Offline jonas_sthlm
#1 Posted : 05 April 2024 12:31:11(UTC)
jonas_sthlm
Has anyone manage connect an capacitor on mLD decoder ?
I get the capacitor 1500uF to charge U-/U+ but the decoder dies immediately when the power goes off.
I find this wiring diagram on moba-hgh.de Huh
Edited by user 06 April 2024 09:49:35(UTC)  | Reason: Not specified
Offline bph
#2 Posted : 05 April 2024 13:32:31(UTC)
Should work....
Could it be that something is not wired correctly. ? e.g. is the diode mounted the right way?
this thread might also help: (the instructions on the moba-hgh.de is not the best)
https://www.marklin-users.net/forum/posts/t31226-Marklin-Hobby-and-Trix-22075---22097---mSD-upgrade--buffer-capacitor
Offline jonas_sthlm
#3 Posted : 05 April 2024 15:10:15(UTC)
jonas_sthlm
I probably didn't connect it wrong Blushing I used this instruction...
The same capacitor works with mSD decoder so why not with mLD.... I dont get it Confused
Offline jonas_sthlm
#4 Posted : 05 April 2024 21:25:09(UTC)
jonas_sthlm
Someone has succeeded here making it to work with 470yF/35V together with PCB Mellow
Should this capacitor be requested between GND and +Ub if not using 21MTC PCB for mLD/mSD...
Edited by user 07 April 2024 11:10:03(UTC)  | Reason: Not specified
Offline bph
#5 Posted : 06 April 2024 22:03:46(UTC)
Perhaps you also need a capacitor on the +5v for the decoder processor. ?
I have not used capacitors on old mLD but only used them on mSD and as you also noticed it works fine.
Offline mmervine
#6 Posted : 06 April 2024 23:04:31(UTC)
mmervine
This video may be helpful:
thanks 1 user liked this useful post by mmervine
Offline jonas_sthlm
#7 Posted : 07 April 2024 13:32:25(UTC)
jonas_sthlm
The video is great but doesn't clarify functionality of mLD decoders...
Like I mentioned the powerpack works with the same generation of mSD decoder.
Yes the question are, and I will try decoder with circuit board later to see if the +5 capacitors will do the magic Huh
By the way how do you know its +5 on the board ?
This page was generated in 0.267 seconds.
