Offline Pabbi
#1 Posted : 04 October 2015 14:38:00(UTC)
Pabbi
youtube video : crossing
Hi, is there any way I can make the lights and boom more stable ? Lights blinking and boom going up down.
Also tried to connect a light bulb to the contact track set and it flickers a lot ?
using Marklin H0 74923 crossing and Contact Track Set 2295
Edited by user 04 October 2015 20:42:49(UTC)  | Reason: Not specified
Offline BrandonVA
#2 Posted : 06 October 2015 18:49:54(UTC)
BrandonVA
Hi, Pabbi,
What are you using to power the crossing? Is it running off track power?
I would suggest powering it off a separate transformer (such as 6646, 6647, etc), it can share a common ground (brown wire) with the digital. The Yellow power to the transformer must be independent of the digital power.
-Brandon
#3 Posted : 06 October 2015 22:07:51(UTC)
When used with C track as it should be, the 74923 has a stable boom and the lights do not flicker.
A short touch of the tracks with a hand and the boom goes down for about a second.
Maybe you didn't connect it correctly? Maybe the two wires to the outer rails have been swapped?
Automatic Railroad Grade Crossing upgrade (Digital)
by gamolina 19/07/2022 02:00:19(UTC)
Fatal Highway-Railroad Grade Crossing Collision, Midland, TX (Prototype)
by ShannonN 19/02/2018 16:45:00(UTC)
Railroad grade crossing (Digital)
by springboard 13/11/2008 13:58:57(UTC)
This page was generated in 0.345 seconds.
