Offline kimmo
#1 Posted : 28 September 2003 20:52:38(UTC)
kimmo
I am planning to buy two Viessmann 5217 modules for monitoring contact tracks. They are much cheaper than Märklin s88's. Does anyone have any first hand comment on them?
Do they come with the necessary cable to connect to the Interface Unit, and does someone know how long this cable is? And is any extra cables needed to connect these two modules together (I guess the same cable is used)?
Do Märklin 7130 plugs fit to this module (for track wiring)? How about the new 71400 plugs?
Thanks!
Kimmo
#2 Posted : 29 September 2003 00:52:32(UTC)
Hello Kimmo,
I have a 5211 (6083 equivalent) and while the device works well, the 7130 plugs keep falling out.. I am fairly sure that the 5217 uses the same sockets... It's one of the main reasons why I have halted work on the layout.. (the other is that I am saving up for a new lok) Very annoying..
Offline kimmo
#3 Posted : 29 September 2003 09:34:09(UTC)
kimmo
<br />the 7130 plugs keep falling out..
Thanks for the note!
Does someone know if Viessmann has plugs which are made for their modules, and what the item number is?
And would anyone have an answer to my below question?
[size=1" face="Verdana" id="quote]quote:Originally posted by kimmo
<br />Do they come with the necessary cable to connect to the Interface Unit, and does someone know how long this cable is? And is any extra cables needed to connect these two modules together (I guess the same cable is used)?
Thanks!
Kimmo
Offline Thanos
#4 Posted : 29 September 2003 11:10:39(UTC)
Thanos
[size=1" face="Verdana" id="quote]quote:Does someone know if Viessmann has plugs which are made for their modules, and what the item number is?
I am using Viessmann decoders and plugs have never fell off the sockets![:0] As a matter of fact the sockets are very tight for the plugs - I am using BRAWA plugs. Viessmann however has plugs of their own make but I have never tried them (item numbers 6831 and the classic 6870-6878 and 6879-6887).
For use with the 5217, Viessmann produces an extension wire (150cm). The item number is 5230.biggrin
Thanos
Offline kimmo
#5 Posted : 29 September 2003 12:37:24(UTC)
kimmo
[size=1" face="Verdana" id="quote]quote:Originally posted by Thanos
<br />For use with the 5217, Viessmann produces an extension wire (150cm). The item number is 5230.
Thanos, I know there is an extension cable 5230. But is there a shorter cable that already comes with the module? And if that distance is enough, is this default cable enough for both connect the modules to the Interface Unit and to each other (if two modules are used)? And how long is the cable that comes with the module? If I know this, it will help me to determine if I need that extension cable or not. Since I am ordering these abroad, and will have to pay a hefty shipping cost, I would hate to find out that I am missing something just because I didn't know, and cannot find replacement from the local store.
[size=1" face="Verdana" id="quote]quote:I am using BRAWA plugs.
What is the item number for these plugs?
Thanks again.
Kimmo
Offline Peter Neumann
#6 Posted : 29 September 2003 17:03:47(UTC)
Peter Neumann
In my 5211 decoders, I use the Märklin sockets instead of the Viessmann plugs that come with the decoder simply because the Märklin plugs make better / tighter connections in the sockets. Additionally, I solder each wire end carefully so as to insure the best possible contact when it is screwed into the plug.
Peter Neumann
Offline kimmo
#7 Posted : 29 September 2003 18:06:36(UTC)
kimmo
I can see that there are a little contradictory experiences here. Adrian says that the Märklin plugs are falling off, and Peter says that they make better / tighter connections. Smile
Are we talking about the same Märklin plugs here (7130)?
From Peter's response one can understand that Viessmann module comes with plugs. Is that the case with 5217, too? And what about the cable? Is that coming with the module, too? And does that fit to 6051 and between the modules? And how long is it? Anyone know?
Kimmo
Offline Thanos
#8 Posted : 29 September 2003 19:43:00(UTC)
Thanos
[size=1" face="Verdana" id="quote]quote:But is there a shorter cable that already comes with the module? And if that distance is enough, is this default cable enough for both connect the modules to the Interface Unit and to each other (if two modules are used)? And how long is the cable that comes with the module?
The Viessmann 5217 Feedback decoder comes with 1m length of special wire and an s88 plug! Smile So I guess that with combination of the 5230 extension wire you will not have any problem!wink
[size=1" face="Verdana" id="quote]quote:From Peter's response one can understand that Viessmann module comes with plugs. Is that the case with 5217, too?
Yes it comes with plugs but they are the 6831 plugs which are different from the standard plugs.
Viessmann 6831
Viessmann std plugs
[size=1" face="Verdana" id="quote]quote:What is the item number for these plugs?
All the BRAWA plugs can be seen at: http://www.brawa.de/produkte2.p...gorieid=73&sprache=1
Thanos
Offline McLae
#9 Posted : 29 September 2003 19:56:33(UTC)
McLae
I use several Viessmann items. I am quite happy with them, but the first thing I do when I open the box is remove the screws from the bag of plastic plugs and throw away the plugs. I use Marklin and Brawa plugs for my connections (Old Marklin, not the new stuff).
The McLae
Offline Thanos
#10 Posted : 29 September 2003 19:59:21(UTC)
Thanos
[size=1" face="Verdana" id="quote]quote:Originally posted by McLae
<br />I use several Viessmann items. I am quite happy with them, but the first thing I do when I open the box is remove the screws from the bag of plastic plugs and throw away the plugs. I use Marklin and Brawa plugs for my connections (Old Marklin, not the new stuff).
Same for me! biggrin I really can't see the use of the plugs that Viessmann supplies.
Thanos
Offline kimmo
#11 Posted : 29 September 2003 20:11:02(UTC)
kimmo
Thanks for all answers, guys! All my quesions are getting answered, one by one. Smile
Except one. From Thanos's answer it is still not clear to me if I definately need the extension cable (5230) or if I can do without. 1 meter between the first module and the Interface Unit is enough for me, so is 1 meter from the first unit to the second. And we talk about the feedback module 5217 here. So is the same default cable OK for both connections, or do I always need the extension cable to connect two units together? Sorry if I am repeating myself...[}:)]
Kimmo
Offline McLae
#12 Posted : 29 September 2003 23:26:13(UTC)
McLae
The cables that come with the 5217 plug into the 5217(s88) and either another 5217 or the 6021(IB).
Looks like this: 6021&lt;----&gt;5217&lt;----&gt;5217.
with extension cable, looks like this:
6021&lt;----&gt;5217&lt;---(5230)---&lt;&lt;----&gt;5217.
The cables that come with the 5217 have plugs female---female.
the 5230 has plugs female----male.
You plug the regular cable into one end of the extension cable, so you are using both the regular cable and the extension cable. (Just like an extension power cord.)
Hope this helps
The McLae
#13 Posted : 30 September 2003 00:24:13(UTC)
McLae, you have just pointed me to a product (5230) that solves a planning problem for me... How to connect scattered S88:s... The 5230 is 150 cm long and makes it possible to put the S88:s where they are needed (close to detection rails) instead of having long thin wires from the detection points to the s88 inputs which makes readout more prone to errors... Thanks! Smile
Offline Thanos
#14 Posted : 30 September 2003 09:29:47(UTC)
Thanos
<br />McLae, you have just pointed me to a product (5230) that solves a planning problem for me... How to connect scattered S88:s... The 5230 is 150 cm long and makes it possible to put the S88:s where they are needed (close to detection rails) instead of having long thin wires from the detection points to the s88 inputs which makes readout more prone to errors... Thanks! Smile
One question gives so many answers! biggrin This forum is really working... Cool
Also Juhan, if you consider the reasonable cost for the 5230 (around €10) those scattered S88s will not be so scattered anymore!
Thanos
Offline kimmo
#15 Posted : 30 September 2003 10:07:36(UTC)
kimmo
Thanks Thomas, all!
Now the connections/cables are clear. And it is the way I thought it would be, but I just wanted a confirmation from someone who knows better than me...
But then one (last Smile) question. Which size of wires you use from the detection point to the module? 0,14mm2 like Viessmann/Brawa wires or 0,19mm2 like Märklin wires, or something else? And do you use the same wire with the accessory decoders too (like k83)?
[size=1" face="Verdana" id="quote]quote:if you consider the reasonable cost for the 5230 (around €30)
At Lok Shop 5230 extension cable costs 8,44 EUR.
Kimmo
Offline kimmo
#16 Posted : 30 September 2003 12:26:20(UTC)
kimmo
<br />The cables that come with the 5217 plug into the 5217(s88) and either another 5217 or the 6021(IB).
I just noticed this: The article here https://www.marklin-users.net/html/digital/DI6051.html says that the feedback modules (s88 or 5217) are connected to the 6051 Interface Unit, not to the 6021 Central Unit, as you say. Which is correct?
Kimmo
Offline Thanos
#17 Posted : 30 September 2003 19:24:27(UTC)
Thanos
[size=1" face="Verdana" id="quote]quote:Which size of wires you use from the detection point to the module? 0,14mm2 like Viessmann/Brawa wires or 0,19mm2 like Märklin wires, or something else?
Well, I really haven't seen any difference! However, people say that Marklin cables are the best.biggrin
[size=1" face="Verdana" id="quote]quote:And do you use the same wire with the accessory decoders too (like k83)?
I haven't plugged my s88 yet, but I intend to use the same wire!wink
[size=1" face="Verdana" id="quote]quote:At Lok Shop 5230 extension cable costs 8,44 EUR.
That is correct! I should have said: "if you consider the reasonable cost for the 5230 (around €10)"... sorry [:I]
Thanos
Offline PeFu
#18 Posted : 30 September 2003 22:09:22(UTC)
PeFu
<br />The article here https://www.marklin-users.net/html/digital/DI6051.html says that the feedback modules (s88 or 5217) are connected to the 6051 Interface Unit, not to the 6021 Central Unit, as you say. Which is correct?
They are connected to the 6051 Interface.
Cool Peter
Offline McLae
#19 Posted : 01 October 2003 02:11:52(UTC)
McLae
Sorry about the 6021/6051 confusion. Since I have an IB (and started with a 6023), which everything plugs into, I thought the s88 would also plug into the 6021. My bad, sorry.
Also, I seem to remember that s88/5217 would also connect to a 'Memory' module.
For wire size, the bigger the better, until it gets too big. Too big means: cannot fit into a plug or too fat to fit in the lok. (Like me)
Thomas(McLae)
The McLae
Offline kimmo
#20 Posted : 01 October 2003 09:02:20(UTC)
kimmo
<br />Sorry about the 6021/6051 confusion.
No problem. Smile
[size=1" face="Verdana" id="quote]quote:For wire size, the bigger the better, until it gets too big.
I'll go for Märklin 0.19mm2 wire then.
Thanks!
Kimmo
Offline Thanos
#21 Posted : 01 October 2003 10:40:04(UTC)
Thanos
Hey Kimmo, when you finish work post some pictures of your layout for us to see!biggrin
Thanos
Offline kimmo
#22 Posted : 02 October 2003 22:21:43(UTC)
kimmo
Thanos, all
I have posted some layout-pictures here:
http://personal.inet.fi/private/kimmo.makinen/
Kimmo
Offline Thanos
#23 Posted : 03 October 2003 09:58:30(UTC)
Thanos
Nice job Kimmo! I bet when the dual ramp and the tunnel to the reverse loop is finished your layout will look really great! I especially like the photos with the E-40 resting at the station. It looks very real...Smile
Thanos
#24 Posted : 03 October 2003 15:31:46(UTC)
Way better than mine too...
Offline kimmo
#25 Posted : 03 October 2003 15:43:56(UTC)
kimmo
Thanks for the encouragement. Smile
Kimmo
Viessmann 5217 S88 and Marklin CS2 (Digital)
by fje 25/11/2017 12:48:22(UTC)
viessmann 5217 and CS2 (Digital)
by georgi411 08/12/2014 16:31:40(UTC)
VIESSMANN 5217 (Digital)
by dennis 31/10/2010 22:52:20(UTC)
Viessmann 5217 vs 5233 (Digital)
by svgeorgiad 11/02/2007 11:19:48(UTC)
Intellibox and Viessmann 5217 (s88) problems (Digital)
by jowe7 02/04/2004 00:09:56(UTC)
This page was generated in 0.600 seconds.
