Offline Chuck Burkert
#1 Posted : 08 January 2024 18:37:24(UTC)
Chuck Burkert
This is an odd one. I had a section of track (3 or 4 track pieces) that were dead. Upon replacing one piece at one end of the section the entire section came live. Also, I had a section of 3 or 4 track pieces that were dead with a bumper piece on the end. When I removed the bumper the section of track went live. I can't understand how that would work. Any ideas out there?
Offline rbw993
#2 Posted : 09 January 2024 00:12:06(UTC)
rbw993
What type of Marklin track are you talking about, C, K or M. Makes a difference.
Roger
#3 Posted : 16 January 2024 19:26:53(UTC)
Chuck Burkert
They are M tracks. It's an old set from the 1950s.
Offline rbw993
#4 Posted : 16 January 2024 21:00:48(UTC)
rbw993
It seems that you might have sections that have a short in them. Do a test on the individual the track sections. With the transformer on if you attach one wire from the transformer to the grounded outer rail(s) and then touch the other wire to the center studs or rail there should be no spark. If it sparks there is a short. Or you can check the section with a muti-meter. There should be no continuity between the center an outer rails.
#5 Posted : 16 January 2024 21:06:02(UTC)
Chuck Burkert
Thank you. I’ll give it a go.
Offline Harvey
#6 Posted : 07 February 2024 04:14:08(UTC)
Harvey
One possibility is that the metal connection between the tracks got bent and are not touching. I have experienced that a few times.
Harvey
thanks 1 user liked this useful post by Harvey
#7 Posted : 07 February 2024 11:01:55(UTC)
Hi Chuck
I have used this M track for decades and I love it.
Two things that may help you a lot:
- prepare long nose plier with a piece of metal (screw or nut) so that it limits the closing. Use it to straighten the fishplates (rail joiners) so that the "grip" come back as with new M track rails. The closing limit on the pliers is there to prevent you of squeezing too much the joiners.
- inspect the central tongues of each rail and bend them very very little upwards. This make the stud contact so much better.
Nothing is more aggravating (I think) when you have intermittent contacts between track section.
Marklin 88320 and control tracks (Small scale)
by Steve444 21/02/2024 03:13:12(UTC)
Faller compatibility with Marklin c-tracks (H0-scale)
by fabstar68 19/12/2023 15:23:05(UTC)
Circuit tracks (Digital)
by Bones 13/12/2023 02:07:12(UTC)
Two connecting tracks and power control sticks (322979) on same track (Digital)
by trainman11 26/10/2023 12:41:04(UTC)
Wunderland gone 2 tracks (H0-scale)
by river6109 28/09/2023 00:52:05(UTC)
Question about contact tracks (General MRR)
by Chris6382chris 09/09/2023 00:04:09(UTC)
Marklin Circuit and contact tracks (Digital)
by Luna 25/07/2023 05:37:21(UTC)
Contact track K-2295 - C-24995 and various M-tracks (General MRR)
by auntmartha 24/05/2023 18:10:29(UTC)
Unknown digital unit connected to straight tracks (Model railroad wiring)
by 3030guy 10/04/2023 10:54:30(UTC)
contact tracks in hidden yards (Digital)
by Don Morris 24/03/2023 01:56:40(UTC)
Railway tracks CAD Templates (Model railroad software)
by Silvia 16/01/2023 20:51:04(UTC)
Locos are shorting out tracks (H0-scale)
by tinroofrusted 21/12/2022 05:45:05(UTC)
Mixing C and M tracks - best tricks? (H0-scale)
by einotuominen 12/12/2022 17:53:29(UTC)
by Thewolf 12/12/2022 02:50:23(UTC)
Pre connecting contact tracks on MS2 before changing to CS3 (Model railroad wiring)
by einotuominen 19/09/2022 06:14:46(UTC)
Trackside telephone poles (General MRR)
by Mr. Ron 03/08/2022 19:09:28(UTC)
7286 Turntable activates empty shed contact tracks. (H0-scale)
by luckas 15/06/2022 11:02:54(UTC)
HO Trains. Tracks and accessories. (General MRR)
by GeorgeM 09/06/2022 14:45:36(UTC)
M contact tracks (H0-scale)
by BenP 27/04/2022 15:47:03(UTC)
Ballasting and colorizing model tracks and switches (Model railroad photography)
by CVI 08/03/2022 11:57:14(UTC)
Clean painted tracks question. (Painting & Weathering)
by Puttputtmaru 21/02/2022 16:41:52(UTC)
Trackside Telephone Cabin (Model kits & layout details, kitbashing and such)
by Bogenschütze 31/01/2022 16:21:00(UTC)
Bridging power between tracks (H0-scale)
by Carguy1 11/12/2021 17:00:02(UTC)
What runs good on Marklin k-tracks? (H0-scale)
by Puttputtmaru 26/03/2021 21:41:40(UTC)
Contact Tracks for K track (H0-scale)
by Harvey 14/03/2021 01:34:22(UTC)
German Trackside Signage (General MRR)
by Bogenschütze 05/02/2021 09:56:53(UTC)
Which turnout to use to minimize space between c tracks (H0-scale)
by geir 22/01/2021 21:52:56(UTC)
Two locos simultaneously on m tracks (H0-scale)
by Petros 08/01/2021 20:40:35(UTC)
Number of feeder tracks (Model railroad wiring)
by MtrackJai 07/12/2020 18:10:25(UTC)
16 Contact tracks and I don't know what to do with them (Digital)
by oranda 18/08/2020 15:08:55(UTC)
ATC on M-tracks and introducion (Model railroad wiring)
by carlostau 11/07/2020 14:32:35(UTC)
M Tracks (H0-scale)
by HO Collector 24/05/2020 23:09:31(UTC)
Bridge road section drops on tracks - freight train hits it ; germany (Prototype)
by Minok 03/04/2020 02:11:26(UTC)
Decoder on Analog tracks (Digital)
by Norton1972 02/02/2020 18:01:09(UTC)
Dead spots on C contact tracks (General MRR)
by obb_taurus 12/01/2020 19:41:32(UTC)
How sensitive are locomotives to dirty tracks (General MRR)
by obb_taurus 28/12/2019 18:50:28(UTC)
Marklin feeder tracks (Small scale)
by Nrwatson 25/11/2019 22:37:46(UTC)
The Evolution of Model Railroading's Tracks (General MRR)
by michelvr 12/09/2019 15:12:33(UTC)
Some newbie questions on how to connect feeder tracks and lighting (Digital)
by rhNOR 18/04/2019 01:12:19(UTC)
Contact Track with C Tracks and MS as moving (Digital)
by federicofreundt 16/03/2019 22:26:46(UTC)
Translate M-tracks to C-tracks (H0-scale)
by mauel 05/01/2019 22:32:38(UTC)
Insulated and non-insulated rail joiners for K tracks (H0-scale)
by PeFu 21/10/2018 13:19:27(UTC)
Mixing Peco and Marklin (K) tracks ? (H0-scale)
by French_Fabrice 12/08/2018 18:31:29(UTC)
Contact M tracks (H0-scale)
by dodo57 01/07/2018 20:27:39(UTC)
My World tracks - Are they compatible with C-Track? (H0-scale)
by rglasinovic 25/05/2018 19:37:43(UTC)
Noisy M tracks (General MRR)
by FV1974 25/03/2018 22:49:15(UTC)
New Märklin Tracks Series (Big scale)
by Rocca 21/03/2018 16:57:55(UTC)
Marklin HO Tracks (General MRR)
by Mfh 16/12/2017 12:10:15(UTC)
Marklin and Trix C Tracks not the same? (H0-scale)
by michelvr 30/11/2017 17:17:00(UTC)
connecting circuit tracks, relays, and control boxes (Model railroad wiring)
by profher 03/08/2017 21:41:03(UTC)
This page was generated in 0.301 seconds.
