Offline poppa-7
#1 Posted : 06 August 2014 01:40:15(UTC)
poppa-7
Hi Everybody
Can anyone give me the procedure for downloading the latest update (3.6) to a USB stick. I can not get it to download direct from the internet, I can only download to version 3.5.99
So I thought that entering the 3.6 file via USB might be successful
Thanks in advance
RussellConfused
#2 Posted : 06 August 2014 06:55:26(UTC)
Hi Russell, USB updates from the CS2 can be downloaded from http://www.maerklin.de/d...ds/software_updates.html
However, I do not know which version is currently on the website. You would normally copy the update file (cs2update.tgz) to the root directory of a USB stick, plug that into the CS2, and run an update.
#3 Posted : 06 August 2014 08:02:30(UTC)
You have to run the upgrade (at least) twice - first you get 3.5.99 with the pink dials and the new update facility, then you should get 3.6.2.
CS2 60215 with 6021 slave (Digital)
by Willr 09/03/2024 00:05:11(UTC)
CS2 60215 English manual (Digital)
by Donb 16/04/2021 17:36:40(UTC)
CS2 60215 and EcoSBoost (Digital)
by anthpao 24/04/2020 20:50:28(UTC)
CS2 60215 "freeze" on startup screen (Digital)
by lapinus57000 23/03/2020 13:45:16(UTC)
My cs2 60215 is failur? (Digital)
by fortuna 04/10/2015 14:16:36(UTC)
Problem with CS2 - CS2 60215 does not start (Digital)
by AlekseyV 14/12/2014 16:43:38(UTC)
CS2 60215 Wifi Connectivity (Digital)
by Rajnish 30/01/2013 11:04:10(UTC)
How do you register a ROCO A/C digital on a CS2 60215? (Digital)
by DV 19/01/2012 04:40:40(UTC)
CAN Gateway CS2 60215 (Digital)
by flashwebb 05/06/2011 01:33:52(UTC)
This page was generated in 0.371 seconds.
