. But I too am interested to learn the answers!
Do people at Märklin itself read this forum? Do they contribute at times?
Best regards and looking forward to learn more,
Rudi
Offline pcederstrand
#36 Posted : 18 February 2005 18:17:03(UTC)
pcederstrand
@ Lawes/Westerlind et all
I assume it was this link you searched for! The pages has got some more work into the SystemMystery wink
Look here "A deeper look inside the M/SystemMystery" and som Tips&Tricks too
Regards /Peter
Regards /Peter
Offline davidrod
#37 Posted : 18 February 2005 22:40:28(UTC)
davidrod
Here is an update to my problem. I connected a 32VA transformer to the mobile station, and although I was able to start all 3 locos, it is very hard to keep them all going at the same time...
Case in point, when two locos have a red light and are waiting for the 3rd one to go through a specific area and make the lights green, at that point when those two start, the system goes into an overhaul... My guess is that it is drawing too much current and that's why it is stopping...
So I guess I have 2 other choices... Either try the booster with the delta trans, or buy a second station... I gotta tell you that doesn't seem too appealing to me...
At this point I think I have no choice but to sell some of the old locos and get new digital "Fuel Efficient" ones :)
I gotta say that you guys are awesome, I wasn't expecting so many answers, truly, thanks for all your help...
One last thing, do you guys know of a website or a place where I could find more info on the electrical part of the trains... I would be interested in finding out how to increase the power to a track, without the MS I guess and without being digital, just plain system... I obviously don't want to get into digital now and the big station from systems won't be out until the end of the year, so I need to find some sort of temporary solution until then... I'm pretty new on this, the only thing I know is that you can't connect two transfermers to the track, but that's about it...
#38 Posted : 19 February 2005 00:40:11(UTC)
nico van zon
[size=1" face="Verdana" id="quote]quote:Originally posted by davidrod
<br />.....So I guess I have 2 other choices... Either try the booster with the delta trans, or buy a second station... I gotta tell you that doesn't seem too appealing to me...
David, buying a second station wouldn't be of much help. When you connect two Mobile stations, one of them will be the master and this one delivers the power. The other one is the slave and acts only as a control station. The slave will not supply extra power because its booster is not functioning in this setup.
Rudi,
my suggestion of a bridge rectifier meant indeed to put the rectifier before the meter and put the whole thing in series with one of the supply wires (in the case of measuring current of course)
You are right that this introduces a voltageloss of about 1.2V. It's not very elegant, but it's a coarse method to get some idea of how the current behaves.
I understand you have an oscilloscope, and this offers an other opportunity. You could put a low value resistor, e.g. 0.1 ohms, in series with the supply and measure the voltage drop across the resistor with your scope. On the second channel you could watch the voltage, and this might give you valuable information about the relation between current and voltage.
Offline hmsfix
#39 Posted : 19 February 2005 01:24:19(UTC)
hmsfix
Yor very interesting discussion on current consumption made me test it with my CU and a few loks with delta, 6090x, and Faulhaber motor).
To measure the "real" current, it is important to note that the CU, MS, IB etc. produce an output voltage which is switched between +18 and -18 volts whith very rapid speed and in a more or less non-periodic sequence. Also, the "+" and "-" polarities do not appear equally often. Therefore, ususal ac ampere meters are not relieable. Perhaps the True-RMS-Meters, but I do not now whether they can cope with the rather fast pulse sequence (frequencies of several 10 kHz are qite common, and usual amp meters are specified for not more than a few 100 Hz)
But there is a simple solution: take a common analog DC multimeter and connect it to the "+" and "-" connectors of a strong enough rectifier bridge (I took four diodes BY 255 (= 1N5404) that can withstand 3 A). Then send the output current from your digital unit (the red cable) through the AC connectors of that rectifier. The fast polarity changes are removed from the meter in this way, and you will have an almost constant current through the DC meter: the current measurement is reliable. If you have an oscilloscope, test it.
To be honest, there is one drawback: the current drawn by an digital lok (delta, 8090x, Faulhaber) is not at all constant, but also pulsed due to the pulse width modulation of the decoder that controls motor speed! The frequency is much lower than that of the digital signal and does not have any polarity changes. Therefore any cheap analog DC multimeter will average out the changes i.e. you get a time-averaged current (this is not the same as True-RMS, but it has a definite meaning and does not cost more than 1 EUR for the diodes, provided you have an old fashioned, analog multimeter at your disposal)
With that method I could essentially reproduce what perz and davidrod have already explained. However, my locos doubled their power consumption under load: the 6090x lok needed 250 mA when running idle, but 500 mA when going uphill with a heavy train. A train of 5 illuminated passenger cars pulled by the 6090x lok consumed 750-800 mA. The Faulhaber powered lok was most economic: it required 120 mA (300 mT with load and steam generator on). The "winner" was a delta lok with 500 - 900 mA, the PA-doubletraction (2 high-efficiency motors) was also quite good (450 - 800 mA).
My conclusion: Current consumption depends not only on the loks, but also on the trains. It may happen that even can't get even 1 train out of your station with the 18 VA toy.
Hans Martin
Offline Sam
#40 Posted : 19 February 2005 07:24:58(UTC)
Sam
this has been a very informative thread, as a 60652 MS starter set owner, I'm hoping that when I get a cable for my 42VA transformer, I can get a few more VA's out of it, cause I can hardly run 3 C-sinus locs on the 18VA transformer.. I'll report my findings later.
In the mean time, I am going to be saving for a 60212! (sorry, my pic hosting is down)
http://www.maerklin.de/p...12&picname=60212.jpg
Era I-V / HO & 1 Gauge / C-Track & Mobil Station, with Central Station.
#41 Posted : 19 February 2005 10:50:31(UTC)
Lars Westerlind
[size=1" face="Verdana" id="quote]quote:Originally posted by nico van zon
Nico,
the discussion about only one functional booster is correct, however, I don't understand the conclusion. Do you say I'm wrong when I say that the separately bought MobStat is 1.9 A and the one in most starter sets is 1.2 A? If I'm right, 1.9 A as master certainly helps.
/lars
#42 Posted : 19 February 2005 11:09:54(UTC)
nico van zon
Lars,
your conclusion is correct. When you have 2 different MobStats then you must use the one with the highest current rating as the master.
This is BTW the advice that Marklin gives on its own site. I may notice here that many questions in this thread could have been avoided when everybody had first read the whole site of Marklin systems. Most of the andwers are thereCool
Offline frankv
#43 Posted : 19 February 2005 15:48:32(UTC)
frankv
Where is the fun in that??biggrin
Offline Sam
#44 Posted : 19 February 2005 16:57:11(UTC)
Sam
I am still wondering if there is any "Real" difference between the starter set and the un-bundled Mobil Station as they both have the identical part number.. how can that be?? Marklin would be violating a major rule of electrical hardware naming. My Firebrigade starter set came with a 60652, and a 18VA "powerpack" I wonder if it is indeed limited to 1.2A or 1.9?? Some were saying above that Marklin says there is no difference based on the MS only.
Offline HueyCE
#45 Posted : 19 February 2005 18:58:43(UTC)
HueyCE
According to my dealer there is no difference except one between the 1.2 and the 1.9. There is a different current limiter installed in the 1.2.
Ira
Offline Sam
#46 Posted : 20 February 2005 01:43:32(UTC)
Sam
[size=1" face="Verdana" id="quote]quote:Originally posted by HueyCE
<br />According to my dealer there is no difference except one between the 1.2 and the 1.9. There is a different current limiter installed in the 1.2.
Ira
I wonder if it can be modified... really lame of Marklin to do that if you ask me.
#47 Posted : 20 February 2005 10:15:27(UTC)
nico van zon
[size=1" face="Verdana" id="quote]quote:Originally posted by Sam
<br />...I wonder if it can be modified... really lame of Marklin to do that if you ask me.
Marklin justifies this by telling that the heavier MobStat is too expensive for the cheap startersets. But in my opinion this is a commercial lie. There can hardly be any price difference between a 1.2 amp driver and a 1.9 amp driver.
Apart from that, it's much cheaper to produce only one version.
#48 Posted : 20 February 2005 10:43:23(UTC)
Lars Westerlind
It wouldn't surprise me if the sole difference is in software! Both have current limiters so that's not the difference either. But more probable there is some little component that could be replaced.
Why shouldn't Märlklin do the same as has been done in other markets for a long time? Slowly we european learn from the americans...
/lars
#49 Posted : 20 February 2005 15:55:04(UTC)
nico van zon
<br />....Why shouldn't Märlklin do the same as has been done in other markets for a long time?
They should not do it because it's customer cheating[:(]
Offline davidrod
#50 Posted : 20 February 2005 16:06:34(UTC)
davidrod
Have any of you guys ever send an email to techincal support from the markling website? I was wondering if perhaps we could get a straight answer from them there...
I gotta say that from a business standpoint this has to be the most supid decision that they have ever made... If the whole idea of the starter sets is to get people involved in the hobby at a cheap price, later to be really into it and buying all sorts of extra locos and tracks, then why put this stupid limitations...
I'm sorry, but I feel like I have been lied to, I know many of you don't feel this way, but in the advertisents it clearly says that you can control up to 10 locomotives at the same time. Maybe their translators do a poor job and they don't have any lawyers looking at this stuff, but you can't sell a car with power windows, power locks, Air Conditioner, sound system, that goes 200 km/h and then have someone tell you, oh! but you can't use them all at the same time... You see, the car needs to be parked so that you can blast the sound system, but before you do that make sure the windows are down... I mean... It just doesn't make any sense....
But anyways, taking apart that, and the fact that the new guys that they are trying to get Digital stuff to don't know much about electrics or electronics, it just plains looks very bad indeed...
I can't help it but look at the other brands when I go to a hobby shop, and see that some of their items or 1/10th of the price of the Marklin one. Yes, sure, the quality and detail of Marklin you don't get anywhere else, I'm 100% behind that, but this whole fiasco with this new mobile station has made me look at marklin with a different set of eyes....
I just wish someone in there would look at this boards and take our feedback to make it a better product. If it wasn't for places like this and fellow hobbists like you many of us would be lost...
Well, I still am ;)
2 Pages12>
This page was generated in 1.891 seconds.
