#1 Posted : 19 May 2016 11:08:22(UTC)
A bit of history for reference
https://www.marklin-user...eat-with-extreme-caution
from /paket/73decoder
paket
.name=decoder
.descr=Update-Files für Decoder-Firmware (mSD/mLD und mSD3/mLD3) und Sound-Firmware
.vers=1.17.19.0 + 1.032 + 3.0.1.0 + 3.0.1.2
1.17.19.0 latest base mLD/mSD - NO UPDATE
1.032 Latest mSD - NO UPDATE
3.0.1.0 Latest mSD/3 - NEW plus UPDATES
3.0.1.2 Latest mLD/3 - NEW plus UPDATES
.date=19.5.2016
.mode=normal
Variants...
- mLD3_248244_245 v3.0.1.2 : 10May2016 : AC, DC,MM, DCC, MFX. : series decoder
- mLD3_248244_246 v3.0.1.2 : 10May2016 : AC, DC,MM, DCC, MFX. : retrofit decoder
- mLD3_248244_247 v3.0.1.2 : 10May2016 : AC, DC,MM, DCC, MFX+ : Series Decoder / Games World
- mLD3_264612_246 v3.0.1.2 : 10May2016 : AC, DC,MM, DCC, MFX. : retrofit decoder
- mSD3_259851_243 v3.0.1.0 : 29Mar2016 : AC, DC,MM, DCC, MFX. : Series Decoder / Games World / Crane trucks : T23540 - Crane trucks DB AG, Goliath
- mSD3_259851_244 v3.0.1.0 : 29Mar2016 : AC, DC,MM, DCC, MFX+ : Series Decoder / Games World / Crane trucks : 49954 - Crane trucks DB AG, Goliath
- mSD3_259851_245 v3.0.1.0 : 29Mar2016 : AC, DC,MM, DCC, MFX. : series decoder
- mSD3_259851_247 v3.0.1.0 : 29Mar2016 : AC, DC,MM, DCC, MFX+ : Series Decoder / Games World
- mSD3_263819_246 v3.0.1.0 : 29Mar2016 : AC, DC,MM, DCC, MFX. : retrofit decoder : 60975, 60976, 60977, 60978, 60979
- mSD3_264613_246 v3.0.1.0 : 19Mar2016 : AC, DC,MM, DCC, MFX. : retrofit decoder : 60985, 60986, 60987
NOTE1: Trix Golith is not mFX+
NOTE2: Unable to discern the meaning of the two pairs of mLD/3 retrofit decoder - speculation may be 60972 v 60982 - both threads (248244 and 264612) present meta data with a generic "<!-- artikelnr=".*" -->" with the only difference being ther product number itself 248244 v 264612
Meta Data for mSD/3 ...
264613_246 = <!-- artikelnr="6098[567]" --> indicating 60985/60986 & 60987
except for .. 264613_246 v3.0.1.0 file has a rather generic <!-- artikelnr=".*" -->
263819_246 = <!-- artikelnr="6097[56789]" --> indicating 60975/60976/60977/60978 & 60979
devices review-able to date ...
- 60972 batch-sticker (none) original code = 3.0.0.32 = decoder partnumber 248244 (presents the 4 "mLD_248244_246" options for CS2 update before and after)
- 60976 batch-sticker 260064 original code = 3.0.0.28 = decoder partnumber 263819 (present only "mSD_263819_246_3.0.1.0" after update)
mLD3
Version: 3.0.1.2 (10 May 2016)
Improvement: mLD3 with attached Marklin sound module (SUSI), resolution of chuff improved.
Version: 3.0.1.1 (April 19, 2016)
Improvement: driving behavior in analog AC improved suppresses interference, supply voltage and synchronized PWM
Version: 3.0.1.0 (March 29, 2016)
Bugfix: functions in direction or drive changes were triggered after each stop / go, even when no change took place
Improvement: mLD3 now supports Märklin sound module (SUSI)
Version: 3.0.0.32 (25 November 2015)
Corresponds to the factory setting of the retrofit decoder in autumn 2015
mSD3
Fix: Single volume brake squeal now adjustable
Bugfix: steam locomotive, single volume driving sound, state (idle) and driving now connected
Bugfix: initialization of the random generator for the sound now randomly
Bugfix: Play the bursts of steam now also in the sinus and in open loop
Improvement: interrupt load decreases in sound part
Feature: Features of the mobile crane on compiler switches possible
- It can always be carried out only one of the movements (Aux2 / Aux3 / Aux4) same time
- The driving position of the center is kept at zero as long as none of the movements is activated or after the engine has shut down due to overload, characterized ...
- - is always approached with ABV when motion is activated
- - the engine sound does not expire until high when motion is activated
- - is a consumption of the consumables occur only when movement is activated
- The movements are different translated, ie at different rates. The rotary motion is reduced with the aid of shunting speed and approximated by
Bugfix: Undefined drive off with minimal Analogsprannung eliminated
improved regulated unregulated by digital transition analog: bugfix
Bugfix: filtering for analog speed levels improved
Bugfix: starting at Analog unregulated improved (PWM increases)
Version: 3.0.0.28 (31 August 2015)
Number of files transferred: 60 .... (32 x mLD, 28 x mSD)
Total file size: 3880856 bytes
fwd/
fwd/mLD3_248244_245_v3-0-0-32.fwd
fwd/mLD3_248244_245_v3-0-0-32.html
fwd/mLD3_248244_245_v3-0-1-0.fwd
fwd/mLD3_248244_245_v3-0-1-0.html
fwd/mLD3_248244_245_v3-0-1-1.fwd
fwd/mLD3_248244_245_v3-0-1-1.html
fwd/mLD3_248244_245_v3-0-1-2.fwd
fwd/mLD3_248244_245_v3-0-1-2.html
fwd/mLD3_248244_246_v3-0-0-32.fwd
fwd/mLD3_248244_246_v3-0-0-32.html
fwd/mLD3_248244_246_v3-0-1-0.fwd
fwd/mLD3_248244_246_v3-0-1-0.html
fwd/mLD3_248244_246_v3-0-1-1.fwd
fwd/mLD3_248244_246_v3-0-1-1.html
fwd/mLD3_248244_246_v3-0-1-2.fwd
fwd/mLD3_248244_246_v3-0-1-2.html
fwd/mLD3_248244_247_v3-0-0-32.fwd
fwd/mLD3_248244_247_v3-0-0-32.html
fwd/mLD3_248244_247_v3-0-1-0.fwd
fwd/mLD3_248244_247_v3-0-1-0.html
fwd/mLD3_248244_247_v3-0-1-1.fwd
fwd/mLD3_248244_247_v3-0-1-1.html
fwd/mLD3_248244_247_v3-0-1-2.fwd
fwd/mLD3_248244_247_v3-0-1-2.html
fwd/mLD3_264612_246_v3-0-0-32.fwd
fwd/mLD3_264612_246_v3-0-0-32.html
fwd/mLD3_264612_246_v3-0-1-0.fwd
fwd/mLD3_264612_246_v3-0-1-0.html
fwd/mLD3_264612_246_v3-0-1-1.fwd
fwd/mLD3_264612_246_v3-0-1-1.html
fwd/mLD3_264612_246_v3-0-1-2.fwd
fwd/mLD3_264612_246_v3-0-1-2.html
fwd/mSD3_259851_243_v3-0-1-0.fwd
fwd/mSD3_259851_243_v3-0-1-0.html
fwd/mSD3_259851_244_v3-0-1-0.fwd
fwd/mSD3_259851_244_v3-0-1-0.html
fwd/mSD3_259851_245_v3-0-0-28.fwd
fwd/mSD3_259851_245_v3-0-0-28.html
fwd/mSD3_259851_245_v3-0-0-32.fwd
fwd/mSD3_259851_245_v3-0-0-32.html
fwd/mSD3_259851_245_v3-0-1-0.fwd
fwd/mSD3_259851_245_v3-0-1-0.html
fwd/mSD3_259851_247_v3-0-0-28.fwd
fwd/mSD3_259851_247_v3-0-0-28.html
fwd/mSD3_259851_247_v3-0-0-32.fwd
fwd/mSD3_259851_247_v3-0-0-32.html
fwd/mSD3_259851_247_v3-0-1-0.fwd
fwd/mSD3_259851_247_v3-0-1-0.html
fwd/mSD3_263819_246_v3-0-0-28.fwd
fwd/mSD3_263819_246_v3-0-0-28.html
fwd/mSD3_263819_246_v3-0-0-32.fwd
fwd/mSD3_263819_246_v3-0-0-32.html
fwd/mSD3_263819_246_v3-0-1-0.fwd
fwd/mSD3_263819_246_v3-0-1-0.html
fwd/mSD3_264613_246_v3-0-0-28.fwd
fwd/mSD3_264613_246_v3-0-0-28.html
fwd/mSD3_264613_246_v3-0-0-32.fwd
fwd/mSD3_264613_246_v3-0-0-32.html
fwd/mSD3_264613_246_v3-0-1-0.fwd
fwd/mSD3_264613_246_v3-0-1-0.html
Edited by user 22 May 2016 21:40:01(UTC)  | Reason: Not specified
#2 Posted : 20 May 2016 22:55:56(UTC)
The mDT/3 (DecoderTool) "shows" an option for "Firmware download check", however the versions now available to the CS2 do not show up.
"Es sind keine Updates verfueger"
"There are no updates available"
Note: check done with mLD/3(60976) and mSD/3(60972) - both currently at 3.0.0.28 - it may be different for others.
#3 Posted : 20 May 2016 22:57:44(UTC)
Can anyone shed light on ...
"...Improvement: mLD3 now supports Märklin sound module (SUSI) "
#4 Posted : 20 May 2016 23:01:14(UTC)
I would appreciate a better translation of ...
"Feature: Eigenschaften der Kranwagen über Compilerschalter möglich"
Googly =
"Feature: Features of the mobile crane on compiler switches possible"
I think the reset could also be improved on.
Ref
- Es kann immer nur eine der Bewegungen (Aux2/Aux3/Aux4) gleichzeit ausgeführt werden
- -Die Fahrstufe der Zentrale wird auf Null gehalten, solange keine der Bewegungen aktiviert ist oder nach dem der Motoren wegen Überlast abgeschaltet hat, dadurch ...
- - wird immer mit ABV angefahren wenn eine Bewegung aktiviert wird
- - läuft der Motorsound erst hoch wenn eine Bewegung aktiviert wird
- - findet ein Verbrauch der Betriebsstoffe erst statt wenn eine Bewegung aktiviert wird
- Die Bewegungen sind unterschiedlich übersetzt, d.h. unterschiedlich schnell. Die Drehbewegung wird mit Hilfe des Rangiergangs reduziert und dadurch angeglichen
- The movements are translated differently, that is different rates. The rotary motion is reduced with the aid of shunting speed and approximated by
#5 Posted : 22 May 2016 21:47:20(UTC)
I advise mSD/3 users to NOT perform this update, at least not the 3.0.1.0 (final) step
The mLD/3 does not appear to have the same stuff up.
Note: experience to date is limited to the 6097x mSD/3s - it is possible that the 6098x decoders may have sidestepped this bug.
I welcome any comments, either way, to substantiate this.
There is evidence to suggest that this update resets the decoders "Item number" from its 6097x/8x number to "12345"
This "Item number" may be viewed on the "Information" tab when looking at the mFX CVs
While this does not appear to affect the actual operation of the decoder, it makes subsequent "configuration" update, icon(fds)/sound(snd) impossible.
As if all the bugs in the mDT/3 weren't enough, this makes even the available workarounds - unworkable.
I await Marklins reply on how this may be recovered.
It may be possible that a generic (60975 or 60985) may be able to be reinstated, as the firmware also validates against the "Decoder Part Number" (263819)
This should be enough, although you may loose that bit of audit history as to the item being a 60975/6/7/8 or 9.
Whether Marklin will do this , rather than insist the decoder be returned for replacement, is a moot point.
#6 Posted : 22 May 2016 21:57:03(UTC)
With the MSD is was possible to set the number there, too. I don't have an MSD/3 to try it, but I assume it also allows changing the number.
With MSD changing this number to e.g. the loco ref. number will prevent decoder upgrades - until you change it back.
#7 Posted : 22 May 2016 21:59:52(UTC)
I acknowledge that the Item Number field appears as an editable field, however I have not been able to get this to "stick" in my situation.
#8 Posted : 26 May 2016 10:32:33(UTC)
FYI,
It may be a streach to say that the original issue was fixed.
However, Marklin have provided a recent update to the CS2 (to v4.1.2(3) ) which certainly allows the decoders (mSD/3 that were showing item number = 12345 to now show 6097x) to be recognised and allow selection of updates updated (FDS firmware).
This "fix" also includes the mDT/3 decoder tool software now being able to do complete transfers and updates without workarounds.
NOTE: If a file is transferred from the mDT/3 to the CS2 (with a "DT_" prefix to the file names), trying to use the onboard CS2 update still stumbles over the "Info or Flash File for member 1 is missing" message because the metadata in the .html file still refers to a file name WITHOUT the "DT_" prefix.
Offline jonas_sthlm
#9 Posted : 28 May 2016 11:44:44(UTC)
jonas_sthlm
I had a very strange behavior with decoder firmware update,
First I did the latest CS2 update for 4.1.2 (3)
Then I update a locomotive that has a mSD3 decoder with firmware 3.0.1.0
The screen lock after testing some function button so I was necessary to kill the power to get reboot, when reboot was done it locked after some minutes again. I did reboot several times before try remove mSD3 engine and then boot up without.
Then everything works like normal Huh
#10 Posted : 28 May 2016 23:29:15(UTC)
I may have had something similar....
Can you confirm I understand your symptoms correctly ..
- a Lok(Engine) with a mSD/3 update to 3.0.1.0 causes the CS2 to lock up
- without the Lok(engine) on the layout, the CS2 does not lock up
Does your CS2 lockup if the engine has not been sent any commands - just sitting on the layout with power
Exactly how long after rebooting the CS2, and with the engine on the layaout, does the lockup occur
was your mSD/3 updated before the CS2 update to 4.1.2(3) ? (i.e between 18May and 25May) ?
Edited by user 29 May 2016 07:16:29(UTC)  | Reason: Not specified
#11 Posted : 04 June 2016 09:49:47(UTC)
Update for CS 2 - Version 4.1.2
PDF German text - http://www.maerklin.de/f...er_CS2-Version_4.1.2.pdf
Google Translate.
The following changes will be active after installing the update:
1. A control panel for the new Goliath crane 49954 is integrated into the MFX + ® gaming world.
Of the 3 motors for the various movements of the crane may have only one enabled.
This has been reflected in the user interface. As resource consumption has this
Model the consumption of diesel fuel.
2. Immediately is requested during the registration of mfx ® locomotives + whether the consumption of
Should be enabled resources (game mode Semi-Professional). If the green hooks actuated is
this mode is active, when selecting the red "X" of the standard mode, however, is chosen.
So then no consumption of operating materials is enabled.
3. The loading of Lok icons via the web interface is possible again now.
4. When the system is rebooted now are the states of the feedback modules 60881 -
60883 registered first, so that an automatic operation can be started directly.
5. The mfx-registration process has been optimized. Disturbing brief mfx Display indications
thus eliminated.
6. Also multiple installation of new data in the current retrofit decoders are now no problem
This page was generated in 0.502 seconds.
