Offline PeFu
#1 Posted : 21 October 2018 13:19:27(UTC)
PeFu
I'm about to buy some insulated and non-insulated rail joiners for K tracks, and as I'm far away from a MR shop, I would appreciate your recommendation from experience of applicable brand? (and article N.o. if possible) Installing joiners that derail Märklin wheels would be a nightmare... Crying I will need joiners for both flex and common K tracks. It would also be great if the non-insulated joiners are easy to solder on!
Blink
Offline French_Fabrice
#2 Posted : 21 October 2018 15:06:32(UTC)
French_Fabrice
For insulated rail joiners, use Peco SL-11.
For normal rail joiners, Marklin ones are easy to solder. As you speak about flex track, I would thus recommend Marklin 7595 set.
Fabrice
thanks 2 users liked this useful post by French_Fabrice
Offline PeFu
#3 Posted : 21 October 2018 16:09:58(UTC)
PeFu
Thanks Fabrice, I will go for Peco SL-11! I have a few joiners from Mä 7595, they are fine but I will also test the metal Peco SL-10. Cool
Offline applor
#4 Posted : 21 October 2018 23:48:00(UTC)
applor
I agree with Fabrice and after just having laid my entire layout in K track.
Don't bother with the SL-10, they are ill suited for K track (too flat) and a royal pain to install - I ended up using one and binning the rest.
Use the rail joiners from the Marklin 7595 which are perfectly suited and you will need the 7595 anyway for joining flex track.
The SL-11 work well but you do need to ensure they are lined up and pushed all the way in to avoid too big a gap.
Offline amartinezv
#5 Posted : 22 October 2018 10:58:02(UTC)
amartinezv
Hello
I have used fleischmann joiners non insulated but I don’t know the reference, and insulated roco joiners don’t know the reference.
Antonio Martínez
www.raildigital.es/davidruso
This page was generated in 0.487 seconds.
